How to Activate
ars logo AUTO REPLENISHMENT SERVICE
Before following the steps below, please make sure you have gone through the standard setup process for your new printer, which includes installing your ink cartridges and connecting to the internet
< Back
For Wi-Fi Connection, refer to Canon USA's YouTube wireless help video (https://youtu.be/rjatHNx-hEs)
Step 1: Update to Latest Firmware
• From homescreen 1, press on right arrow to get to homescreen 2 and press Update Firmware icon
• Install firmware update (if applicable)
• You will see a notification confirming that your firmware version is latest available
• If firmware update is needed, turn off printer once completed
• Turn printer on by pressing Power Button
printer homescreen
Homescreen 1
down arrow
printer screen with update firmware highlighted
Homescreen 3
* Placement or actual screen may vary
Note: This step is necessary for online enrollment
Step 2: How to Retrieve Serial Number, Check Digits / Verification code
• From homescreen 1, press on right arrow to get to homescreen 4 and press Toner Delivery Settings icon
printer homescreen
Homescreen 1
down arrow
printer homescreen with toner delivery settings highlighted
Homescreen 4
• Press on Register for Toner Replenishment Service Program
Toner delivery settings menu with register for toner replenishment highlighted
down arrow
• Press Register for Program(Recommended) for QR Code, Serial Number and Checksum/Check Digits/Verification Code
• Press Print Registration Instructions to print Serial Number, Checksum/Check Digits/Verification Code and instructions
toner replenishment service registration with register for program and print registration instructions options
down arrow
• Scan QR Code with mobile device to begin enrollment
Register for program page with QR code to website
down arrow
• Swipe up to manually enter Serial Number and Checksum/Check Digits/Verification Code
Register for program page with QR code to website as well as serial number and checksum for printer
Step 3: Activate Auto Replenishment Service
Follow on-screen instructions, if prompted. If a prompt does not appear, follow instructions below.
• Press Toner Delivery Settings icon
• Press Toner Delivery Settings: Deactivated
Homescreen with Toner Delivery Settings button highlighted
down arrow
toner delivery settings menu
• Press Activate to begin setup
• Press Next after reading first validation step
Toner delivery setting activation menu with "activate" highlighted
down arrow
First confirmation screen
Step 4: Final Validation Steps
Next, you should see the validation screen below
• Press OK
• Check server connection status. You should see the following Server Connection Status: Successful screen.
If an error message occurs, follow on-screen instructions
Successful confirmation screen with "OK" highlighted
down arrow
toner delivery settings menu with activated toner delivery status
