Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
EOS C70
Cinema EOS
Canon Store: $
Providing access to all important user functions.
CarePAK PRO provides accidental damage protection for peace of mind. Find an Authorized Dealer.
EOS C70
Developed with an idea of combining the Cinema EOS series with the EOS R series, the new EOS C70 offers exceptional image quality and professional video features in a compact and mobile form factor, perfect for documentary, newsgathering, and corporate videos.
The EOS C70 is the first Cinema EOS camera with a built-in RF-lens mount, which was previously a feature that was only used for the EOS R series of mirrorless cameras. The RF-mount offers users access to Canon's superb line of RF-lenses, which are quick, reliable and provide brilliant image quality. There is also a full 2, 4, 6, 8, and 10-stop internal ND filter system in the relatively small flange depth of the RF-mount.
Canon's EOS C70 is also equipped with a Super 35mm Dual Gain Output (DGO) Sensor that is capable of over 16 stops of dynamic range. The DIG!C DV7 Image Processor expands functionality and flexibility by enabling features such as 4K 120p High Frame Rate recording and Dual Pixel Autofocus.
Features
The
The DGO Sensor is a newly developed imaging system that generates high dynamic range and maintains low noise levels by reading out each photodiode with two different gains. It combines the two with a saturation prioritizing gain for bright areas, and a lower noise prioritizing gain for darker areas.
The
The
Canon Log 2 provides the largest dynamic range and image detail. However, while Canon Log 2 provides the most post-production flexibility and full dynamic range of the sensor, it typically requires more time in post and color correction.
For users looking for most of the benefits of a log workflow, but with shorter turnaround times, Canon Log 3 provides an alternative with only a slightly reduced dynamic range of 14 stops.
The
The
In addition to RF lenses, the EOS C70 offers tremendous flexibility by also being compatible with Canon's broad line of award-winning EF lenses thanks to the new EF - RF optical adapter, Mount Adapter EF-EOS R 0.71x. This adapter converts light transmission from full-frame to Super 35mm image format. It extends the angle of view and optical sensitivity, while seamlessly integrating with the camera’s optical corrections.
The adaptor connects to the camera’s RF mount with additional support from two flanges that securely attach via four screws, making for a very robust connection. Once mounted, the adapter maintains a similar full-frame angle of view on the Super 35mm sensor, while boosting the speed of the attached lens by an average of 1-stop. The adapter also carries all EF information through to the RF contacts, so on certain lenses*, full DPAF, aberration and vignetting correction, and metadata will be available, working just as they do on a native EF mount.
Other adapters that are compatible with EOS C70, include:
• Canon Mount Adapter, EF-EOS R
• Canon Control Ring Mount Adapter, EF-EOS R
• Canon Drop-In Filter Mount Adapter, EF-EOS R with Circular Polarizer Filter
• Canon Drop-In Filter Mount Adapter EF-EOS R with Variable ND Filter
*As of September 25, 2020, the following lenses are compatible: the EF16-35mm f/2.8L III USM (released in October 2016), the EF24-70mm f/2.8L II USM (released in September 2012), the EF24-105mm f/4L IS II USM (released in November 2016). Canon plans to gradually expand the list of compatible lenses by providing free-of-charge firmware updates. EF lenses are still compatible with the camera, but Canon recommends that firmware updates be installed in order to effectively utilize functions which link the camera and lens.
The
The
The
The
The newly-developed thin, motorized ND filter unit has been specifically designed for the RF mount's short flange back. It offers up to 10 stops of ND, allowing users to shoot in various lighting conditions.
The
Canon's
The
The
For the first time in a
In addition, the
The
The
The
The
*V90 SD cards are recommended for Slow & Fast motion recording.
The
The
Specifications
Effective Pixels
3840 x 2160: when 3840 x 2160 or 1920 x 1080 is selected as the resolution (Approx. 8.29 megapixels)
Total Pixels
4206 x 2280; Approx. 9.6 megapixels
Sensor Type
CMOS
Sensor Size
4K: 26.2 x 13.8 (29.6 mm diagonal)
UHD: 4K: 24.6 x 13.8 (28.2 mm diagonal)
Sensor Modes
Pixel Pitch
6.4 µm
Scanning System
Progressive
Number of Sensors
1
Filter
RGB Primary Color Filter (Bayer Array)
Imaging Processor
DiG!C DV 7
Lens Mount
Default Mount: RF Mount
Zoom/Focus Preset
Not Available
Shockless Zoom
Not Available
Digital Teleconverter
Not Available
ND Filter
Mechanical ND filter system with option of clear, 2, 4, and 6 stops; 8 and 10 stops in extended mode
Peripheral Illumination Correction
Available
Chromatic aberration Correction
Available
Distortion Correction
Available (RF Lenses only)
Difraction Correction
Available
Exposure Modes
(1) Manual exposure based on shutter setting, iris setting, ISO/gain setting, and ND filter setting
(2) Push auto iris control, auto iris control
(3) Auto ISO mode
Metering Modes
Standard, Spotlight and Backlight
Gain
Normal Setting -6dB to 54dB
Fine Setting -2dB to 54dB in 0.5 dB increments
ISO
100 to 102,400
Auto Gain Control (AGC)
Not Available
Shockless Gain
Not Available
Exposure Compensation/AE Shift
–2.0 to +2.0 in 0.25 point intervals
Shutter Modes
3 Modes: OFF; Speed; Angle; Slow Shutter; Clear Scan
Speed Mode is selected in 1/3 or 1/4 stop increments
Shutter Speed Range
59.94Hz/24.00Hz: 1/12 to 1/2000
50.00Hz: 1/15 to 1/2000
Shutter Angle Settings
59.94Hz/50.00Hz/24.00Hz: 360, 240, 180, 120, 90, 60, 45, 30, 22.5, 15, 11.25
Iris Settings (EF)
Can be set to 1/2 stop, 1/3 stop or Fine.
(1) Push auto iris control
(2) Auto iris control (Compatible lens required)
Focus Control
Dual Pixel CMOS AF with EOSxITR
Focus Modes
Manual focus, Continuous AF, One-Shot AF, AF-Boosted MF, Face Detection AF
Only lenses that support AF functions can be used in AF modes
System Frequency
59.94 Hz, 50.00 Hz, 24.00 Hz
59.94 Hz mode: 59.94i/59.94P/29.97P/23.98P
50.00 Hz mode: 50.00i/50.00P/25.00P
24.00 Hz mode: 24.00P
Resolution
| Mode | Resolution | Frame Rates |
| XF-AVC | 4096x2160/ 3840x2160 | 59.94p / 29.97p / 23.98p / 50.00p / 25.00p / 24.00p |
| 2048x1080/ 1920x1080 | 59.94p / 29.97p / 23.98p / 50.00p / 25.00p / 24.00p | |
| 1280x720 | 59.94p/50p | |
| MP4 | 4096x2160 / 3840x2160 | 59.94p / 29.97p / 23.98p / 50.00p / 25.00p / 24.00p |
| 2048x1080 / 1920x1080 | 59.94p / 29.97p / 23.98p / 50.00p / 25.00p / 24.00p/ 59.94i / 50i | |
| 1280x720 | 59.94p / 50p |
Color Gamuts*
Cinema Gamut, BT.709, BT.2020
Gamma Curves*
BT.709, Wide DR, Canon Log 2, Canon Log 3, PQ, HLG
*Enabled for recording (including proxy) and output from each terminal
Video Compression Formats
XF-AVC: MPEG-4 AVC/H.264 (10bit, 8bit (proxy))
MP4(HEVC): H.265/HEVC (10bit)
MP4(H.264) : MPEG-4 AVC/H.264 (8-bit)
Audio Recording System
XF-AVC: Linear PCM (24bit, 48kHz) 4-channel recording
MP4 (1) : MPEG-2 AAC LC (16-bit, 48 kHz, 2-channel)
MP4 (2) : Linear PCM (16-bit, 48 kHz, 4-channel)
Recording Time
| XF-AVC Intraframe | ||||
| SD Card | 410 Mbps | 310 Mbps | 160 Mbps | |
| 64 GB | 19 Minutes | 25 Minutes | 50 Minutes | |
| XF-AVC Long GOP | ||||
| SD Card | 260 Mbps | 160 Mbps | 50 Mbps | |
| 64 GB | 30 Minutes | 50 Minutes | 160 Minutes | |
| SD Card | 35 Mbps | 24 Mbps | 17 Mbps | |
| 64 GB | 229 Minutes | 334 Minutes | 472 Minutes | |
SD | H.265 MP4 | |||
64 | 225 Mbps | 170 Mbps | 135 Mbps | 100 Mbps |
35 minutes | 47 minutes | 59 minutes | 80 minutes | |
50 Mbps | 35 Mbps | 12 Mbps | 9 Mbps | |
160 minutes | 229 minutes | 668 minutes | 891 minutes | |
SD | H.264 MP4 | |||
64 | 150 Mbps | 35 Mbps | 8 Mbps |
53 minutes | 229 minutes | 1003 minutes |
File Format
(Still Images (JPEG), Custom Picture Data, Clip Metadata, and menu settings); SD/SDHC/SDXC Supported
File Format
MPEG4: MP4
HEVC: MP4
File System
SDHC card: (up to 32 GB): FAT32
SDXC card (more than 32 GB): exFAT
File division unit: 4 GB for FAT32, none for exFAT
Maximum Clip Number
999 (per media)
Recording Format
Linear PCM; 4-Channel; 24-Bit; 48 kHz
Built-in Microphone
Stereo/Monaural
External Audio Inputs
2 – Mini-XLR inputs (Auto and Manual level settings)
External microphone terminal: (3.5 mm diameter)
Recording Chanel Selection
Up to 4 channel audio recording is supported.
XLR Mic Trimming
Available; -12dB, -6 dB, 0dB or +12 dB
Limiter
Available
Recording Level Adjustment Range
- Infinity to +18dB
Phantom Power
Available; +48V
Headphone Adjustment
16 Settings; Volume is muted at lowest setting
Built-in Speaker
Available; Volume Adjustable
1KHz Tone
Available (off, -12, -18, or -20 dB)
Playback
Clip Display: 3x4 Index Display.
Clip Playback: Forward Search (x5, x15, x60), Reverse Search (x5, x15, x60), Forward frame Advance, Reverse Frame Advance, Record Review, Skip to next clip, skip to previous clip
Clip information Display: Clip Metadata display, custom picture settings
Playback Functions: Clip Delete
Photo Playback: index, single playback, delete, protect
Slow and Fast Motion Recording
Available; Records at a different frame rate then the playback rate allowing for fast and slow motion effects:
| Sensor Mode | Recording Mode | Available Frame Rates | ||||
| Super35 | XF-AVC |
| Super16(Crop) | XF-AVC |
| Super35 | MP4 |
| Super16(Crop) | MP4 |
Special Recording Functions
Relay Recording*; Double-Slot Recording**
* Not available during Slow Motion recording
** Not available in combination with slow and fast motion recording or relay recording
Photo Recording Mode
Available; Images captured to SD Card
Waveform Monitor
Available (HDR Compatible);
(a) Line display
(b) Line + spot: Line display over a red waveform in a red frame.
(c) Line select display
(d) RGB (parade)
(e) YPrPb (parade)
Output gain can be selected as either 1x or 2x. With gain set to 2x, the vertical axis (Y-position) offset value can be chosen.
When gamma is set to PQ, a PQ index (nits index) can be displayed. When gamma is set to HLG, an HLG index (0.0–1.0 relative index) can be displayed.
Vectorscope
Available
False Color
Available
Exposure / Focus Aids
Peaking (2 types), Zebra Pattern, Magnify, Black and White Mode, Focus Guide
Frame Record
Not Available
Pre-Record
Yes, 3 seconds cache (Audio and Video)
Time code
Drop Frame (DF) and Non-Drop Frame (NDF)
Time Code Modes
Regeneration, Record Run, Free Run and External Source
Auto White Balance (AWB)
Available
White Balance
Kelvin Setting:
2,000K to 15,000K in 100K increment
-20CC to +20CC in 1 CC increments
White Balance Presets
Daylight (5,600K); Tungsten (3,200K), Custom A, Custom B
Auto Black Balance
Custom Picture Settings
20 Custom Picture settings
Custom pictures can be adjusted using the following settings and saved for later recall:
Gamma, Black, Black Gamma, Low Key Saturation, Knee, Sharpness, Noise Reduction, Skin Detail, Selective Noise Reduction, Color Matrix, White Balance, Color Correction, Setup Level
Custom Pictures can be saved to an SD card for later use or transferring between cameras
Custom Display
Yes; LCD panel and EVF information display can be customized
On Screen Markers
Available marker options include center, horizontal, grid, aspect, safety zone, and user marker.
With user markers, user can set their preferred size and position.
Markers can be displayed in yellow, blue, green, red, black, gray, or white.
Assign Buttons
13 total assignable buttons on body
Color Bars
Color bars compliant with SMPTE, EBU, or ARIB standards can be selected depending on system frequency selected
Sensitivity
59.94 Hz: f/10 (2048x1080/59.94P) or f/14 (1920x1080/29.97P)
50.00 Hz: f/11 (2048x1080/50.00P) or f/16 (1920x1080/25.00P)
All values for ISO 800, 2000 lux, and reflectance rate of 89.9%
Dynamic Range
Canon Log 2: 1600% / 16+ stops (ISO 800)
Canon Log 3: 1600% / 14 stops (ISO 800)
Type
3.5-inch (8.8 cm diagonal) color wide-screen LCD
Approx. 2,760,000 dots (1280 x RGB x 720),
Aspect Ratio
16:9
Field of View Coverage
100%
Display Adjustments
Brightness, Contrast, Color, Sharpness, and Luminance
Time code In/Out
Yes; BNC Connector (Input and Output)
HDMI
Yes (Type A)
[4096x2160/3840x2160]/1920x1080/1280x720
Audio Input Terminal
2 – Balanced 3-pin XLR (Mic Level, Mic Level with phantom power and Line Level)
3.5mm Microphone terminal
Headphone Jack
Available; 3.5mm stereo mini-jack
Remote Terminals
Remote A (Standard – LANC Compatible or RC-V100)
Remote Control through WiFi/LAN Adapter
USB
Available
CCU
Remote Controller RC-V100 (Optional)
Supply
14.4V DC (Battery Pack)
Power Terminal
14.4 V DC (battery pack), 24.0 V DC (DC IN)
Battery
BP-A Series (BP-A30, BP-A60)
Compact Power Adapter
CA-CP200L (for Camera and Battery charger CG-A20)
GPS Receiver
GP-E2 with Interface cable IFC-40AB III / IFC-150AB III) Via USB-C
Wi-Fi Adapter
Via USB-C
Ethernet Adapter
Via USB-C
Adapter
Canon Mount Adapter EF-EOS R 0.71x
Canon Control Ring Mount Adapter EF-EOS R
Canon Drop-In Filter Mont Adapter EF-EOS R with Circular Polarizer Filter
Canon Drop-In Filter Mont Adapter EF-EOS R with Variable ND Filter
Dimensions
(Width x height x depth, excluding cable and grip belt)
Body Only: Approx. 130.2 x 160 x 115.9 mm
Weight
RF Camera body: Approx. 1.17 Kg (2.6 lbs)
Battery Pack BP-A30: Approx. 225 g (7.9 oz.)
Compact Power Adapter CA-CP200L: Approx. 290 g (10.2 oz.) *Not including AC cable
Battery Charger CG-A20: Approx. 145 g (5.10 oz.)
Mic holder unit: Approx. 56 g ( 2.0 oz.)
Body cap: Approx. 17 g (0.60 oz.)
Temperature and Humidity
Performance requirements: 0ºC to 40ºC, 85% (relative humidity)
Operating requirements: -5ºC to 45ºC, 60% (relative humidity)
Language Support
English, Japanese, Chinese, German, Spanish, French, Italian, Korean, Russian
Time and Date
Automatic Calendar range January 1st, 2020 through December 31, 2050
World Clock
World Clock support – UTC time setting: Setting range from +14:00 to -12:00
Brochures
EOS C70
- EOS C70
- Handle Unit
- SS-1200 Shoulder Strap
- Battery Charger CG-A20
- Compact Power Adapter CA-CP200 L
- AC Power Cable
- Canon BP-A30 Battery Pack
- Microphone Holder Unit
- Show Adapter Base/Knob/Screw (M4)
- Measure Hook
- Body Cap
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EOS C70 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Battery Charger (CG-A20)
This charger unit with a compact design, accepting just one battery at a time. Power is supplied using a CA-CP200B compact adapter.
Battery Pack BP-A30
Battery Pack
Battery Pack BP-A60
Battery Pack.
CA-CP200L Compact Power Adapter
GPS Receiver GP-E2
Rugged and lightweight design Records location as EXIF information to images when shooting Can act as a stand-alone GPS logger Camera time can be synched by the built-in atomic clock
MSRP: 390.0
Canon's innovative new EF - RF optical adapter, the Mount Adapter EF-EOS R 0.71x, converts light transmission from full-frame to the Super 35mm image format. It extends the angle of view and optical sensitivity, while seamlessly integrating with the camera's optical corrections. This unit greatly expands the list of compatible lenses by including Canon's renowned line of EF lenses. In addition to the flanges of the RF mount, four screws securely attach the adapter to the EOS C70 camera. Once mounted, the adapter maintains a similar angle of view of your full frame lenses on the Super 35mm sensor, while boosting the speed of the attached lens. The adapter also carries all EF information through to the RF contacts, so, on certain EF lenses*, full DPAF and metadata will be available with EOS C70 camera, working much as they do on a native EF mount. *As of September 25, 2020, the following lenses are compatible: the EF16-35mm f/2.8L III USM (released in October 2016), the EF24-70mm f/2.8L II USM (released in September 2012), the EF24-105mm f/4L IS II USM (released in November 2016). Canon plans to gradually expand the list of compatible lenses by providing free-of-charge firmware updates. EF lenses are still compatible with the camera, but Canon recommends that firmware updates be installed in order to effectively utilize functions which link the camera and lens.
The RC-V100 Remote Controller provides full access to all important user functions, in addition to basic controls. Learn More
Videos
Introducing the Canon EOS C70
Give This Heart a Pen - A film by Jolade Olusanya
In the film, Jolade explores Sophia's identity as a poet, her love for writing, performing and her unique artistic process. The documentary shows how she works as she moves through the country, capturing its essence and her response to it in her poems.
The EOS C70 was put to the test as the film is splitting between an interior studio location, exterior of the London in day and night and some countryside locations. In the studio, Jolade planned to make the most use of natural light, that pushed the dynamic range of the camera, but allowed him to work fast and concentrate on the performance of the artist.
Scenes shot around London with Sophia and the young parkour talent, Georgia Munroe, show the low light ability of the camera as we move from day to night. The scenes explore the link between poetry and movement, which is represented perfectly by the 4K 120 FPS slow motion feature of the camera.
The video was shot entirely on the Canon EOS C70.
Behind the Scenes of 'Give This Heart a Pen' with the Canon EOS C70
"When I first saw and held the EOS C70 I felt like I can have fun with this, a small but mighty camera. I can make this my own camera." - says Jolade as he explaines his favourite features of the new Canon EOS C70, including the compact, ergonomic body, shooting 4k at 120fps with Dual Pixel CMOS AF and the touch AF.
Watch to hear more from Jolade!
Compact, Versatile, and Robust Design of the Canon EOS C70
Learn about the compact, versatile and robust design of the EOS C70.
Canon EOS C70 Professional Interface
Benefits of the Canon Mount Adapter EF-EOS R 0.71x
Videos
Canon Tech Tip: Direct Touch Control on the EOS C70
Canon Tech Tip: Autofocus on the EOS C70
Canon Tech Tip: Mounting Versatility on the EOS C70
Canon Tech Tip: Image Stabilization on the EOS C70
Tech Tip: Input Terminals on the EOS C70
Canon Tech Tip: COMPACT-SERVO Lenses and the EOS C70
- ${title}${badge}
