Web Content Viewer
Actions
Speedlite 480EG
Support Flashes
Speedlite 480EG Kit Contents
Speedlite 480EG Kit Contents Speedlite 480EG Body TTL Shoe Cord E Wide Panel 480EG-2 & Tele Panel 480EG-135 Instruction Booklet Warranty Card
Specifications
Flash
Type
Grip-style TTL automatic, external sensor-based automatic and manual flash (with bounce function).
Via TTL Shoe Cord E, Synchro Cord 480 or with optional slave unit as off-camera cordless light source.
Guide Number
160 (ISO 100, ft. @ 35mm coverage angle).
Flash Coverage
20mm-135mm (using wide and tele panels).
Number of Flashes
Alkaline-Manganese batteries: 100 to 700
Ni-Cd Battery Pack: 90 to 600
Recycling Time
With Alkaline-Manganese batteries: 0.2 to 17 sec.
With Ni-Cd Battery Pack: 0.2 to 6 sec.
Color Temperature
Same as Daylight.
Flash Duration
1/850 sec. to 1/20,000 sec.
Synchronization
First curtain, X-Sync.
Flash Control System
TTL automatic control by metering light reflected from the film plane (with TTL Shoe Cord E connection); External sensor auto flash control (with Synchro Cord 480); Variable-power Manual.
Flash Coupling Range
TTL autoflash; 2.4-104.9 ft. (with 50mm f/1.4 @ ISO 100)
General
Power Source
With Transistor Pack E: Six size-C LR14 alkaline-manganese (Battery Magazine TP) or NR-SC Ni-Cd (sealed Ni-Cd Pack TP) batteries.
Dimensions
Main Unit: 3-7/8 x 10-1/16 x 4-1/2 in. (98 x 256.5 x 114.3mm)
With clamp and bracket: 11-7/16 x 10-1/16 x 4-1/2 (291 x 256.5 x 114.3mm)
Weight
Main unit: 25.03oz. (715g) without batteries
With clamp and bracket: 37.03oz. (1,065g) without batteries
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Speedlite 480EG that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
