Web Content Viewer
Actions
EOS Rebel Ti
Support EOS 35mm SLR Cameras
Features
EOS Rebel Ti leads SLR photography into the future with a design that's intelligently planned as well as artfully executed.  It's comfortable to hold, carry and use...intuitive so you'll start having fun right away...and loaded with head-turning Canon style.
Rebel Ti's Autofocus is not only the fastest of any camera in its class, it's the smartest.  It knows where your subject is, virtually anywhere in the frame.  It knows whether your subject is moving and predicts its speed.  It even knows how you're holding the camera.  The result?  Carefree shooting with spectacular results.
Proper exposure makes good shots into great ones, and with the Rebel Ti, you can trust the automatic exposure system to do all the work.  From sunny beach and sky scenes to nightscapes and everything in between, exposure is consistent and accurate.
Take as much, or as little, creative control as you want!  With easy preprogrammed shooting options plus semi to full manual control over exposure and focus, you'll set your own pace for discovering the excitement of SLR photography.
EOS Rebel Ti Kit Contents
EOS Rebel Ti Kit Contents EOS Rebel Ti Body Wide Neck Strap EW-100BM 3V Lithium Batteries (CR-2)
Specifications
Type and Major Components
Type
35mm focal plane shutter SLR (Single-Lens Reflex) autofocus/autoexposure camera with built-in motor drive and retractable flash.
Compatible Lenses
Canon EF lenses
Lens Mount
Canon EF mount (electronic signal transfer system)
Viewfinder
Type
SLR-type, eye-level roof prism mirror
Picture Coverage
90% vertical and horizontal coverage of actual picture area
Magnification
0.70x magnification with 50mm lens at infinity
Dioptric Adjustment
-2.5 - +0.5 dpt. Standard: Adjusted to -1. (18.5mm eye relief)
Focusing Screen
Fixed, full-surface new laser-matte screen marked with focusing points.
Mirror
Quick-return half mirror
Viewfinder Information
Shutter speed (If unsuitable, blinks at 2 Hz as a warning.), Aperture (If unsuitable, blinks at 2 Hz as a warning.), AE lock/FE lock Indicator(Partial metering at center.), Exposure level scale with dot indicators in 1/2-stop increments. (+/-2 stops), Flash ready light (blinks at 2 Hz if flash range is ineffective during FE lock), High-speed sync indicator (FP flash), In-focus indicator (Blinks at 2 Hz if focus cannot be achieved.)
Depth-of-Field Preview
Enable with depth-of-field preview button.
Autofocus
Type
TTL-SIR (Secondary Image Registration) CMOS sensor
Focusing Point Selection
The focusing point can be selected by camera (Automatic) or by user(manual).
Focus Modes
1. Autofocus: One of the following two Af modes is set automatically depends on the picture taking mode. The shutter does not release until focus is achieved.
a. One-Shot AF: Autofocus looks when focusing is achieved.
b. Predictive AI Servo AF: Continuously tracks subject movement and achieves focus before the exposure starts.
C. AI Focus AF for automatic switching between One-Shot Af and predictive AF for moving subjects.
2. Manual Focus: Setting the lens' focus mode switch to MF enables manual focusing with the focusing ring.
Focus Operation
Autofocus is activated by pressing the shutter button halfway.
AF Working Range
EV 1-18 ( at ISO 100)
AF Assist Method
Beam automatically emitted when necessary and aimed at the area covered by the active focus point.
Exposure Control
Metering Modes
1. TTL full-aperture metering using a 25 zone SPC (Silicon Photocell). Three metering patterns available: a. 35-zone Evaluative Metering. b. Central partial metering which covers approximately 9.5% of finder area. c. Center weighted average metering (Set automatically in M mode.)2. E-TTL: 7 point, 35-zone preflash metering using Speedlite 550EX, 420EX, or 220EX.3. A-TTL, TTL Flash Metering: off-the-film, 2-zone A-TTL autoflash linked to focusing points, 3-zone TTL autoflash metering
Metering Range
EV 1-20 (with 50mm f1.4 lens at ISO 100)
Exposure Modes
1. Intelligent program AE with variable shift.2. Shutter speed-priority AE3. Aperture-priority AE4. Auto DDEP5. Full Auto (Intelligent program AE, unshiftable)6. Programmed Image Control Modes: Portrait, Landscape, Close-up, Sports, Night Portrait and Flash Off7.E-TTL program flash AE8.A-TTL program flash AE9. TTL program flash AE10. Metered manual
Multiple Exposure
Up to 9 exposures can be preset. Automatically clears upon completion. Cancellable midway.
Exposure Compensation
1. Auto exposure Bracketing (AEB) up to +/-2EV in 1/2 steps2. Manual exposure compensation up to +/-2EV in 1/2 steps.3. Unavailable in the Full Auto and Programmed modes.
Shutter
Type
Vertical-travel, focal plane shutter with all speeds electronically controlled. Front and rear shutter curtains both have dedicated electromagnetic release control. (Curtain speed: 6.3ms/24mm)
Shutter Speeds
30 to 1/2000 sec., Bulb; X-sync at 1/90. Can be set in 1/2 stop increments.
Built-in-Flash
Type
Built-in, retractable TTL autoflash head in the pentaprism. Auto pop-up and serial-controlled.
Guide Number
39 ft. / 12m (ISO 100)
Flash Coverage Angle
Covers the angle of view of 28mm lens.
Flash Duration
1ms or less
Recycling Time
approximately 2 seconds. The icon lights in the viewfinder when ready
Color Temperature
Equivalent to daylight
Shooting Distance Range
Red-Eye Reduction
Red-Eye Reduction lamp lights while the shutter button is pressed halfway and focusing and metering are achieved.
Film Transport
Film Loading
Automatic prewind system. After film positioning and back cover closure, the film automatically winds to the 1st frame.
Film Speed Setting
ISO 25-5000 automatically set in 1/3 step increments according to DX code. Can also be set manually from ISO 6-6400 in 1/3 step increments.
Film Transport
Single-frame advance or continuous advance set automatically according to the picture-taking mode.
Film Wind
One of two modes can be set: Single Frame and Continuous. (In Continuous Mode, with AF locked, approximately 2.5 fps and in AI Servo AF Mode, approximately 1.3 fps.)
Film Rewind
Automatically rewinds at the end of roll. Midroll rewinding possible.
Shooting
Shooting Modes
Full Auto, Portrait, Landscape, Close-up, Sports, Night Scene, Flash off, Intelligent Program AE, Shutter Speed-Priority AE, Aperture-Priority AE, Manual Exposure, Automatic Depth-of-Field AE
Continuous Shooting
Approx 2.5 images/sec
Power Source
Battery
Two CR2 lithium batteries housed inside the camera grip
Battery Check
Battery level is displayed by the battery level indicator on the LCD panel. Battery level is indicated in one of four levels.
Shooting Capacity
Dimensions
Size (W x H x D)
5.12 x 3.46 x 2.52 in./ 130 x 88 x 64mm
Weight
12.9 oz. / 365g without batteries
Other
Date/Time Imprint
(EOS Rebel Ti Date only) Day/Month/Year, Month/Day/Year, Year/Month/Date, Date/Hour/Minute
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EOS Rebel Ti that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
