How to Activate
ars logo AUTO REPLENISHMENT SERVICE
Before following the steps below, please make sure you have gone through the standard setup process for your new printer, which includes installing your ink cartridges and connecting to the internet
< Back
Step 1: Update to Latest Firmware
• Select Menu
Homescreen with menu button highlighted
Alt
• Select System Management Settings
Menu menu with system management setting highlighted
Alt
• Select Update Firmware
system management settings menu with update firmware highlighted
Alt
• Select Via Internet
• Install firmware update (if applicable)
• You will see a notification confirming that your firmware version is latest available
• If firmware update is needed, your device will power off and restart once the update is complete
Update firmware menu with via internet highlighted
Note: This step is necessary for online enrollment
Step 2: How to Retrieve Serial Number, Check Digits / Verification Code
• Select Menu
Alt
• Select Toner Delivery Settings
Homescreen with Toner Delivery Settings button highlighted
Alt
• Select Register for Toner Replenishment
Toner delivery settings menu with register for toner replenishment highlighted
Alt
• Select Yes to print serial number and verification code
• Select Close to continue or Cancel to stop printing
Registration instructions printing screen
Step 3: Activate Auto Replenishment Service
• Follow above instructions to get to Menu
Alt
Toner delivery set menu with toner delivery settings highlighted
Alt
• Select Activate to begin setup
Toner delivery setting activation menu with "activate" highlighted
Alt
• Select Next button after reading first confirmation screen
First confirmation screen
Alt
• Select Accept button to accept and continue setup
Conditions of use screen
Step 4: Final Validation Steps
Next, you should see the following validation screen
• Select OK button
successful connection screen
Alt
• If an error message occurs, follow on-screen instructions
• Check server connection status by selecting
Server Connection Status
toner delivery setting menu with server connection status highlighted
Alt
You should see the following Successful screen
successful connection with server screen
