Web Content Viewer
Actions
X-ray Source G-311 D Series
X-ray Source
Contact information form - email to Canon ANELVA Products Group
Contact Us
Features
1. Diamond Window
2. 0.29 mm X-ray Target Window Thickness
  • Capable of high geometrical magnification*
3. High Resolution and High Power Simultaneously
  • 4 μm L/S resolution at 10 W
4. Wide X-ray Cone Angle
  • 168° X-ray cone angle
5. Quick Warm-up
  • Operational within 3 min of power up
  • Quick image acquisition after facility maintenance
6. Fast Image Capture
  • 0 kV to 110 kV within 1 sec
7. Embedded Pulse X-ray Irradiation Mode
  • Allows for on/off X-ray irradiation at pulse setting
  • Lower X-ray dose than continuous exposure
  • Contributes to longer life of X-ray tube and X-ray detector
* Dependent on size of sample
Applications
G-311 D X-ray Source series are applicable for in-line and off-line non-destructive X-ray inspections, such as:
  • X-ray radioscopy
  • X-ray CT
† Please note that our X-ray Sources were developed specifically for industrial use and cannot be used in food, beverage or medical imaging for human body.
This is to make Misc appear on the page when needed.
Specifications
Download Specifications
G-311MH-D
G-311MH-DP
G-311ML-D
G-311VH-D
X-ray Tube Type Sealed Transmissive Type
X-ray Irradiation Mode Continuous or Pulse
X-ray Pulse Width 1 sec 50 msec 1 sec 1 sec
X-ray Pulse Duty Ratio 50 %
Tube Voltage Operational Range 60 - 110 kV 40 - 110 kV 60 - 110 kV
Min. Resolution by JIMA RT RC-02B 4 μm 4 - 5 μm 4 - 8 μm
Max. Target Output Power 10 W 30 W
Tube Current Operational Range 10 - 100 μA 10 - 300 μA
Max. Power Consumption 40 W 65 W
X-ray Cone Angle 168 °
X-ray Window Material / Thickness Diamond / 0.29 mm
Target Material Tungsten
Weight Including High Voltage Power Supply 21 kg
Method of Cooling Convection Cooling
Input DC Voltage 24 V
High Voltage Power Supply Built-in
Operating Ambient Temperature 10 - 40 °C
Storage Temperature 0 - 50 °C
Operating and Storage Humidity 85 % (No Condensation)
External Control RS-232C
G-311MH Dimensions Chart - Top, Side, Bottom views
 Return to Top
