Web Content Viewer
Actions
EOS D60
Support DSLR
Features
With 6.3 effective megapixels, true photographic quality has finally been brought to the digital domain.  A huge 22.7 x 15.1mm imaging area is the first advantage you'll notice. Behind it, Canon's CMOS technology is providing high-level signal processing and an array of noise reduction improvements that rely on very small amounts of power.  So you can do more with less.  Plus, two filters -- a hybrid infrared filter and an RGB primary color filter -- put vivid, accurate color at your fingertips.
Sharper images. Wider tonal range. Virtually no color bleeding. Thanks to the D60 onboard Digital Signal Processing (DSP) chip, you're in control -- not the camera. And the best part is, it's fast. Image data flows from the CMOS sensor at blazing speed, unhindered by signal noise and other garbage. Which means you have more latitude to crop, enlarge, or retouch pictures with minimal deterioration and superior results.
Some of the best photographs in the world have been missed while the camera processes previous shots. Not with the EOS D60. We improved the memory buffer so that you can shoot 8-frame bursts at 3 frames-per-second and get the highest-quality JPEG and RAW images without waiting for images to load. The result: fast-moving action scenes as easy as a still life.
Sometimes you want the convenience of a JPEG image. Other times, you need the maximum image quality that only a RAW file can provide. With the EOS D60, you no longer have to decide in advance! Every D60 RAW file contains an embedded 2048 x 1360 JPEG file that can be extracted instantly with the supplied driver software. You can still set the camera to shoot JPEGs only with up to 6 variations in resolution and compression, but no matter what format you choose, the final picture will be clear, crisp, and accurate. And uniquely yours.
There are some things you don't mess with.  The way a camera feels in your hand is one of them.  With the D60, we added advancements inside, but outside you'll find every button and dial exactly where it should be.  Like the EOS D30, it's designed around a stainless steel alloy chassis, and is protected by specially treated interior and exterior surface coatings.  And the LCD monitor allows for wider peripheral angles, better visibility at low light levels, and more playback options. Smart and stylish, the D60 is definitely one to hold on to.
We're always improving the technology behind our AF systems, and with the D60, you get to enjoy the benefits. Exceptional low light performance, right down to EV0.5.  An improved laser matte screen for easier manual focusing. Superimposed, illuminated AF points for framing and focusing. And manual or automatic focusing point selection. Like most of our advancements, it's all based on the opinions of some very important photographers: our customers.
Get released from slow shutter release. With the D60 we not only significantly reduced lag time, we stabilized it as well.  So the shutter release is the last thing that will mess up a perfect photo.  Digital noise at slow shutter speeds up to 30 seconds, which can degrade image quality significantly with conventional digital cameras, no longer requires a custom function to be reduced with the D60.  And when digital noise is under control, you're in better control of what you want the camera to do.
You'll see it as soon as you bring the camera to your eye.  A much improved viewfinder -- not to mention every piece of information you'll ever need, from aperture to shutter speed to exposure level to flash ready status. And you'll be able to monitor the number of shots you have left at the maximum burst rate, see focusing points illuminated, and more.  It's all neatly organized and extremely intuitive, and right there in front of your eyes.
Specifications
Type
Type
Digital AF/AE SLR
Recording Media
Type I and II CF card
Image Format
22.7 x 15.1 mm (0.89 x 0.59 in.)
Compatible Lenses
Canon EF lenses.
Lens Mount
Canon EF mount
Image Sensor
Type
High-sensitivity, high-resolution, single-plate, color CMOS
Pixels
Effective pixels: Approx. 6.3 megapixels
Total Pixels
Approx. 6.52 megapixels
Aspect Ratio
3:2
Color Filter System
Low Pass Filter
Located in front of the imaging element, non-removable
Recording System
Recording Format
Design rule for Camera File system (JPEG) and RAW. Exif 2.2 compliant
Image Format
JPEG and RAW
File Size
1) Large/Fine: Approx. 2.5 MB (3072 x 2048), (2) Large/ Normal: Approx.1.3 MB (3072 x 2048), (3) Middle/Fine: Approx. 1.4 MB (2048 x 1360), (4) Middle/Normal: Approx. 0.7 MB (2048 x1360), (5) Small / Fine: Approx. 0.9 MB (1536 x 1024), (6) Small/ Normal: Approx. 0.5 MB (1536 x 1024), (7) RAW: Approx. 7.4 MB (3072 x 2048)
Folders
Set automatically
File Numbering
(1) Serial numbering, (2) Auto reset
Interface
USB Ver. 1.1
White Balance
Settings
Auto, daylight, overcast, tungsten light, fluorescent light, flash, and manual (read off 18% gray card or white subject)
Viewfinder
Type
SLR-type, eye-level viewfinder (with fixed pentaprism and no condenser lens)
Coverage
Approx. 95% vertically and horizontally with respect to the effective pixels
Eye Point
20mm
Dioptric Adjustment Correction
-3.0 - +1.0 diopter
Focusing Screen
Fixed, new laser matte screen
Mirror
Quick-return half mirror (Transmission: reflection ratio of 40:60, no mirror cut-off with EF 600mm f/4 or shorter lens)
Viewfinder Information
AF points, partial metering circle, shutter speed, aperture, shots remaining, busy, CF card full, CF card error, no CF card, AE lock, FE lock, exposure level, flash exposure compensation, flash ready, high speed sync and AF/MF focus confirmation
Depth Of Field Preview
Enabled with depth-of-field preview button
Eyepiece Shutter
None
Autofocus
Type
Multi-BASIS, TTL-CT-SIR (TTL secondary phase difference detection)
AF Points
3
AF Working Range
EV 0.5-18 (at ISO 100)
Focusing Modes
One-Shot AF, Predictive AI Servo AF, One-Shot/Predictive AI Servo AF (D60 automatically selects One-Shot AF or AI Servo AF), Manual focusing (MF)
AF Point Selection
Automatic selection or manual selection
Selected AF Point Display
Superimposed in viewfinder and indicated on LCD panel
AF Assist Beam
Incandescent lamp, maximum effective range 12.5 ft./3.8m
Exposure Control
Metering Modes
TTL full aperture metering with 35-zone SPC. (1) Evaluative metering, (2) Partial metering at center (approx. 9.5% of viewfinder), (3) Center weighted average metering
Metering Range
EV 2-20 (at normal temperature with 50mm f/1.4 lens at ISO 100) Exposure Control Systems: Program AE (shiftable), shutter-priority AE, aperture priority AE, depth-of-field AE, full auto, programmed image control modes (Portrait, Landscape, Close-up, Sports, and Night Scene), E-TTL flash AE, and manual
ISO Speed Range
Equivalent to ISO 100-1000
Exposure Compensation
Auto exposure bracketing (AEB): +/-2 stops in 1/2 or 1/3-stop increments Manual: +/-2 stop in 1/2 or 1/3-stop increments
AE Lock
Auto: Operates in One-Shot AF mode evaluative metering when focus is achieved
Manual: By AE lock button in all metering modes
Shutter
Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled 1/4000 to 30 sec. (1/3 and 1/2-stop increments), bulb, X-sync at 1/200 sec. Soft-touch electromagnetic release Electronically-controlled 10-sec. delay Remote control with N3 type contact
Type
Shutter Speeds
Shutter Release
Self Timer
Remote Control
Built in Flash
Type
Auto pop-up, retractable, built-in flash in the pentaprism with serial control, E-TTL autoflash
Guide Number
12/39 (at ISO 100 in meters/feet)
Recycling Time
Approx. 3 sec.
Flash Ready Indicator
Flash-ready icon lights on in viewfinder
Flash Coverage
Up to 18mm lens angle of view (equivalent to 28mm in 35mm format)
External Speedlite
EOS Dedicated Speedlite
E-TTL autoflash with EX series Speedlite
Drive System
Drive Modes
Single frame, Continuous, self-timer
Continuous Shooting Speed
Approx. 3 fps (at 1/250 sec. or faster shutter speed) Max. burst during continuous shooting: 8 shots
LCD Monitor
Type
TFT color LCD monitor
Monitor Size
1.8 inches
Pixels
Approx. 114,000 pixels
Coverage
100% with respect to the effective pixels
Brightness Control
2-level (standard/brighter) adjustment provided
Playback
Display Format
(1) Single image with information(2) Single image(3) 9-image index(4) Magnified(5)Auto play
Highlight Alert
In the single image with information display mode, the highlight portions which do not contain image information will blink
Image Protection and Erase
Protection
A single image can be protected or unprotected
Erase
A single image or all images stored in a CompactFlash card can be erased if they are unprotected
Menus
Menu Categories
(1) Shooting Menus [8]
(2) Playback Menus [4]
(3) Setup Menus [11]
LCD Monitor Language
English, Japanese, French, or German
Firmware Update
Updating by the user is possible
Power Source
Battery
One Battery Pack BP-511 (lithium ion rechargeable battery)
Number of Shots
Dimensions and Weight
Dimensions (W x H x D)
5.9 x 4.2 x 3.0 in. / 149.5 x 106.5 x 75 mm
Weight
27.5 oz. / 780g
Operating Environment
Working Temperature Range
0 - 40° C / 32-104° F
Working Humidity Range
85% or less
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EOS D60 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
