Web Content Viewer
Actions
EOS-1D C
Cinema EOS
Tech Explained: Learn The Science Behind 4K Optics.
0% Financing Available
Click here to learn more about this special offer. Restrictions apply.
Providing access to all important user functions.
Features
Compact, Durable, Self-Contained 4K Video Recording
The EOS-1D C is an HD video powerhouse providing cinematographers 4K video capture in a single unit, with no need for external power or recording devices. The EOS-1D C is fully self-contained, with the ergonomic ease-of-use portability one expects from a Canon DSLR. Control layout is intuitive for both still and video shooting and the compact size provides an unobtrusive method to getting your desired footage. The EOS-1D C is also fully sealed for protection against dust and moisture.
18.1 Megapixel Full-Frame CMOS Sensor
The EOS-1D C carries the latest generation of Canon's Full-Frame CMOS sensor. With a Full-Frame sensor, Canon EF and EF Cinema lenses will perform to their true potential, while improved signal-to-noise ratio provide clearer shadows and highlights in both bright and low-light environments. Achieve high quality results across the ISO range from 100 to 51200, expandable from ISO 50 to 204800. The sensor in the EOS-1D C also minimizes the rolling shutter effect with a high-speed read across the sensor bus for true-to-life images.
4K Motion JPEG YCbCr 4:2:2, 8-bit video recording
The EOS-1D C is a completely self-contained device that captures 4K video in a cropped-sensor configuration at 24fps in YCbCr color space with a sampling ratio of 4:2:2 and 8-bit depth. Color and luminescence are preserved, while footage can easily adapt to existing post-production workflows without conversion. 4K video can be monitored on the camera's rear LCD, or HD video can be output via HDMI to an external recorder for proxy editing. 4K files can also be played in native resolution using the EOS MOVIE Player.
Full HD Recording and Super 35mm Crop Mode
In addition to standard frame rates of 30fps, 25fps and 24fps, the EOS-1D C also enables Full HD recording at 60fps and 50fps and supports high-speed shooting for spectacular slow-motion footage. The camera's built-in LCD monitor can both preview and play back footage at its native frame rate. The EOS-1D C also supports Super 35mm Crop in Full HD at 30fps, 25fps, and 24fps. Image compression is H.264 and HDMI support permits external monitoring and playback of footage independent of shooting mode. When monitoring Super 35mm Crop images, the monitor automatically masks the image to aid composition.
Dual DiG!C 5_ Image Processors
The EOS-1D C utilizes dual DIGIC 5+ Image Processors for stunning speed and image quality. Each DIGIC 5+ Image Processor contains twin 4-channel A/D converters for outstanding image quality, and refined algorithms reduce noise at high ISO values. The EOS-1D C also applies real-time correction of chromatic aberration and other optical artifacts based on data stored in-camera. Lens data can be added and deleted by using the included EOS Utility software.
Canon Log Gamma
Canon Log Gamma is a setting that sets the EOS-1D C to maximize dynamic range and provide a wide exposure latitude. The files produced using log format are ideal for post-production processes where corrections, color matching, and grading are applied, providing users with a high level of creative freedom in post-production without substantially degrading image quality. When using Canon Log, the EOS-1D C can provide a dynamic range of up to 800%.
HDMI Output with Time Code
The EOS-1D C offers several new capabilities via HDMI output. Connect via HDMI to an external video recorder and output uncompressed YCbCb 4:2:2 8-bit video footage. Output frame rate is independent of shooting rate, allowing it to be matched to the capabilities of the external recorder. HDMI output supports Full HD video, even when recording 4K video to the on-board CF cards. Time code is embedded into the footage for easy synchronization of audio or visual effects. Camera control is also enabled via HDMI; the transport controls on the external recorder can be used to control the camera remotely. In addition, footage can be previewed simultaneously on the camera's LCD monitor and via the HDMI output for multiple monitoring options.
Compatibility with EF Cinema and EF Lenses
The EOS-1D C is compatible with the full line of Canon EF lenses, including EF Cinema lenses (Cinema zooms are compatible only in Super 35mm Crop mode; Cinema primes are compatible in all modes). Ultra-wide, zoom, 4x macro, tilt-shift, and super-telephoto lenses in the EF line are tools to realize your most ambitious cinematic vision. EF Cinema Lenses merges the technology of advanced Canon cinema optics and compatibility with a broad array of industry-standard accessories.
Built-in Headphone Terminal
The EOS-1D C includes a built-in headphone terminal which outputs unprocessed sound, giving you the clear audio image while the camera is recording it.
WFT-E6A Wi-Fi® Unit with Remote Capabilities
The EOS-1D C can connect to an optional Wi-Fi® transmitter unit WFT-E6A to provide unique capabilities not found in competitive units. Users can control the EOS-1D C using any web-enabled devices such as laptops, smartphones, and tablet PC's. Functions of the EOS-1D C with the WFT-E6A include the ability to adjust shooting parameters, start and stop the camera, monitor a remote feed and input metadata. Bluetooth v2.1 +EDR communicates with external GPS units to embed location data with your footage.
Fully Featured 12.0 fps, 18.1 Megapixel Full-Frame DSLR Camera
The EOS-1D C shares its heritage with the EOS-1 Series family and is a world-class DSLR camera besides being a cinema powerhouse. Dual DIGIC 5+ Image Processors and an 18.1 Megapixel Full-Frame CMOS sensor provide a burst shot rate of 12.0 fps for capturing the action with exceptional quality. With ISO sensitivity ranging from 100 to 51200, expandable to L: 50, H1: 102,400, H2: 204,800, the EOS-1D C allows you to grab the best possible shot even in the most challenging lighting. The 61-Point High-Density Reticular autofocus system with a coordinated 100,000 pixel RGB metering system provides sharp images with incredible color and clarity.
Click here to view the new features available with this factory update.
Specifications
Resolution
Approx. 18.1 million effective pixels (Total pixels: Approx. 19.3 million)
Recording Pixels
5208 x 3477 effective pixels
Sensor Type
Pixel Size
6.95 microns square
Lens Focal Length Factor
Same as indicated on lens (as indicated on lens)
4K: approx. 1.3x; Super 35mm Crop: approx. 1.6x
Compatible Lenses
Canon EF Lenses (excluding EF-S, EF-M lenses)
Canon EF Cinema (CN-E) lenses*
* Since the image circle of EF Cinema zoom lenses only support the image sizes of Super 35mm Crop and APS-C, vignetting will occur if you shoot larger image sizes.
Number of AF Points
61
Number of Cross-Type AF Points
1 to 5 cross-type AF points at f/2.8
10 to 20 cross-type AF points at f/4
15 to 21 cross-type AF points at f/5.6
1 cross-type AF point at f/8
(The number of cross-type AF points will differ depending on the lens.)
AF Area Selection Modes
Single-point AF (Manual selection)
- Auto selection 61-point AF
- Single-point Spot AF (Manual selection)
- AF point expansion (Manual selection, 4 points: up, down, left, and right)
- AF point expansion (Manual selection, surrounding 8 points)
- Zone AF (Manual zone selection)
AF point setting for vertical/horizontal orientation
Available
Focus Modes
One-Shot AF
- Predictive AI Servo AF*
- Manual focus
* For automatic AF point selection, the AF point to start the AI Servo AF operation can be selected. For automatic AF point selection, the active AF point can be displayed.
Recording Format
MOV
4K: Motion JPEG
Super 35mm Crop, Full HD, HD
- MPEG-4 AVC (H.264), variable bit rate
- Audio: Linear PCM, Meta information is embedded in the MOV file (no separate THM file)
- NTSC and PAL
Coverage
Approx. 100% vertically and horizontally
Color Space
Color space matches the TV monitor
Color Sampling Method
- YCbCr 4:2:2 (8bit): 4K
- YCbCr 4:2:0 (8bit): Super 35mm Crop, Full HD, HD, SD
Color Profile (Color Matrix)
- Rec. ITU-R BT.601: 4K, SD
- Rec. ITU-R BT.709: Super 35mm Crop, Full HD, HD
Image Creation Processing
- Based on current Picture Style
- Canon Log gamma * View Assist possible.
Video Range
Full range (0-255)
Timecode
Count up: Rec run, Free run
Start time setting: Manual entry, Reset, Set to camera time
Count indicator: Rec/Play time (Recording and playback time), Timecode
Drop frame: Enable, Disable
Maximum File Size Per Video Clip
4GB
Maximum Length for a Movie
12 hours
HDMI Output for Movie Footage
Possible - Output frame rate: Auto/24p/50i/60i
- Adding time code is possible
- Possible to synchronize an external recording device to start/stop recording
Signal Compatible with HDMI Output
1080: 60i/50i/24p, 480/60p, 576/50p
Before movie shooting: 1080: 60i/50i/24p
During movie shooting: 1080: 60i/50i/24p
Audio Recording Method
Linear PCM
- Internal monaural microphone
- External stereo microphone jack
Recording level automatically adjusted.
Sampling frequency: 48 kHz, Bits: 16 bit x 2 ch
Compatible with a commercially-available external microphone with 3.5mm dia. stereo mini-jack.
Headphone Terminal
Stereo mini-jack (3.5mm diameter) provided * Max. -9dBv (with 16 kΩ)
Sound Recording Adjustment
Sound-recording level: Auto, Manual (64 levels), None
* With the movie silent setting, recording level can be changed with touch pad.
- Sound-recording meter: Provided
- Wind filter: Disable/Enable
Video Snapshots
Not provided
Creative Image Processing
- Canon Log gamma (View Assist possible)
Focusing
Same as focusing with Live View shooting
- During movie shooting, the image cannot be magnified for manual focusing.
- Compatible with power focus mode in movie shooting.
Metering Method
1. AF point-linked evaluative metering
- When the AF mode is Live mode or Face Detection Live mode
2. Center-weighted average metering
- For manual focusing or when the AF mode is set to Quick mode
- Metering range: EV 0 to EV 20 (At 73°F / 23°C and ISO 100, with 50mm f/1.4 lens)
Video Exposure Control
1. Program AE for movie shooting
- For shooting modes other than manual exposure and bulb
- Shutter speed (1/30-1/4000 sec., signal accumulation time), aperture, and ISO speed automatically set.
2. Manual exposure
- For manual exposure.
- Shutter speed (signal accumulation time), aperture, and ISO speed (auto/manual) manually set. The shutter speed (signal accumulation time) is limited to 1/4000 sec. at the maximum and to 1/30 sec. at the minimum for 24/25/30 fps or 1/60 sec. or higher for 50/60 fps.
ISO Speed
- P, Av, Bulb: Automatically set within ISO 100-25600
Expandable to H (equivalent to ISO 51200), H1 (equivalent to ISO 102400) and H2 (equivalent to ISO 204800).
- Tv: Automatically set within ISO 100-25600
- M: With Auto ISO, automatically set within ISO 100-25600.
With manual setting, ISO 100?25600 set manually (in 1/3- or wholestop increments). Expandable to H (equivalent to ISO 32000/40000/51200), H1 (equivalent to ISO 102400) and H2 (equivalent to ISO 204800).
* If highlight tone priority is set, the ISO speed range will be ISO 200-25600.
Exposure Compensation
Up to ±3 stops in 1/3-stop increments
AE Lock
Possible
- During movie shooting, press AE Lock button to set AE lock and the AF point selection button to cancel AE lock (no automatic cancellation).
- AE lock (canceled automatically when metering turns off) possible before movie shooting. Movie shooting can start while AE lock is in effect.
Movie Digital Zoom
Not Provided
Information Display
Switchable with INFO button (5 settings)
Image Stabilization
With an IS lens and the Image Stabilizer switch turned on, image stabilization operates during metering and movie shooting.
Movie Playback
The following playback is possible:
Playback, Slow motion (variable speed possible), Jump to first frame, Previous frame, Next frame, Jump to last frame, Edit first or last frame, and Audio volume (11 levels, including mute)
* The audio level when the camera is connected to a TV set is adjusted with the TV set.
Editing Out First/Last Scenes
First/last scenes editable (deletion) in 1-sec. increments
Still Photo Extraction
Possible with updated version of ImageBrowser EX
Image Type / Processing
JPEG, RAW (14-bit)
Image Format Options
JPEG (compression adjustable) RAW (CR2)
M-RAW
S-RAW
RAW + JPEG
M-RAW + JPEG
S-RAW + JPEG
Resolution Options
Large - 5184 x 3456 (Approx. 17.90 million pixels)
Medium 1 - 4608 x 3072 (Approx. 14.20 million pixels)
Medium 2 - 3456 x 2304 (Approx. 8.00 million pixels)
Small - 2592 x 1728 (Approx. 4.50 million pixels)
RAW - 5184 x 3456 (Approx. 17.90 million pixels)
M-RAW - 3888 x 2592 (Approx. 10.10 million pixels)
S-RAW - 2592 x 1728 (Approx. 4.50 million pixels)
Data Recording Format
Complies with Design rule for Camera File system 2.0 and Exif 2.3
Folder Setting
Creating new folders and selecting folders in the card is possible.
Storage Media
CF card (2 slots)
- Type I/II drive (Incompatible with Microdrive)
- High-speed writing possible with UDMA CF cards.
Recording Options
Standard
- Select one of the CF cards to record.
Auto switch card
- When the current card becomes full, the camera switches to the other card automatically.
Record separately
- The same image is saved to both cards, but in a different size (L, M1, M2, S, RAW, M-RAW, or S-RAW) that was set for the respective card.
Record to multiple
- The same image is saved to both cards in the same size (RAW+JPEG also possible).
Image copying: Possible between the two CF cards (2 slots).
Noise Reduction
Long exposure noise reduction (set with a menu):
- Functions with exposures 1 sec. or longer.
- [Auto] or [Disable](always applied) settable.
High ISO speed noise reduction (set with a menu):
- [Standard], [Low], [High], or [Disable] can be selected.
Imaging Processor
Maximum Frames Per Second
12 fps High-speed continuous shooting
14 fps Super high-speed continuous shooting:
Drive Modes
Single Shooting
High-speed continuous shooting (12 fps)
Low-speed continuous shooting (3 fps)
Silent single shooting
Self-timer (10 sec. and 2 sec.)
Super high-speed continuous shooting (14 fps)
Number of Maximum Frames / Burst
JPEG Large: 180
JPEG Medium 1: 310
JPEG Medium 2: 1390
JPEG Small: 6430
RAW: 38
M-RAW: 28
S-RAW: 41
RAW + JPEG Large: 17
M-RAW + JPEG Large: 19
S-RAW + JPEG Large: 20
High-speed continuous shooting with 8GB UDMA-7 card based on Canon's testing standards and may vary depending on shooting conditions.
Flash Sync Speed
Up to 1/250 sec.
Shutter Lag Time
(1) During SW-1 ON, time lag between SW-2 ON and start of exposure: Approx. 0.09 sec. *With flash, approx. 0.035 sec.
(2) Time lag between simultaneous SW-1/SW-2 ON and start of exposure: Approx. 0.55 sec.
Start-up Time
Approx. 0.1 sec (Based on CIPA testing standards)
UDMA High-Speed Compatible
LCD Monitor
Kelvin setting (setting range: 2000K to 15000K), daylight, tungsten, settings (A/B)
Frame Rate
3.2-inch (Screen aspect ratio of 3:2)
- Approx. 1,040,000 dots
- Approx. 100% coverage
- Approx. 170° vertical and horizontal viewing angle
Brightness Adjustment
Manually adjustable to one of seven brightness levels
Playback Options
Single image display
Two types of single-image full display and two types of shooting information display.
Index display
4-image index and 9-index image
Jump display, Jump 1 image, Jump 10 images, Jump 100 images, Date, Folder,Movies, Stills, or Rating
3-Part Dust Reduction System
Movie recording, custom picture settings, metadata 2-slot
SD Card
Recording of movies and photos (JPEG), custom pictures, metadata, menus and other data possible
Video Compression Formats
EOS Integrated Cleaning System:
1. Self Cleaning Sensor Unit - * Carrier wave type, removes dust adhering to the infrared- and ultraviolet-blocking glass. Self-cleaning executed automatically (taking about 1.8 sec.) when power is turned on or off. Manual execution also possible (taking about 5.2 sec.). Low-pass filter has a fluorine coating.
2. Dust Delete Data acquisition and appending - The coordinates of the dust adhering to the infrared- and ultraviolet-blocking glass are detected by a test shot and appended to subsequent images. The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots.
3. Manual cleaning
ISO Range
100-51,200 in 1/3-stop or whole-stop increments
ISO Expansion Range
- L: 50
- H1: 102,400
- H2: 204,800
Auto ISO: 100-51,200
Shutter Speed Range
1/8000 to 1/30 sec., bulb, X-sync at 1/250 sec.
Shutter speed's control range can be set with a Custom Function.
Exposure Modes
Program AE (shiftable), Shutter-priority AE (Safety shift possible), Aperture-priority AE (Safety shift possible), Manual exposure, Bulb, E-TTL II autoflash program AE
Metering Modes
252-zone metering with approx. 100,000-pixel RGB AE sensor and TTL maximum aperture metering employed.
EOS iSA (Intelligent Subject Analysis) system employed.
Evaluative metering (linked to all AF points)
Partial metering (center, approx. 6.5% of viewfinder)
Spot metering (center, approx. 2.5% of viewfinder)
- Center spot metering
- AF point-linked spot metering (Custom Function)
- Multi-spot metering
Up to eight multi-spot meter readings can be taken.
Metering Range
EV 0-20 (at 73°F / 23°C with 50mm f/1.4 lens at ISO 100)
Manual: ±5 stops in 1/3- or 1/2-stop increments
AEB: ±3 stops in 1/3- or 1/2-stop increments
Automatic Image Correction
Peripheral Illumination Correction
Chromatic Aberration Correction
Highlight Tone Priority
Auto Lighting Optimizer
White Balance Modes
Auto (AWB)
Preset (Daylight, Shade, Cloudy, Twilight, Sunset Tungsten, White fluorescent, Flash)
Custom (Custom WB)
Color Temperature (Approx. 2,500-10,000 Kelvin)
Personal WB settings PC-1 - PC-5 (up to five white balance data that you set yourself with the provided software.)
White Balance Bracketing
Alter white balance in amber-blue direction or magenta-green direction, ±3 levels in single-level increments
Picture Styles
Auto, Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined 1-3
Compatible Flashes
Canon EX-Series Speedlites (Manual flash only with non EX-Speedlites)
E-TTL II
Yes
FE Micro adjustment
Available
Flash Exposure Lock
Available
Flash Exposure Compensation
±3 stops in 1/3-stop or 1/2-stop increments
PC Socket
Not Provided
Display
Intelligent Viewfinder uses a transparent LCD for superimposed display of the following:
AF Information
- AF Points
- AF Confirmation
- AF Status Indicator
Exposure information
- Metering mode
- shooting mode
- AE lock
- Shutter speed
- Aperture
- Exposure compensation
- ISO speed (always displayed)
- Exposure level
- Exposure warning
Flash information
- Flash ready
- High-speed sync
- FE lock
- Flash exposure compensation
Image information
Battery check
Composition information
- Grid, electronic level
Coverage
100%
Eyepoint
Approx. 20mm
Magnification
0.76x
Focusing Screen
Interchangeable
Diopter
-3 ~ +1.0 (user-adjustable)
Type
Electronic viewfinder with image sensor
Autofocus
Live mode (Contrast based) Face Detection Live mode (Contrast based)
Quick mode (Phase based)
Live View Features
Magnified view, 3 Grid types, Correct Exposure/Exposure Simulation Display activated through Menu (Aspect Ratio indicator not provided.)
Exposures
2 to 9
Type
Additive, Average, Bright, Dark
Shutter Durability
400,000 Cycles
Copyright Capability
The copyright information set with the camera is appended to the image as part of the Exif information
Camera System Information
Basic information:
- Serial No.
- Firmware version
- Shutter-release cycles
Camera status log:
- Error log
- Caution log
Video Output
HDMI mini OUT terminal (Type C), CEC compatible
Audio (stereo)/video (NTSC/PAL selectable) OUT terminal
External Microphone IN Terminal
3.5mm diameter stereo mini-jack
Headphone Terminal
Provided
PC Terminal
Not provided
Digital Terminal
For personal computer communications, direct printing (Hi-Speed USB)
Audio (stereo)/video (NTSC/PAL) output
Connects to GPS Receiver GP-E2 (Non-dedicated GPS)
Remote Control Terminal
N3-type terminal
Wireless Remote Control
Enabled with Wireless Controller LC-5
System extension terminal
For Wireless Transmitter WFT-E6A and GPS Receiver GP-E1
Ethernet terminal
RJ-45 jack (for gigabit Ethernet)
Battery
LP-E4 or LP-E4N Lithium-Ion battery pack
- With the AC Adapter Kit ACK-E4, AC power is possible.
Battery Life
With a fully charged LP-E4N Battery Pack:
Approx. 2 hr. 10 min. (at 73°F/23°C)
Approx. 2 hr. (at 32°F/0°C)
Battery Information
The power source type, remaining capacity (in 1% increments + 6-level battery check), shutter count, and recharge performance can be checked.
The battery registration and operation history (serial number, remaining battery level when removed, and date) cannot be checked.
Battery rechargeable regardless of remaining capacity.
Exterior Material
Magnesium alloy
Weight (without eye-cup)
Approx. 54.5 oz./1545g (CIPA Standard)
Approx. TBA oz./TBA g (Body only*)
* with date/time function battery
Weather Sealing
Dust and water resistant
Dimensions, W x H x D
6.2 x 6.4 x 3.3 in. (158 x 163.6 x 82.7mm)
EOS-1D C
EOS-1D C EOS-1D C Body Eyecup Eg Battery Pack LP-E4N Battery Charger LC-E4N Cable Protector and Clamp Stereo AV Cable AVC-DC400ST USB Interface Cable IFC-200U Wide Strap L7 EOS Digital Solution Disk Software Instruction Manual
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EOS-1D C that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Resources
Case Studies
No Place Like Home
08/03/17
10.23 MB
White Papers
Canon Log Gamma Curves
12/18/18
0.81 MB
The Promise of 4K
11/1/18
9.84 MB
Software Development Kit (SDK)
The Canon EOS Digital Camera Software Development Kit (EDSDK) enables developers to integrate select Canon cameras directly into their software application solutions, giving them access to remote camera control and communication functionality of the camera. There are two versions of the EDSDK compatible with Windows or Macintosh.
The Software Developer Kit is provided free of charge and can be found at DeveloperCommunity.usa.canon.com.
To learn more please visit the Canon Developer Community site and register to download Canon’s SDKs.
This is to make Misc appear on the page when needed.
Videos
“The Farmers” with Stableford Studios
Watch Tyler Stableford, one of Canon’s prestigious Explorers Of Light, use an imagePROGRAF large format printer paired with a Canon EOS-1D C, a Canon 5D Mark III, and a Canon 1D X, to capture THE FARMERS project.
From 4K to Large Format Prints with Ori Media
Watch Michael Ori, founder of Ori Media, discuss how he uses a Canon imagePROGRAF large format printer paired with a Canon EOS-1D C to simultaneously record 4K video, rip stills and create high quality prints.
Wish I Was Here: Behind the Scenes
Go behind the scenes with DP Larry Sher, ASC as he takes us through the opening sequence of Zach Braff’s Wish I Was Here, featuring a low shot captured while running full speed with the Canon EOS-1D C on a MōVI handheld stabilizing system.
Shooting with the Canon EOS-1D C
When co-Directors Kate Rolston and Tyler Stableford traveled to remote areas of Ethiopia to shoot a documentary, they packed the Canon EOS-1D C.
Canon Collaborations: The EOS 1D-C as Configured by Ori Media
When tasked with shooting an anti-smoking campaign for Utah Department of Health, the team from Ori Media needed a small, versatile camera to help them get the job done efficiently without sacrificing quality.
Awards
TIPA's 2013 Best Video DSLR
 Return to Top
