Web Content Viewer
Actions
EOS ELAN 7/7E
Support EOS 35mm SLR Cameras
Features
The EOS ELAN 7/7e features Canon's exclusive Eye Controlled Focus. Quite simply, Eye Control is the fastest, easiest method of selecting a focus point.
The autofocus tracking speed of the EOS ELAN 7 /7e rivals that of the leading top-of-the-line cameras available today. With a top shutter speed of 1/4000 of a second and fastest in its class 4 fps film advance, the ELAN 7/7e is a prime choice for demanding sports or wildlife photographers.
The Canon EOS line boasts a new ergonomic design. The ELAN 7/7e is smaller and more compact, with controls placed intuitively, in a user-friendly design, for a superior shooting experience.
The construction of the camera body is newly reinforced, with strategically placed metal top and front cover plates, for rugged reliability in any environment.
New shooting possibilities open when you shoot in silence. WhisperDrive™ transport brings near silent shooting, when used with Canon's exclusive USM lenses.
In most any situation you find yourself, the versatile selection of exciting system accessories and lenses for the Canon EOS ELAN 7/7e will meet your needs.
Specifications
Type and Major Components
Type
35mm vertical-travel focal plane shutter SLR (Single-Lens-Reflex) camera with multi-point autofocus (Eye Controlled Focus), auto exposure with built-in flash.
Compatible Lenses
Canon EF Lenses
Lens Mount
Canon EF Mount (electronic signal transfer system).
Viewfinder
Type
Fixed eye-level pentaprism with approximately 90% vertical and 92% horizontal coverage of actual picture area and 0.70x magnification with 50mm lens at infinity. Center and six outside focusing points controlled by eye movement.
Focusing Screen
Fixed New Laser-Matte screen with 7 focusing points.
Mirror
Quick-return half mirror (60% reflection / 40% transmission).
Viewfinder Information
Inside Image Area: Focusing points with superimposed display. Below Image Area: (from left to right) Eye Controlled Focus indicator; AE Lock / FE Lock symbol; flash ready signal; High- Speed Sync in use signal; flash exposure compensation indicator; shutter speed and aperture indicating LEDs (blinks at 2hz when setting is unsuitable), also present DEP 1 / DEP 2 information, Calibration (Cal 1 to 5, END-1 to 3); Exposure compensation scale / manual metering scale, Red- Eye Reduction lamp on / reduction progress indicator; in- focus indicator (blinks at 2hz when focus cannot be achieved).
Eyepiece Shutter
None.
Autofocus
Focusing Point Selection
Selected automatically by camera or manually by user. Focusing point selection via Eye Controlled Focus available.
Focus Modes
(1) One-Shot AF (2) Predictive AF with AI Servo AF (3) AI Focus AF (4) Manual.
Focus Operation
(1) AF activated by pressing the shutter button halfway. (2) Pressing AE Lock button.
AF Working Range
EV 1~ 18 (at ISO 100 with the standard chart).
Exposure Control
Metering Range
EV 1~ 20 (ISO 100).
Exposure Modes
(1) Intelligent Program AE with variable shift (2) Shutter speed-Priority AE (3) Aperture-Priority AE (4) Depth-of-Field AE (DEP) (5) Full Auto (6) Programmed Image Control: Portrait, Landscape, Close-up, Sports and Night Scene (7) Manual, (8) E-TTL Program Flash, (9) A-TTL Program Flash, (10) TTL Program Flash.
Multiple Exposure
Up to 9 exposures can be preset. Automatically clears upon completion. All data based on Canon's Standard Test Method. Subject to change without notice.
Exposure Compensation
(1) Auto Exposure Bracketing (AEB) to +/-2 stops in 1/2 stop increments repeatable. May be used in Intelligent Program, Shutter- Priority, Apert re-Priority, Depth-of-Field, and Manual modes only. (2) User- set expos re compensation up to +/-2 stops, in 1/2 stop increments, with Quick Control Dial. (3) Flash Exposure.
Built-in-Flash
Type
Built-in, retractable TTL automatic flash; pops-up automatically when needed in low light/ backlight situations except when in Landscape, Sports or Creative Zone modes; manual pop- up (pull up by hand) in P, Av, Tv, M, modes.
Guide Number
43 (ISO 100, ft.)
Recycling Time
Approximately two seconds.
Film Transport
Film Loading
Automatic take-up with a sprocketless system. Film is automatically advanced to the first frame when the camera back is closed.
Film Speed Setting
ISO 25-5000 automatically set in 1/3-stop increments according to DX code. Can also be set manually from ISO 6-6400 in 1/ 3-stop increments. High- speed infrared film cannot be used.
Film Transport
Choice of single frame or continuous shooting at approximately 4 fps (3.5 fps in AI Servo AF), with additive frame counter.
Film Rewind
Film is automatically rewound at the end of the roll or after 36 exposures, with a mid-roll film rewind option. Choice of high-speed (5 seconds with 24 exposure roll) or silent rewind (13 seconds with 24 exposure roll) modes.
Power Source
Battery
Two CR123A lithium batteries (6V) loaded through the camera grip bottom.
Optional battery pack BP-300: Compatible with four AA batteries or two CR123A lithium batteries.
Battery Check
Automatic battery check when the Command Dial is released from OFF.
Shooting Capacity
24 exposure rolls
Dimensions
Size (W x H x D)
5.78 x 4.06 x 2.72 /146.7mm x 103mm x 69mm)
ELAN 7E Date: 5.78(W) x 4.06(H) x 2.72(D) /146.7mm(W) x 103mm(H) x 69mm(D)
Weight
20.3 oz / 575g
ELAN 7E Date: 20.5 oz. / 580g
(Add 1.12 oz. / 32g for two CR123A batteries)
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EOS ELAN 7/7E that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
