WCM Rendering with Meta tags
Actions
View from a PowerShot G3X flip screen
Practicing with a solar filter for the eclipse
Being Safe Using Solar Filters
By: Dave Henry and Ken Sklute
August 03, 2017
So far in our eclipse series we’ve discussed camera bodies and lenses that can be used to photograph the upcoming total solar eclipse. This article covers solar filters, the most important consideration for solar photography and direct viewing of the solar eclipse.
IT IS NEVER SAFE TO LOOK AT THE SUN WITHOUT PROPER EYE PROTECTION WHEN ANY PART OF IT IS VISIBLE BEHIND THE MOON!
IT IS ALSO NOT A GOOD IDEA TO LOOK THROUGH YOUR CAMERA’S OPTICAL, EYE-LEVEL VIEWFINDER WHEN PHOTOGRAPHING A SOLAR ECLIPSE, EVEN WITH A SOLAR FILTER ON THE LENS, BECAUSE THERE ARE A LOT OF DIFFERENT SOLAR FILTERS ON THE MARKET. SOME ARE SAFE ONLY FOR PHOTOGRAPHY WHILE OTHERS ARE SAFE FOR BOTH PHOTOGRAPHY AND VIEWING THROUGH YOUR CAMERA’S VIEWFINDER EYEPIECE.  USING A SOLAR FILTER ON THE FRONT OF THE LENS, AND VIEWING ON YOUR CAMERA’S LCD MONITOR (AND LIVE VIEW FUNCTION) INSTEAD OF THE VIEWFINDER IS ALWAYS THE SAFE WAY TO PHOTOGRAPH AN ECLIPSE!
viewing eclipse through camera's LCD monitor
Safety
Now that we’ve made our camera and lens decisions, we’re going to be actively involved with looking at and photographing the eclipse. We need to pay close attention to the use of the solar filter.
We can’t stress the importance of safety for your eyes and your camera gear enough. Beware of solar filters being marketed on the Internet as “safe.” Our emails are full of questions from readers asking about these filters. Just because they claim to be safe doesn’t mean they are. A truly safe filter for viewing and photography should have a CE or ISO certification.
There is a difference between solar filters used by the public for viewing the solar eclipse and photographers photographing the solar eclipse.
Some marketers are saying that ND filters that restrict 14 – 16.5 stops of light are ‘safe.’ These may be safe for photography use only but definitely not for direct viewing. Restricting the light being passed through a filter is only part of the story. A safe filter for photography and viewing also restricts infrared and ultraviolet light beyond 800nm. Neutral density filters don’t do this. In some cases, you may feel the warmth in your eye but in most you won’t. At that point the damage is done to your eye.
Solar Filters And The Phases Of A Solar Eclipse
When an eclipse begins, you’ll notice a small notch in the lower right edge of the sun disk. That’s the moon slowly creeping its way across the face of the sun. This is the beginning of the partial phase of an eclipse. Gradually, over about an hour and a half, more of the sun becomes eclipsed by the moon until it finally covers all the sun. This is called totality. About 2½ minutes of totality, which varies across the country, allows us the only opportunity to view (without any solar filters) the sun’s corona. It’s truly amazing.
After totality, the moon continues to move across the face of the sun, gradually revealing more of the sun disk, until the moon lips away in her orbit around the earth.
Approximately 15 seconds before totality, and the same time (in reverse order) after totality, there is a final burst of very bright light referred to as the diamond ring effect. And within seconds after that, a few tiny bead-like shimmering rays of sunlight are peaking between the valleys of the craters on the moon. This is affectionately referred to as “Baily’s beads” after the nineteenth century English astronomer, Francis Baily.
During all the partial phases of the eclipse, you absolutely need a solar filter on the front of the lens. During totality however, you must remove the solar filter to be able to photograph and view the sun’s corona
About 15 seconds before totality begins, where the moon almost completely covers the sun, you will notice that last burst of light that has become known as the diamond ring effect.
At this point you have two options regarding removal of your solar filter, based on your experience and comfort level.
Experienced eclipse photographers usually want to capture this effect, and will remove their solar filter, at the diamond ring effect, from the lens to do so. This can be very risky — the light coming through the camera is still very intense so always use the camera’s LCD screen to position the sun in your frame to be safe. Never look through the camera’s eyepiece.
The other option for cautious, first-time shooters may instead prefer to leave their solar filter on the lens, and wait until true totality begins (see below) to remove their solar filter.
For cautious photographers who don’t want to risk viewing and shooting the partially exposed sun with no solar filter on the lens:  as soon as the “beads” disappear, you can remove the solar filter for about 2½ minutes (varies depending on your location in the path of totality) until Baily’s beads reappear again. When Baily’s beads reappear, that’s the end of totality. Then, immediately replace the solar filter on the front of your lens. Do not remove it again until you’re finished photographing the sun. Always use your LCD screen to compose your images and position the sun. Don’t use your camera’s viewfinder — unless you have an approved solar filter safe for viewing and photographing the sun on your lens!
Baily’s beads and the diamond ring effect happen again in reverse order at the end of totality.
Again, experienced eclipse photographers will want to photograph both Baily’s beads and the diamond ring effect without the solar filter on the lens — but it can involve some risk, since you are viewing at least some of the full brightness of the sun.  If you opt to do this, you have to closely monitor the increasing intensity of the light as the moon continues moving away from the sun’s disk. This happens within seconds. Once the diamond ring becomes very bright, you need to quickly replace your solar filter. It’s all about judgment, timing and evaluating the light.
From this point on through all the remaining partial phases, the solar filter needs to be in place on the front of your lens. Do not remove it again until you’re finished photographing the sun. Always use your LCD screen to compose your images and position the sun. Don’t use your camera’s viewfinder - unless you have an approved solar filter safe for viewing and photographing the sun on your lens!
Using Solar Filters Safely
Never look at the sun directly without accredited and approved solar filtration over your eyes. There are special solar viewing frames that can be used over your eyeglasses or solar viewing glasses for those that don’t wear glasses. Permanent, irreversible eye damage and/or blindness can result in seconds and you won’t even know it.
Never point your camera into the sun without a special solar filter. All camera lenses need an accredited and approved solar filter mounted on the front of the lens. This includes super-telephoto lenses which normally rely on small, drop-in filters which fit into holders toward the rear of the lens — even super-tele lenses require approved and properly-fitted solar filters, covering the front elements of these lenses. Not using a solar filter at eclipse magnifications can ruin your camera in seconds!
Intense light passing through your lens at eclipse magnifications, without a solar filter, can damage your image stabilization and aperture mechanisms, damage your sensor and shutter, and cause permanent eye damage. Eclipse magnification is a lot different than what landscape photographers do when they have the sun peeking through a tree canopy with their wide angle lens stopped down to f/22 to create a starburst effect. In that case the sun is so tiny and the exposure is so brief, there isn’t any damage.
Never improvise, modify or use general photography neutral density (ND) filters regardless of density even up to 16 stops. They are totally insufficient to provide the protection your eyes, and your equipment, need. Neutral density filters, regardless of density, transmit high levels of invisible infrared and ultraviolet radiation which can cause a thermal retinal burn. You won’t feel anything, but the damage is done. Stacked neutral density filters don’t do anything more than reduce the intensity of the visible spectrum either. And, as photographers, we know that shooting through multiple filters dramatically reduces sharpness too. Buy an approved solar filter. They’re relatively inexpensive and are designed for the task. Don’t risk your eyes or your sensor!
Types of Solar Filters
Solar filters can transmit or restrict different wavelengths of light such as “white” light and Hydrogen-Alpha light. The most common solar filters used by amateur photographers transmit “white” light – which refers to the visible spectrum and not necessarily the color of the sun disk it produces.
Scientists and advanced photographers may want to see details such as prominences and solar flares on the surface. In this case, you’ll need a special filter known as a hydrogen-alpha (or H-alpha) filter. This type of solar filter can be expensive and is available from professional solar filter companies such as Astronimik, Baader, or Thousand Oaks Optical.
For most of the rest of us, there are many “white” light solar filters on the market. There are round non-silvered glass filters, round silvered glass filters, thin metalized Mylar sheets and special silver/black polymer solar film filters.
There are filters meant for photography and filters meant for observing. The first decision you need to make is whether or not you want a “photographic only” solar filter to protect your camera’s sensor, or a filter safe for visual observing (or while looking through your eyepiece if your camera doesn’t have Live View on your LCD screen) to protect your eyes.
The next consideration you need to make is the color of the sun that the filter will produce. Non-silvered glass and metalized Mylar produce a blueish-white sun disk while professional silver/black polymer solar film produces a yellow sun disk.
Threaded Small Lens Solar Filters
Most glass filters are not silvered on the front and are good for photography only, but read the instructions that come packaged with your filter.
The Hoya Pro ND100000 (5.0) filter is the most commonly available filter and produces a blueish-white solar disk. Most camera retailers have this filter available in traditional threaded filter sizes up to 82mm. The Canon EF 100-400mm zoom, the EF 300mm f/4, and the EF 400 f/5.6 telephotos use a 77mm filter thread. The popular Canon EF 70-300mm f/4-5.6L zoom uses a 67mm filter thread.
Hoya Pro ND100000 filter
The Hoya Pro ND100000 (5.0), or similar filters, are designed for photography only and will do the job, but isn’t recommended for visual viewing such as looking through your camera’s eyepiece or holding it up to your eye for solar viewing. Read the instructions. Use your LCD screen only to safely view the eclipse if you’re using this type filter.
Large Lens Solar Filters
As photographers, we’re used to using glass filters such as polarizers and neutral density filters that thread into the front of our lenses. Since the beginning of digital photography, many advanced photographers have become used to using large square or rectangular resin (plastic looking) filters that are of very high optical quality. They are used in special holders mounted onto the front of the lens.
With large front-mounted filters in mind, there are different types of solar filtration available for large diameter Canon L-series, big white telephoto lenses. In this case, you’ll use large filters that mount over the front of the lens – often referred to as full aperture filters.
There are two ways to mount these filters. You can buy them in sheets and fashion your own frame large enough to cover the front of your lens or buy the filter already mounted into a round aluminum housing that slips over the front of the lens.
mounting a solar filter
Just as in the mounting, there are two types of solar material used in these type filters: Metalized Mylar foil and Silver/black polymer film.
Thin, metalized Mylar is an inexpensive foil type filter that will do the job and is available all over the Internet. Be careful as to the source some of these Internet resources use. It is difficult sometimes to determine the actual manufacturer of this material because, in some cases, this material is also used in the food packaging industry and is repurposed as a solar filter. This Mylar material is prone to pinholes. This is usually sold in sheets that can be cut to fit various homemade mounting devices. Being silvered on both sides, this material is highly reflective and has the possibility of creating reflections off the front of your glass, onto the back of the silvered Mylar filter and then back into your lens. Check the photo below (sent in by a reader) which shows this ghost-like halo. This type filter produces a blueish/white sun disk.
ghost-like halo produced by Mylar solar filter
Silver/black polymer film has the optical quality of glass and is flat compared to the wrinkle prone metalized Mylar foil material. The advantage of this type filter is that the silvered front surface restricts the transmission of the infrared and ultraviolet spectrum making it safe for direct viewing or photography. And, the black reverse side of the filter eliminates the “ghosting” reflection off the back of the filter. This type of filter produces a yellow-orange colored sun disk and is relatively inexpensive.
These filters are completely safe for viewing as well as photography. They block the harmful Infrared and ultraviolet wavelengths.
A popular source for large-lens slip-on filters, solar viewing glasses and solar viewing frames is Thousand Oaks Optical. Their filters are used by scientists, astronomers and most observatories all over the world. They’re also approved by NASA and CE and ISO certified. Check their website for the filter size for your telephoto or super telephoto lens.
thousand oaks optical filter
Don’t Use the Rear Filter Tray
Most of the large Canon L-series super-telephoto lenses have a rear mounted slip-in filter tray. NEVER use a solar filter in this tray. This filter mounting system is designed for terrestrial photography using traditional photography filters. It is not designed to house a filter to be directed celestially into the sun. At these magnifications, you will destroy the filter — similar to taking a magnifying glass to a leaf and put your lens, sensor and your eyes in danger. The intense light and heat could fry aperture and image stabilization mechanisms, damage the autofocus sensor and, if the mirror is locked up ruin your sensor. Buy the correct front-mounted solar filter. They’re relatively inexpensive and completely safe.
Solar Eclipse – Direct Viewing
If you’re part of a solar viewing group, or just want to enjoy viewing the solar eclipse without a camera, there are safe options as well. You can use special-purpose solar filters, such as “eclipse glasses” or hand-held, cardboard mounted solar viewers.
For this kind of viewing, there are many sources for cardboard mounted solar filters such as Eclipse2017.org, Greatamericaneclipse.com and ThousandOaksOptical.com (Thousand Oaks also has a large rectangular “viewer” for people that wear eyeglasses; you simply hold it in front of your eyeglasses).
IT IS OK TO WATCH, ENJOY, AND PHOTOGRAPH A SOLAR ECLIPSE - BUT ONLY IF YOU DO IT SAFELY AND WITH PROPER EYE AND CAMERA PROTECTION!
If you have questions you'd like Dave and Ken to address in an upcoming article, email them at: info@theeclipseguys.com.
Click here for more information on photographing the solar eclipse!
SAFETY FIRST: Never look at the sun without accredited and approved solar filtration over your eyes. Permanent, irreversible eye damage and/or blindness can result in seconds. Never point your camera into the sun without an approved solar filter over your camera lens(es). Not using a solar filter at eclipse magnifications will ruin your camera in seconds. Never improvise, modify or use general photography neutral density filters.
