Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
EOS Digital Rebel XT
Simple, Limitless Performance
For convenience, ease of use and no-compromise SLR performance, look no further than the EOS Digital Rebel XT. Featuring Canon's Digital Trinity - an 8.0 Megapixel CMOS sensor, Canon's own DIGIC II Image Processor and compatibility with over 50 EF Lenses - the new Digital Rebel XT has an all new lightweight and compact body, improved performance across the board and the easiest operation in its class, simplifying complex tasks and ensuring the perfect shot every time. With intuitive simplicity, powerful performance and unprecedented affordability, the Rebel XT is the EOS digital camera for everyone.
Features
The EOS Digital Rebel XT features Canon's 8.0 Megapixel CMOS (Complementary Metal Oxide Semiconductor) sensor, which captures images of exceptional clarity and tonal range and offers the most pixels in its class. This APS-C size sensor (22.2 x 14.8mm) has the same 3:2 ratio as film cameras, creating an effective angle of view that is 1.6x the normal EF Lens focal length. Featuring an on-chip Noise Reduction Circuit with an expanded ISO range, the Digital Rebel XT's sensor offers professional sophistication in a consumer package.
Digic II Image Processor
The EOS Digital Rebel XT's sensor is driven by the DIGIC II Image Processor, which has been enhanced across the board with improvements in speed and image quality. Information captured by the sensor is processed and assembled into images of exceptional clarity and resolution. Consuming very little energy, DIGIC II works with the sensor to ensure natural colors, accurate white balance and speedy write times, letting you focus on taking pictures.
Much smaller than its predecessor, the Digital Rebel XT measures 4.98" across, 3.71" tall and only 2.63" deep, so it fits perfectly in your hand. Plus the Digital Rebel XT weights less than two pounds, too!
The EOS Digital Rebel XT was designed from the ground up to be faster and more intuitive than the Digital Rebel. From the ultra-fast 0.2 sec. startup time, shutter release lag of 100 msec. and viewfinder blackout time of 175 msec., the Digital Rebel XT will never keep you waiting. A new high speed shutter shoots at speeds of up to 1/4000 sec. for up to 14 shots and synchronizes with your flash at 1/200 sec.
The EOS Digital Rebel XT has a newly developed high-precision 7-point AF system for speedy and accurate focusing in any situation. You can easily choose your own point of focus or direct the camera to choose it automatically. You can even use predictive AF to ensure that moving subjects stay focused while you compose your shot. With a built-in dioptric adjustment mechanism and a new precision matte screen, achieving sharp focus is fast and easy with the Digital Rebel XT, no matter where or when you're taking pictures.
The Digital Rebel XT offers some of the easiest operation available in a digital camera today. But when you're ready, it offers a number of advanced setting options previously found only on higher-end models.
Metering Patterns
With the Digital Rebel XT, you have a choice of whether to use 35-zone AF point evaluative metering, partial metering at the center of the image or center weighted averaged metering, similar to a meter in a traditional 35mm camera.
AF Modes
Where the original Digital Rebel chose your AF mode for you, the Digital Rebel XT offers a choice of one-shot, AI Servo or AI focus, letting you make the call yourself.
Custom Functions
9 Custom functions with 24 settings settable with the camera.
C. Fn |
Custom Function |
No. |
Setting |
01 |
SET button/Cross Key Functions |
0 |
Normal |
1 |
SET: Quality |
2 |
SET: Parameter |
3 |
SET: Playback |
4 |
Cross Keys: AF frame selection |
02 |
Long Exposure Noise Reduction |
0 |
Off |
1 |
On |
03 |
Flash Sync. Speed in AV Mode |
0 |
Auto |
1 |
1/200 sec. (fixed) |
04 |
Shutter Button/AE Lock Button |
0 |
AF/AE lock |
1 |
AE lock/AF |
2 |
AF/AF lock, no AE lock |
3 |
AE/AF, no AE lock |
05 |
AF-assist Beam |
0 |
Emits |
1 |
Does not emit |
2 |
Only extension flash emits |
06 |
Exposure Level Increments |
0 |
1/3-stop |
1 |
1/2-stop |
2 |
Disable |
07 |
Mirror Lock up |
0 |
Disable |
1 |
Enable |
08 |
E-TTL II |
0 |
Evaluative |
1 |
Average |
09 |
Shutter Curtain Sync. |
0 |
1st curtain sync. |
1 |
2nd curtain sync. |
Flash Exposure Compensation
The EOS Rebel XT offers a whole new level of flash photography: Canon's spectacular E-TTL II flash system can be customized with flash exposure compensation and eight customized flash metering modes. These improvements have no effect on automatic functions - the Rebel XT is one of the simplest digital SLRs you'll ever use, but these advanced features are at your fingertips the instant you want them.
Printing your photographs could not be easier with the Digital Rebel XT. Simply connect your EOS Digital Rebel XT to any PictBridge-compatible printer, select your image and print settings, press the Direct Print button and your photograph will start printing. Exif Print 2.2 includes shot information with each image to optimize the printing of each of your photographs. Additionally, the Digital Rebel XT is ready to connect to both Windows XP and Mac OS X computers without any extra software thanks to PTP compatibility.
The EOS Digital Rebel XT is compatible with all Canon lenses in the EF lineup, ranging from ultra-wide-angle to super-telephoto lenses and including Canon's new EF-S series Lenses, manufactured specifically for the Digital Rebel series and the EOS 20D. The EF lineup employs advanced optical know-how to deliver unprecedented performance in all facets of the photographic process. Rebel XT users will find the all-new EF-S 17-85mm f/4-5.6 IS USM Lens a perfect match for their new camera. It offers a 35mm equivalent of a 27-136mm zoom range and includes Canon's Image Stabilizer (which adds an equivalent of 3 stops) and a full time manual focus mechanism, all in a compact, robust construction.
Flash Photography
The EOS Digital Rebel XT features the acclaimed E-TTL II flash metering system. Whether using its pop-up flash or any of the flashes in the Speedlite line, E-TTL II provides stable flash brightness through numerous exposures.
Canon's new Speedlite 580 EX is perfectly suited to the Digital Rebel XT. It features a maximum guide number of 58, together with an auto zoom function that compensates for the sensor size, enabling high output flash with more accurate results. It includes an AF assist beam that works in conjunction with the Rebel's focusing system and automatically sends color temperature information to the camera when the flash fires, producing consistently accurate colors.
Specifications
Type
Type
Recording Media
Image Format
Compatible Lenses
Lens Mount
Image Sensor
Type
Pixels
Total Pixels
Aspect Ratio
Color Filter System
Low Pass Filter
Recording System
Recording Format
Image Format
Simultaneous Recording: Possible
File Size
Folders
File Numbering
Interface
White Balance
Settings
Viewfinder
Type
Coverage
Magnification
Eye Point
Dioptric Adjustment Correction
Focusing Screen
Mirror
Viewfinder Information
Depth Of Field Preview
Eyepiece Shutter
Autofocus
Type
AF Points
AF Working Range
Focusing Modes
AF Point Selection
Selected AF Point Display
AF Assist Beam
Exposure Control
Metering Modes
Metering Range
ISO Speed Range
AE Lock
Shutter
Type
Shutter Speeds
Shutter Release
Self Timer
Remote Control
Built in Flash
Type
Guide Number
Recycling Time
Flash Ready Indicator
Flash Coverage
External Speedlite
EOS Dedicated Speedlite
Drive System
Drive Modes
Continuous Shooting Speed
Maximum Burst
LCD Monitor
Type
Monitor Size
Pixels
Coverage
Brightness Control
Playback
Display Format
Highlight Alert
Image Protection and Erase
Protection
Erase
Menus
Menu Categories
LCD Monitor Language
Firmware Update
Power Source
Battery
Dimensions and Weight
Dimensions (W x H x D)
Weight
Operating Environment
Working Temperature Range
Working Humidity Range
EOS Digital Rebel XT Kit Contents
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EOS Digital Rebel XT that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Battery Charger CB-2LW
Use the battery charger to charge the battery packs. It plugs directly into a power outlet without a cable.
MSRP: 55.0
Battery Grip BG-E3
MSRP: 220.0
Battery Pack NB-2LH
Lithium-Ion rechargeable battery (720mAh).
MSRP: 70.0
CF Wallet
MSRP: 7.0
Camera Cover R-F-3 Body Cap
MSRP: 7.0
Car Battery Charger CBC-NB2
Use the CBC-NB2 car battery adapter to charge NB-2L or BP-2F12 batteries while you're on the road simply by plugging it into your car's cigarette lighter socket so they're always ready to go whenever you and your camera are.
MSRP: 125.0
Custom Media Case 10DG
MSRP: 23.0
MSRP: 23.0
Deluxe Back Pack 200EG
Backpack with carry handle and detachable strap. Holds 1-2 Cameras bodies, 3-4 lenses and accessories. Inside measurements (W x H x D): 10 x 14.75 x 5 inches. Rugged nylon, water-repellent, urethane coated for extra durability. Well-arranged divider system for secure storage and easy access. Lightweight construction, padded shoulder straps and back for comfort. Front webbing ideal for storing a light jacket. Tripod carrying straps. Color: Black with Olive.
MSRP: 75.0
Deluxe Gadget Bag 100EG
Waterproof bag holds 1-2 cameras and 3-4 lenses with room for accessories. Front and Rear zippered pouches. Zippered full-length mesh pouch inside top cover. Divider system for secure storage and easy access. Size: 9" (W) x 7" (H) x 5.5" (D)
MSRP: 50.0
Deluxe Gadget Bag 10EG
This gadget bag is an excellent value, with all the quality material of the Professional 1, at a slightly smaller size. It is designed to hold two 35mm SLR bodies, 5 - 8 lenses, plus film and accessories. It features full padding and interior partitions, leather reinforcing, high strength quick-release buckles, padded exterior pockets, leather snap handle and shoulder strap. Size: 10.5" (W) x 8"(H) x 7.5" (D)
MSRP: 130.0
Deluxe Tripod 200
This lightweight, high quality tripod is designed for easy portability and maximum stability. It features a 3-way pan head for precise control and smooth movement. The 3-section tubular leg construction allows for exceptional stability indoors or out.
MSRP: 45.0
Deluxe Tripod 300
The Canon Deluxe Tripod 300 was designed for ease of portability when traveling and maximum stability when used in any situation with a compatible Canon digital camera. The Deluxe Tripod 300 features a 3 way pan head for precise control while the 3 section tubular leg construction allows enhanced stability indoors and outdoors. The three-section Deluxe Tripod 300 reaches a maximum height of 62" and folds down to 23" and has a maximum load capacity is 4.4 lb.
MSRP: 45.0
Digital Gadget Bag 100DG
Designed especially for digital SLRs. Can hold your cameras, lenses, accessories and even a laptop computer. Durable, water-repellent nylon exterior. Padded interior dividers and easy-access storage pockets.
MSRP: 99.99
Digital Gadget Bag 200DG
Size 10.5"(W) x 7.5"(H) x 7"(D)
MSRP: 100.0
Dioptric Adjustment Lens E (+0.5)
The Dioptric Adjustment Lens provides near- and far-sighted users a clear viewfinder image without the use of eyeglasses. The lens fits into the eyepiece holder of you EOS camera. Please see the Compatibility tab for a list of compatible EOS cameras.
MSRP: 17.0
Dioptric Adjustment Lens E (+1)
MSRP: 17.0
Dioptric Adjustment Lens E (+1.5)
MSRP: 17.0
Dioptric Adjustment Lens E (+2)
MSRP: 17.0
Dioptric Adjustment Lens E (-2)
MSRP: 17.0
Dioptric Adjustment Lens E (-3)
MSRP: 17.0
Dioptric Adjustment Lens E (-4)
The Dioptric Adjustment Lens provides near- and far-sighted users a clear viewfinder image without the use of eyeglasses. The lens fits into the eyepiece holder of you EOS camera. Requires Rubber Frame Ef, Eb or Ec
MSRP: 17.0
Direct Interface Cable DIF-100
MSRP: 19.0
Gadget Bag 2400
Fits DSLR and Standard Lens Kit. Made from Cordura Nylon. Large Zippered Front Accessory Pocket. Zippered Mesh Pocket Inside Top Lid. Two Side Accessory Zippered Pockets. Tripod Loops on Bottom. Five Movable, Padded Internal Dividers. Two Strap Handles with Grip. Removable Shoulder Strap. Rubber Feet for Ground Protection.
MONOPOD 100
MSRP: 45.0
Mini Tripod 7
For use with SLR or compact cameras.
MSRP: 24.0
Monopod 500
The Canon Monopod 500 is a compact, lightweight 5-section monopod that comes with a mini-ball head. It features a foam grip on the top leg section, a hand strap, flip lock leg sections, and rubber leg tip. Maximum height of 64.5" extended and folded length of 21.9". Load capacity of 8.5 pounds. Weight of 1.1 pounds.
MSRP: 45.0
NECK STRAP EW-100DBIII
Wide neck strap.
MSRP: 20.0
Neck Strap L4
MSRP: 27.0
Off-Camera Shoe Cord 2
MSRP: 80.0
PCMCIA Adapter
MSRP: 32.0
Professional Gadget Bag 1EG
Large gadget bag for the traveling professional. Size: 14.2" (W) x 8.7"(H) x 8.3"(D). This bag is designed to hold two 35mm SLR camera bodies, seven to ten lenses, flash, film, accessories, etc. It features full padding and interior dividers for cameras and lenses, as well as padded outside pockets. Features adjustable tripod straps, and high strength buckles for the main compartment. The Canon logo is embroidered on the top flap.
MSRP: 150.0
Rubber Frame Ec
Rubber Frame for EOS Camera
Semi-Hard Case EH-18L
MSRP: 70.0
Video Cable VC-100
Enables direct image display from the EOS to an HD television or a similar display device. Comes standard with the EOS 1Ds Mark III, 1D Mark IV, 1D Mark III, 1Ds Mark II, 1D Mark II N, 1D Mark II, 5D Mark II, 7D, 5D, 50D, 40D, 30D, 20D, 10D, Digital Rebel XTi, Digital Rebel XT and Digital Rebel. Please see Compatibility tab for compatible models.
MSRP: 8.0
Wide Neck Strap
Wide Neck Strap EW-100BM
Wide Neck Strap EW-100MA
MSRP: 17.0
Wide Strap EW-100 DB II
Wireless Remote Controller RC-1
MSRP: 30.0
Wireless Remote Controller RC-5
MSRP: 30.0
Brochures
- ${title}${badge}
