Web Content Viewer
Actions
EOS Rebel T2
Support EOS 35mm SLR Cameras
Features
Easy to Focus, Easy to Shoot
The Rebel T2 gives you a full package of highly sophisticated automatic features that let you tackle even the toughest photographic situations - fearlessly. From the Mode Dial, simply select the Image Zone setting that matches your scene and the Rebel T2 automatically picks the optimal settings. Or choose Creative Zone settings for complete manual control.
The Fastest Autofocus In Its SLR Class
The Rebel T2 superimposes seven focusing points across the viewfinder for tack sharp focus automatically - even when your subject is off center. Or set your own focusing point using the Cross-Key AF Point Selector. You can also choose from three Autofocus Modes - One-Shot AF, AI Focus AF and AI Servo AF - to handle a wide range of subjects and environments with superior precision. The Rebel T2 also gives you the fastest shutter speed in its class - 1/4000 second so you can shoot as rapidly as life demands.<br/> To deliver the perfect exposure that makes unforgettable pictures, the Rebel T2 also has a 35-zone metering system. It's linked to the seven autofocus points so even when you're confronted with complex conditions, like backlight, you'll get superb pictures. To further refine exposure settings, there's an Orientation Detection Sensor that automatically determines the position of the earth and sky in your photo and makes the appropriate adjustments. <br/> 7-Point AF
A Camera that Feels Like It's Made for You
Comfort counts when you're shooting. So the Rebel T2 was equipped with a secure grip made for one-handed operation. Better still, the Shutter Button, Main and Mode Dials, LCD Panel Buttons and the Cross-Key AF Point Selector are all within easy reach. You can even check the camera status in the dark, thanks to the backlit, oversized LCD panel.
Error-Free Operation
When shooting is action-packed, it's not always easy to keep track of all the essentials. That's where the Rebel T2 shines. Its Safety Shutter-release Lock prevents you from shooting if you forget to load film or there is no lens attached. There's also a Camera Shake Warning that sounds when shutter speed is too slow to give you the pictures you want. <br/> Safety Shutter-release Lock
An Unprecedented Level of Flash Control
Equipped with an extra-powerful, super-bright built-in flash and the very latest E-TTL II flash technology, the Rebel T2 delivers new flash precision. Using distance-based information, the new E-TTL II flash metering system automatically analyzes your scene and adjusts for variations in brightness, reflections and framing. This gives your pictures the true-to-life, even illumination that sets them apart from ordinary snapshots. AE Lock&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160; FE Lock
EF Lenses Open New Worlds
The advanced design and superior quality of Canon's internationally acclaimed EF Lenses mean that they can keep pace with your ever-advancing photographic skills. Engineered for maximum compatibility, the EF Lenses work seamlessly with the on-board systems of both the EOS Rebel and EOS Digital Rebel cameras. To provide you with a full range of creative possibilities, Canon has created over 50 EF Lenses&#160;- from 14mm to 600mm&#160;- to meet your needs.
EOS Rebel T2
EOS Rebel T2 Rebel T2 Body EF 28-90mm f/4-5.6 III Wide Neck Strap EW-100BM Two 3V Lithium Batteries (CR-2)
Specifications
Type and Major Components
Type
35mm focal plane shutter SLR (Single Lens Reflex) autofocus/autoexposure camera with built-in motor drive and retractable flash
Compatible Lenses
Canon EF Lenses
Lens Mount
Canon EF mount (electric signal transfer system)
Viewfinder
Type
SLR-type, eye-level roof prism mirror
Picture Coverage
90% vertical and horizontal coverage of actual picture area
Magnification
0.7x magnification with 50mm lens at infinity
Dioptric Adjustment
-2.5 - +0.5 dpt. Adjustable by user
Focusing Screen
Fixed, full-surface new laser-matte screen marked with focusing points
Mirror
Quick-return half mirror
Viewfinder Information
Shutter speed (If unsuitable, blinks at 2 Hz as a warning), Aperture (If unsuitable, blinks at 2 Hz as a warning), AE lock/FE lock Indicator (Partial metering at center), Exposure level scale with dot indicators in 1/2 stop increments. (+/-2 stops), Flash ready light (blinks at 2 Hz if flash range is ineffective during FE lock), High-speed sync indicator (FP flash), In-focus indicator (Blinks at 2 Hz if focus cannot be achieved)
Depth-of-Field Preview
Enabled with depth-of-field preview button
Autofocus
Type
7-point AF
Focusing Point Selection
The focusing point can be selected by camera (Automatic) or by user (manual); manual AF point selection possible M, P, Tv, Av, and M exposure mode only
Focus Modes
User-selectable M, P, Tv, Av, and M exposure mode; in other modes, set automatically by camera
1. One-Shot AF: camera locks focus in stationary subjects
2. AI Servo AF: camera continually tracks moving subjects
3. AI Focus AF: camera assesses subject, and automatically selects One-Shot AF or AI Servo AF.
Focus Operation
Autofocus is activated by pressing the shutter button halfway
AF Working Range
EV 1-18 (at ISO 100)
AF Assist Method
Via built-in flash: pulses repeatedly low light if flash is raised.
Exposure Control
Metering Modes
1. TTL full-aperture metering using a 35-zone SPC (Silicon Photocell). Three metering patterns available. a. 35-zone Evaluative Metering. b. Central partial metering which covers approximately 9.5% of finder area. c. Center weighted average metering (Set automatically in M mode.)
2. E-TTL II: 35-zone preflash metering using Speedlite 550EX, 420EX, 220EX or EX series Macro flashes MR-14EX or MT-24EX. EX series Speedlites or built-in flash required.
Metering Range
EV 1-20 (with 50mm f1.4 lens at ISO 100)
Exposure Modes
1. Intelligent program AE with variable shift (P)
2. Shutter speed-priority AE (Tv)
3. Aperture-priority AE (Av)
4. Auto DEP (A-DEP)
5. Full Auto (Intelligent program AE, unshiftable)
6. Programmed Image Zone Modes: Portrait, Landscape, Close-up, Sports, Night Portrait and Flash Off
7. E-TTL II program flash AE
8. Metered manual
Multiple Exposure
Up to 9 exposures can be preset. Automatically clears upon completion. Cancellable midway
Exposure Compensation
1. Auto Exposure Bracketing (AEB) up to +/-3 EV in 1/2 stops
2. Manual exposure compensation up to +/-3 EV in 1/2 stops.
3. Available in the Full Auto and Programmed modes
Shutter
Type
Vertical-travel, focal plane shutter with all speeds electronically controlled. Front and rear shutter curtains both have dedicated electromagnetic release control. (Curtain speed: 6.3ms/24mm)
Shutter Speeds
30 to 1/4000 sec., Bulb; X-sync at 1/125
Built-in-Flash
Type
Built-in E-TTL II autoflash for high-precision, stable flash exposures (FE Flash enabled)
Flash AE Controls
13m/42.6 ft. (ISO 100)
Flash Coverage Angle
Covers the angle of view of 28mm lens
Flash Duration
1ms or less
Recycling Time
Approx. 2 seconds. The icon lights in the viewfinder when ready
Color Temperature
Equivalent to daylight
Red-Eye Reduction
Red-Eye Reduction lamp lights while the shutter button is pressed halfway and focusing and metering are achieved
Film Transport
Film Loading
Automatic prewind system. After film positioning and back cover closure, the film automatically winds to end of roll. As pictures are taken, film is rewound one frame at a time back into cassette.
Film Speed Setting
ISO 25-5000 automatically set in 1/3 stop increments according to DX code. Can also be set manually from ISO 6-6400 in 1/3 stop increments
Film Transport
Single-frame advance or continuous advance set automatically according to the picture-taking mode
Film Wind
One of two modes can be set: Single Frame and Continuous. (In Continuous Mode, with AF locked, approximately 3.0 fps and in AI Servo AF Mode, approximately 2.8 fps)
Film Rewind
Automatically rewinds at the end of roll. Mid-roll rewinding possible
Power Source
Battery
Two CR2 lithium batteries housed inside the camera grip
Battery Check
Battery level is displayed by the battery level indicator on the LCD panel. Battery level is indicated in one of four levels.
Dimensions
Size (W x H x D)
5.1 x 3.5 x 2.5 in./130 x 90 x 64mm
Weight
12.9 oz./365g (without batteries)
Other
Date/Time Imprint
Day/Month/Year, Month/Day/Year, Year/Month/Date, Date/Hour/Minute (Only available with the EOS Rebel T2 Date model)
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EOS Rebel T2 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
