Web Content Viewer
Actions
EOS M5 EF-M 18-150mm IS STM Kit
EOS M Series Cameras
Item Code: 1279C021AA
EOS M Series
Stylish, compact and powerful. See the possibilities of the EOS M family.
Features
The EOS M5 camera features a 24.2 Megapixel (APS-C) sensor capable of capturing large image and movie files. At 24.2 Megapixels, the EOS M5’s sensor delivers images suitable for enlargements with sufficient resolution for significant trimming. Whether making poster-sized prints, zooming in on a particular detail or making Full HD movies, the EOS M5’s sensor is primed to deliver. An ISO range of 100–25600 means images can be captured with low noise and high detail, even in dimly lit situations.
When the action is happening fast, you and your camera have to be ready to capture that unforgettable photo – and with the EOS M5 camera, there’s virtually no wait for it to focus, even in low light. Inside, its Dual Pixel CMOS AF system offers fast and precise autofocus that stays locked onto your subject, even if your subject is in motion, for both photos and videos. This advanced Canon technology uses 24.2 million sensors to quickly determine how far away an object is and therefore where the lens should focus, and is available while using the electronic viewfinder and when using Live View on the rear screen. Dual Pixel CMOS AF helps ensure your images are sharp, while keeping to a minimum the time it takes to lock focus onto your subject, and smoothly maintaining focus where you want it.
Continuous Shooting at Up to 7.0 fps (Up to 9.0 fps with AF Lock)
To help you get multiple images of a fast-moving subject and ensure you capture the moment you want, the EOS M5 camera is capable of taking up to 7.0 frames per second (up to 9.0 fps with AF Lock). Whether you’re capturing an athlete making a goal or a toddler running clumsily after bubbles, the EOS M5 can take the shot and stay locked on with its new DIGIC 7 Image Processor.
The new DIGIC 7 Image Processor’s enhanced tracking and detection capabilities help keep subjects in focus, while helping to ensure each image has a high level of sharpness and minimum picture noise. Whether you’re capturing a fast-moving athlete or a feisty puppy, the DIGIC 7 Image Processor in the EOS M5 camera can stay locked on throughout the action. Improved face tracking helps keep your friend or family member the subject of the photo. Even in extreme cases, like in low saturation or low-light dusk, dawn or darkened interior moments, the DIGIC 7 Image Processor helps keep what you’re photographing in focus. It also features the new Dual Sensing IS, which uses data from the image itself to help minimize the blur caused by camera shake and body movement. This results in clear, sharp pictures even at slow shutter speeds. All this is in addition to upgraded detail and noise reduction abilities, especially in low light with high ISO settings. Powerful all around, the DIGIC 7 Image Processor helps ensure your photos and videos look sharp and lifelike with minimal unwanted noise or grain.
Whether you’re creating artistic film clips or capturing special occasions, the advanced video capabilities of the EOS M5 camera can catch them in the quality they deserve. Incredibly realistic 1080p Full HD video is recorded at 60 fps with stereo sound in convenient MP4 format. Video is smooth and richly detailed even when played back on a large-screen HDTV via the camera’s HDMI output. The MP4 format’s small file size lets you fit more on a single memory card, and makes downloading and sharing quick and easy. Manual movie mode is also available: adjust settings and even select focus points by using the touch panel LCD screen. You can do this even while looking through the viewfinder to express your vision your way however you shoot – all from a powerful camera that is easily portable.
Sometimes you need to move the camera to create the video you want, whether you’re panning over a gorgeous scenic vista or chasing after an excited puppy. Even when you hold the camera as steady as you can, some unintentional shaking is possible. To counter this, the EOS M5 camera features 5-axis Digital Image Stabilization* when recording video. Blur due to movement in the horizontal and vertical, yaw and pitch (tilting) and roll directions are all digitally minimized in-camera. For more stabilization, when a combination IS-compatible lens is attached, the EOS M5 can use the lens’s Optical IS in conjunction with Digital IS for even less chance of blur due to shaking. These help ensure the videos you record are as sharp as possible.
* Maximum image stabilization is achieved when using either the EF-M 18–150mm f/3.5–6.3 IS STM or the EF-M 15–45mm f/3.5–6.3 IS STM with the lens firmware update.
In certain situations, like a bright sunny day, a viewfinder is preferable to a screen. The built-in high-resolution electronic viewfinder on the EOS M5 camera features approximately 2,360,000 dots so you can see high amounts of detail in what you’re capturing. Its Organic Light Emitting Diode (OLED) technology offers high-contrast, high-color images that can help properly display the scene you want to capture. Touch and Drag AF lets you use the rear screen as a touchpad while you’re using the viewfinder, so you can choose what you want the camera to focus on with just a tap of your finger and without moving the camera away from your face.
The EOS M5 camera has a large, high-resolution, 3.2" LCD monitor that tilts up 85° and down 180°, ideal for composing pictures at high and low angles with ease. Its touch screen is designed to be fast and easy to use for many operations, allowing accessible AF selection right on the panel.
Spending time scrolling through menus and settings can distract you from enjoying the moment, or potentially missing a candid or action-filled shot. The EOS M5 camera features multiple customizable dials to help you keep the adjustments you want, right at your fingertips. The Main Dial is around the shutter, so you barely have to move your finger to change certain settings. The Quick Control Dial and Dial Function button on top lets you adjust settings like ISO speed quickly with your thumb. The handy Exposure Compensation Dial gives you fast access to exposure, so you can brighten shadows or bring down the highlights without having to dive through menus.
Built-in Wi-Fi®* Capability
The EOS M5 camera is designed to make Wi-Fi® connections* fast and easy. It can exchange data with other Wi-Fi® compatible Canon cameras, connect directly to Canon’s Connect Station CS100 device, upload directly to various web services like CANON iMAGE GATEWAY***, Facebook® and YouTube®, and even play back images and movies on DLNA-compatible digital electronics.
Built-in NFC** Capability
With its built-in NFC (Near Field Communication) capability**, the EOS M5 camera connects directly to NFC-compliant Android devices by simply touching the NFC icon located on the camera to the device.
Remote Shooting & Wireless Printing
With the Canon Camera Connect app* installed, the EOS M5 camera connects to and can be controlled by your compatible smartphone or tablet for simple remote shooting. Plus, it can also connect and print directly to IP-compatible printers.
* Compatible with iOS® versions 8.0/8.1/8.2/8.3/8.4/9.0/9.1/9.2/9.3, Android™ smartphone and tablet versions 4.1/4.2/4.3/4.4/5.0/5.1/6.0. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
** Compatible with Android™ smartphone and tablet versions 4.0/4.1/4.2/4.3/4.4/5.0/5.1/6.0.
*** One-time registration is required on CANON iMAGE GATEWAY online photo album.
Thanks to Bluetooth®**** pairing, you can easily connect to and remotely control the EOS M5 camera from compatible smartphones when using the free Canon Camera Connect app (version 1.3.20). Once you’ve set up the initial pairing, you’re able to set the camera to automatically connect when turned on. With this connection you’re able to control camera operations like capturing an image, without needing to touch the camera. For that next level of connectivity, a direct Wi-Fi® connection can be established, letting you use your phone as a viewfinder, and check and download previously captured photos and videos.
^ When applications are active. Switch from Bluetooth® to Wi-Fi® when viewing the images on the camera via the compatible smartphone.
****Compatible with select smartphone and tablet devices (Android™ version 5.0 or later and the following iOS® devices: iPhone 4s or later, iPad 3rd gen. or later, iPod Touch 5th gen. or later) equipped with Bluetooth® version 4.0 or later and the Camera Connect App Ver. 1.3.20 or above. This application is not guaranteed to operate on all listed devices, even if minimum requirements are met.
You don’t want to miss that key moment by having to wait for the camera to turn on. With a quick startup time^^ of approx. 1.0 second, the EOS M5 camera goes from off to able to take a picture almost immediately. Thanks to its fast processing, there's also limited time between image captures. This means the EOS M5 is ready to take that first photo, and the next and the next, when you need it.
^^ Approx. 66% faster than the EOS M3 camera.
To expand creative opportunities, the EOS M5 camera is compatible with both EF-M lenses designed specifically for the EOS M series of digital cameras, as well as the full line of Canon’s EF and EF-S lenses^^^, plus other EOS accessories like Speedlites, Speedlite Transmitters and even Macro Ring Lites. Whether the EOS M5 is a primary or secondary camera, it boasts smooth compatibility with a wide range of EOS accessories.
^^^ Mount Adapter EF-EOS M is required when using EF/EF-S lenses for EOS M series digital cameras.
Specifications
Type
Digital single-lens non-reflex AF/AE camera
Recording Media
SD/SDHC/SDXC memory card
* UHS-I compatible
Compatible Lenses
EF-M lens (when using EF-M Mount Adapter: EF/EF-S lens group)
Equivalent to approximately 1.6x the focal length indicated on a mounted lens
Lens Mount
Canon EF-M mount
Type
CMOS sensor
Pixels
Effective pixels: Approx. 24.2 Megapixels
Total pixels: Approx. 25.8 Megapixels
  • Pixels may decrease due to image processing.
Pixel Unit
Square pixel approx. 3.72 µm
Aspect Ratio
3:2
Dust Deletion Feature
Auto / Manual
Recording Format
EXIF 2.3 (DCF2.0)
JPEG/RAW (CR2 a Canon 14-bit RAW format)
File Size
3:2 Aspect Ratio
Large: 6000 x 4000
Medium: 3984 x 2656
Small 1: 2976 x 1984
Small 2: 2400 x 1600
16:9 Aspect Ratio
Large: 6000 x 3368
Medium: 3984 x 2240
Small 1: 2976 x 1680
Small 2: 2400 x 1344
4:3 Aspect Ratio
Large: 5328 x 4000
Medium: 3552 x 2664
Small 1: 2656 x 1992
Small 2: 2112 x 1600
1:1 Aspect Ratio
Large: 4000 x 4000
Medium: 2656 x 2656
Small 1: 1984 x 1984
Small 2: 1600 x 1600
File Numbering
Continuous, Auto Reset
RAW + JPEG Simultaneous Recording
Yes
Picture Style
Auto, Standard, Portrait, Landscape, Fine Detail, Neutral, Faithful, Monochrome, User Def. 1-3
Settings
  1. Auto
  2. Day Light
  3. Shade
  4. Cloudy
  5. Light bulb
  6. White fluorescent light
  7. Flash
  8. Color temperature
  9. Custom
White Balance Correction
Blue/Amber: ±9 levels
Green/Magenta: ±9 levels
Type
Built-in electronic color viewfinder with 0.39-type screen size and approx. 2.36 million dots
Grid Display
3 types
Depth Of Field Preview
Provided
Type
Dual Pixel CMOS AF (Face+Tracking AF, 1-point AF)
AF Points
49 points (Maximum)
AF Working Range
EV -1–18 (at room temperature, ISO 100, when using EF-M 22mm f/2 STM)
Focusing Modes
  1. Autofocus
    • One-Shot AF
    • Servo AF
  2. Manual focus
  3. AF+MF (Manual focus after One-Shot AF: when shooting still images during movie recording)
AF Assist Beam
Built-in LED lamp
Metering Modes
Real-time metering using the image sensor
  1. Evaluative
  2. Partial metering
  3. Center-weighted evaluative metering
  4. Spot
Metering Range
EV 1-20 (at room temperature, ISO 100)
Exposure Control Systems
  1. Program AE
  2. Shutter-priority AE
  3. Aperture-priority AE
  4. Manual exposure
ISO Speed Range
ISO Auto Range (AUTO mode): ISO 100-6400
Max. ISO Speed (P mode): ISO 25600
Max. Speed Limit Setting in ISO AUTO: ISO 25600
  1. Manual: ±3 stops in 1/3-stop increments
  2. AE Bracketing: ±2 stops in 1/3-stop increments
    AE Bracketing can be used together with manual compensation.
AE Lock
Manual / Auto
Type
Electronic control only
Shutter Speeds
1/4000 sec. to 30 sec. in Auto mode
Highest flash-sync shutter speed: 1/200 sec.
Self Timer
Off, 2 sec. delay, 10 sec. delay, Custom, Remote Control
Camera Start-up Time
Approx. 1.0 sec.
Type
Manual pop-up flash
Guide Number
Gno. approx. 5 (ISO 100/m)
Flash Coverage
Covers approx. 15mm focal length (35mm film size conversion: approx. 24mm)
Flash Exposure Compensation
Flash Metering
E-TTL II autoflash
FE Lock
Provided
External Flash Settings
Flash functions settable with the camera
Drive Modes
Single shooting, Continuous shooting (High-speed continuous shooting, low-speed continuous shooting)
File Format
MP4
Video: MPEG-4 AVC / H.264
Audio: MPEG-4 AAC-LC (stereo)
File Size
Recording Sizes:
1920 x 1080 (Full HD), 1280 x 720 (HD) and 640 x 480 (VGA)
Frame Rates
[1920 x 1080]: 59.94 fps / 29.97 fps / 23.976
[1280 x 720]: 59.94 fps
[640 x 480]: 29.97 fps
Provided (±3 stops in 1/3-stop increments)
Type
TFT color, liquid-crystal monitor
Monitor Size
3.2 type
Pixels
Approx. 1.62 million dots
Brightness Control
Adjustable to one of five brightness levels
Interface Languages
25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese)
Display Format
  1. Single-image display
  2. 1 shot + information display
    • Simple information
    • Detailed information
      • Histogram
      • Lens information
      • Picture Style
      • Noise reduction
      • Correction data
  3. Index display
  4. Image rotate
Highlight Alert
Provided
Quick Control Dial
Provided
Image Protection
Provided
Compatible Printers
PictBridge-compatible printers
Printable Images
JPEG, RAW*, MP4 and MOV files are printable.
* Prints JPEG images used for display, which are taken on the same model.
DPOF
DPOF print ordering provided (Complies to DPOF Version 1.1)
Custom Controls (Camera Controls / Buttons Customization)
Functions can be assigned to the following controls (set in Custom Functions):
  • Shutter button
  • Main dial
  • Quick control dial
  • Cross button (up, down, left, right)
  • Control dial
  • M-Fn button
  • Movie button
  • Touchpad AF button
USB Terminal
Micro USB
Video Out Terminal
HDMI OUT Terminal Type D
HDMI output while recording available
Battery
LP-E17
Battery Life
Number of Still Image Shots (CIPA compliant)
Monitor On: Approx. 295 shots
Electronic Color Viewfinder On: Approx. 295 shots
Number of Still Image Shots (Eco Mode On)
Monitor On: Approx. 420 shots
Movie Recording Time (CIPA compliant)
Monitor On: Approx. 85 min.
Electronic Color Viewfinder On: Approx. 90 min.
Playback Time
Approx. 4 hr.
  • Time when playing back a slideshow of still images.
Dimensions (W x H x D)
Approx. 4.6 x 3.5 x 2.4 in. (115.6 x 89.2 x 60.6mm)
  • CIPA compliant.
Weight
Approx. 13.4 oz. / 380.0g (Body only)
Approx. 15.1 oz. / 427.0g (Including battery pack, memory card)
  • CIPA compliant.
Working
14-104°F / -10-40°C
Working Humidity
90% or less
EOS M5 EF-M 18-150mm IS STM Kit EOS M5 Camera Body EF-M 18-150mm f/3.5-6.3 IS STM Lens (Graphite) Battery Pack LP-E17 Battery Charger LC-E17 Neck Strap EM-300DB USB Cable IFC-600PCU
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EOS M5 EF-M 18-150mm IS STM Kit that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Download and view the EOS M Series Comparison Chart to see a side-by-side comparison of our EOS M cameras to better help you decide which camera is right for you.
This is to make Misc appear on the page when needed.
Sample Images
Shooting Mode Aperture Priority AE
Shutter Speed (Tv) 1
Aperture (Av) 8.0
ISO Speed 200
Lens EF-M 11-22mm f/4-5.6 IS STM
White Balance Shade
Picture Style Landscape
ISO speed is based on recommended exposure index.
Shutter Speed (Tv) 1/5
Aperture (Av) 4.0
ISO Speed 100
Lens EF-M 28mm f/3.5 Macro IS
White Balance Color Temperature (4600K)
Picture Style Fine Detail
Videos
Introducing the Canon EOS M5
Join Diana Bowe from Canon USA as she introduces the new EOS M5 camera with insight as to which kits the camera is available with as well as major features for both still and video modes such as combination IS, a built-in electronic viewfinder, Dual Pixel AF modes for both still and video, and much more.
Get Acquainted with the Canon EOS M5
Join Diana Bowe from Canon USA as she takes a more in-depth look at the new EOS M5 camera. Take the deeper dive as she reviews features such as high-speed shooting, frame rates, combination IS, a built-in electronic viewfinder, time-lapse movie mode, panning mode, Dual Pixel AF modes for both still and video, and much more.
Canon EOS M5 Sample Movie: "Southern Wind"
Experience how the EOS M5 camera can chronicle every part of your travels and help you relive the thrill of the adventure..
Canon Autofocus
For over 30 years, autofocus has been a vital tool for making sure your images are sharp. In this video, learn how Canon has continually created new breakthroughs in autofocus technology.
DISCLAIMERS
* Maximum image stabilization is achieved when using either the EF-M 18-150mm f/3.5-6.3 IS STM or the EF-M 15-45mm f/3.5-6.3 IS STM with the lens firmware update.
** Compatible with iOS® versions 8.0/8.1/8.2/8.3/8.4/9.0/9.1/9.2/9.3, Android™ smartphone and tablet versions 4.1/4.2/4.3/4.4/5.0/5.1/6.0. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
*** Compatible with Android™ smartphone and tablet versions 4.0/4.1/4.2/4.3/4.4/5.0/5.1/6.0.
****Compatible with select smartphone and tablet devices (Android™version 5.0 or later and the following iOS® devices: iPhone 4s or later, iPad 3rd gen. or later, iPod Touch 5th gen. or later) equipped with Bluetooth® version 4.0 or later and the Camera Connect App Ver. 1.3.20 or above. This application is not guaranteed to operate on all listed devices, even if minimum requirements are met.
^ When applications are active. Switch from Bluetooth® Smart to Wi-Fi® when viewing the images on the camera via the compatible smartphone.
 Return to Top
