Web Content Viewer
Actions
EOS C300 Mark II PL
Cinema EOS
Item Code: 1131C002AA
0% Financing Available
Click here to learn more about this special offer. Restrictions apply.
Providing access to all important user functions.
Find an authorized Canon dealer or rental house for Cinema EOS C300 Series.
Features
Canon 8.85 Megapixel Super 35mm CMOS Sensor
The heart of any Canon camera is its superb image-sensor technology. The EOS C300 Mark II PL Digital Cinema Camera integrates an 8.85 Megapixel Super 35mm 16:9 CMOS sensor that supports 4K (DCI) recording with a maximum resolution of 4096 x 2160 pixels. The camera fully utilizes the image data delivered by this 4K CMOS sensor to also enable Over Sampling HD Processing for 2K (DCI) and Full HD1080/60p recording.
Each pixel in this CMOS imaging sensor also maintains a wide pixel pitch that maximizes the amount of light that falls on to each photo site, thus enhancing the EOS C300 Mark II PL’s sensitivity while also minimizing noise and supporting ISO speeds of up to 102,400 for extreme low-light imaging. This sensor also reduces data-readout time to about half of what it was in the original EOS C300 Camera, which results in a significant reduction in rolling-shutter artifacts.
The information yielded from the 4K sensor is fully utilized to enable high-image-quality 2K (DCI)/Full HD recording (Over Sampling HD Processing) and to support multi-purpose production needs.
Dual DIGIC DV 5 Image Processors
The EOS C300 Mark II PL Digital Cinema Camera's re-designed imaging system includes dual DiG!C DV 5 image processors, which work in concert with the camera's advanced Super 35 CMOS sensor and XF-AVC codec to enable a wide variety of image quality and feature improvements. These include 15 stops of dynamic range, Canon Log 2 recording, Dual Pixel CMOS AF, simultaneous 4K and HD proxy recording, and 2K/Full HD frame rates of up to 120 fps.
Internal CFast™ 4K Recording Technology
CFast™ (CompactFast) 2.0 cards are the next-generation mass-storage media employed by the EOS C300 Mark II PL for in-camera 4K video recording. The EOS C300 Mark II PL Digital Cinema Camera features two CFast™ card slots, each of which is protected by a convenient hinged cover. The camera also includes an SD card slot for HD and Proxy recording. For example, the camera can simultaneously record 4K on two CFast™ (2.0) cards along with 2K proxy images on its SD card for off-line editing.
Proper operation cannot be guaranteed for all recording media. Long term usage may reduce a CFast™ card's write speed. We recommend users regularly fully format and refresh their card using the "Full Format and Refresh Tool." available via the following URLs:
ScanDIsk: https://kb.sandisk.com/app/answers/detail/a_id/17370
Lexar: https://www.lexar.com/support/downloads
Canon Log Gamma 2/ACES/Rec. 2020 Support
The EOS C300 Mark II PL Digital Cinema Camera features a new log gamma designated as Canon Log Gamma 2, which was designed explicitly for the camera's 10-bit recording capabilities. The files produced using Log format are ideal for color correction/grading in post-production, providing users with a high level of creative freedom while minimizing degradation of image quality. When using Canon Log 2, the Cinema EOS C300 Mark II PL can provide a dynamic range up to 1600%.
Users can now set the Canon Log 2 gamma profile which achieves a uniform output n a wide area of the log space making it easy to perform post-processing.
Canon XF-AVC Codec
The EOS C300 Mark II PL Digital Cinema Camera incorporates the new Canon XF-AVC codec that allows 4K image data to be recorded internally onto CFast (2.0) cards. (The camera features two CFast card slots and an SD card slot.) This makes it easy for users to record high quality compressed 4K images in the camera body without the need for external recorders. If full uncompressed RAW recording is needed, the EOS C300 Mark II PL Digital Cinema Camera can output its signal through dual 3G-SDI outputs to an external recorder.
Slow- and Fast-Motion Recording (Up to 120 fps)
The EOS C300 Mark II PL Digital Cinema Camera features shooting speeds ranging from 1 fps (for time-lapse filming) to its highest speed of 120 fps (in 2K/Full HD). A wide range of expressive effects are made possible for creative digital filmmaking.
Multiple Recording Modes (HD/2K/4K)
Multiple recording modes, resolutions and frame rates make the EOS C300 Mark II PL Digital Cinema Camera creatively flexible and able to work in any production environment.
Canon EOS C300 Mark II PL with PL-Lens Mount
Designed to integrate into existing production setups, the EOS C300 PL is fully compatible with a wide variety of industry-standard PL-mount lenses, ensuring the finest in today's technology and operability will work seamlessly with trusted optics already in the filmmakers possession. Compatibility with Canon's existing PL mount lenses means filmmakers can take advantage of the brilliant new optical designs Canon has developed for the Cinema market.
Canon's amazing CN-E PL mount zoom lenses deliver superlative performance for large-scale, big budget movie productions. The PL CN-E series is 4K ready and comes in two models: Wide Angle CN-E14.5-60mm T2.6 L S/SP and Telephoto CN-E30-300 T2.95-3.7 L S/SP.
Canon Cinema Zoom Lenses
Canon's Cinema Zoom lenses offers outstanding optical performance for demanding high-end productions. With fluorite, aspherical lens elements and an advanced optical design, our Cinema Zoom lenses are capable of 4K-image reproduction. The wide-angle CN-E14.5-60mm T2.6 L S/SP provides industry-leading breadth of range; the telephoto CN-E30-300mm T2.95-3.7 L S/SP rivals best-in-class zoom magnification and telephoto focal length. Together these lenses cover the range most commonly used in cinema shooting.
Additional Lenses are already under development, reflecting's Canon's commitment to offer the broadest range of professional cinema lenses to meet filmmaker's needs, now and in the future.
Versatile and Refined Ergonomics
The EOS C300 Mark II PL Digital Cinema Camera builds on the innovative and efficient ergonomic design of the original, while also providing new advantages. Redesigned from the ground up to maximize shooting comfort and usability improvements asked for by users, the EOS C300 Mark II PL Digital Cinema Camera's modular design allows different components to be added or removed as needed to not only meet the demands of a particular shooting environment, but to also maximize the comfort of the camera operator. In addition to the core body of the EOS C300 Mark II PL Digital Cinema Camera, the EOS C300 Mark II PL Digital Cinema Camera comes with a removable hand grip, improved low-angle camera handle extension with additional attachment points, and removable LCD monitor and control panel with XLR audio inputs.
Ultra-High Resolution OLED EVF with Adjustable Viewing Angle
The EOS C300 Mark II PL Digital Cinema Camera features a 0.46 Inch 1.77 Megapixel color OLED EVF (Organic Light Emitting Diode Electronic ViewFinder). OLED technology increases the color reproducibility, contrast and response of the viewfinder, making camera operation and the judging of image characteristics seen in the viewfinder much easier. The EVF also offers 60º of tilt for more comfortable operation in a variety of positions.
Connectivity and Camera Control
The EOS C300 Mark II PL Digital Cinema Camera comes equipped with two 3G-SDI, a genlock input, a time code input/output, and an HDMI output. (The camera's various "assist-displays" - waveform monitor, edge monitor, peaking, zebra and magnify - can be output to the SDI and HDMI outputs.)
RC-V100 Remote Support LANC Compatible
The EOS C300 Mark II PL Digital Cinema Camera supports the Canon RC-V100 multi-functional remote controller for enabling image quality adjustments and camera operations to be set from a distance. The EOS C300 Mark II PL Digital Cinema Camera is also LANC compatible and supports a variety of LANC accessories from third-party manufacturers.
Wireless Remote Capabilities
Users can take dynamic control of the functionality of the EOS C300 Mark II PL Digital Cinema Camera using a standard web browser with the optional WFT-E6A or WFT-E8A wireless file transmitter. Almost all shooting operations and settings can be controlled from a laptop, tablet or smart phone. Focusing functions have been added, and the focusing area can even be moved by touch, allowing accurate focusing operations even when direct access to the camera is not available.
Full Manual Control
The EOS C300 Mark II PL Digital Cinema Camera is also a fully manual digital camera. Users of the EOS C300 Mark II PL Digital Cinema Camera have full manual control of all camera functions including iris, shutter speed, gain, zoom, focus, and audio, giving them the ability to adapt to both technical and artistic challenges when shooting. For maximum customization, users have access to Custom Picture Settings, Custom Functions, and Custom Display Options to tailor the camera precisely to their needs.
Specifications
Sensor
CMOS sensor (single-panel) equivalent to Super 35 mm
Total Pixels
Approx. 9.84 megapixels (4206 x2340)
Number of effective pixels
Approx. 8.85 megapixels (4096 x 2160): When 4096 x 2160 or 2048 x 1080 is selected as the resolution
Approx. 8.29 megapixels (3840 x 2160): When 3840 x 2160 or 1920 x 1080 is selected as the resolution
Lens Mount
PL mount
Exposure Modes
(1) Manual exposure based on shutter setting, iris setting, ISO/gain setting, and ND filter setting
(2) Push auto iris control, auto iris control (Light metering system selection, shift possible)
Shutter Setting
Speed, Angle, Clear Scan, Slow, or Off mode selected
Either 1/3 or 1/4 steps selected as speed increment
lris Setting
1/2-stop, 1/3-stop or fine setting selected
(1) Push auto iris control
(2) Auto iris control *
* Available only with some EF lenses
ISO
1 step, 1/3 step settings
[*100 - 160 - 25600 -*102400
*When the sensitivity is expanded
Gain
Normal [*-6dB - -2dB - 42dB - *54db]
Fine: Setting in 0.5d8 step increments possible
* When the sensitivity is expanded
ND Filter
5 density settings (2,4,6,8(*), 10(*) stops) [(*) when expansion is selected]
Motorized drive
Focus Control
DAF (Dual Pixel CMOS AF) supported
Manual focus, one-shot AF, continuous AF, AF-Boosted MF (*), face detection AF (Only lenses that support AF functions can be used in any of these modes.)
*See Technical Description.
LCD Monitor
4 (10.1 cm diagonal) color wide-screen LCD with 16:9 aspect ratio
Approx. 1.23 million dots (854 x RGB x 480), 100% field of view coverage
Viewfinder
0.46 (1.18 cm on the diagonal), color organic EL display with a widescreen 16:9 aspect ratio
Approx. 1.17 million dots (1024 x RGB x 576), 100% field of view ratio
White Balance
Kelvin setting (setting range: 2000K to 15000K), daylight, tungsten, settings (A/B)
Frame Rate
59.94 Hz, 50.00 Hz, 24.00 Hz
59.94 Hz mode 59.94i / 59.94P / 29.97P / 23.98P
50.00 Hz mode 50.00i / 50.00P / 25.00P
24.00 Hz mode 24.00P
CFast Card
Movie recording, custom picture settings, metadata 2-slot
SD Card
Recording of movies and photos (JPEG), custom pictures, metadata, menus and other data possible
Video Compression Formats
MPEG-4 AVC/H.264
Audio Recording System
Linear PCM (16bit/24bit- 48 kHz - 4ch)
File Format
MXF
Bit Rate
410/310/225/210/160Mbps Intra-frame 50Mbps Long GOP
35 or 24Mbps Long GOP (for proxy recording on SD cards)
CFast Card
Intraframe recording
Resolution : 4096x2160 / 3840x2160 / 2048x1080 / 1920x1080
Color Sampling: YCC422 10bit/(*)RG8444 (12bit/10bit)
(*) Only with 2048x1080 or 1920x1080; 29.97P, 23.98P, 25.00P and 24.00P
Long GOP recording
Resolution : 2048x1080 / 1920x1080
SD Card
Movies: Long GOP recording only (*)
Color Sampling: YCC420 8bit
Photo: JPEG
(*) Proxy recording using low bit rate
Count-Up
Drop frame(*) or non-drop frame
Operation Mode
Rec run, free run, regeneration
(*) Only in the 59.94 Hz mode
Zoom Remote Controller
Canon RC-V100
Special Rec
Slow & Fast motion recording (max. 120 fps supported), frame recording, pre-recording, interval recording
Other
Relay recording, double slot recording, 4K RAW output, custom picture settings, color bar, peaking display, zebra display, My Menu settings, waveform monitor display, edge monitor display, customized functions, function assignment buttons (1 to 11), key lock, marker displays, Enlarged display, custom display Browser remote control using WFT unit, peripheral illumination correction, monaural microphone, fan control, magnification chromatic aberration compensation, GPS information recording, etc.
Playback Operations
Normal playback, fast forward (at speeds of 5x, 15x, 60x), fast reverse (at speeds of 5x, 15x, 60x), frame forward, frame reverse, forward skip, reverse skip, rec review
Clip Display
3x4 (clip) index screen
[Original, OK mark, check mark, shot mark, expand, proxy, photo (SD card) index displays available]
Clip Information Displays
Clip metadata display, custom picture data display
Edit
Clip deletion, clip copying
Body
Input
GENLOCK terminal (also serves as SYNC OUT terminal), TIME CODE terminal (input output switching), REMOTE terminal, MIC terminal, AUDIO terminal
Output
MON. terminal, REC OUT terminal, HDMI OUT terminal, headphones terminal, SYNC OUT terminal (also serves as GENLOCK terminal), TIME CODE terminal (input output switching), VIDEO terminal
Input/output control
Expansion system terminal (WFT/other unit)
Edit
Monitor Unit
Input
INPUT terminal (XLR) x 2, VIDEO terminal
Output
AUDIO terminal
Power Supply
14.4V DC (battery pack), 16.7 V DC (DC-IN)
Image Processing Platform
Dual Digic DV 5
Main Unit Weight
Approx. 4.4 lb (2000 g)
Dimensions (W x H x D)
Approx. 5.9 x 7.2 x 7.2 in (149 x 183 x 183 mm)- with thumb rest
EOS C300 Mark II
EOS C300 Mark II EOS C300 Mark II Body (with Grip) Shoulder Strap Camcorder Body Cap Monitor Unit Handle Unit Handle Bracket Expansion Unit Attachment Battery Pack (BP-A30) Battery Charger (CG-A10) Power Adapter (CA-A10) Eye Cup Viewfinder Cap Thumb Rest Tripod Base (TB-1) Measure Hook (x1) 50 cm Cables for Monitor Unit (x2) Hexagon Socket, Head Cap Screws (x10) with Allen Key
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EOS C300 Mark II PL that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Resources
Case Studies
How I Shot That: DP Jim Frohna Brings an Indie Film Approach to Shooting Amazon’s ‘I Love Dick’
08/03/17
4.87 MB
White Papers
Canon Log Gamma Curves
12/18/18
0.81 MB
High Dynamic Range (HDR): What it is and What it is Not
11/01/18
1.89 MB
Cinema EOS On-Set HDR/WCG Ecosystem
11/01/18
1.45 MB
Image Performance Enhancements in the EOS C300 Mark II
12/09/15
10.82 MB
Extended Recording Capabilities in the EOS C300 Mark II
12/09/15
7.39 MB
Ergonomic and Operational Enhancements to the EOS C300 Mark II
12/09/15
11.09 MB
The Promise of 4K
11/01/18
0.85 MB
Deep Dive - High Dynamic Range (HDR) in the EOS C700 and EOS C300 Mark II Cameras PART 1
11/01/18
3.30 MB
Deep Dive - High Dynamic Range (HDR) in the EOS C700 and EOS C300 Mark II Cameras PART 2
11/01/18
2.77 MB
Articles
Side-by-side video comparisons of Canon Log, Canon Log 2, and Canon Log 3
07/28/16
Stay Sharp: Automatically Controlling focus in the EOS C300 Mark II
12/01/15
Interactive Simulator
This is to make Misc appear on the page when needed.
Videos
Behind the Scenes: Social Sanctuary
Social Sanctuary started with a few simple objectives: to create work for those who were left jobless in the entertainment industry, to give artists a Covid-19 safe platform to share their gifts with the world, and to create thrilling shows designed to entertain a public that has been robbed from those experiences. They were able to achieve all this thanks to a top notch cinematic look using all Canon products.
Behind the Scenes: Happy Happy Joy Joy
Happy Happy Joy Joy is a documentary that takes a look at the impact of the legendary cartoon show Ren & Stimpy, and its enigmatic creator. this video, Director Ron Cicero and Director of Photography Kimo Easterwood discuss how the Canon EOS C300 Mark II cinema camera provided them with everything they needed to capture intimate conversations on sensitive subjects without having the equipment get in the way of the story.
Behind the Scenes: The Trade, Season Two
Season Two of the Showtime documentary series The Trade focuses on human smuggling and trafficking in Central America and the United States. This intense project required equipment that would be rugged, reliable, and inconspicuous, while still delivering beautiful imagery.
Behind The Scenes: The Legendary Sikh Riders of Surrey
The documentary The Legendary Sikh Riders of Surrey follows a motorcycle club consisting of members of the Sikh religion as they ride across North America. Due to the nature of the film, it was critical for Director of Photography Jordan Halland to have gear that was compact and lightweight, so that he could travel with it easily on a motorcycle. In this video, learn why the Canon EOS C300 Mark II and COMPACT-SERVO lenses were ideal for shooting this film.
Blue Ox Films
For Blue Ox Films, every day brings a new challenge. From major corporate commercials to documentary television series, their talents and equipment are constantly being put to the test. In this testimonial video, see why Blue Ox Films relies on Canon’s robust line of Cinema cameras and lenses to cover their myriad of projects.
Behind The Scenes: The Pollinators
A cinematic journey around the United States follows migratory beekeepers and their truckloads of honey bees as they pollinate the flowers that become the fruits, nuts and vegetables that get eaten. Learn how Director Peter Nelson utilized Canon Cinema Cameras and Lenses to tell this important story about the threat to honey bees and how we can improve it.
Behind the Scenes: Murder in the Bayou
Based on a best-selling book, this five-part true crime docu-series investigates the unsolved murders of 8 women whose bodies were discovered in drainage canals and on desolate back roads in and around Jennings, Louisiana. Learn how Cinematographer Jeff Hutchens utilized the C300 Mark II and EF Lenses to tell their stories, and the stories of those who surround them.
Southeast Christian Church
Southeast Christian’s mission is to connect people to Jesus and one another, marked by its unified multisite community. SECC has multiple campuses serving the specific needs of the areas in which they are located, while receiving centralized teaching form the Blankenbaker Campus in Louisville, KY. Learn how SECC utilizes Canon’s Cinema EOS Cameras, Cinema Lenses and Broadcast Lenses to capture their services.
Eastside Baptist Church Uses Canon Cinema EOS Cameras and Compact-Servo Lenses
At Eastside Baptist Church in Marietta, Georgia, storytelling is an important aspect of spreading their message. Learn how they were able to utilize Canon C300 Mark II Cameras and COMPACT-SERVO lenses to provide an imaging solution that can be used seven days a week to generate compelling content for their services and for social media.
USC School of Cinematic Arts Uses Canon Professional Camcorders and Cinema EOS Cameras
One of the most prestigious film schools in the country, the USC School of Cinematic Arts relies on a large array of Canon professional camcorders and cinema cameras to introduce the next generation of filmmakers to the art and science of cinematography.
Trick Shot
A classic con movie with a twist, Trick Shot is a a film about a family of con artists who travel across the country to pay off their son’s gambling debt and get more than they bargain for.
Trick Shot: Behind the Scenes
A behind the scenes look at the making of Trick Shot, the first film to be shot on the EOS C300 Mark II Digital Cinema Camera. Director Evan Kaufmann, Director of Photography Gale Tattersall and others share their impressions of working with Canon's new EOS C300 Mark II Digital Cinema Camera.
Introducing the Canon EOS C300 Mark II
Join Canon U.S.A.’s Technical Advisor Brent Ramsey as he discusses the new features and benefits of the EOS C300 Mark II Cinema camera.
Canon EOS C300 Mark II Tutorial Series: New Features
In this video tutorial series, hosted by Canon Digital Learning Center contributor, Jem Schofield, take a look at the new internal and external features of this camera and how it compares and differs from its predecessor.
Canon EOS C300 Mark II: Assignable Buttons & Applying LUTs
Join Canon Digital Learning Center contributor Jem Schofield, as he discusses how to use assignable buttons to make applying LUTs quicker and more convenient during your productions.
Canon MA-400 Overview with Jem Schofield
Join Canon Digital Learning Center contributor Jem Schofield, as he gives a quick overview of the Canon MA-400 microphone adapter used on the EOS C300 Mark II.
Canon Dual Pixel Autofocus
Even with today’s advancements in digital photography and cinematography, being precisely in focus isn’t that easy – especially when doing it alone.
 Return to Top
