Web Content Viewer
Actions
Digital Rebel XTi
Support DSLR
Features
High performance digital SLR with 10.1 Megapixel Canon CMOS sensor and DIGIC II Image processor.
Canon's CMOS (complementary metal oxide semiconductor) sensor captures images with exceptional clarity and tonal range and offers the most pixels in its class. It offers many of the same new technologies as used by Canon's professional cameras to maximize each pixel's light gathering efficiency. Its APS-C size sensor creates an effective 1.6x field of view (compared to 35mm format). Canon's DIGIC 4 Image Processor dramatically speeds up all camera operations for intuitive operation and offers improvements in both fine detail and natural color reproduction. It works in concert with the EOS Rebel T1i's image sensor to achieve unprecedented levels of performance in all lighting situations.
With the EOS Rebel T1i, analog to digital signal conversion is executed by a 14-bit processor, which generates digital data with incredibly smooth tones. A feature that originally appeared in top-of-the-line pro digital SLR cameras, the 14-bit conversion gives incredibly smooth transitions from light to dark colors with far less risk of "banding." A sky at sunset is a perfect example. With this rich 14-bit gradation, the EOS Rebel T1i offers RAW images of the highest quality that can be processed with Canon's Digital Photo Professional software. Even JPEG files, which are always finished at 8-bits per channel, use the full 14-bit conversion initially to generate the best possible color and tonal detail.
Large 2.5-inch LCD monitor with new user interface and wide viewing angle. Fast 3 frames-per-second shooting with 27-frame burst and a 0.2 second startup time. High precision, wide area 9-point autofocus system.
The EOS Rebel T1i shoots brilliant video, even in full high definition. By simply selecting Movie mode on the EOS Rebel T1i's mode dial, the camera's 3.0-inch LCD lights up, and it's ready to go. Shooting is at a frame rate of 30 fps when shooting SD or HD quality video (640 x 480 and 1280 x 720 pixels, respectively) and at a frame rate of 20 fps in Full HD (1920 x 1080 pixels) recording. Sound is recorded through the camera's built-in microphone. Playback modes are simple to access, and all Live View AF features can be used in shooting video.
Picture Style settings for a broad range of control over color, contrast and sharpening. Print/Share button featuring advanced camera direct capabilities for greater user control while direct printing.
With Live View Function on the EOS Rebel T1i, you can enjoy nearly every camera function available in normal shooting, all with the convenience of composing on the camera's brilliant 3.0-inch LCD monitor. You can zoom in and navigate the composition and there's even a grid overlay for architectural shots. Live View focusing modes include Quick mode, Live mode and Face Detection AF mode and these are easily selectable through the convenient Live View Function menu.
Strong, lightweight body with the EOS Integrated Cleaning System including a Self Cleaning Sensor Unit
The EOS Digital Rebel XTi not only sports a newly-refined body with better ergonomics and an improved grip, but it also has some of Canon's most advanced improvements in dust reduction. No matter how careful photographers may be to change lenses in dust free areas and to keep their equipment as clean as possible, dust often ends up on their cameras' sensors, creating distracting spots on recorded images. The Digital Rebel XTi's integrated hardware and software solutions make trouble with dust a thing of the past. The Digital Rebel XTi is the first digital EOS SLR camera to feature this important technology: by ensuring the sensor is free of dust and debris, the camera delivers a cleaner image. Self Cleaning Sensor Unit<br/> To combat against stray dust that enters the camera and adheres to the image sensor during a lens change, the Digital Rebel XTi features an all-new, Canon-designed Self Cleaning Sensor Unit. The low pass filter cleans itself automatically with ultrasonic vibrations, removing dust from the sensor assembly. Dust Delete Data Detection<br/> Dust that has been missed by the Integrated Self Cleaning Sensor Unit can also be erased with software included in Digital Photo Professional (DPP) Version 2.2. The Digital Rebel XTi's imaging sensor is able to single out the dust particles on its surface, then plots out their location coordinates within the image. This data is transmitted along with the image, whether JPEG or RAW, and can be either manually or automatically erased in Canon's DPP 2.2. This added software option ensures the cleanest possible image, perfect for printing or archiving.
Fully compatible with over 60 EF and EF-S Lenses and a wide range of EOS System accessories
EF & EF-S Lenses<br/> The EOS Digital Rebel XTi is compatible with all Canon lenses in the EF lineup, ranging from ultra-wide angle to super telephoto lenses, and including Canon's EF-S series lenses, manufactured specifically for Canon&#8217;s APS-C sized digital sensor. Canon lenses employ advanced optical expertise and micron-precision engineering to deliver unprecedented performance in all facets of the photographic process. Aspherical optics and fluorite elements, for example, are featured in the universally acclaimed L Series lenses, and Canon's Image Stabilizer technology in select lenses minimizes the effect of camera shake. Through Canon lenses, photographers can truly maximize the quality and liberating performance of the EOS Digital Rebel XTi. Flash Photography<br/> The EOS Digital Rebel XTi features the acclaimed E-TTL II flash metering system. Whether using its flush-mounted integral flash (guide no. of 43 ft./13m at ISO 100), or any of the flashes in the EX Speedlite line, E-TTL II provides reliable flash output through numerous exposures. Canon's Speedlite 430EX is perfectly suited to the EOS Digital Rebel XTi. It includes a maximum guide number of 141 ft./43m at ISO 100, and when mounted on the camera, automatically compensates for the camera&#8217;s sensor size, enabling high output flash, with more flashes per charge. It includes an AF-assist Beam, which works in conjunction with the EOS Digital Rebel XTi&#8217;s focusing system, and automatically sends color temperature information to the camera when the flash fires, for more accurate white balance rendition with flash photography. Additional Accessories<br/> In addition to Canon's EF lenses and Speedlite flashes, many other accessories are designed by Canon to work perfectly with the EOS Digital Rebel XTi. The Battery Grip BG-E3 adds a vertical shutter release, and can hold two NB-2LH Battery Packs for increased shooting capacity. Canon's Semi Hard Case EH18-L can accommodate the EOS Digital Rebel XTi with a small zoom lens (an EF-S 18-55mm is included in the EOS Digital Rebel XTi Lens Kit). Software Canon EOS Digital Solution Disk (Version 13.0)<br/> The EOS Digital Rebel XTi comes bundled with the updated Canon EOS Digital Solution Disk (Version 13.0), which features powerful software programs designed to extend the EOS experience to the computer. These include Canon's ZoomBrowser EX for Windows&#174; (Version 5.7), ImageBrower for Macintosh&#174; OS X (Version 5.7), Digital Photo Professional (Version 2.2), Canon&#8217;s EOS Utility (Version 1.1) and PhotoStitch (Version 3.1). Each application is designed to perfect captured images, and streamline the digital workflow. Digital Photo Professional (Version 2.2) is an image processing program that enables high-speed RAW image processing, high-speed previewing for real-time image adjustment and support for sRGB, Adobe RGB and Wide Gamut RGB color spaces. Because it&#8217;s CMS (Color Management System) compatible, Digital Photo Professional allows for easy image layout and printing in Adobe RGB in conjunction with Easy-PhotoPrint and PictBridge printers. It also features the Digital Rebel XTi&#8217;s Dust Delete Data Detection tool for cleaner images. EOS Utility (Version 1.1) for Macintosh or Windows handles the connection between the camera and computer, whenever they&#8217;re connected via USB. It allows remote controlled shooting from the computer, handles downloading of images from the camera to the computer, and allows seamless linking to either Canon&#8217;s ZoomBrowser/ImageBrowser or Digital Photo Professional software once images have been copied to the hard drive. Furthermore, it&#8217;s used to upload settings back into a USB-connected camera. ZoomBrowser EX (Version 5.7) for Windows and ImageBrowser (Version 5.7) for Mac OS X are the easy, user-friendly options for viewing and editing of JPEG and even RAW image files. Both allow viewing of numerous types of images including finished TIFF and BMP files. Both also have a variety of search options for finding images, allow re-naming of single images or batches of files, and offer a variety of options for printing without using a separate image-editing program.
Digital Rebel XTi Kit Contents
Digital Rebel XTi Kit Contents Digital Rebel XTi Body (Silver of Black) (A) Eyecup Ef (not shown) Wide Strap EW-100DBII (C) Video Cable VC-100 (D) USB Interface Cable IFC-400PCU (E) Battery Pack NB-2LH (F) Battery Charger CB-2LW (G) EOS Digital Solution Disc and Instruction Manuals (H) "Great Photography is Easy" Booklet and "Do More with Macro" Booklet (not shown)
Specifications
Type
Type
Digital AF/AE SLR with built-in flash
Recording Media
CompactFlash (CF) Card Type I & II
Image Format
0.87 x 0.58 in./22.2 x 14.8mm (APS-C size sensor)
Compatible Lenses
Canon EF and EF-S lenses
Lens Mount
Canon EF mount
Image Sensor
Type
High-Sensitivity, high-resolution, single-plate, CMOS sensor
Pixels
Approx. 10.10 megapixels
Total Pixels
Approx. 10.50 megapixels
Aspect Ratio
3:2 (Horizontal : Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
Fixed position in front of the CMOS sensor
Dust Deletion Feature
(1) Automatic sensor cleaning
(2) User-activated sensor cleaning
(3) Dust Delete Data appended to image data
Recording System
Recording Format
JPEG, RAW, and RAW+JPEG simultaneous recording provided. The RAW and JPEG images are saved as separate files in the CF card.
Image Format
JPEG, RAW (Canon .CR2)
File Size
(1) Large/Fine: Approx. 3.8MB (3,888 x 2,592)
(2) Large/Normal: Approx. 2.0MB (3,888 x 2,592)
(3) Medium/Fine: Approx. 2.3MB (2,816 x 1,880)
(4) Medium/Normal: Approx. 1.2MB (2,816 x 1,880)
(5) Small/Fine: Approx. 1.3MB (1,936 x 1,288)
(6) Small/Normal: Approx. 0.7MB (1,936 x 1,288)
(7) RAW: Approx. 9.8MB (3,888 x 2,592)
File Numbering
(1) Continuous numbering (2) Auto reset (3) Manual reset (the image numbering is reset to 0001, a new folder is created where subsequent images are saved)
Color Space
Selectable between sRGB and Adobe RGB
Picture Style
Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Def. 1-3
Interface
USB 2.0 Hi-Speed, mini-B port. NTSC/PAL for video output
White Balance
Settings
Auto, Preset (Daylight, Shade, Cloudy, Tungsten Light, White Fluorescent Light, Flash), Manual (Custom, or user-set Color Temperature)
Auto White Balance
Auto white balance with the image sensor
Color Temperature Compensation
White balance bracketing: +/- stops in 1-stop increments
White balance correction: blue/amber bias +/- 9 levels, magenta/green bias +/- 9 levels
Color Temperature Information Transmission
Provided
Viewfinder
Type
Eye-level SLR with pentamirror
Coverage
Approx. 95% horizontally and vertically
Magnification
0.8x (-1 dpt with 50mm lens at infinity)
Eye Point
Approx. 21mm
Dioptric Adjustment Correction
-3.0 to +1.0 diopter
Mirror
Quick-return half mirror (Transmission: reflection ratio of 40:60)
Viewfinder Information
AF (AF points, focus confirmation light), Exposure (shutter speed, aperture, exposure level, AE lock, exposure compensation, AEB level, bulb), Flash (flash ready, red-eye reduction lamp on, high-speed sync, FE lock, FEB shooting, flash exposure compensation, insufficient flash warning during FE lock), White balance correction, Maximum burst, CF card full warning, CF card error warning, No CF card warning
Depth Of Field Preview
Enabled with depth-of-field preview button (with Speedlite 580EX, 430EX, MR-14EX or MT-24EX; pressing the depth-of-field preview button fires a modeling flash)
Autofocus
Type
TTL-CT-SIR with CMOS sensor
AF Points
9 AF points
AF Working Range
EV -0.5-18 (ISO 100 at 73°F/23°C)
Focusing Modes
Autofocus: One-Shot AF, Predictive AI Servo AF, AI Focus AF (automatic switching between One-Shot/Predictive AI Servo AF); Manual Focus (MF)
AF Point Selection
Automatic selection, Manual AF point selection
Selected AF Point Display
Superimposed on viewfinder and LCD monitor
AF Assist Beam
Intermittent firing of built-in flash (Emitted automatically when necessary under low light, and linked to all 9 AF points. Not emitted in the Landscape, Sports and Flash OFF modes)
Exposure Control
Metering Modes
Max. aperture TTL metering with 35-zone SPC
(1) Evaluative metering (linked to all AF points)
(2) Partial metering (approx. 9% at center of viewfinder)
(3) Center-weighted average metering
Metering Range
EV 1-20 (ISO 100 at 73°F/23°C with EF 50mm f/1.4 USM lens)
ISO Speed Range
Basic Zone: automatically set by the camera
Creative Zone: equivalent to ISO 100-1,600
Exposure Compensation
(1) User-set with multi-controller (2) AEB (Auto Exposure Bracketing)
Bracketing range: +/- 2 stops in 1/3- or 1/2-stop increments
AE Lock
Auto: Applied in One-Shot AF mode with evaluative metering when focus is achieved
User-set: Applied with AE lock button
Shutter
Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled 1/4000 to 30 sec. (1/3- and 1/2-stop increments), X-sync at 1/200 sec. Soft-touch electomangetic release; shutter lag time approx. 100 msec. 10 sec. delay, 2 sec. delay with C.Fn-7-1 (mirror lockup) Remote control with Remote Switch RS-60E3 or Wireless Remote Controllers RC-1/RC-5
Type
Shutter Speeds
Shutter Release
Self Timer
Remote Control
Built in Flash
Type
Auto pop-up, retractable, built-in flash in the pentaprism
Guide Number
43 ft./13m (ISO 100)
Recycling Time
Approx. 3 sec.
Flash Ready Indicator
Flash-ready indicator lights in viewfinder
Flash Coverage
17mm lens focal length (equivalent to 27mm in 135 format)
FE Lock
Provided
Flash Exposure Compensation
+/-2 stops in 1/3- and 1/2-stop increments
External Speedlite
EOS Dedicated Speedlite
E-TTL II autoflash with EX Series Speedlites
Zooming to Match Focal Length
Provided
PC Terminal
N/A
Drive System
Drive Modes
Single, Continuous, Self-timer/Remote control
Continuous Shooting Speed
Approx. 3 fps (at shutter speed of 1/250 sec. or faster)
Maximum Burst
JPEG: approx. 27 frames (Large/Fine)
RAW: approx. 10 frames
RAW+JPEG: approx. 8 frames (Large/Fine)
LCD Monitor
Type
TFT color, liquid-crystal monitor
Monitor Size
2.5 in. diagonal with a viewing angle of approx. 160° vertically and horizontally
Pixels
Approx. 230,000 pixels
Coverage
Approx. 100%
Brightness Control
7 levels provided
Interface Languages
18
Playback
Display Format
Single image, 9-image index, Magnified zoom (approx. 1.5x to 10x), Auto play, Auto review right after shooting, Histogram, Rotate, Jump
Highlight Alert
In the single image (INFO) display mode, the highlight portions containing no image information will blink
Histogram
Brightness, RGB
Image Protection and Erase
Protection
A single image can be protected or unprotected
Erase
A single image or all images stored in a CF card can be erased if they are unprotected
Direct Printing
Compatible Printers
PictBridge, CP Direct, and Bubble Jet Direct-compatible printers
Printable Images
JPEG images (DPOF printing possible)
Easy Print feature
Provided
DPOF: Digital Print Order Format
DPOF
Version 1.1 compatible
Direct Image Transfer
Compatible Images
JPEG and RAW images
*Images to be used for wallpaper on the personal computer screen must be JPEG images
Customization
Custom Functions
11 Custom Functions with 29 settings
Power Source
Battery
Battery Pack NB-2LH, quantity 1
*AC power enabled with AC Adapter ACK-DC20
*With Battery Grip BG-E3, size-AA batteries can be used
Battery Life
[Number of shots: Approx.]
*The above figures apply when a fully-charged Battery Pack NB-2LH is used.
*The figures above are based on CIPA (Camera & Imaging Products Association) testing standards
Battery Check
Automatic
Power Saving
Provided; power turns off after 30 sec., 1, 2, 4, 8, or 15 min.
Date/Time Battery
One CR2016 Lithium Battery
Start-up Time
Approx. 0.2 sec.
Dimensions and Weight
Dimensions (W x H x D)
4.98 x 3.71 x 2.56 in./126.5 x 94.2 x 65mm
Weight
18 oz./510g (body only)
Operating Environment
Working Temperature Range
32-104°F/0-40°C
Working Humidity Range
85% or less
Battery Pack
Type
For NB-2LH
Rechargeable lithium-ion battery
Rated Voltage
7.4 V DC
Battery Capacity
720 mHh
33.3 x 16.2 x 45.2mm/1.3 x 0.6 x 1.8 in.
Weight
Approx. 43 g/1.5 oz.
Battery Charger
Type
For CB-2LW
Compatible Battery
Battery Pack NB-2LH
Recharging Time
Approx. 105 min.
Rated Input
100 - 240 V AC, 50/60 Hz
Rated Output
8.4 V DC
0°C-40°C/32°F - 104°F
85% or less
91 x 56 x 22.5mm/3.6 x 2.2 x 0.9 in.
Weight
Approx. 68 g/2.4 oz.
Kit Lens
Angle of View
For EF-S 18-55mm f/3.5-5.6 II
Diagonal extent: 74°20' - 27°50'
Horizontal extent: 64°30' - 23°20'
Vertical extent: 45°30' - 15°40'
Lens Construction
11 elements in 9 groups
Minimum Aperture
f/22 - 36
Closest Focusing Distance
0.28m/0.92 ft. (from image sensor plane)
Maximum Magnification and Field of View
18mm: 0.10x (248 x 161mm/9.8 x 6.3 in.)
55mm: 0.28x (81 x 54mm/3.2 x 2.1 in.)
Filter Size
58mm
Hood
EW-60C
Diameter x Length
68.5 x 66mm/2.7 x 2.6 in.
Weight
Approx. 190 g/6.7 oz.
Case
LP814
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Digital Rebel XTi that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Loading...
 Return to Top
