WCM Rendering with Meta tags
Actions
Auroras Lake Myvatn, Iceland
Photographing Auroras
By: Jennifer Wu
May 03, 2018
Auroras
Stream of Light - The moon had set, thus there was little light on the mountains. Later that evening, the light from the aurora is reflected on the river and illuminates it and some of the mountains. Brooks Range, Alaska. f/2.8, 20 seconds, ISO 1000, EF 16–35mm f/2.8L II USM at 16 mm, Canon EOS 5D Mark II.
In awe of the spectacular colors, I dreamed of seeing the northern lights and photographing them. I called a friend, asking him to go with me to Alaska and though auroras were on his bucket list, he wanted his first trip to Alaska to be in summer. I promised rugged Alaskan landscapes with fall colors like summer, but with even better colors and he agreed! I hadn’t been to Fairbanks, Alaska before, but I was sure it would be grand. Arriving, we were greeted with a snow-covered landscape. “Where are the fall colors?” he asked and I quickly promised him that the northern lights would be spectacular.
The first two nights were completely overcast with no sign of the lights. By the third night we could only see a hint of green color through heavy clouds. With a promising weather forecast on the forth night, we drove north along the Haul Road to a mountain pass and waited in the bitter cold, hoping for clear skies and auroras.
The moon had set below the horizon, darkening the star-filled sky.  At 1 a.m. the clouds finally cleared and the auroras appeared! They were dim at first, but at least visible. We photographed the light show as it danced in the night sky. It was more than I could have imagined! Curtains of light formed, swaying with rhythmic motion, dimming and then glowing more intensely. Excited, I watched a dream coming true. Now, my friend can’t wait to return to photograph more of these "fall colors!"
Auroras
Purple Aurora - Without a moon, the mountain landscape becomes a silhouette at Geysir Hot Springs, Iceland. f/2.8, 10 seconds, ISO 800, EF 24-70mm f/2.8L II USM at 24mm, Canon EOS 5D Mark III.
Auroras
Auroras dance in the night sky with amazingly colorful light. They can be seen mainly around the North and South Pole and are referred to as aurora borealis or northern lights in the northern hemisphere, and as aurora austrails or southern lights in the southern hemisphere.
Auroras are created when the Earth’s magnetic field is disturbed by charged particles from solar winds or solar storms created by the sun. These particles, in the form of electrons and protons, are drawn into the upper atmosphere near the poles by the earth’s magnetic field. If they interact with the Earth’s atmosphere, then they create the auroras we see.
Auroras emit light in red, green and blue or a combination of colors producing various shades such as magenta and violet with more intense solar storms. Green is the most common color, then violet. However, blue is rare. The colors appear much stronger when viewed in a photograph as opposed to what we can see with our naked eyes. I have often seen white light that looks like a bright cloud, but discovered strong green light when using Live View or reviewing the photographs on the LCD screen or computer. Take photographs even if you think the auroras are dim or colorless because you might be surprised!
Composition
Scout your location in the daytime, looking in all directions and use a compass to pay particular attention to the northeast to northwest, where auroras often form. They can form an arc from the northwest to southeast.
While photographing, you can chronicle the auroras as they change in shape, increase and decrease in intensity. Various shapes are possible with arches, curtains, circular curtains, vertical lines or the aurora corona. The corona is seen as radiating lines coming out from a single point, directly above.
Photograph Both Horizontal and Vertical
Auroras
Colorful Night, Horizontal Composition - My first inclination is to shoot vertical for auroras as they reach overhead as streams of light into the sky. However, don’t forget to take horizontal images too. Multiple colorful streams of auroras fill the sky with the red and magenta colors above the green colors. The lights occur at different distances from the Earth depending on the gasses present with blue often the closest, then green with red above and the farthest from Earth. Lake Myvatn, Iceland. f/3.5, 13 seconds, ISO 2500, EF 16-35mm f/2.8L II USM at 16mm, Canon EOS 5D Mark III.
Auroras
Colorful Night, Vertical Composition - Both the vertical and horizontal compositions worked for this scene. I set up one camera with a tripod photographing horizontally and set up a time-lapse sequence to continuously photograph the scene with one second between frames. Once that was set up, I used a second tripod and camera to shoot vertical to vary the composition. f/4.0, 13 seconds, ISO 2500, EF 14mm f/2.8L II USM, Canon EOS-1D X.
Where to Photograph the Auroras?
Auroras typically form 60 to 200 miles above the surface of Earth in a three to six degree latitude band away from the South and North Poles, but can be seen in the upper contiguous 48 states of the United States when there’s a big solar flare. That being said, the active bands near the North Pole will give you a much better chance of seeing auroras as they are present about two-thirds of the year. The South Pole’s active band is in Antarctica and not easily accessible. Only very intense solar storms can be seen in Southern New Zealand, Falkland Islands, South Georgia and South Sandwich Islands.
The best locations in the United States are in Alaska, (Fairbanks, Coldfoot, Wiseman and Barrow). Other good locations outside the United States include Tromsø, Norway; Kiruna, Sweden; Whitehorse, Churchill and Yellowknife in Canada; Kangerlussuaq and Tasiilaq, Greenland; Jökulsárlón, Lake Kleifarvatn and Lake Myvatn in Iceland and Murmansk, Russia. Staying away from light pollution and city lights helps improve aurora visibility.
Photograph of Aurora Band of Light - These images show the prediction of the aurora in the three to six degree latitude band near the North and South Poles, with the night side of the earth being darker. (Credit: Newell, P. T., T. Sotirelis, and S. Wing (2009), Diffuse, monoenergetic, and broadband aurora: The global precipitation budget, J. Geophys. Res., 114, A09207)
When is it Best to Photograph the Auroras?
The months with the highest activity are March and then September, followed by April and October. Anytime between mid-April and mid-August has high potential, but be aware that the long days during the summer months from May through July do not get dark enough in the most common areas of aurora activity.  I’ve photographed with different conditions: in the fall, when it is the warmest and auroras reflect in lakes that are not yet frozen over; in winter with beautiful light reflecting snow-covered landscapes; and in spring with melting water and possible snowy foregrounds.
Sunspots and resulting solar flares create the magnetic disturbance for the aurora activity, but it isn’t the same every year. The sun is on an eleven-year cycle of intense solar activity and the next big event is the year 2024, with above average solar activity continuing for several years following. Don’t be discouraged from going any year.
Auroras
Sunspots - Sunspots are the dark colored spots you see here, which emit intense magnetic fields. Photographed with a solar filter and cropped to just the sun. f/5.6, 1/500th  second, ISO 640, EF 200-400mm f/4L IS USM EXT for actual focal length of 560mm, Canon EOS 5DS R.
What Time is Best to Photograph Auroras?
The auroras are most active between 10 p.m. to 2 a.m., however, it is possible to see them anytime it is dark enough. In the band of activity, twilight is long-lasting and it is possible to see faint auroras an hour before or after sunset and sunrise. After auroras disappear, wait for another round, called an aurora substorm, to reoccur. Your patience may be rewarded with a delightful light show!
Light Display
Light Display - Fascinated, I watched the lights play like musical notes that quickly changed rhythm, lighting up one area while disappearing in another. Lake Myvatn, Iceland. f/2.0, 10 seconds, ISO 1600, EF 24mm f/1.4L II USM, Canon EOS 5D Mark III.
Aurora Forecasts
Maximum aurora intensity usually occurs two days following sunspots and their resulting solar flares. The particles in solar winds take from one to three days to reach the Earth’s atmosphere.
The sun rotates on its axis every 27 to 28 days. Sunspots don’t always create the aurora, but sunspots with aurora activity can reappear in 27 to 28 days for another light display. Sunspots can be present for a few hours to many months but may dissipate by the next sun cycle, making long term forecasts not as accurate as current activity. Monitor the recorded activity of your location 27 days prior to your trip or if you are able, go 27 days after intense aurora activity.
Understanding Forecasts
The aurora activity happens if the sun’s magnetic field interacts with the Earth’s field.  The NOAA Kp-Index provides the level of the Earth’s magnetic activity and ranges from a value of zero with little to no activity to a value of nine with extreme activity. The larger the number, the more colorful and grandiose the light show, and the farther they can be seen from the common aurora band.
Kp-Index Map
Kp-Index Map - The aurora KP prediction levels of 3, 5, 7 and 9 are shown with a map overlay depicting how far away they will occur from the general aurora band of activity. (Credit: NOAA/Space Weather Prediction Center).
Aurora Forecast Resources
• Aurora Forecast app and other apps provide current night aurora predictions. Set up an app to alert you when there is aurora activity in your area.
NOAA Space Weather Prediction Center:  predicts the next 30 minutes of activity based on solar winds and is updated every 30 seconds. In addition, there is a link for the three day forecast.
University of Alaska Fairbanks Geophysical Institute
University of Alaska Fairbanks Geophysical Institute Aurora Prediction
University of Alaska Fairbanks Geophysical Institute Aurora Prediction - This prediction shows maps with the current and long-term forecasts. (Credit: University of Alaska Fairbanks Geophysical Institute)
Lenses
Wide-angle lenses work best for photographing auroras and the large expanse of the night sky while minimizing the movement of the stars. Both wide-angle and telephoto lenses work for aurora with star trails. I recommend an f/2.8 or faster lens. Using an f/4.0 lens is possible, however you will need bright auroras and there will be more noise from collecting less light, resulting in a higher ISO.
Ultra wide focal lengths from 14mm to 16mm work well when auroras fill the sky or fill the frame overhead. Wide focal lengths from 24mm to 35mm work well when the auroras are a curtain or stream, but not filling the sky. Excellent f/2.8 or faster lenses include: 14mm, 15mm, 16-35mm, 24mm, 24-70mm and 35mm.
Corona and Lake
Corona and Lake - The corona is when the aurora forms rays that give the appearance of radiating out from a single center when looking overhead. This happens when the auroras are high in the sky. The corona is in the upper right area of the frame. The 14mm ultra wide-angle lens allowed for large coverage of the sky. Lake Myvatn, Iceland.  f/4.0, 13 seconds, ISO 1600, EF 14mm f/2.8L II USM, Canon EOS-1D X.
Exposure Settings
Set the camera exposure before you leave to go out photographing. A good starting point is: f/2.8, ISO 1600 and the maximum shutter speed as determined by your lens, such as 20 seconds. Reduce the shutter speed to five to ten seconds or less to stop the movement of the auroras, as needed after reviewing the image on the LCD screen. Sometimes they move faster and sometimes slower, so the shutter speed will vary. Look for increased detail and lines in the auroras.
With a narrower aperture, such as f/2.8 instead of f/1.4, the image will typically exhibit less chromatic aberration and be sharper across the frame. I recommend using f/2.8 but use a wider f/1.4 aperture if the auroras are dim or fast moving.
Finally, adjust the ISO to create a good exposure at a desired shutter speed and aperture. Starting with 1600 ISO however will vary depending on how bright the auroras are that night. I recommend not going over 6400 ISO.
Use Live View to review the RGB histogram before taking an exposure. Set your histogram to RGB instead of Brightness View. In Brightness View you only know if all three color-channels are clipped and with RGB you can see if the individual red, green or blue channels are clipped. When making an exposure, reduce exposure as needed to prevent a spike on the right side of the histogram. Any clipping on the right will mean that you have overexposed and lost detail highlights.
Be sure to have some detail in the mid-tone and highlight areas of the histogram with auroras and information into the far right bar of the histogram. This will provide a good exposure. You can also turn on Highlight Alert to show “blinkies” for overexposure as an extra precaution.
Do not use the LCD screen to determine exposure because your eyes will adjust to the dim light, making an underexposed image look good.
For more on understanding histograms, refer to this article.
Aurora and Star Trail
Aurora and Star Trail - Lake Myvatn, Iceland. I set up a time-lapse and combined 142 frames in Photoshop® to create this star trail image.  f/2.8, 8 seconds, ISO 2500, EF 16-35mm f/2.8L II USM at 16mm, Canon EOS 5D Mark III.
Working in Cold Weather
I have never had a lens or camera stop working from the cold in minus F°except when frost froze the controls or batteries got too cold. Keep gear functional by keeping extra batteries warm in your pocket to conserve their power. To stay warm, use chemical hand and toe warmers that have stickers. Put them on your lens in freezing weather to prevent frost on the front element of the lens and camera battery area. Use a lens hood to reduce frost.  They can easily be strapped to your gear with simply hook and loop straps.
Protect your gear from condensation and fogging by closing your camera bag, covering with your coat and not opening it in a warm room or car until it comes up to room temperature slowly.
Green Curtains
Green Curtains - The aurora formed curtains that waved in the sky, growing brighter and then disappearing into the night. The half moon was not visible, however it still provided light in the sky since it was close to the horizon. The warm glow on the horizon is from ambient city lights. Photographed at Lake Myvatn, Iceland. f/2.8, 4 seconds, ISO 1600, EF 24mm f/1.4L II USM, Canon EOS 5D Mark III.
Using Filters
Remove any filters for aurora photography. Neutral density and polarizers will cause your exposure to be longer and create more noise in your image. UV filters will cause concentric rings in auroras that are impossible to remove in post-processing.
Moonlight
The moonlight will have different effects on your aurora photographs. While you can photograph the aurora in any moon phase be aware that while a full moon provides extra light on the landscape, it will also wash out auroras and stars. A half moon provides plenty of light to fully light the landscape, but allows you to see more stars and brighter auroras than the full moon. A new moon, the phase of the moon when it is not visible from earth, will allow for more intense colors and more visible stars, but with a dark silhouetted landscape. With little to no moonlight and strong aurora activity, the landscape can still be partially lit by the light from auroras alone.
On Left: Moon Lit Crater and Aurora - The half moon fully lit the crater. There are more stars in the sky here than what you would see on a night with a full moon. f/2.0, 6 seconds, ISO 1600, EF 24mm f/1.4L II USM, Canon EOS 5D Mark III.
On Right: Mountain Lights - The half moon has already set here. Notice how much darker the mountains are in this image and how many more stars, versus the image on the left. This is due to the moon setting about a half hour before taking this photograph. In addition, the lights were not very strong and only had a prediction level of one. Due to the low light, I used a wider aperture of f/1.4 to funnel as much light as possible into the camera and use a lower ISO setting. f/1.4, 10 seconds, ISO 1600, EF 24mm f/1.4L II USM, Canon EOS 5D Mark II.
More Information
For more detailed information about night photography, please read my article on Photographing the Milky Way and night photography series.
Additional Aurora Resources:
Alaska Aurora Webcam
• Astronomy North Weather Canada Aurora Forecasts and resources: http://astronomynorth.com
• AuroraMAX: watch for photographs of current activity in your area. - Facebook page - Twitter page
Canadian Space Agency: Canada Resources
Iceland Webcam
Stellarium: free planetarium software
SOTERIA Flare Predictor Tool shows sunspots and solar flares
Space Weather Solar Flares, Long Term Forecasts, aurora forecast daily tweets
Time and Date for moon phase
Tromsø, Norway Webcam
The CDLC contributors are compensated spokespersons and actual users of the Canon products that they promote.
http://learn.usa.canon.com
