Web Content Viewer
Actions
XU-81W
PTZ & Remote Cameras
Item Code: 6143B004AA
Features
  • High Quality HDTV/SDTV Video Images
    The XU-81W has a single 1/3-inch CMOS imaging sensor with 2.1 Megapixels. Utilizing a Canon 20x HD Zoom Lens, it captures exceptional, high-quality images in full-HDTV format. Dynamic Range Compensation allows for shooting in environments with a high contrast of light and shade (such as a building lobby on a sunny day) by automatically correcting the contrast of the video according to the range of scene illumination.
  • Optimized Design for Broadcast Applications
    The XU-81W incorporates high operability optimized for broadcast applications. By pressing a single pre-set button on operation panel (provided optionally), the camera head pans and tilts very smoothly while simultaneously zooming, allowing for on-air movements similar to manually-operated cameras. Also, the XU-81W utilizes HD-SDI output, the standard in the broadcast market, which enables it to acquire beautiful, important images from a distance of up to 100m.
  • Waterproof and Dustproof for Indoor / Outdoor Applications
    With a waterproof and dustproof design featuring an IP55 enclosure rating, the XU-80W can be installed in challenging locations and is not affected by environmental conditions. The model with servo ND filter and wiper unit is also available as XU-81W for outdoor applications. The XU-80W is also equipped with washer.
  • Fast, Quiet, and Precise Pan & Tilt Movements
    The XU-81W is an exceptional PTZ camera which combines smooth, fast, and highly precise movement. In Normal Mode, operational movement has a noise rating of NC<30, making it extremely suitable for quiet indoor environments. In High Speed Mode, the movements of the pan-tilt mechanism are accelerated by 50%, which is valuable in circumstances where higher speed is required.
  • Upright/Inverted Mounting Option
    The XU-81W can be mounted upright or inverted (ceiling mount). In either position, the picture image will automatically flip when the tilt angle reaches 90°.
  • Compact Size and Weight
    The XU-81W includes a handle for convenient portability, and weighs only 14.5 lbs/6.6 kg, making setup almost effortless.
  • Locally Switchable Output/Control
    Users have the ability to select either the 1080i or 720p HD output to match their existing systems. Additionally, control can be toggled between RS-232 and RS-422, making the XU-81W extremely adaptable to new and existing multi-camera environments.
  • Low-light Capability/Night Mode
    When shooting under low-light conditions, the XU-81W can acquire extra brightness by using the slow-shutter function (frame accumulation). The black & white mode without the IR cut filter will also support shooting in near-darkness.
This is to make Misc appear on the page when needed.
Pan-Tilt Section:
Operation Condition Indoors / Outdoors
Operation Angle Pan: ±180° Tilt: +220°~-40°
Operation Speed Pan/Tilt: 0.3~40°/ sec (normal speed mode)
Pan/Tilt: 0.3~60°/ sec (high speed mode)
Preset Position 128
Stationary accuracy ±10' below
Video Output HD: BNC (HD-SDI), SD: BNC (Composite Monitor)
GENLOCK Input BNC (BB Sync/HD3value Sync)
Picture Flip Function Flip: ON/OFF
Control Interface D-sub9 (RS-232) ×1, 6pin(RS-422) ×1
Operating Temperature Ambient -15~40°C / ~90% (non-condensing)
Control Protocol NU Protocol
Communication Speed 9,600bps
Microphone Waterproof Microphone: lower part of the camera /0dBm/600 unbalanced output (with limiter)
Noise NC30 (40°/s), NC45 (60°/s) (when Wiper, ND Filter, and IRC Filter are not in operation)
Power Source DC12V±10%
Power Consumption 20W
Size (W×H×D) 217×311×217[mm] (without projection)
Weight 6.6kg (without ND Filter and Wiper)
HD-SDI Format 1080/59.94i / 1080/50i / 720/59.94p / 720/50p
SD Format NTSC/PAL (linked with the HD-SDI output)
GENLOCK Internal/External, Auto Switching
Waterproof/Dustproof Rating IP55
Wind-Velocity-Resistance Normal Operation: ~15m/s
Operation Possible: ~30m/s
Non Destruction: ~60m/s
Optional Outdoor Installation Washer
Camera & Lens:
Image Sensor 1/3CMOS
Focal Length / F-No. f=4.7-94mm / F1.6-3.5
Minimum Object Distance 1m (at Tele End)
Angle of View W59.4° - T3.0° (1920×1080)
Zoom Ratio 20x
Digital Zoom 12x
Focusing System AUTO/MANUAL/INF
Shutter Speed 2sec~1/10,000sec
Gain AUTO/MANU (0~+32dB)
White Balance AUTO/OUTDOOR/INDOOR/MANU/ATW
ND Filter OFF/1/32
Mounting Options Upright/Inverted
AE Control AUTO/MANU/NIGHT/Shutter priority/ Aperture priority
ICR ON/OFF
Manuals
Brochures
Loading...
Video
The XU-81 is a part of the EVERCAM XU series of HD PTZ cameras.
 Return to Top
