Web Content Viewer
Actions
EOS C500
Cinema EOS
Item Code: 6345B002AA
Tech Explained: Learn The Science Behind 4K Optics.
0% Financing Available
Click here to learn more about this special offer. Restrictions apply.
Providing access to all important user functions.
Find an authorized Canon dealer or rental house for Cinema EOS.
Features
4K/2K Workflow
The EOS C500 fully supports both 4K and 2K image resolutions; as such, it is the ideal choice for demanding video productions across a wide gamut that ranges from high-quality commercials and TV dramas to motion-picture releases. A 4K workflow offers four times the resolution of standard high-definition acquisition, resulting in life-like theatrical presentations, a familiar, film-style workflow, full versatility during post-production, and added flexibility for visual effects.
Canon design engineers have developed a 4K/2K acquisition platform and matching workflow for the video and motion-picture industries. With 4K rapidly moving to become the de facto standard for theatrical projection, the need for high-resolution acquisition is a production reality. The EOS C500 is designed to fit seamlessly with projects shot entirely in 4K, or for mixed 4K/2K productions. Coupled to external data recorders, the EOS C500 is a true “4K powerhouse,” while still retaining the flexibility to handle standard HD workflows.
Cinema RAW Development Software
  • Playback RAW clips and preview on a PC monitor
  • Output preview image from SDI to the master monitor
    • Supports AJA KONA 3G only
    • 4K output will be supported using four 3G-SDI cables
  • Output industrial standard files
    • DPX, MOV (Mac only)
    • Proxy (HD and SD size) output is supported
The software will be available through download from the EOS C500's Drivers & Software section.
System Requirements (As of July 2012)
OS Windows 7, SP1, 64-bit version MAC OS X v10.7 or 10.8
CPU Intel Core i7, 3.06 GHz
recommended
Intel Xeon, 2.8 GHz Quad
recommended
GPU NVIDIA GeForce GTX680 NVIDIA Quadro 4000
RAM 16 GB
Storage Any with read/write speed of 600 MB/s *1
SDI expansion card *2 AJA KONA 3G with driver v10.3.0 *3 AJA KONA 3G with driver v10.3.1 *3
Available End of October 2012 Mid-December 2012
*1 Keeping RAW clips on a separate drive from the save destination of developed clips is recommended.
*2 Required only when checking SDI output on an external monitor.
*3 As of September 2012.
4K, 2K Multiple Output Formats
Mode Resolution Frame Rate
4K RAW 10-bit 4096 × 2160 /
3840 × 2160
59.94p / 29.97p / 23.98p /
50.00p / 25.00p / 24.00p
4K HRAW 10-bit 4096 × 1080 /
3840 × 1080
2K RGB 444 12-bit 2048 × 1080 /
1920 × 1080
2K RGB 444 10-bit 2048 × 1080 /
1920 × 1080
2K YCC 422 10-bit 2048 × 1080 /
1920 × 1080
For enhanced creativity, and to accommodate a variety of workflows, the EOS C500 offers a range of 10- and 12-bit imaging modes. These comprise: 4K Output Priority Mode in resolutions up to 4096x2160 pixels; 2K Output Priority Mode in resolutions up to 2048x1080 pixels; and internal MXF File format recording up to 50 Mbps, utilizing MPEG-2 data compression at a variety of user-selectable frame rates and image resolutions.
Because the discrete needs of cinema and television production can vary from project to project, the EOS C500 offers two forms of 4K origination. Users can dynamically select either the DCI source-image format – SMPTE 2048-1:2011 standard – or the alternative, TV-centric Quad-HD source-image format – SMPTE 2036-1:2009 and ITU-R BT.1769 standards.
For added flexibility, the EOS C500 lets users select uncompressed Canon RAW output for use in both 4K and 2K productions. Instead of utilizing the built-in Compact Flash/CF storage media, Canon RAW-format output is delivered to external recording systems via built-in dual 3G-SDI ports. Dual uncompressed HD-SDI outputs support external monitoring. To provide proxy video sources for offline non-linear video editing systems, HD content can also be written simultaneously to dual, onboard CF cards.
2K/Full HD images can be output as either RGB 4:4:4 12-bit/10-bit or YCC 4:2:2 10-bit data for both 59.94Hz and 50Hz projects at up to 50 Mbps rates; because of data-bandwidth restrictions, recording onto the EOS C500's built-in Compact Flash/CF card drive are made at Full HD resolutions. As well as serving as a primary source for video capture, HD images streamed onto the CF card can be used as proxies for off-line editorial.
Cinema RAW Capture
The EOS C500 lets you capture images in a choice of 4K Cinema RAW and 4K Half Cinema RAW modes at frame rates up to, respectively, 60 fps and 120 fps, with 10-bit resolution. For enhanced flexibility, these two Bayer RAW modes are offered in a choice of Digital Cinema Initiatives/DCI 1.895:1 or Quad Full High Definition/QFHD 16:9 aspect ratios.
4K RAW data output from the EOS C500 image sensor can be recorded using about one-third of the space required for 4K RGB data, and Cinema RAW-based recording systems offer an enhanced degree of creative freedom during post-processing.
Primary applications for Cinema RAW include video production for high-end commercials and major motion-picture releases, in addition to footage for high-quality visual effects. 4K Cinema RAW data output can be processed using the Cinema RAW Development software application, which is available through the Canon website.
Canon MPEG-2 4:2:2 50 Mbps XF Codec
For trouble-free exchange of video and audio material, the EOS C500 uses the industry-standard Material Exchange Format (MXF) for its internal recording file structure. With MXF, video and audio are interwrapped into a single file, together with important metadata about the project. In addition to providing the highest level of compatibility with non-linear editing/NLE systems, use of MXF-format files offers integration with high-end, networked DAM (Digital Asset Management) and MAM (Media Asset Management) systems used by many TV networks and production studios.
When HD is required – either as the acquisition format, or as a proxy file system for 4K output – the EOS C500 supports the highest image quality, with Full HD 1920x1080 resolution, 50 Mbps bit rate and 4:2:2 color sampling. The system delivers outstanding results via its powerful built-in MPEG-2 XF codec and recording to Compact Flash/CF card installed within the camera body. MPEG-2 compression is fully compatible with existing industry infrastructures and non-linear editing platforms.
Canon 4K Super 35mm 16:9 CMOS Sensor
The EOS C500 features a Canon-designed Super 35mm, 16:9 CMOS sensor with full 4K resolution capable of delivering pristine-quality, 8.85-megapixel images needed for commercial applications with minimal moiré and other artifacts. Based on the same technology as the well-received EOS C300, the EOS C500's High-Sensitivity CMOS image sensor has the additional ability to directly output full 4K, 10-bit RAW Bayered data through two dedicated 3G-SDI connectors. The sensor's large, Super 35mm size lets you capture cinematic shallow depth-of-field imagery, yet maintain the enhanced image characteristics demanded by professional cinematographers.
During data transfer, the uncompressed information from the EOS C500's 4096x2160 Bayer-type CMOS image sensor is read out and transferred as RAW data to the 3G-SDI output. Prior to editing and/or image processing, this pristine RAW data is recomposed using a process known as de-Bayering to extract the highest amount of detail information from the camera's sensor, and capable of delivering truly breathtaking results for both film and TV projects.
By maintaining a wide pixel pitch, the sensor maximizes the amount of light that falls on each photo site, thereby enhancing the EOS C500's sensitivity and reducing image noise. By using a single CMOS sensor to capture individual Red, Green and Blue channels for each Full HD 1920x1080 frame, the EOS C500 produces color performance that is comparable with conventional three-chip designs. Of course, during 4K recording, the EOS C500 uses a debayering algorithm to process and output a full-resolution 4096x2160 image.
Canon Log Gamma
The EOS C500 features a log gamma setting that sets the camera to maximize dynamic range and provide wide exposure latitude. The files produced using log format are ideal for post-production processes where corrections, color matching and grading are applied. It provides users with a high level of creative freedom in post-production without substantially degrading the image quality. When using Canon Log, the EOS C500 can provide a dynamic range up to 800%. Canon Log Gamma can be applied in any EOS C500 recording or output mode.
Canon EOS C500 with EF-Lens Mount
To integrate easily into the working style and equipment array of film crews and production houses, the EOS C500 with a Canon EF-lens mount is completely compatible with all of Canon's EF lenses, including compact primes, super telephotos, specialty Tilt-Shift, Macro and Fisheye lenses - over 60 in all.
EF and L-Series Lenses
A unique combination of the world's most advanced optical, microelectronic, and precision manufacturing technologies, the Canon's EF lenses, compatible with the EOS C500, are perfected in Canon's laboratories and proven in the field. Whatever the application, whatever the budget, there are Canon EF lenses perfect for nearly every scenario. Their compatibility not only affords the Cinema EOS access to some of the finest optics on the market, it opens up myriad possibilities with Canon's superlative specialty lenses, including a range of Tilt-Shift lenses, Close-up lenses and even Canon's amazing EF 8-15mm f/4L Fisheye Zoom.
Canon EF Cinema Lenses
Canon EF Cinema lenses are designed and engineered to meet or exceed the exacting standards of working professionals. Every Canon EF Cinema lens is designed to fulfill contemporary 4K production standards, surpassing the performance requirements of any HD imaging system. Zoom lenses feature large aspherical lens elements to achieve sharp, consistent images in every shooting situation. Geared inner focusing minimizes focus-induced changes in the angle of view, rendering focus breathing virtually zero. The 11-blade aperture diaphragms ensure smooth out-of-focus areas and beautiful bokeh - and innovative glass construction counteracts barrel expansion and contraction to avoid temperature-induced marking discrepancies. EF Cinema lenses provide markings on angled surfaces on both sides of the barrel, making it easy to read focus and aperture settings from behind or either side of the camera. Focus markings can be switched from standard labeling to metric. Control rings are designed to maintain the proper amount of resistance with consistent operating torque. EF Cinema lenses share uniform gear position, diameter and rotation angle as well as front lens diameters, enabling the film crew to quickly change to another Canon zoom or prime lens or compatible third-party accessories like matte boxes and rods without adjustments.
Canon EF Cinema Zoom Lenses
Canon's Cinema EF Zoom lenses offer unrivaled optical performance for demanding high-end productions, available in both EF and PL mount configurations. With fluorite, aspherical lens elements and advanced optical design, these unequalled Cinema EF Zoom lenses are capable of 4K-image reproduction. The wide-angle CN-E14.5-60mm T2.6 L S/SP provides industry-leading breadth of range; the telephoto CN-E30-300mm T2.95-3.7 L S/SP rivals best-in-class zoom magnification and telephoto focal length. Together these lenses cover the range most commonly used in cinema shooting.
Canon EF Cinema Prime Lenses
The brilliant series of Cinema EF Prime lenses offers spectacular 4K-image quality in lightweight, compact designs. Three models for EF mount cameras - CN-E24mm T1.5 L F, CN-E50mm T1.3 L F, and CN-E85mm T1.3 L F - offer consistent form factors and marking optimized for motion picture production. Whether you shoot with a Canon EOS C500 or EOS DSLR, the compact and consistent lens design makes for excellent handling. Audiences will also love the results from the 11-blade aperture diaphragms, fast t-stops and proven Canon lens elements.
Additional lenses are already under development, reflecting Canon's commitment to offer the broadest range of professional cinema lenses to meet filmmaker's needs, now and in the future.
Terminal Connectors
The EOS C500 comes complete with essential I/O interfaces via professional-grade BNC and multi-pin connectors.
  • Two 3G-SDI connectors output the Canon Log Gamma and audio signals at resolution and frame rates established within the EOS C500's 4K/2K priority modes.
  • Two Monitor connectors can be used to feed a video signal to an external monitor in 4K/2K priority mode, with a choice of either Rec709 or Wide DR color-adjustment, look-up tables (LUTs). (Marker, zebra and peaking signals can be set to output to only one of the monitor ports.) Signal format is YCC 4:2:2, 10-bit.
  • A Sync Out connection carries a choice of HD Sync/HD-Y or SD black burst/composite signals.
  • A Genlock Input can be used for synchronizing the camera with an external video device.
  • A Timecode In/Out connector enables the EOS C500 to either lock to external timecode or feed its internally generated timecode to external systems.
  • An HD/SD SDI connector serves as a standard interface for commercial HD equipment, with multiplexed audio and video signals in a digital format.
  • Two XLR Audio connectors are provided on the modular monitor control unit. The audio inputs provide 2-channel audio recording with the ability to switch between line-level, mic-level and mic-level with phantom power supply.
Versatility, Reliability and Durability
Designed from the ground up to maximize shooting comfort and usability, the EOS C500's modular design enables different components to be added or removed as required to meet the needs of a particular shooting scenario, and also to increase the comfort of a camera operator. In addition to the core camera body, the EOS C500 features a low-angle, camera-handle extension plus a removable LCD Monitor and control panel with XLR audio inputs. (However, to accommodate the EOS C500's 3G SDI outputs, the handgrip is fixed in a single position and not removable.)
The EOS C500 features an Ultra-High Resolution 1.55 Megapixel EVF with approximately 100% field-of-view coverage for comfortable viewing and accurate image composition, focus and color adjustment. The viewfinder's angle is adjustable for additional user comfort. The Camera Control Unit features a 4-inch, 1.23 Megapixel rotating LCD screen that offers approximately 100% field-of-view coverage. Mounted onto the camera control pad, the display panel can be freely rotated to provide the operator with flexible viewing angles and convenient access to the control panel. For added flexibility, the panel can also be mounted in different positions to accommodate different viewing positions required by the operator, director or producer. Such flexibility and ease of movement makes the display easier to use than a rigid design that can be easily bumped during a shoot.
Full Manual Control
The EOS C500 incorporates a number of built-in features that camera cinematographers and camera operators need to ensure accurate exposure and color levels during production.
  • A versatile waveform monitor provides detailed analyses of both overall image brightness and RGB Components.
  • To check color balance and view the effects of white-balance adjustments, an on-board vectorscope displays real-time image hue and saturation analysis.
The EOS 500 offers full manual control of all functions, including iris, shutter speed, gain, zoom, focus and audio levels, thereby allowing the camera operators to adapt to both technical and artistic challenges during the shooting. For maximum customization, you have access to Custom Picture Settings, Custom Functions and Custom Display Options to tailor the EOS C500 precisely to your specific needs.
For situations in which conditions require critical focusing, the EOS C500 offers several focus aids. A pair of Peaking Modes and a Magnify Focus Assist are available in both standby and record mode, making it extremely easy to check and confirm critical focus settings. An Edge Monitor Focus Assist system, which was first introduced with the Canon XF Series camcorders, shows overall focus of the image plus focus status of focus-check boxes.
Expanded EF Lens Communication
With the November 5th, 2015 firmware update, EF Lens communication has been expanded to allow servo lens control from the from the RC-V100 remote control. An external battery/power source is necessary to drive the lens, as power cannot be supplied by the camera.
Slow and Fast Motion
During internal CF recording mode, the EOS C500 provides a Slow and Fast Motion Mode that can be used to record at a different frame rate than the playback frame rate, thereby resulting in either a fast or slow motion effect. Because the EOS C500 is recording real frames, and simply modifying the data playback rate, there is no overall quality loss due to interpolation; maximum image quality is maintained. In HD 1080 mode, fast motion is supported at up to 30-times normal rate and as slow as 1/1.25 sec.; in HD 720 mode, fast motion is supported up to 60-times the normal rate, and as slow as 1/2.5 seconds. In 4K/2K output modes the camera provides variable frame rate control that can be output to external recorders.
The EOS C500 incorporates an interval recording function. With this feature set, users can program the camera to record a specified number of frames at specified intervals for time-lapse capture.
WFT-E6 Wi-Fi® unit with Remote Capabilities
The EOS C500 can be used with the optional WFT-E6A Wi-Fi transmitter to provide unique capabilities not found in competitive units. Using any web-enabled devices such as a laptop PC, smartphone or tablet, you can control and adjust a number of the EOS C500's operational functions, including camera start and stop plus shooting parameters, in addition to monitoring a remote video feed and inputting session metadata. A built-in Bluetooth sensor will communicate automatically with external GPS units to secure location data that can be embedded with your video footage.
Specifications
Effective Pixels
4096 x 2160 pixels; Approx. 8.85 megapixels
Total Pixels
4206 x 2340 pixels; Approx. 9.84 megapixels
Sensor Type
CMOS
Sensor Size
Super 35; 26.2 x 13.8 (29.6 mm diagonal); 6.4 µm cell pitch
Scanning System
Progressive
Number of Sensors
1
Filter
RGB Primary Color Filter (Bayer Array)
Imaging Processor
Digic DV III
Interchangeable Lens System
Choice of PL or EF mounts for compatibility with a wide variety of lens systems.
ND Filter
Mechanical ND filter system with option of clear, 2, 4, and 6 stops
Iris Dial
Iris Dial located on camera body for use with EOS EF Lenses with electronic Iris control (EF Camera version only)
Peripheral Illumination Correction
Available on EF Mount model only
Exposure Modes
Manual
Gain
Normal Setting -6dB to 30 dB TBD
Fine Setting 0dB to 24 dB in 0.5 dB increments
ISO
320 to 80,000
Shutter Modes
3 Modes: OFF; Speed; Angle; Slow Shutter; Clear Scan
Speed Mode is selected in 1/3 or ¼ stop increments
Shutter Speed Range
59.94i/59.94p: 1/60 to 1/2000 in 1/4 or 1/3 stops; SLS: ¼, 1/8, 1/15, 1/30; CS: 59.94 Hz - 250.27 Hz
29.97p: 1/30 to 1/2000 in 1/4 or 1/3 stops; SLS: ¼, 1/8, 1/15; CS: 29.97 Hz - 250.27 Hz
23.98p/24p: 1/24 to 1/2000 in 1/4or 1/3 stops; SLS: 1/3, 1/6, 1/12; CS: 23.97 Hz - 250.27 Hz
50i/50p: 1/50 to 1/2000 in 1/4 or 1/3 stops; SLS: 1/3, 1/6, 1/12 1/25; CS: 50.00 Hz - 250.78 Hz
25p: 1/25 to 1/2000 in 1/4 or 1/3 stops; SLS: 1/3, 1/6, 1/12; CS: 25.00 Hz - 250.78 Hz
Shutter Angle Settings
59.94i/59.94p: 360, 240, 216, 180, 120, 90, 60, 45, 30, 22.5, 15, 11.25
29.97p: 360, 240, 216, 180, 120, 108, 90, 60, 45, 30, 22.5, 15, 11.25
23.98p/24p: 360, 345.6, 288, 240, 180, 172.8, 144, 120, 90, 86.4, 72, 60, 45, 30, 22.5, 15, 11.25
50i/50p: 360, 300, 240, 180, 150, 120, 90, 60, 45, 30, 22.50, 15, 11.25
25p: 360, 300, 240, 180, 150, 120, 90, 75, 60, 45, 30, 22.50, 15, 11.25
Iris (Aperture) Range
EF Lens only - ½. 1/3 stop or fine setting can be selected
Smooth Manual control on Cinema Lenses
Focus Settings
Manual
AF Modes
None
Resolution
Resolution
Compression
8 Bit MPEG-2 Long GOP
Maximum Bit rate
50Mbps (CBR)
Recording Options
Recording Options
Recording Media
CF Card (Type 1 Only); 2 Slots (Movie Files); UDMA supported
SD Card (Still Images (JPEG), Custom Picture Data*, Clip Metadata, and menu settings); SD/SDHC/SDXC Supported; MMC Cards are not supported
*Custom Picture Data and settings is not compatible with data from others Canon models
File Format
MXF (OP-1a)
File System
FAT 32
Maximum Clip Number
999 (per media)
Recording Format
Linear PCM; 2-Channel; 16-Bit; 48 kHz
Built-in Microphone
None
External Audio Inputs
2 - XLR inputs (Auto and Manual level settings)
External microphone terminal: (3.5 mm diameter)
Recording Channel Selection
This is used to set the allocation of the audio channels:
CH1/CH2: The CH1 signals are allocated to the L output channel, and the CH2 signals are allocated to the R output channel.
CH1/CH1: The CH1 signals are allocated to the L output channel, and the CH1 signals are allocated to the R output channel.
CH2/CH2: The CH2 signals are allocated to the L output channel, and the CH2 signals are allocated to the R output channel.
ALL CH/ALL CH: Signals obtained by mixing the CH1 and CH2 signals are allocated to the L and R output channels.
XLR Mic Trimming
Available; -12dB, -6 dB, 0dB or +12 dB
Limiter
Available
Recording Level Adjustment Range
- Infinity to +18dB
Phantom Power
Available; +48V
Headphone Adjustment
16 Settings; Volume is muted at lowest setting
Built-in Speaker
None
1KHz Tone
Available; -12, -18, or -20 dB
Playback
Clip Display: 3x4 Index Display, Original, OK Mark, Check Mark, Shot Mark, Expand, Photo (SD Card), Clip Metadata
Clip Playback: Forward Search (x5, x15, x60), Reverse Search (x5, x15, x60), Forward frame Advance, Reverse Frame Advance, Record Review, Skip to next clip, skip to previous clip
Clip information Display: Clip Metadata display, custom picture settings Playback Functions: Inter-media Copy (Single Clip, All Clips, Last Clip); Clip Delete (Single Clip, All Clips, Last Clip)
Still Image Playback: index, single playback, erasure, protect
Special Recording Functions
Relay Recording*; Double-Slot Recording**; Copying between Media
* Not available during Slow Motion 50 Mbps recording
** Not available in combination with Slow and fast motion recording
NOTE: Special features other than Slow and Fast Motion Recording are not available in 4K and 2K modes
Photo Recording Mode
Available; Images captured to SD Card
Waveform Monitor
Available; 2 Modes (Standard and RGB Component)
Vectorscope
Available
Exposure/Focus Aids
Peaking (2 types), Zebra Pattern*, Magnify, Edge Monitor Focus Assist, Black and White Mode
*Can be output via the SDI or HDMI Jack (HD Only)
Interval Record
Available; ability to set time interval and number of frames to record
Interval can be set in 25 levels ranging from 1 second to 10 minutes.
(1s/2s/3s/4s/5s/6s/7s/8s/9s/10s/15s/20s/30s/40s/50s/1m/2m/3m/4m/5m/6 m/7m/8m/9m/10m)
NTSC 59.94i/29.97p/23.98p/24.00p: Selectable between 1, 3, 6, 9 frames
NTSC 59.94p: Selectable between 2, 6, 12 frames
PAL 50i/25p/50p: Selectable between 2, 6, 12 frames
Frame Record
Available; Records a set number of frames each time the record button is pressed
NTSC 59.94i/23.98p/24.00p: Selectable between 1, 3, 6, 9 frames
Pre-Record
Yes, 3 seconds cache (Audio and Video)
Scan Reverse
When using a Depth of Field Converter or other lens adapters it flips or reverses the image automatically so it is recorded correctly.
Time code
*Drop Frame (DF) and Non-Drop Frame (NDF)
*Drop frame works with NTSC models only and is not available in 24P
Time Code Modes
Regeneration, Record Run, Free Run and External Source
Auto White Balance (AWB)
Not Available
White Balance
Kelvin Setting 2,000K to 15,000K in 100K increments
White Balance Presets
Daylight (5,400K); Tungsten (3,200K); Kelvin
White balance shift is available within Presets (-9 to +9)
Auto Black Balance
Available
23 Custom Picture settings
A total of nine 9 Customized Pictures are available in the camera and up to 20 can be saved to an SD card
Custom pictures can be adjusted using the following settings and saved for later recall:
Gamma, Black, Black Gamma, Low Key Saturation, Knee, Sharpness, Noise Reduction, Skin Detail, Selective Noise Reduction, Color Matrix, White Balance, Color Correction, Setup Level
Custom Pictures CP8 and CP9 ship with the following presets:
C8: Cinema - Suited for giving recorded media a film tone.
C9: EOS Standard - Used to match the quality of DSLR video shot in EOS standard mode
Custom Functions
Available, 9 total functions
Custom Display
Yes; LCD panel and EVF information display can be customized
Total of 27 display and icons that can be turned on and off
On Screen Markers
Yes
Assign Buttons
15; Can be assigned functions as desired (37 functions Available)
Color Bars
Color bars compliant with SMPTE, EBU, or ARIB standards can be selected.
Minimum Subject Illumination
59.94 Hz Mode: 0.3 Lux
(f/1.2, 24 dB, 29.97p, 1/30 sec.)
50.00 Hz Mode: 0.25 Lux
(f/1.2, 24 dB, 25p, 1/25 sec.)
Sensitivity
59.94 Hz Mode: F9
(1920 x 1080/59.94i, ISO 640 (0 dB), 2000 lux, 89.9% Reflection)
50.00 Hz Mode: F10
(1920 x 1080/50i, ISO 640 (0 dB), 2000 lux, 89.9% Reflection)
S/N Ratio
59.94 Hz Mode: 54 dB (Typical)
(1920x1080/29.97p, Canon Log, ISO 850, Dynamic Range 800%)
50.00 Hz Mode: 54 dB (Typical)
(1920x1080/25p, Canon Log, ISO 850, Dynamic Range 800%)
Dynamic Range
During Normal Shooting: 300%
*With Canon Log Gamma: 800%
*ISO 850 or above - gain 2.5dB or above
Viewing Angle Adjustment
Available; Viewing Angle can be adjusted up and down 60°
Diopter Adjustment Range
+2.0 to -5.5
EVF Adjustments
Brightness, Contrast, Color, and Backlight (Normal or Bright)
Display Adjustments
Brightness, Contrast, Color, Sharpness, and Backlight (Normal or Bright)
HD/SD SDI
Yes; (with embedded audio);
HD 8-bit 4:2:2 (YPbPr) 1920x1080: 59.94i/50i/23.98/24.00, 1280x720: 59.94p/50p/23.98/24.00
SD 8-bit 4:2:2 (YPbPr) 480: 59.94i, 576: 50i BNC Connector, output only
SD-SDI:
NTSC 480i/PAL 576i: Compliant with SMTPE 259M
Embedded Audio: Compliant with SMTPE 272M
Time Code Standard: (VITC/LTC) SMTPE 12M
HD-SDI: (Compliant with SMTPE 292M)
1080i/720p: Compliant with SMTPE 292M
Embedded Audio: Compliant with SMTPE 299M
3G SDI
Available; 2x BNC
Output Modes: RAW (10-bit); RGB 4:4:4 (10-bit/12-bit); YCC 4:2:2 (10-bit)
Frame Rates: 23.98p/24.00p/25.00p/29.97p/59.94p/50p
Video Monitor Out
Available; 2x BNC
Resolution: 2048x1080 / 1920x1080
Frame Rates: 23.98p/24.00p/25.00p/29.97p/30p/59.94p/50p/60p
Color Space: YPbPr: 10-bit
Time code In/Out
Yes; BNC Connector (Input and Output)
Genlock
Yes; BNC Connector (Input Only)
Adjustment range: -1023 to +1023
Synch Out
Yes, BNC Connector
(1) HD tri-level signal (HD Sync) 1920x1080: 59.94i/50i/23.98/24.00, 1280x720: 59.94p/50p/23.98, 24.00; The HD standard analog component Y signal with the black muted is output.
(2) HD-Y signals (HD-Y) 1920x1080: 60i, 59.94i/50i, 1280x720: 60p/59.94p/50p; Only the HD standard analog component Y signal is output.
(3) Black burst signal 480: 59.94i, 576: 50i; The SD standard analog composite signal with the black muted is output.
(4) Composite 480: 59.94i, 576: 50i; The SD standard analog composite signals are output.
HDMI
Yes (Type A)
HD 8-bit 4:2:2 (YPbPr) 1920x1080: 60i/59.94i/50i, 1280x720: 60p/59.94p/50p
Audio Input Terminal
2 - Balanced 3-pin XLR on Monitor Unit (Mic Level, Mic Level with phantom power and Line Level)
3.5mm Microphone terminal
Headphone Jack
Available; 3.5mm stereo mini-jack
Remote Terminals
Available (Fully LANC Compatible)
Remote control through WFT-E6A accessory is also possible
Supply
DC 7.4 V (Battery Pack) / DC 8.4 V (DC In)
Power Terminal
DC in on camera (no need for Dummy Battery)
Battery
BP-9 Series (Excluding BP-925)
Compact Power Adapter
CA-940N
Tripod Adapter
Canon TA-100
Tripod Adapter Base
Canon TB-1
Zoom Remote Controller
Canon ZR 2000
Wi-Fi Adapter
WFT-E6A
Dimensions
Approx. 6.3 x 7.0 x 6.7 in (160 x 179 x 171 mm)
C500 + Monitor Unit: Approx. 7.3 x 9.8 x 7.4 in (185 x 249 x187 mm)
C500 + Handle Unit + Monitor Unit: Approx. 7.3 x 11.2 x 11.9 in (185 x 284 x 301 mm)
Main Unit Weight
C500 Body: Approx. 4.0 lb. (1820 g)
Monitor Unit: Approx. 1.4 lb. (645 g)
Handle Unit: Approx. 6.3 oz. (180 g)
Total Equipped Weight
C500: Approx. 6.0 lb. (2705 g)*
C500: Approx. 6.4 lb. (2885 g)**
* Weights include the monitor unit, BP-955, 2x CF cards.
** Weights include the monitor unit, handle unit, BP-955, 2x CF cards.
Temperature and Humidity
Performance requirements: 0°C to 40°C, 85% (relative humidity)
Operating requirements: -5°C to 45°C, 60% (relative humidity)
Language Support
English, Japanese, Chinese, German, Spanish, French, Italian, Polish, Russian
Time and Date
Automatic Calendar range January 1st, 2010 through December 31, 2031 selectable in American, Japanese and European Date formats.
World Clock
World Clock support - UTC time setting: Setting range from +14:00 to - 12:00
EOS C500
EOS C500 EOS C500 Body (with Camera Cover) Monitor Unit (with Microphone Holder Unit and Screws for MHU) Handle unit Thumb Rest WFT Adapter Tripod Adapter Base Eye Cup EVF CAP SS-1200 Shoulder Strap BP-955 Battery Pack (with Terminal Cover) CG-940 Battery Charger CA-940 Compact Power Adapter DC Cable for CA-940 AC Cable XF Utilities Disc Ver.31 Instruction Manual
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EOS C500 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Resources
Case Studies
No Place Like Home
08/03/17
10.23 MB
White Papers
Canon Log Gamma Curves
12/18/18
0.81 MB
Canon-Log Cine Optoelectronic Transfer Function
11/01/18
1.53 MB
Sensitometric Characteristics of the EOS Digital Cine Camera
11/01/18
0.62 MB
New 35mm CMOS Image Sensor for Digital Cine Motion Imaging
11/01/18
1.27 MB
Choice of Wide Color Gamuts in Cinema EOS C500 Camera
11/01/18
0.98 MB
How a 4K Image Sensor originates a superior real-time 2K or HD
11/01/18
6.30 MB
The Promise of 4K
11/01/18
0.85 MB
Cinema EOS for 2K and HD Origination
11/01/18
0.84 MB
Interactive Simulator
This is to make Misc appear on the page when needed.
Videos
Transparent: Behind the Scenes
Go behind the scenes of the 2015 Golden Globes winning Best TV Series – Transparent, a comedy by Amazon Studios about a family that comes to terms with the revelation that their father (Jeffrey Tambor) is transgender.
4K, 2K, or HD – The Great Debate on Resolution
Leading cinematographers Steven Poster, ASC, Shane Hurlbut, ASC, Dallas Sterling, and Sam Nicholson, ASC, at the 2014 Cine Gear Expo for an insightful conversation on resolution as they compare and contrast their experiences shooting in 4K, 2K, and HD.
RC-V100 Remote Control
The versatile RC-V100 Remote Controller for EOS C-Series Digital Cinema cameras and the XF305/300/205/200 Professional Camcorders provide full access to all important user functions.
Need for Speed: Behind the Scenes
Cinematographer Shane Hurlbut, ASC takes you on an adrenaline-pumping ride behind the scenes of the upcoming blockbuster Need for Speed. Shane relied on the Canon Cinema EOS C500 digital cinema camera, the Cinema EOS 1D-C digital SLR, and Canon lenses to capture the heart-pounding, high-velocity speed racing action coming soon to the big screen.
Canon Collaborations: The EOS C500 Configured by the Crew of Human Voice
Acclaimed cinematographer Rodrigo Prieto, ASC, AMC and director Edoardo Ponti take you to beautiful Naples, Italy to give you an intimate behind-the-scenes look at the making of Human Voice, a short film starring Sophia Loren.
Canon Powershot “Be Ready”: Behind The Scenes
Go behind the scenes with director Dave Meyers and his crew as they shoot a Canon PowerShot commercial in 2K with a Cinema EOS C500. John Veleta, DIT gives an in depth tour of the shoot's workflow and camera configuration, while DP Marcelo Durst explains some of the benefits the EOS C500 brings to the table.
 Return to Top
