How to Activate
ars logo
AUTO REPLENISHMENT SERVICE
Before following the steps below, please make sure you have gone through the standard setup process for your new printer, which includes installing your ink cartridges and connecting to the internet
< Back
Step 1: Update to Latest Firmware
• Select Menu from Home Screen, then select Management Settings
Homescreen with menu button highlighted
gray down arrow
Menu menu with system management setting highlighted
• Select Remote UI Settings/Update Firmware
Management settings menu with remote UI settings / update firmware highlighted
gray down arrow
• Select Update Firmware
RUI Set. / Update Firmware menu with update firmware highlighted
• Select Via Internet
• Install firmware update (if applicable)
• You will see a notification confirming that your firmware version is latest available
• If firmware update is needed, turn off printer once completed
• Turn printer on by pressing the Power Button
alt
Note: This step is necessary for online enrollment
Step 2: How to Retrieve Serial Number, Check Digits / Verification Code
• Select Menu from Home Screen, then select Toner Delivery Settings
alt
gray down arrow
• Select Register for Toner Replenishment
alt text
• Select OK button to print serial number and check digits / verification code
alt
gray down arrow
• Select <Close> to continue or <Close> to stop printing
alt text
Step 3: Activate Auto Replenishment Service
• Follow on-screen instructions, if prompted. If a prompt does not appear, follow the instructions below.
• Select Toner Delivery Set from the Home Screen
Homescreen with Toner Delivery Settings button highlighted
gray down arrow
• Select Toner Delivery Settings
Toner delivery set menu with toner delivery settings highlighted
• Select Activate to begin setup
Toner delivery setting activation menu with "activate" highlighted
gray down arrow
• Select OK button after reading first confirmation screen
First confirmation screen
• Select OK button to accept and continue setup
Toner delivery setting agreement screen
Step 4: Final Validation Steps
Next, you should see the following validation screen
• Select OK button
successful connection screen
• If an error message occurs, follow on-screen instructions
• Check server connection status by selecting
Server Connection Status
toner delivery setting menu with server connection status highlighted
gray down arrow
You should see the following Successful screen
successful connection with server screen
