Web Content Viewer
Actions
EOS 5D
Support DSLR
Features
Small, lightweight full-frame digital SLR with a 12.8 Megapixel CMOS Sensor and superb image quality.
The EOS 5D's full-frame CMOS sensor records 4,368 x 2,912 pixels-that's 12.8 Megapixels, larger than many other companies' top-of-the-line sensors. The same size as a 35mm image on a traditional camera, the sensor operates without a conversion factor. This is perfect for taking advantage of the spectacular optics in Canon's L-series, and will be a joy for wide-angle enthusiasts who can make the most of their wide-angle lenses. This new CMOS sensor, designed in-house by Canon, provides smooth, high-resolution images similar to the EOS-1Ds Mark II but in a more compact body. Two automatic noise reduction features maximize the effectiveness of the EOS 5D's on-chip noise reduction. Noise reduction can be activated when noise is detected or it will simply come into play on any exposure of 1 second or longer.
* As of August 2005.
DIGIC II Image Processor for outstanding image quality and performance - 3.0 fps for up to 60 consecutive JPEG or 17 RAW frames in a burst.
The EOS 5D's new 12.8 Megapixel sensor is driven by the revolutionary DIGIC II Image Processor for unprecedented performance and image quality. Thanks to the DIGIC II Image Processor, the EOS 5D is capable of shooting up to 3 frames-per-second for up to 60 JPEG or 17 RAW images. The information captured by the sensor is processed and assembled into images of exceptional clarity and resolution. Photographers can expect precise, natural colors, spot-on white balance and speed in any number of lighting situations. By handling larger volumes of image data, the DIGIC II Image Processor also contributes to lower power consumption: photographers will discover that they can shoot all day with the EOS 5D without having to change the battery!
New larger 2.5 inch LCD screen can be viewed even at extreme angles up to 170&deg.
The EOS 5D has been designed to provide the photographer with instant feedback, saving valuable time when reviewing images. A new 2.5 inch LCD screen with approximately 230,000 pixels not only displays more information, it can be viewed at a far greater angle (170°) than many other conventional LCD screens. The full-featured shot information screen not only provides an RGB histogram, it displays the AF frames used. Magnification to check exposure and critical focus has never been faster. It is also simple to jump quickly in image intervals up to 100. Menus are accessed at the touch of a button, and feature larger, easier to read text than previous models. Whether changing color parameters, setting up custom functions, organizing folders, setting white balance, or any other feature, the new screen is designed with the professional in mind. Photographers get to their information quickly, so they never lose a shot.
New "Picture Style" function for superior command of in-camera color, contrast and sharpness.
"Picture Style" settings simulate the characteristics of different film styles, including Snapshot mode, for punchy, print-from-the-camera color, Portrait mode, for softer, more natural skin tones; Landscape, for vivid blues and greens and overall sharpness, plus Neutral, Faithful and Monochrome, which can be customized to emulate color filters with black and white film.
High-precision 9-point AF with 6 additional Supplemental points surrounding the center point for superior focus tracking.
In addition to 9 different AF points for locking focus on subjects, even if they are not in the center of the composition, the EOS 5D features 6 Supplemental points around the center AF point which help to ensure an even greater degree of focus accuracy when tracking a moving subject. This feature is significant for sports photographers, as well as anyone who needs to keep focus locked on an unpredictable subject. The Supplemental AF points are not displayed in the viewfinder, and they cannot be manually selected. However, they are used in AI Servo AF mode when the EOS 5D is set for automatic focusing point selection, and also when the center focusing point is selected together with Custom Function 17-1.
Strong and light magnesium-alloy body with new shutter durability-tested to 100,000 exposures.
The EOS 5D has a solid and substantial feel that complements its compact dimensions. The camera body is constructed of a magnesium-alloy known for its lightweight and ultra-rigid strength. The EOS 5D also boasts a newly developed, high-speed and durable shutter unit that was designed to meet the demanding requirements of a full frame sensor in a relatively compact body. With a top shutter speed of 1/8000 sec. and with a remarkable 100,000-cycle shutter life, it truly is a camera built to professional standards.
Compatible with over 50 Canon EF lenses and most EOS System accessories.
EF Lenses
The EOS 5D is compatible with all Canon lenses in the EF lineup (except EF-S lenses), ranging from 14mm Ultra-Wide to 600mm Super Telephoto lenses. The EF lineup employs advanced optical know-how and sub-micron precision engineering to deliver unprecedented performance in all facets of the photographic process. Aspherical optics and Fluorite elements, for example, are featured in the universally acclaimed L-series Lenses while Canon's Image Stabilization feature minimizes the effect of camera shake.
Flash Photography
The EOS 5D features Canon's E-TTL II flash metering system introduced with the EOS-1D Mark II. E-TTL II provides consistently accurate flash exposure from shot to shot. Canon's Speedlite 580EX and 430EX are perfectly suited to the EOS 5D. They include an AF-assist Beam, which works in conjunction with the EOS 5D's focusing system, and automatically sends color temperature information to the camera when the flash fires, for more accurate color rendition with flash photography.
Additional Accessories
In addition to Canon's EF lenses and EX Speedlites, several other accessories are designed to work specifically with the EOS 5D. The Battery Grip BG-E4 adds a vertical shutter release, and is compatible with up to two of Canon's Lithium-ion battery packs, or alternatively a set of six AA-size batteries, for increased shooting capacity and greater convenience when traveling.
Data Verification Kit DVK-E2
Canon's Data Verification DVK-E2 is an option for the EOS-1Ds Mark II, EOS-1D Mark II N, EOS 5D and EOS 20D. Like its predecessor, this kit can verify whether or not a photo is an untouched original. Its use of a Secure Mobile (SM) card reader, instead of an IC card reader, makes it more compact and affordable than the previous version.
Wireless File Transmitter WFT-E1A
This accessory allows photographers to transmit images from their cameras directly to a computer over a local area network (LAN). It is compatible with the EOS-1Ds Mark II, 1D Mark II N, and 5D, with the EOS 20D through firmware upgrades. It includes a mini-antenna and IEEE1394 cable.
Specifications
Type
Type
Digital AF/AE SLR
Recording Media
CompactFlash (CF) Card Type I and II
Image Format
1.41 x 0.94 in./35.8 x 23.9mm
Compatible Lenses
Canon EF lenses (except EF-S lenses)
Lens Mount
Canon EF mount
Image Sensor
Type
High-sensitivity, High-resolution, Single-plate CMOS Sensor
Pixels
Approx. 12.8 megapixels
Total Pixels
Approx. 13.3 megapixels
Aspect Ratio
3:2 (Horizontal : Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
Fixed position in front of the image sensor
Recording System
Recording Format
JPEG, RAW and RAW+JPEG simultaneous recording provided. Backup image recording enabled (Same image recordable on CF card standards)
Image Format
JPEG, RAW
File Size
(1) Large/Fine: Approx. 4.6MB (4,368 x 2,912) (2) Large/Normal 2.3MB (4,368 x 2,912) (3) Medium/Fine: Approx. 2.7MB (3,168 x 2,112) (4) Medium/Normal: Approx. 1.4MB (3,168 x 2,112) (5) Small/Fine: Approx. 2.0MB (2,496 x 1,664) (6) Small/Normal: Approx. 1.0MB (2,496 x 1,664) (7) RAW: Approx. 12.9MB (4,368 x 2,912)
Folders
Folder creation/selection enabled
File Numbering
(1) Continuous numbering (2) Auto reset (3) Manual reset
Color Space
Selectable between sRGB and Adobe RGB
Picture Style
Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined 1, 2, 3
Interface
Hi-Speed USB (Print/PTP/PC connect, selectable)
Video output (NTSC/PAL)
White Balance
Settings
Auto, Preset (Daylight, Shade, Cloudy/Twilight/Sunset, Tungsten Light, White Fluorescent Light, Flash), Manual (Custom, Color Temperature)
Auto White Balance
Auto white balance with the image sensor
Color Temperature Compensation
White balance bracketing: +/-3 stops in full-stop increments
White Balance Correction: Blue/Amber bias +/- 9 levels
Magenta/Green bias +/- 9 levels
Blue/Amber bias and Magenta/Green bias cannot be set together during White Balance Bracketing
Color Temperature Information Transmission
Provided
Viewfinder
Type
Eye-level SLR with fixed pentaprism
Coverage
Approx. 96% horizontally and vertically (coverage against JPEG Large)
Magnification
0.71x (-1 dpt with 50mm lens at infinity)
Eye Point
20mm
Dioptric Adjustment Correction
-3.0 to +1.0 diopter
Focusing Screen
Standard focusing screen: Ee-A
Mirror
Quick-return half mirror (Transmission: reflection ratio of 40:60, no mirror cut-off with EF 600mm f/4 or shorter lens)
Viewfinder Information
AF (AF points, focus confirmation light), Exposure (shutter speed, aperture, spot metering circle, exposure level, AE lock, exposure compensation, AEB level), Flash (flash ready, red-eye reduction lamp on, high-speed sync, FE lock, FEB shooting, flash exposure compensation, insufficient flash warning during FE lock), White balance correction, Maximum burst, CF card full warning, CF card error warning, No CF card warning
Depth Of Field Preview
Enabled with depth-of-field preview button (with Speedlite 580EX, 550EX, 430EX, MR-14EX, or MT-24EX, pressing the depth-of-field preview button fires a modeling flash)
Eyepiece Shutter
None (eyepiece cover provided on strap)
Autofocus
Type
TTL-CT-SIR AF-dedicated CMOS Sensor
AF Points
9 AF points (plus 6 invisible Supplemental AF points)
AF Working Range
EV -0.5-18 (at ISO 100 at 20°C/68°F)
Focusing Modes
Autofocus, (One-Shot AF, Predictive AI Servo AF, AI Focus AF (automatic switching between One-Shot/Predictive AI Servo AF)), Manual Focus (MF)
AF Point Selection
Manual selection, Automatic selection
Selected AF Point Display
Superimposed in viewfinder and indicated on LCD screen
AF Assist Beam
Emitted by the dedicated Speedlite
Exposure Control
Metering Modes
Max. aperture TTL metering with 35-zone SPC
(1) Evaluative metering (link to all AF points)
(2) Partial metering (approx. 8% of viewfinder)
(3) Spot metering (approx. 3.5% of viewfinder)
(4) Center-weighted average metering
Metering Range
EV 1-20 (at 68°F/20°C with 50mm f/1.4 lens, ISO 100)
ISO Speed Range
Equivalent to ISO 100-1600 (in 1/3-stop increments), ISO speed can be expanded to ISO 50 and 3200
Exposure Compensation
(1) Manual, (2) AEB (Auto Exposure Bracketing)Bracketing range: ±2 stops in 1/2- or 1/3-stop increments
AE Lock
Auto: Applied in One-Shot AF mode with evaluative metering when focus is achieved
Manual: By AE lock button
Shutter
Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled 1/8000 to 30 sec. (1/3-stop increments), X-sync at 1/200 sec. Soft-touch electromagnetic release 10 sec. delay Remote control with N3 type terminal
Type
Shutter Speeds
Shutter Release
Self Timer
10 sec. delay
Remote Control
External Speedlite
EOS Dedicated Speedlite
E-TTL II autoflash with EX-series Speedlite
Zooming to Match Focal Length
Provided
Flash Exposure Compensation
±2 stops in 1/3- or 1/2-stop increments
FE Lock
Provided
PC Terminal
Provided
Drive System
Drive Modes
Single, Continuous (approx. 3 fps), Self-timer
Continuous Shooting Speed
Approx. 3 fps (at 1/250 sec. or faster for all recording quality settings)
Maximum Burst
JPEG: Approx. 60 frames (JPEG/Large)
RAW: Approx. 17 frames
RAW+JPEG: Approx. 12 frames
LCD Monitor
Type
TFT color liquid-crystal monitor
Monitor Size
2.5 in.
Pixels
Approx. 230,000
Coverage
100% for JPEG images
Brightness Control
5 levels provided
Interface Languages
15
Playback
Display Format
Single image, 9-image index, Magnified zoom (approx. 1.5x to 10x), Auto play, Auto play right after shooting, Rotated, Jump
Highlight Alert
In the single image (INFO) mode, the highlight portions containing no image information will blink
AF Point Display
Enabled
Histogram
Brightness, RGB
Image Protection and Erase
Protection
A single image can be protected or unprotected
Erase
A single image or all images stored in a CF card can be erased if they are unprotected
Direct Printing
Compatible Printers
CP Direct, Bubble Jet Direct, and PictBridge-compatible printers
Printable Images
JPEG images (DPOF printing possible)
Easy Print feature
Provided
DPOF: Digital Print Order Format
DPOF
Version 1.1 compatible
Customization
Custom Functions
21 Custom Functions with 57 settings
Register Basic Camera Settings
Under Mode Dial's setting
Sound Recording
Recording Methods
None
File Format
N/A
Recording Time
N/A
Power Source
Battery
One Battery Pack BP-511A/BP-514/BP-511/BP-512
Battery Life
Approx. 800 (68°F/20°C), approx. 400 (32°F/0°C)
* The above figures comply with CIPA standard and apply when a fully-charged Battery Pack BP-511A is used.
Battery Check
Automatic
Power Saving
Provided. Power turns off after 1, 2, 4, 8, 15, 30 min.
Date/Time Battery
One CR2016 Lithium Battery
Dimensions and Weight
Dimensions (W x H x D)
6.0 x 4.4 x 3.0 in./152 x 113 x 75mm
Weight
28.6 oz./810g (Body only. Battery: 2.9 oz./82g)
Operating Environment
Working Temperature Range
32-104°F/0-40°C
Working Humidity Range
85% or less
Battery Pack
Type
For BP-511A
Rechargeable lithium-ion battery
Rated Voltage
7.4 V DC
Battery Capacity
1390 mAh
38 x 21 x 55mm/1.5 x 0.8 x 2.2 in.
Weight
Approx. 82g/2.9 oz.
Battery Charger
Type
For CG-580
Compatible Battery
Battery pack BP-511A, BP-514, BP-511, or BP-512
Recharging Time
BP-511A, BP-514: Approx. 100 min.
BP-511, BP-512: Approx. 90 min.
Rated Input
100 - 240 V AC
Rated Output
8.4 V DC
0°C - 40°C/32°F - 104°C
85% or less
91 x 67 x 31mm/3.6 x 2.6 x 1.2 in.
Weight
Approx. 115/4.0 oz.
EOS 5D Kit Contents
EOS 5D Kit Contents EOS 5D Body (A) Eyecup Eb (not shown) Wide Neck Strap EW-100 DGR (C) Video Cable VC-100 (D) USB Interface Cable IFC-400PCU (E) Battery Pack BP-511A (F) Battery Charger CG-580 (G) EOS Digital Solution Disc (H) Software Instruction Manual (not shown)
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EOS 5D that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
