Web Content Viewer
Actions
EOS 20Da
Support DSLR
Specifications
Type
Type
Digital, single-lens reflex, AF/AE camera with built-in flash
Recording Media
Type I and II CF card
Image Format
22.5mm x 15.0mm
Compatible Lenses
Canon EF and EF-S lenses (35mm-equivalent focal length is equal to approx.1.6 times the marked focal length.)
Lens Mount
Canon EF mount
Image Sensor
Type
High-sensitivity, high-resolution, single-plate CMOS sensor
Pixels
Approx. 8.25 megapixels (3520x2344)
Total Pixels
Approx. 8.50 megapixels (3600x2360)
Aspect Ratio
3:2
Color Filter System
RGB primary color filter
Low Pass Filter
Located in front of the image sensor, non-removable
Recording System
Recording Format
JPEG (except when Adobe RGB is set) supporting Design rule for Camera File system and RAW
Image Format
JPEG and RAW (12-bit)
File Size
(1) Large/Fine: Approx. 3.6 MB (3504x2336 pixels)
(2) Large/Normal: Approx. 1.8 MB (3504x2336 pixels)
(3) Medium/Fine: Approx. 2.2 MB (2544x1696 pixels)
(4) Medium/Normal: Approx. 1.1 MB (2544x1696 pixels)
(5) Small/Fine: Approx. 1.2 MB (1752x1168 pixels)
(6) Small/Normal: Approx. 0.6 MB (1752x1168 pixels
(7) RAW (3504x2336 pixels): 8.7MB RAW + Small/Normal: Approx. 9.3 MB RAW + Small/Fine: Approx. 9.9 MB RAW + Medium/Normal: Approx. 9.8 MB RAW + Medium/Fine: Approx. 10.9 MB RAW + Large/Normal: Approx. 10.5 MB RAW + Large/Fine: Approx. 12.3 MB * Exact file sizes depend on the subject and ISO speed.
File Numbering
Consecutive numbering, auto reset
Color Space
sRGB, Adobe RGB
Two sets of standard parameters plus up to three sets of custom processing parameters (4 items with 5 settings each) as well as monochrome photography with custom parameters can be set.
White Balance
Settings
Auto, Daylight, Shade, Cloudy, Tungsten, Fluorescent, Flash, Manual Color Temperature Setting and Custom
Auto White Balance
Via image sensor data
Color Temperature Compensation
+/- 9 steps in 1-step increments
Viewfinder
Type
Eye-level pentaprism
Coverage
Approx. 95% vertically and horizontally (Coverage against JPEG Large)
Magnification
0.9x (-1 dpt. with 50mm lens at infinity)
Eye Point
20mm
Dioptric Adjustment Correction
-3.0 - +1.0 dpt.
Focusing Screen
Fixed, Precision Matte screen
Mirror
Quick-return half mirror (Transmission: reflection ratio of 40:60. No mirror cut-off with lenses up to EF 600mm f/4)
Viewfinder Information
AF (AF points, focus confirmation light), exposure (shutter speed, aperture value, manual exposure, AE lock, exposure compensation amount, AEB level, partial metering area), flash (flash ready, red-eye reduction lamp on, high-speed sync, FE lock, flash exposure compensation), warnings (exposure warning, improper FE lock warning, CF card full warning, CF card error warning, no CF card warning, busy), maximum burst for continuous shooting, shots remaining.
Depth Of Field Preview
Enabled with depth-of-field preview button
Autofocus
Type
TTL-CT-SIR with a CMOS Sensor (TTL Cross Type secondary image registration)
AF Points
9
AF Working Range
EV 0.5-18 (at 20° C, ISO 100)
Focusing Modes
One-Shot AF, Predictive Al Servo AF, AI Focus AF, Manual focus (MF)
AF Point Selection
Automatic selection, Manual AF point selection
Active AF Point Indicator
Superimposed in viewfinder and indicated on LCD panel
AF Assist Beam
Intermittent firing of built-in flash
Effective Range
Approx. 4.0m/13.1 ft. at center, approx. 3.5m/11.5 ft. off-center
Exposure Control
Metering Range
EV 1-20 (at 20° C with 50mm f/1.4 lens, ISO 100)
ISO Speed Range
Basic Zone modes: Automatic
Exposure Compensation
AEB: +/-2 stops in 1/2- or 1/3 stop increments
AE Lock
Auto: Applied when focus is achieved in the One Shot AF mode with evaluative metering. Manual: Applied with AE lock button
Shutter
Vertical-travel focal-plane shutter with all speeds electronically controlled 1/8000 - 30 sec. (1/2- or 1/3-stop increments), bulb, X-sync at 1/250 sec. Soft-touch electromagnetic release 10 sec. delay N3-type remote control
Type
Shutter Speeds
Shutter Release
Self Timer
10 sec. delay
Remote Control
Built in Flash
Type
Auto pop-up E-TTL II autoflash (retractable)
Guide Number
13 (ISO 100m), 43 (ISO 100 ft.)
Recycling Time
Approx. 3 sec.
Flash Ready Indicator
Flash-ready indicator lights in viewfinder
Flash Coverage
17mm lens angle covered
Flash Exposure Compensation
+/-2 stops in 1/2- and 1/3 stop increments
External Speedlite
EOS Dedicated Speedlite
E-TTL II autoflash set with EX-series Speedlites
PC Terminal
Provided
Drive System
Drive Modes
Single frame, Continuous, Self-timer
Continuous Shooting Speed
Approx. 5 fps (at 1/250 sec. or faster speeds)
Maximum Burst
23 shots (Large/Fine JPEG) or 6 shots (RAW or RAW+JPEG)
LCD Monitor
Type
TFT color liquid-crystal monitor
Monitor Size
1.8 in.
Pixels
Approx. 118,000 pixels
Coverage
Approx. 100% for JPEG images
Brightness Control
5 levels
Playback
Display Format
Single image, 9-image index, Magnified zoom, Auto play, Auto play right after shooting
Highlight Alert
In the single image and single image (Info) modes, any overexposed highlight areas with no image information will blink
Image Protection and Erase
Protection
Single images can be protected or unprotected
Menus
Menu Categories
Shooting menu: Red
Playback menu: Blue
Setup menu: Yellow
LCD Monitor Language
12 languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified Chinese, and Japanese)
Firmware Update
Update possible by the user
Power Source
Battery
One Battery Pack BP-511A/BP-511/BP-512/BP-514AC power can be supplied via the optional DC coupler.
Battery Life
At 68° F / 20° C: 650 (No Flash), 500 (50% Flash Use), At 32° F / 0° C: 500 (No Flash), 400 (50% Flash Use). These figures apply when a fully-charged Battery Pack BP-511A/BP-511/BP-512/BP-514 is used.
Battery Check
Automatic
Power Saving
Provided. Power turns off after 1, 2, 4, 8, 15, or 30 min
Dimensions and Weight
Dimensions (W x H x D)
5.7 x 4.2 x 2.8 in. / 144 x 105.5 x 71.5mm
Weight
24.2 oz / 685 g (body only)
Operating Environment
Working Temperature Range
32 - 104° F / 0 - 40° C
Working Humidity Range
85% or lower
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EOS 20Da that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
