Web Content Viewer
Actions
RC-IP100
PTZ & Remote Cameras
Item Code: 5231C004AA
Features
Control up to 100 Canon Supported cameras
The RC-IP100 controller provides IP control for 99 supported Canon PTZ cameras utilizing Canon’s new XC protocol. Additionally, through the serial port, the CR-X500 and other legacy Canon PTZ cameras that support the NU protocol can be simultaneously controlled.
Smooth PTZ movement and Precise Control for Professional Productions
It’s easy to achieve smooth PTZ movements with the accuracy and precise responsiveness of the joystick equipped on the RC-IP100. Camera operators could be confident when making on-air movements with the responsiveness of the controller – creating an effective video production.
Adjust Pan, Tilt, Zoom and Change Camera Function Settings Remotely
Control, adjust and set Pan, Tilt, and Zoom functions smoothly, register up to 100 presets per camera, and manage trace movement, picture quality settings and much more with the advanced RC-IP100. The trace function can store camera movements for instant recall with a push of a button. Furthermore, the controller covers a wide range of functionality and customization and is a superb option for supported Canon PTZ cameras.
Equipped with 7” diagonal Touch Screen, Control and Zoom Lever and 4 Customizable Buttons
The RC-IP100 Controller is equipped with a control lever, zoom lever and 7” LCD touch panel GUI for intuitive operation. There are also 2 User and 4 Function buttons that are programmable for even more customization.
Specifications
Power
12V DC (AC adapter power supply)
Dimensions
Width 350mm (13.7 in) x Height 110mm (4.3 in) x Depth 182 mm (7.1 in)
Weight
Approx. 2.1 kg (4.6 lbs.)
Operating Temperature
0 °C ~ 40 °C
Controller Supported Cameras
CR-N500, CR-N300 (IP)
Number of Connectable Cameras
1 unit (RS422)
100 units (*When RS422 is connected: 99 units)
Preset (Store/Play/Delete)
100 per camera (CR-N500, CR-N300)
Trace (Store/Play/Delete)
10 per camera (CR-N500, CR-N300)
Communication System
IPv4
Touch Panel
7-inch (diagonal) touch screen
Tally
D-Sub 9 pin
LAN
R -45 x 1 (10 BASE-T/100 BASE-TX)
Serial
RJ-45 x 1 (RS422)
RC-IP100 Remote Camera Controller
RC-IP100 Remote Camera Controller Kit Contents
  • RC-IP100 Remote Camera Controller
  • AC Adapter
  • AC Cable
  • Printed Documents
Videos
Introducing Canon's Family of 4K PTZ Cameras
Designed for integration into a wide range of applications, Canon's line of 4K UHD PTZ cameras capitalizes on Canon’s digital imaging and operational expertise from both professional camcorders and network cameras.
Introducing Canon's CR-N500 4K UHD PTZ Camera
Canon’s CR-N500 4K UHD PTZ camera produces exceptional image quality and is equipped with powerful features and functions to be utilized in many industries including House of Worship, Education, Broadcast, Corporate, Events and more.
This is to make Misc appear on the page when needed.
DISCLAIMERS
Warning
This is a class A product. In a domestic environment this product may cause radio inference in which case the user may be required to take adequate measures.
 Return to Top
