Web Content Viewer
Actions
EOS C300
Cinema EOS
0% Financing Available
Click here to learn more about this special offer. Restrictions apply.
Providing access to all important user functions.
Find an authorized Canon dealer or rental house for Cinema EOS C300 Series.
Features
New Canon Super 35mm CMOS Sensor
Modeled on the Super 35mm 3-perf motion picture film standard, the Canon CMOS sensor has an active image size of 24.4 x 13.5mm. It uses 3840 (H) x 2160 (V) photosites to perform the crucial optoelectronic transformation of digital imaging. Each photosite is a generous 6.4 x 6.4 micrometers in area and each has a microlens that ensures the highest efficiency in light transfer to the individual photodiode. Proprietary technologies within the photosite simultaneously lower the image sensor noise floor while enhancing the photon capacity of the photodiode - a combination that assures superb dynamic range. The image sensor employs an innovative readout technique that delivers full bandwidth individual RGB video components without the need for any debayering algorithms. Each of these components has a 1920 (H) x 1080 (V) sampling structure at up to 60 frames. From these original video components, a 1080-line 60i format or a 1280 (H) x 720 (V) at 60P HD format are selectively derived.
Wide Dynamic Range
The EOS C300 incorporates the first Canon CMOS sensor designed specifically for high frame rate motion pictures, offering not only high resolution and shallow depth-of-field but also high sensitivity with low noise. Working together, Canon's Super 35mm sensor and DIGIC DV III Image Processor achieve a remarkably high signal-to-noise ratio that enables recordings with great detail and dynamic range even in minimal light.
Canon Log Gamma
Shooting in Canon Log mode, cinematographers can set the camera exposure value using their customary light meter practices. Canon Log is a special nonlinear transfer function embodied within the DIGIC DV III RGB video processing system. This transfer function is specifically designed to facilitate the post-production of digital images originating in Cinema EOS in a manner similar to the post-production of images digitally transferred from motion picture film (the contemporary DI process). By managing the disposition of quantization bits, Canon Log ensures excellent tonal reproduction within both highlight and low-light regions of a given digital image - maintaining a total dynamic range of 800%. These sophisticated video grading processes restructure a new digital representation achieving a sought-after creative look on a quality reference display.
Low Light/High ISO Ability
A dark and stormy night? With the EOS C300, it's no problem. The combination of sensor and image processor render an extraordinary signal-to-noise ratio and as such make shooting at high ISO (up to ISO 16000) a breeze.
Reduced Rolling Shutter and Moiré Artifacting
The EOS C300 uses enhanced signal processing to minimize rolling shutter skews and to reduce moiré artifacts. A high-speed readout significantly reduces the subjective visibility of the vertical skewing on fast-moving horizontal subjects, a typical pitfall of the CMOS image sensor neutralized by Canon technology.
Canon DIGIC DV III Image Processor
Designed and built by Canon for the highest HD RGB processing, the DIGIC DV III Image Processor uses proprietary circuits and architecture to deliver the highest image quality at the highest speeds, with low power consumption and minimal heat output. It processes the RGB representations originated in the single CMOS sensor of the camera into three channels (Red, Blue and Green) to maintain the rich resolution and clean color fidelity formerly possible only in three-chip sensor designs.
XF Codec Image Quality
To create digital files robust enough for major post-production, the EOS C300 delivers the highest image quality with its XF Codec - the same codec used by other Canon XF - professional camcorders. With 4:2:2 color sampling, image files have double the vertical resolution of color components created with 4:2:0 color sampling, minimizing jagged edges between red and blue and ensuring ample quality for chroma key compositing with green screens. Thanks to the Canon XF Codec and the EOS C300's superior resolution, original color quality and cinematic look will hold up through post-production - with results that meet or exceed the filmmakers expectations.
Canon EOS C300 with EF-Lens Mount
To integrate easily into the working style and equipment array of film crews and production houses, the EOS C300 with a Canon EF-lens mount is completely compatible with all of Canon's EF lenses, including compact primes, super telephotos, specialty Tilt-Shift, Macro and Fisheye lenses - over 60 in all.
EF and L-Series Lenses
A unique combination of the world's most advanced optical, microelectronic, and precision manufacturing technologies, the Canon's EF lenses, compatible with the EOS C300, are perfected in Canon's laboratories and proven in the field. Whatever the application, whatever the budget, there are Canon EF lenses perfect for nearly every scenario. Their compatibility not only affords the Cinema EOS access to some of the finest optics on the market, it opens up myriad possibilities with Canon's superlative specialty lenses, including a range of Tilt-Shift lenses, Close-up lenses and even Canon's amazing EF 8-15mm f/4L Fisheye Zoom.
Canon EF Cinema Lenses
Canon EF Cinema lenses are designed and engineered to meet or exceed the exacting standards of working professionals. Every Canon EF Cinema lens is designed to fulfill contemporary 4K production standards, surpassing the performance requirements of any HD imaging system. Zoom lenses feature large aspherical lens elements to achieve sharp, consistent images in every shooting situation. Geared inner focusing minimizes focus-induced changes in the angle of view, rendering focus breathing virtually zero. The 11-blade aperture diaphragms ensure smooth out-of-focus areas and beautiful bokeh - and innovative glass construction counteracts barrel expansion and contraction to avoid temperature-induced marking discrepancies. EF Cinema lenses provide markings on angled surfaces on both sides of the barrel, making it easy to read focus and aperture settings from behind or either side of the camera. Focus markings can be switched from standard labeling to metric. Control rings are designed to maintain the proper amount of resistance with consistent operating torque. EF Cinema lenses share uniform gear position, diameter and rotation angle as well as front lens diameters, enabling the film crew to quickly change to another Canon zoom or prime lens or compatible third-party accessories like matte boxes and rods without adjustments.
Broad Compatibility with EOS Cameras
The versatility of the Canon Cinema EOS approach also makes it compatible with more cinema optics than any other camera system. EF-mount EF Cinema Prime lenses are compatible with Canon EOS DSLRs - including full-frame models like the EOS-1D X and the EOS 5D Mark II as well as cameras like the EOS 7D and EOS 60D and their APS-C sized sensors.
Canon EF Cinema Zoom Lenses
Canon's Cinema EF Zoom lenses offer unrivaled optical performance for demanding high-end productions, available in both EF and PL mount configurations. With fluorite, aspherical lens elements and advanced optical design, these unequalled Cinema EF Zoom lenses are capable of 4K-image reproduction. The wide-angle CN-E14.5-60mm T2.6 L S/SP provides industry-leading breadth of range; the telephoto CN-E30-300mm T2.95-3.7 L S/SP rivals best-in-class zoom magnification and telephoto focal length. Together these lenses cover the range most commonly used in cinema shooting.
Canon EF Cinema Prime Lenses
The brilliant series of Cinema EF Prime lenses offers spectacular 4K-image quality in lightweight, compact designs. Three models for EF mount cameras - CN-E24mm T1.5 L F, CN-E50mm T1.3 L F, and CN-E85mm T1.3 L F - offer consistent form factors and marking optimized for motion picture production. Whether you shoot with a Canon EOS C500 or EOS DSLR, the compact and consistent lens design makes for excellent handling. Audiences will also love the results from the 11-blade aperture diaphragms, fast t-stops and proven Canon lens elements.
Additional lenses are already under development, reflecting Canon's commitment to offer the broadest range of professional cinema lenses to meet filmmaker's needs, now and in the future.
Designed with Filmmakers in Mind
With everything a cinematographer needs, the EOS C300 comes ready to produce. A logical layout of buttons and dials make operation simple. A lock switch turns off all controls except the recording button and function buttons. Small ridges between the buttons help prevent activating functions by mistake. A backlit display panel is great for low-light viewing. A tally lamp is clearly visible from the side or behind the camera.
Compact and Modular Design
The EOS C300 body is surprisingly small (5.24" x 7.0" x 6.7") and easily hand-held at just over 3 lbs. There is a bright 1.55 megapixel electronic viewfinder that comes bundled with a removable combination 4-inch, 1.23 megapixel monitor and control panel. The camera also has a removable hand grip with a control dial and function buttons for hand-held shooting in DSLR style - or remove it and use the supplied thumb rest for completely stripped down shooting. The EOS C300 has a manually-operated built-in Neutral Density glass filter offering 1/4, 1/16 and 1/64th steps of filtering. Hand-held or using a tripod, on location or in the studio, even on 3-D rigs, the EOS C300 fits shooting situations that are challenging for larger cameras.
Ultra High Resolution EVF
The EOS C300 features a 0.52-inch, 1.55 Megapixel Color EVF and approximately 100% field of view coverage for comfortable viewing and accurate judgment of composition, focus and color. The angle of the viewfinder is adjustable for additional user comfort.
CF Memory Card Recording
For versatility and reliability, the EOS C300's recording and terminal specifications are completely compatible with the prevailing industry standards. It records to CF cards through dual slots. From a cost and reliability standpoint, CF cards have no equal. Solid state, and easy to find, 2 hours of 4:2:2 50 Mbps footage can be recorded on two reusable and hot swappable 32 GB CF cards with ease. It's even possible to record to two CF cards simultaneously and relay-record for uninterrupted shots and copy from one card to another.
Multiple Recording Formats and Advanced Recording
With the realities of production in mind, the EOS C300 can record in a number of different modes, resolutions and frame rates, delivering quality recordings perfect for any application. 24.00p mode matches the exact frame rates of film cameras, so there's no need for time-consuming frame-rate conversion. And the camera can shoot in both PAL and NTSC modes at 50 Mbps (CBR), 35 Mbps (VBR) and 25 Mbps (CBR) with a range of settings for resolution, color, frame rate and recording time. Whether shooting with the expectation of significant editing and post-production, recording for compatibility with HDV editing, or simply creating the longest possible HD image files, the EOS C300 camera will perform flawlessly.
High-Speed, Slow-Motion, Time-Lapse and Stop-Motion
Beyond the advantages of file-based recording, the EOS C300 offers a number of creative possibilities in post-production. By capturing fewer frames per second, the camera can transform normal action into intense high-speed motion up to 60x. By capturing more frames per second, the camera can slow down motion to 1/2.5x at 720p. The EOS C300 can also be programmed to record a set number of frames at defined intervals for amazing time-lapse photography - and a frame-recording feature is perfect for stop-frame animation.
Connectivity
To connect to external monitors, switchers, VTRs and NLE systems with SDI inputs, the EOS C300 features industry-standard HD-SDI Output, Genlock, and Timecode terminals plus audio terminals with Linear PCM recording. Timecode and Genlock enable synchronized multiple camera capture, perfect for multiple camera shots, 3D acquisition and more. The HD-SDI Sync terminal can be switched to output to HD Sync, HD Y, Black Burst, and Composite.
Full Manual Control and Focusing Aids
Providing the cinematographer with everything they need in the palm of their hands, the EOS C300 comes ready to produce. The cameras have a Waveform Monitor (WFM) function that shows the overall brightness of a scene, with RGB Parade Display to view red, green and blue brightness or Spot Display to isolate the luminance distribution of a chosen area. The Vectorscope (VS) display shows real-time hue and saturation levels. For sharp focus, the EOS C300 camera has two peaking modes and a magnified focus assist function. An Edge Monitor Focus Assist provides both a waveform representing the overall degree of focus and a red waveform that represents focus in three specific areas displayed on the camera's 4" LCD monitor. To maintain proper highlight exposure, it offers a zebra bar feature as well. It's all in the camera.
Expanded EF Lens Communication
With the November 5th, 2015 firmware update, EF Lens communication has been expanded to allow servo lens control from the from the RC-V100 remote control. An external battery/power source is necessary to drive the lens, as power cannot be supplied by the camera.
WFT Wireless Remote Control over Wi-Fi
Offering a new level of mobility, the Canon Wireless File Transmitter WFT-E6A opens up a world of wireless options to the EOS filmmaker. The EOS C300 camera comes preconfigured so that camera settings can be viewed and controlled on third party devices with web browsers, including computers, smartphones and tablets without the need for additional in-camera software. With the WFT-E6A module the camera can be controlled from up to 150 feet away over an 802.11 a/b/g/n wireless network. The WFT-E6A enables superior camera control: users can start and stop recording; adjust focus, white balance, gain and other parameters; and adjust the aperture of Canon EF lenses. This offers huge potential for specialty applications where cameras must be controlled remotely such as nature documentaries or reality TV. It also enables input marking for metadata; and offers a live view of the composition. It supports incorporating GPS information into the file metadata - useful for general cinematic applications, and essential for expedition filmmakers. A basic window mode even enables use with the Apple iPhone®, iPod touch® and iPad®, as well as with handheld devices operating the Android™ operating system.
Specifications
Effective Pixels
3840 x 2460 pixels; Approx. 8.29 megapixels
Total Pixels
4206 × 2340; Approx. 9.84 megapixels
Sensor Type
CMOS sensor (single-panel) equivalent to Super 35 mm
Sensor Size
Super 35; 24.6 x 13.8 (28.2 mm diagonal); 6.4 µm cell pitch
Scanning System
Progressive
Number of Sensors
1
Filter
RGB Primary Color Filter (Bayer Array)
Imaging Processor
Digic DV III
Interchangeable Lens System
Canon EF Mount
[Canon EF lens group supported, including EF-S lens)
ND Filter
Mechanical ND filter system with option of clear, 1/64. 1/16, and 1,4
Iris Dial
Iris Dial located on camera body for use with EOS EF Lenses with electronic Iris control
Peripheral Illumination Correction
Available on EF Mount model only
Exposure Modes
(1) Manual exposure based on shutter setting
(2) Push auto iris control / Auto iris control(metering system selection/ AE shift possible)
Gain
Normal -6 dB to 42 dB
Fine setting 0 dB to 24 dB in 0.5 dB increments
ISO
320 to 80,000
1-stop setting or 1/3-stop setting
Shutter Modes
3 Modes: OFF; Speed; Angle; Slow Shutter; Clear Scan
Shutter Speed Range
59.94i/59.94p: 1/60 to 1/2000 in 1/4 or 1/3 stops; SLS: 1/4, 1/8, 1/15, 1/30; CS: 59.94 Hz -250.70 Hz
29.97p: 1/30 to 1/2000 in 1/4 or 1/3 stops; SLS: 1/4, 1/8, 1/15; CS: 29.97 Hz - 250.70 Hz
23.98p/24p: 1/24 to 1/2000 in 1/4or 1/3 stops; SLS: 1/3, 1/6, 1/12; CS: 23.97 Hz - 250.70 Hz
50i/50p: 1/50 to 1/2000 in 1/4 or 1/3 stops; SLS: 1/3, 1/6, 1/12 1/25; CS: 50.00 Hz - 250.70 Hz
25p: 1/25 to 1/2000 in 1/4 or 1/3 stops; SLS: 1/3, 1/6, 1/12; CS: 25.00 Hz - 250.70 Hz
Shutter Angle Settings
59.94i/59.94p: 360, 240, 216, 180, 120, 90, 60, 45, 30, 22.5, 15, 11.25
29.97p: 360, 240, 216, 180, 120, 108, 90, 60, 45, 30, 22.5, 15, 11.25
23.98p/24p: 360, 345.6, 288, 240, 180, 172.8, 144, 120, 90, 86.4, 72, 60, 45, 30, 22.5, 15, 11.25
50i/50p: 360, 300, 240, 180, 150, 120, 90, 60, 45, 30, 22.50, 15, 11.25
25p: 360, 300, 240, 180, 150, 120, 90, 75, 60, 45, 30, 22.50, 15, 11.25
Iris (Aperture) Range
EF Lens only and lens dependent
Focus Control
Manual Focus/One-Shot AF/ Continuous AF
(AF is dependent on interchangeable lens)
Signal System
NTSC and PAL
Compression
8 Bit MPEG-2 Long GOP
Maximum Bit rate
50Mbps (CBR)
Recording Options
Recording Options
Recording Media
CF Card (Type 1 Only); 2 Slots (Movie Files); UDMA supported
SD Card (Still Images (JPEG), Custom Picture Data*, Clip Metadata, and menu settings); SD/SDHC/SDXC Supported; MMC Cards are not supported
*Custom Picture Data and settings is not compatible with data from others Canon models
File Format
MXF (OP-1a)
File System
FAT 32
Maximum Clip Number
999 (per media)
Recording Format
Linear PCM; 2-Channel; 16-Bit; 48 kHz
Built-in Microphone
None
External Audio Inputs
2 - XLR inputs (Auto and Manual level settings)
External microphone terminal: (3.5 mm diameter)
Recording Channel Selection
This is used to set the allocation of the audio channels:
CH1/CH2: The CH1 signals are allocated to the L output channel, and the CH2 signals are allocated to the R output channel.
CH1/CH1: The CH1 signals are allocated to the L output channel, and the CH1 signals are allocated to the R output channel.
CH2/CH2: The CH2 signals are allocated to the L output channel, and the CH2 signals are allocated to the R output channel.
ALL CH/ALL CH: Signals obtained by mixing the CH1 and CH2 signals are allocated to the L and R output channels.
XLR Mic Trimming
Available; -12dB, -6 dB, 0dB or +12 dB
Limiter
Available
Recording Level Adjustment Range
- Infinity to +18dB
Phantom Power
Available; +48V
Headphone Adjustment
16 Settings; Volume is muted at lowest setting
Built-in Speaker
None
1KHz Tone
Available; -12, -18, or -20 dB
Playback
Index Displays: Index Display, Normal, “OK Mark” Index, Check Mark Index, “Shot Mark” Index, Expand Index, Photo Index
Clip Playback: Forward Search (x5, x15, x60), Reverse Search (x5, x15, x60), Forward frame Advance, Reverse Frame Advance, Record Review, Clip Jump (Forward and Backward), Skip Playback
Playback Functions: Inter-media Copy (Single Clip, All Clips, Last Clip); Clip Delete (Single Clip, All Clips, Last Clip)
Still Image Playback: index, single playback, erasure, protect
Special Recording Functions
Relay Recording*; Double-Slot Recording**; Copying between Media
* Not available during Slow Motion 50 Mbps recording
** Not available in combination with Slow and fast motion recording
Photo Recording Mode
Available; Images captured to SD Card
Waveform Monitor
Available; 2 Modes (Standard and RGB Component)
Vectorscope
Available
Exposure/Focus Aids
Peaking (2 types), Zebra Pattern*, Magnify, Edge Monitor Focus Assist, Black and White Mode
*Can be output via the SDI or HDMI Jack (HD Only)
Interval Record
Available; ability to set time interval and number of frames to record
Interval can be set in 25 levels ranging from 1 second to 10 minutes.
(1s/2s/3s/4s/5s/6s/7s/8s/9s/10s/15s/20s/30s/40s/50s/1m/2m/3m/4m/5m/6 m/7m/8m/9m/10m)
NTSC 59.94i/29.97p/23.98p/24.00p: Selectable between 1, 3, 6, 9 frames
NTSC 59.94p: Selectable between 2, 6, 12 frames
PAL 50i/25p/50p: Selectable between 2, 6, 12 frames
Frame Record
Available; Records a set number of frames each time the record button is pressed
NTSC 59.94i/23.98p/24.00p: Selectable between 1, 3, 6, 9 frames
Pre-Record
Yes, 3 seconds cache (Audio and Video)
Scan Reverse
When using a Depth of Field Converter or other lens adapters it flips or reverses the image automatically so it is recorded correctly.
Time code
*Drop Frame (DF) and Non-Drop Frame (NDF)
*Drop frame works with NTSC models only and is not available in 24P
Time Code Modes
Regeneration, Record Run, Free Run and External Source
Drop Frame and Non Drop Frame available
White Balance
Kelvin Setting 2,000K to 15,000K in 100K increments
White Balance Presets
Daylight (5,400K); Tungsten (3,200K); Kelvin
White balance shift is available within Presets (-9 to +9)
Custom Picture Settings
23 Custom Picture settings
A total of nine 9 Customized Pictures are available in the camera and up to 20 can be saved to an SD card
Custom pictures can be adjusted using the following settings and saved for later recall:
Gamma, Black, Black Gamma, Low Key Saturation, Knee, Sharpness, Noise Reduction, Skin Detail, Selective Noise Reduction, Color Matrix, White Balance, Color Correction, Setup Level
Custom Pictures CP8 and CP9 ship with the following presets:
C8: Cinema - Suited for giving recorded media a film tone.
C9: EOS Standard - Used to match the quality of DSLR video shot in EOS standard mode
Custom Functions
Available, 9 total functions
Custom Display
Yes; LCD panel and EVF information display can be customized
Total of 27 display and icons that can be turned on and off
Assign Buttons
15; Can be assigned functions as desired (30 functions Available)
Color Bars
Color bars compliant with SMPTE, EBU, or ARIB standards can be selected.
Minimum Subject Illumination
59.94 Hz Mode: 0.3 Lux
(f/1.2, 24 dB, 29.97p, 1/30 sec.)
50.00 Hz Mode: 0.25 Lux
(f/1.2, 24 dB, 25p, 1/25 sec.)
Sensitivity
F9 (ISO 640 (0db) 2000 lux, 89.9% Reflection, in 1080/59.94i mode)
F10 (ISO 640 (0db) 2000 lux, 89.9% Reflection, in 1080/50.00i mode)
S/N Ratio
ISO 850, Using Canon Log Gamma)
54B (Typical, 1920x1080
Dynamic Range
During Normal Shooting: 300%
*With Canon Log Gamma: 800%
*ISO 850 or above - gain 2.5dB or above
Type
0.52-inch Color (1,555,000 dots)
Viewing Angle Adjustment
Available; Viewing Angle can be adjusted up and down 60°
Diopter Adjustment Range
+2.0 to -5.5
EVF Adjustments
Brightness, Contrast, Color, and Backlight (Normal or Bright)
Type
Rotating 4 inch Wide Screen Color LCD Display (1,230,000 dots) on detachable controller
Display Adjustments
Brightness, Contrast, Color, Sharpness, and Backlight (Normal or Bright)
HD/SD SDI
Yes (with embedded audio);
HD 4:2:2(YCbCr) 1920x1080: 60i/50i, 1280x720: 60p/50p; SD 4:2:2 (YCbCr) 640x480: 60i/50i
BNC Connector, output only
SD-SDI:
NTSC 480i/PAL 576i: Compliant with SMPTE 259M
Embedded Audio: Compliant with SMPTE 272M
Time Code Standard: (VITC/LTC) SMPTE 12M
HD-SDI: (Compliant with SMPTE 292M)
1080i/720p: Compliant with SMPTE 292M
Embedded Audio: Compliant with SMPTE 299M
Time code In/Out
Yes; BNC Connector (Input and Output)
Genlock
Yes; BNC Connector (Input Only)
Adjustment range: -1023 to +1023
Synch Out
Yes, BNC Connector
(1) HD tri-level signal (HD Sync) The HD standard analog component Y signal with the black muted is output.
(2) HD-Y signals (HD-Y) Only the HD standard analog component Y signal is output.
(3) Black burst signal The SD standard analog composite signal with the black muted is output.
(4) Composite; The SD standard analog composite signals are output.
HDMI
Yes (Type A)
Audio Input Terminal
2 - Balanced 3-pin XLR (Mic Level, Mic Level with phantom power and Line Level)
Headphone Jack
Available; 3.5mm stereo mini-jack
Remote Terminals
Available (Fully LANC Compatible)
Power Terminal
DC in on camera (no need for Dummy Battery)
Battery
BP-9 Series
Compact Power Adapter
CA-940
Tripod Adapter
Canon TA-100
Tripod Adapter Base
Canon TB-1
Zoom Remote Controller
Canon ZR 2000
Wi-Fi Adapter
WFT-E6A
Dimensions
C300 (Body plus Thumb Rest):
Approx. 5.2 x 7.0 x 6.7 in (133 x 179 x 171 mm)
C300 (Body plus Grip):
Approx. 6.9 x 7.0 x 6.7 in (174 x 179 x 171 mm)
The following is the same for both models:
C300 + Monitor Unit: Approx. 7.3 x 9.8 x 7.4 in (185 x 249 x187 mm)
C300 + Handle Unit + Monitor Unit: Approx. 7.3 x 11.2 x 11.9 in ( 185 x 284 x 301 mm)
Main Unit Weight
C300 Body: Approx. 3.2 lb. (1430 g)
C300 PL Body: Approx. 3.6 lb. (1630 g)
Grip: Approx. 8.1 oz. (230 g)
Handle Unit: Approx. 6.3 oz. (180 g)
Total Equipped Weight
C300: Approx. 5.6 lb. (2520 g)*
C300: Approx. 6.0 lb. (2700 g)**
* Weights for both models include the grip, monitor unit, BP-955, 2x CF cards.
** Weights for both models include the grip, monitor unit, Handel Unit, BP-955, 2x CF cards.
Temperature and Humidity
Performance requirements: 0°C to 40°C, 85% (relative humidity)
Operating requirements: -5°C to 45°C, 60% (relative humidity)
Language Support
English, Japanese, Chinese, German, Spanish, French, Italian, Polish, Russian
Time and Date
Automatic Calendar range January 1st, 2010 through December 31, 2031 selectable in American, Japanese and European Date formats.
World Clock
World Clock support - UTC time setting: Setting range from +14:00 to - 12:00
EOS C300
EOS C300 EOS C300 Body (with Grip/Camera cover R-F-3) Monitor unit Handle unit Battery Pack BP-955 (also available as optional accessory) Battery Charger CG-940 Compact Power Adapter CA-940 (also available as optional accessory) Eye Cup Viewfinder Cap Thumb rest Tripod base TB-1 WFT Attachment Measuring Hook AC Cable x2 DC Cable (for CA-940) Shoulder Strap SS-1200 XF Utilities Disc Ver. 3.0
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EOS C300 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Resources
Case Studies
Church of the Highlands
08/03/17
4.63 MB
No Place Like Home
08/03/17
10.23 MB
How DP Bob Richman Captured the Stunning Big Sky Landscapes for ‘Rancher, Farmer, Fisherman’
08/03/17
4.87 MB
White Papers
Canon Log Gamma Curves
12/18/18
0.81 MB
Canon-Log Cine Optoelectronic Transfer Function
11/01/18
1.53 MB
Sensitometric Characteristics of the EOS Digital Cine Camera
11/01/18
0.62 MB
New 35mm CMOS Image Sensor for Digital Cine Motion Imaging
11/01/18
1.27 MB
Cinema EOS for 2K and HD Origination
11/01/18
0.84 MB
Best Practices for Data Management
06/20/12
7.26 MB
RGB Resolution Considerations in a New CMOS Sensor for Cine Motion Imaging
06/20/12
7.34 MB
Interactive Simulator
This is to make Misc appear on the page when needed.
Available Packages
Cinema EOS C300 Package with Dual Pixel CMOS AF Feature Upgrade
EOS C300 (Body Only) PACKAGE with Dual Pixel CMOS AF Feature Upgrade
Item Code: 0044C002
This package includes:
  • EOS C300 w/ Dual Pixel CMOS AF Feature Upgrade
Cinema EOS C300 24-70 Package with Dual Pixel CMOS AF Feature Upgrade
EOS C300 24-70 PACKAGE with Dual Pixel CMOS AF Feature Upgrade
Item Code: 0044C006
  • EF 24-70mm f/2.8L IS USM Lens
Cinema EOS C300 (Body Only) PACKAGE with Dual Pixel CMOS AF Feature Upgrade and the Zacuto Shoulder Mounting Kit
Item Code: 0044C008
  • Zacuto Shoulder Mount
  • Z-Finder Recoil
  • Helmet Coldshoe Handle
  • VCT Universal Baseplate with 15mm rods
  • Grip Relocator
Videos
RC-V100 Remote Control
The versatile RC-V100 Remote Controller for EOS C-Series Digital Cinema cameras and the XF305/300/205/200 Professional Camcorders provide full access to all important user functions.
Canon Collaborations: The Crew of Maker Studios and their Go-To Gear
Partnered with over 50,000 content creators, Maker produces and distributes a wide range of programming across genres.
The Sacrament: Behind the Scenes
Director of Photography Eric Robbins and acclaimed writer/director Ti West pull back the curtain on horror film The Sacrament, explaining why the Canon EOS C300 was the right tool for their creepy found-footage thriller.
Canon Collaborations: The Crew of VICE on HBO and their Go-To Gear
VICE on HBO takes you deep into the world’s biggest political and cultural clashes. To capture the hair-raising stories you see on screen, VICE Media’s Director of Photography Jake Burghart and Segment DP Jerry Ricciotti are no strangers to shooting in extreme conditions.
 Return to Top
