Web Content Viewer
Actions
EOS Rebel GII
Support EOS 35mm SLR Cameras
Features
Proper exposure makes good shots into great ones, and with the Rebel GII, you can trust the automatic exposure system to do all the work.  From sunny beach and sky scenes to nightscapes and everything in between, exposure is consistent and accurate.
With easy preprogrammed shooting options plus semi to full manual control over exposure and focus, you'll set your own pace for discovering the excitement of SLR photography.
Owning a Rebel Ti gives you access to Canon's world-renowned line of precision lenses and accessories that will have you creating spectacular images well into the future.
EOS Rebel GII Kit Contents
EOS Rebel GII Kit Contents EOS Rebel GII Body Wide Strap EW-100BM Lithium Batteries 3V CR123A
Specifications
Type and Major Components
Type
35mm SLR(single-lens reflex) AF/AE camera with built-in winder and built-in flash.
Compatible Lenses
Canon EF Lenses
Lens Mount
Canon EF mount (Fully electronic control)
Viewfinder
Type
SLR-type, eye-level roof mirror pentaprism
Picture Coverage
90% vertical and horizontal coverage of actual picture area
Magnification
0.70x magnification with 50mm lens at infinity
Dioptric Adjustment
No standard diopter provided
Focusing Screen
Fixed, new laser-matte screen marked with focusing points and partial metering circle
Mirror
Quick-return half mirror
Viewfinder Information
Shutter speed (if unsuitable blinks at 2hz as warning), Aperture (if unsuitable blinks at 2 Hz as warning), AE lock or FE lock (Partial metering at center), Focusing point indicator (The indicator for the selected focusing point is displayed while the shutter button is pressed halfway or during metering.), Exposure scale in 1/2-stop increments (±2 stops), Flash Ready Light (Blinks as a flash-required warning in low-light (2 Hz while the built-in flash is retracted), High-speed sync (FP flash), In-focus (during AF and MF) indicator (Blinks at 2 Hz if focusing is impossible)
Viewfinder information display cannot be turned off.4.
Autofocus
Type
TTL-CT-SIR (Through-the-Lens Secondary Image Registration) Multi-BASIS with 3 focusing points |+|
Focusing Point Selection
The focusing point can be selected by camera (Automatic) or by user (Manual).
Focus Modes
1. Autofocus: One of the following two AF modes is set automatically (not user-settable) to suit the picture-taking mode. The shutter does not release until focus is achieved.
a. One-Shot AF: Autofocus locks when focusing is achieved with stationary subject.
b. Al Servo AF for automatic switching between One-Shot AF and predictive AF for moving subjects.
2. Manual Focus: Setting the lens' focus mode switch to MF ( or M) enables manual focusing with the focusing ring.
Focus Operation
Af is activated by pressing the shutter button halfway.
AF Working Range
EV 2-18 ( at ISO 100,standard chart)
AF Assist Method
Beam automatically emitted when necessary and aimed at the area covered by the active focus point.
Exposure Control
Metering Modes
1. TTL max. aperture metering with 6 zone silicon photocell. Three metering patterns available.
a. Evaluative metering
b. Center weighted average metering (Set automatically in M mode).
c. Partial Metering (Measure approx. 9% of central area; activated while pressing AE Lock Button only.)
2. E-TTL (with EOS dedicated external Speedlite) 6 zone metering of E-TTL pre-flash
3. A-TTL, TTL Flash Metering A-TTL autoflash linked to focusing points, 3-zone TTL autoflash
Metering Range
EV 2-20 (with 50mm f/1.4 lens at ISO 100)
Exposure Modes
1. Intelligent program AE (P/Shiftable)
2. Shutter speed-priority AE(Tv/No Safety shift)
3. Aperture-priority AE(Av/No safety shift)
4. Depth-of-field Ae(A-DEP/Non-shiftable)
5. Full Auto (intelligent program AE/Non-shiftable
6. Programmed Image Control modes; Portrait, Landscape, Close-up, Sports and Night Scene
7. Metered Manual, User sets speed/aperture +/- 2 stop viewfinder read-out
8. E-TTL autoflash program AE( with accessory Ex-type speedlites)
9.A-TTL autoflash program AE
10. TTL autoflash program AE
Multiple Exposure
Up to 9 exposures can be set. Automatically clears upon completion. Cancelable midway.
Exposure Compensation
1. Auto Exposure Bracketing(AEB) up to +/- 2Ev in 1/2 steps.
2. Manual exposure compensation up to =/-2 EV in 1/2 steps
*AEB is not available in the Full Auto and Programmed modes. Exposure Compensation and AEB are possible in P, Tv, Av and A-DEP exposure modes. Exposure Compensation and AEB are possible in P, Tv, Av and A-DEP exposure modes, AEB also possible in Manual mode.
Shutter
Type
Vertical-travel, focal plane shutter with all speeds electronically-controlled. Front and rear shutter curtain both have dedicated electromagnetic released control. (Curtain speed 6.3ms/24mm)
Shutter Speeds
30 to 1/2000 sec. (in 1/2 stop increments), bulb,X-sync at 1/90 sec.
Built-in-Flash
Type
Built-in, serial-controlled, retractable TTL autoflash head in the pentaprism
Guide Number
39ft/ 12m (ISO 100)
Flash Coverage Angle
Covers the angle of view of 28mm lens.
Flash Duration
1ms or less
Recycling Time
Approx, 2 seconds. The icon lights in viewfinder when ready.
Color Temperature
Equivalent to daylight
Shooting Distance Range
*At distances closer than 3.3 ft (1m), flash coverage will be partially obstructed by the lens barrel.
Red-Eye Reduction
Red-Eye Reduction lamp lights while the shutter button is pressed halfway and focusing metering are achieved.
Film Transport
Film Loading
Automatic prewind system. After film positioning and back cover closure, the film automatically winds to the 1st frame.
Film Speed Setting
ISO 25-5000 automatically set in 1/3 stop increments according to DX code. Can also be set manually from ISO 6-6400 1/3 increments.
Film Transport
Single-frame advance or continuous film advance set automatically to the picture-taking mode.
Quiet Film Transport: Film winding sound level Approximately 56dB
Film Transport Confirmation: By up/down counting of frame counter in LCD panel.
Film Wind
Automatic. One of two modes is automatically set: Single-frame and continuous.(In Continuous Mode, with AF locked, approximately 1fps)
Film Rewind
Film rewound as the film advances to the next frame. Midroll rewinding possible.
Power Source
Battery
Two CR123A/DL123A lithium batteries (3v) housed inside the camera grip.
Battery Check
Automatic battery check when the Command Dial is released from OFF. Battery level is indicated on the LCD panel is one of four levels.
Shooting Capacity
The table below indicates the number of 24-exposure rolls that can be taken with two new CR123A batteries and Canon EF28-80mm F/3.5-5.6 lens.
AE Usage FA: Flash Usage
Dimensions
Size (W x H x D)
5.7 (W) x 3.6 (H) x 2.5 (D) in./ 145 (W) x 92(H)x61.9(D) mm
Weight
12.35 oz./350g without batteries
13.45 oz./382g with batteries
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EOS Rebel GII that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
