Web Content Viewer
Actions
Speedlite 200E
Support Flashes
Speedlite 200E Body Kit Contents
Speedlite 200E Body Kit Contents Speedlite 200E Body Instruction Manual Warranty Card
Specifications
Flash
Type
Clip-on type TTL automatic flash with directly coupled contacts. Series control system.
Guide Number
20 m/65 ft.(ISO 100)
Flash Coverage
Covers the angle of view of a 35mm lens.(Covers the angle of view of a 28mm lens with the optional wide adapter attached.)
Number of Flashes
400 - 4000 with new alkaline batteries.
Recycling Time
Approx. 0.5 to 4 sec.
Flash Duration
1 ms. or less.
Sync Timing
First curtain sync only.
Flash Control System
TTL automatic control by metering light reflected from the film plane.
Shooting Distance Range
0.7-7m/2.3-23 ft. (Based on ISO 100 film. The shooting distance range changes according to film speed.)
Effective Distance Range
1-5m/3.3-16.4 ft.
AF Auxiliary Light
Automatically emitted when the shutter button is pressed halfway if necessary.
General
Power Source
Four AA-size batteries.
Dimensions
64 (W) X 104 (H) x 41 (D)mm / 2-1/8 (W) x 4-1/16 (H) x 1-5/8 (D)
Weight
130g/4.6 oz without batteries230g/8.1 oz with batteries.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Speedlite 200E that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
