Web Content Viewer
Actions
EOS Rebel T2i EF-S 18-55mm IS Kit
Support DSLR
Features
18.0 Megapixel CMOS (APS-C) sensor and DIGIC 4 Image Processor for high image quality and speed.
The EOS Rebel T2i has an 18.0 Megapixel CMOS (complementary metal oxide semiconductor) sensor that captures images with exceptional clarity and tonal range and offers more than enough resolution for big enlargements or crops. This first-class sensor features many of the same new technologies as used by professional Canon cameras to maximize each pixel's light-gathering efficiency. Its APS-C size sensor creates an effective 1.6x field of view (compared to 35mm format). DIGIC 4 Image Processor
The Canon DIGIC 4 Image Processor dramatically speeds up the entire EOS Rebel T2i's camera operations for intuitive operation and offers improvements in both fine detail and natural color reproduction. It works in concert with the EOS Rebel T2i's CMOS Image Sensor to achieve phenomenal levels of performance in nearly any situation. CMOS Image Sensor
ISO 100-6400 (expandable to 12800) for shooting from bright to dim light.
The EOS Rebel T2i features an expanded ISO range that makes shooting possible in situations previously unthinkable without flash. With an ISO rating up to 6400 (expandable to ISO 12800), along with the DIGIC 4 Image Processor's improved noise-reduction technology, creative possibilities abound. Combine the EOS Rebel T2i with one of Canon's EF or EF-S lenses with Optical Image Stabilizer and the shooting possibilities for both movies and stills expand even further.
Improved EOS Movie mode with manual exposure control, expanded recording, new Movie Crop recording in 640 x 480 and external microphone IN terminal for access to improved sound quality.
Designed for the evolving, tech-savvy user, the EOS Rebel T2i features HD Video capture technologies – manual exposure control for more creative control, for example – borrowed directly from professional Canon SLRs to capture stellar video with all the benefits of shooting with an SLR. By shooting video with the EOS Rebel T2i, photographers as well as filmmakers can take advantage of the creative features native to SLR cameras. Along with its manual controls, the EOS Rebel T2i allows for full use of Canon EF and EF-S lenses, including Macro and Fisheye, providing a plethora of shooting options once reserved only for still photography. The resulting HD video is a standout in its beautiful depth-of-field characteristics and remarkable capture capability under poor lighting conditions. In a first for EOS cameras, a Movie Crop function is included: An SD-quality movie (640 x 480) can be cropped to the equivalent of about 7x magnification of regular shooting. Video can be captured at a number of resolutions and frame rates for numerous applications. It can capture 1920 x 1080 Full HD video at frame rates of 24 (23.976), 25 or 30 (29.97) frames per second, for up to 4GB per clip. Movies are saved as MOV files and can be viewed in Full HD through the EOS Rebel T2i's HDMI output. Other recording sizes include HD at 1280 x 720 (50/60 (59.94) fps) or SD/VGA at 640 x 480 (50/60 (59.94) fps). The EOS Rebel T2i has a built-in microphone for simple mono recording and stereo sound can be recorded through a self-powered external microphone.
Enhanced iFCL 63-zone, Dual-layer metering system; and 9-point AF system utilizing a high-precision, f/2.8 cross-type center point.
The EOS Rebel T2i features Canon's newest Dual-layer sensor, with 63 zones. By measuring not only the amount of light, but also taking into account color and luminosity, this new system delivers a very high level of accuracy for better results every time. Since the metering sensor has a color measurement function, exposure errors and focus errors caused by different light sources are minimized; the EOS Rebel T2i gives stable exposure from shot to shot in situations where light changes, such as sports on a cloudy day, or indoor holiday scenes. Additionally, the EOS Rebel T2i has a high-precision, 9-point AF system utilizing a high-precision, f/2.8 cross-type center point. The 9-point AF system uses both normal and high-precision focus depending on the aperture and available light. The 9 focus points can be chosen automatically or manually selected. Metering zones
Wide 3.0-inch (3:2 aspect ratio) Clear View LCD monitor (1.04 million dots) for improved viewing.
The EOS Rebel T2i has a high-resolution 3.0-inch Clear View LCD monitor that features 1.04 million dots/VGA for spectacular detail. It also has the same aspect ratio (3:2) as the camera's sensor, making for clear and easy Live View composition. An anti-reflective and water-repellant coating provides a clearer and more smudge-resistant surface and screen brightness can be adjusted in 7 steps in accordance with ambient light.
New Quick Control Screen button for easy access to frequently used settings.
The EOS Rebel T2i's refined button layout includes a dedicated button that directs the camera immediately to the Quick Control screen, where it's simple to navigate among any number of settings, including ISO, Exposure and Flash Exposure compensation, drive mode, white balance, image quality and much, much more.
Improved layout with dedicated Live View/Movie shooting button.
Without the need to navigate through a bunch of menus, the EOS Rebel T2i transitions effortlessly between still and movie mode. By pressing the Live View/Movie button, a situation that had required menu access with other cameras, still images can change to a movie shoot and vice versa. It’s literally as simple as the press of a button.
New compatibility with SDXC memory cards, plus new menu status indicator for Eye-Fi* support.
The EOS Rebel T2i is compatible with both SDXC memory cards for greater storage capacity and with Eye-Fi SD cards, which are outfitted with a Wi-Fi transmitter (IEEE 802.11b/g) and internal antenna for wireless, high-speed transfer of images. With an Eye-Fi card installed, the EOS Rebel T2i can display the Eye-Fi's connection status and error notes with ease, for fully functional wireless uploading of images directly from the camera. *Canon cameras are not guaranteed to support Eye-Fi card functions, including wireless transfer. In case of an issue with the Eye-Fi card, please consult with the card manufacturer. The use of Eye-Fi cards may not be available outside the United States and Canada, please contact the card manufacturer for territory availability.
3.7 fps continuous shooting up to approximately 34 JPEGs or approximately 6 RAW.
The EOS Rebel T2i can shoot up to 3.7 frames per second (fps) for up to approximately 6 consecutive RAW files or approximately 34 full-resolution JPEGs. Shooting at speeds of up to 1/4000 sec., the EOS Rebel T2i can capture even rapidly-unfolding scenes with ease.
Compatible with the full line of Canon EF and EF-S lenses.
EF Lenses<br/>The EOS Rebel T2i is compatible with all Canon lenses in the EF lineup, including compact and lightweight EF-S lenses, ranging from ultra-wide angle to super telephoto lenses. Canon lenses employ advanced optical expertise and micron-precision engineering to deliver outstanding performance and deliver beautiful results. Special technologies like the Canon Image Stabilizer technology in select lenses helps to minimize the effect of camera shake, effectively adding up to four stops of light. With a dizzying array of lenses perfect for travel, sports, still life and everything in between, photographers can truly maximize the quality and performance of their EOS Rebel T2i with superlative Canon optics.
Specifications
Type
Digital, single-lens reflex, AF/AE camera
Recording Media
SD memory card, SDHC memory card, SDXC Memory Card
Image Format
22.3mm x 14.9mm (APS-C size)
Compatible Lenses
Canon EF lenses including EF-S lenses (35mm-equivalent focal length is approx. 1.6x the lens focal length)
Lens Mount
Canon EF mount
Type
High-sensitivity, high-resolution, large single-plate CMOS sensor
Pixels
Effective pixels: Approx. 18.00 Megapixels
Aspect Ratio
3:2 (Horizontal: Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
Fixed position in front of the CMOS sensor
Dust Deletion Feature
(1) Self-Cleaning Sensor Unit
(2) Dust Delete Data appended to the captured image
(3) Manual cleaning of sensor
Recording Format
Design rule for Camera File System 2.0 and Exif 2.21
Image Format
Still: JPEG, RAW (14-bit, Canon original), RAW+JPEG
Video: MOV (Image data: H.264, Audio: Linear PCM)
File Size
(1) Large/Fine: Approx. 6.4MB (5184 x 3456 pixels)
(2) Large/Normal: Approx. 3.2MB (5184 x 3456 pixels)
(3) Medium/Fine: Approx. 3.4MB (3456 x 2304 pixels)
(4) Medium/Normal: Approx. 1.7MB (3456 x 2304 pixels)
(5) Small/Fine: Approx. 2.2MB (2592 x 1728 pixels)
(6) Small/Normal: Approx. 1.1MB (2592 x 1728 pixels)
(7) RAW: Approx. 24.5MB (5184 x 3456 pixels)
Exact file sizes depend on the subject, ISO speed, Picture Style, etc.
File Numbering
Continuous numbering, auto reset, manual reset
Color Space
sRGB, Adobe RGB selectable
Picture Style
Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined 1-3
Settings
Auto, Daylight, Shade, Cloudy, Tungsten Light, White Fluorescent Light, Flash, Custom
Color Temperature Compensation
White balance correction: ±9 stops in full-stop increments
White balance bracketing: ±3 stops in full-stop increments
Blue/amber direction or magenta/green direction possible
Color Temperature Information Transmission
Provided
Type
Eye-level SLR (with pentamirror)
Coverage
Vertical/Horizontal approx. 95%
Magnification
Approx. 0.87x (with 50mm lens at infinity, -1 m-1 (dpt))
Eye Point
Approx. 19mm (from eyepiece lens center)
Dioptric Adjustment Correction
-3.0 to +1.0m-1 (diopter)
Focusing Screen
Fixed, Precision Matte
Mirror
Quick-return half mirror (transmission: reflection ratio of 40:60, no mirror cut-off with EF600mm f/4L IS USM or shorter lenses)
Viewfinder Information
AF information
AF points and focus confirmation light
Exposure information
Shutter speed, aperture, ISO speed (always displayed), AE lock, exposure level, spot metering circle, exposure warning
Flash information
Flash ready, flash exposure compensation, high-speed sync, FE lock, red-eye reduction light
Image information
Highlight tone priority (D+), monochrome shooting, maximum burst (1-digitdisplay), white balance correction, SD card information
Depth Of Field Preview
Enabled with depth-of-field preview button
Type
TTL-CT-SIR AF-dedicated CMOS sensor
AF Points
9 AF points (center AF point is cross-type)
Focusing Modes
Auto, One-Shot AF, Predictive AI Servo AF, AI Focus AF, Manual Focusing (MF)
AF Point Selection
Automatic selection, manual selection
Selected AF Point Display
Superimposed in viewfinder and indicated on LCD monitor
AF Assist Beam
Intermittent firing of built-in flash
Effective range: Approx. 4.0m/13.1 ft. at center, approx. 3.5m/11.5 ft. at periphery. When EOS-dedicated Speedlite attached, the Speedlite's AF-assist beam is emitted instead.
Metering Modes
63-zone TTL full-aperture metering Evaluative metering (linkable to any AF point)Partial metering (approx. 9% of viewfinder at center)Spot metering (approx. 4% of viewfinder at center)Center-weighted average metering
Metering Range
EV 1-20 (at 73°F/23°C with EF 50mm f/1.4 USM lens, ISO 100)
ISO Speed Range
ISO 100~6400 (in 1-stop increments), H: 12800
Basic Zone modes: ISO 100~3200 set automatically
Exposure Compensation
Manual: ±5 stops in 1/3- or 1/2-stop increments (can be combined with AEB)
AE Lock
(1) Auto AE lock
* In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved.
(2) Manual AE lock
* With AE lock button. (AE lock is updated each time you press the button.)
Enabled in all metering modes.
Shutter
Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled1/4000 sec. to 1/60 sec., X-sync at 1/200 sec.
1/4000 sec. to 30 sec., bulb (Total shutter speed range. Available range varies by shooting mode)Soft-touch electromagnetic release10-sec. or 2-sec. delay or 10-sec. delay plus continuous shooting Remote Switch RS-60E3
Remote Controller RC-1/RC-5/RC-6
Type
Shutter Speeds
Shutter Release
Self Timer
Remote Control
Type
Retractable, auto pop-up flash
Guide Number
13/43 (ISO 100, in meters/feet)
Recycling Time
Approx. 3 sec.
Flash Ready Indicator
Flash-ready icon lights in viewfinder
Flash Coverage
Up to 17mm lens focal length (equivalent to 27mm in 135 format)
FE Lock
Provided
Flash Exposure Compensation
±2 stops in 1/3- or 1/2-stop increments
Flash exposure compensation for built-in flash and Speedlite can be set with the camera.
Drive Modes
Single, continuous, self-timer (10 sec. or 2 sec. delay)/remote control
Continuous Shooting Speed
Max. 3.7 shots/sec. (with One-Shot AF or AI Servo AF)
Maximum Burst
JPEG (Large/Fine): Approx. 34, RAW: Approx. 6
Based on Canon's testing standards with a 2GB SD memory card, ISO 100 and Standard Picture Style
Varies depending on the subject, SD memory card brand, image-recording quality, etc.
Shooting Modes
Still photo shooting and video shooting
Focusing
Autofocus (One-Shot AF): Live mode, Face Detection Live mode, Quick mode; Manual focus (5x or 10x manually)
Metering Modes
Real-time evaluative metering with image sensor
Metering Range
EV 0-20 (at 73°F/23°C with EF 50mm f/1.4 USM lens, ISO 100)
Grid Display
Provided (Two grid displays)
Exposure Simulation
Provided
Silent Shooting
Not provided
Type
TFT color, liquid-crystal monitor
Monitor Size
3.0 in.
Pixels
Approx. 1,040,000 dots (VGA)
Coverage
Approx. 100%
Viewing angle: 160°
Brightness Control
7 levels provided
Interface Languages
English, German, French, Dutch, Danish, Portuguese, Finnish, Italian,Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian,Romanian, Ukraine, Turkish, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean and Japanese
Display Format
(1) Single image display
- Two types of single-image full display and two types of shooting information display.
(2) Index display
- 4-image index and 9-index image.
(3) Jump display
- 10/100 images, shooting date, movies, stills
Highlight Alert
Provided (Overexposed highlights blink)
Protection
Erase protect (or cancel) each image individually
Erase
Single image, selected images or all images in the SD card can be erased (except protected images)
Compatible Printers
PictBridge-compatible printers
Printable Images
JPEG images compliant to Design rule for Camera File System (DPOF printing possible) and RAW images captured with the EOS Rebel T2i
Easy Print feature
Provided
DPOF
Version 1.1 compatible
Compatible Images
JPEG and RAW images
Only JPEG images can be transferred as wallpaper on the personal computer screen
Custom Functions
Total 12
My Menu Registration
Up to 6 menus, Custom functions and other top-tier options can be registered
Battery
One Battery Pack LP-E8
AC power can be supplied via AC Adapter Kit ACK-E8
With Battery Grip BG-E8, AA-size batteries can be used
Number of Shots
Number of shots (approx.)
The above figures apply with a fully-charged Battery Pack LP-E8.
The figures above are based on CIPA (Camera & Imaging Products Association) testing standards.
Battery Check
Auto
Power Saving
Provided. Power turns off after 30 sec., 1, 2, 4, 8, 15 min.
Date/Time Battery
Built-in secondary battery
Start-up Time
Approx. 0.1 sec.
Dimensions (W x H x D)
Approx. 5.1 x 3.8 x 3.0 in./128.8 x 97.5 x 75.3mm
Weight
Approx. 18.7 oz./530g (CIPA standard, includes battery and memory card.)
Working Temperature Range
32-104°F/0-40°C
Working Humidity Range
85% or less
EOS Rebel T2i 18-55mm
EOS Rebel T2i 18-55mm EOS Rebel T2i Body EF-S 18-55mm f/3.5-5.6 IS Lens Eyecup Ef (not shown) Wide Strap EW-100DBIII USB Interface Cable IFC-130U AV Cable AVC-DC400ST Battery Pack LP-E8 Battery Charger LC-E8E EOS Digital Solution Disc and Instruction Manuals "Great Photography is Easy" Booklet and "Do More with Macro" Booklet (not shown)
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EOS Rebel T2i EF-S 18-55mm IS Kit that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
