Web Content Viewer
Actions
Looking for support for this product?   Product Support
Looking to register this product?   Register Now
Wireless File Transmitter WFT-E4 II A
MSRP: $699.99
Features
It's easy to connect the EOS 5D Mark II and WFT-E4 II A to a computer via a wired or wireless setup. Whether with a Pushbutton Configuration (PBC Method), Wi-Fi Protected Setup (WPS) PIN Method, or through a camera-controlled connection wizard, connections are achieved quickly, simply and securely. No matter the location, there's a connection protocol appropriate for the parameters of the shoot.
The EOS 5D Mark II with WFT-E4 II A attached can pair with a computer for remote Live View composing, shooting and image transfer. This means easy control of the shoot through a computer, netbook, iPod Touch or iPhone, onsite or off, and is a simple and effective way to confirm and shoot no matter the physical location of the subject and photographer.
With the WFT-E4 II A, users have a number of different options for image transfer both on and offsite. When connected to an offsite server, it's simple to set the camera and WFT-E4 II A to shoot and upload images directly through fast IEEE 802.11 a/b/g networks. Images can simultaneously be saved to the camera or to a tethered hard drive.
GPS devices can be connected to the WFT-E4 II A to transmit location and elevation data along with the EXIF data for each image. With Bluetooth, photographers can fully employ GPS units without the concern of tangled wires, and can connect directly to Bluetooth compatible printers. With USB, the WFT-E4 II A can even be setup for direct recording to an external storage device.
Camera linking with the WFT-E4 II A attached makes it possible for up to 10 cameras to shoot simultaneously. Up to 10 cameras can be connected independent of a network, and set up to take a shot the instant the shutter is released on the Master (Main) camera. With an effective range up to approximately 330 feet, this linked shooting is invaluable for multi-angle coverage.
Specifications
Type
Image transfer accessory compatible with IEEE 802.11a, IEEE 802.11b, IEEE 802.11g wireless LAN and Ethernet (wired LAN) (IPsec-compatible). Can be connected via USB to external media, GPS devices and Bluetooth units.
Compatible Cameras
EOS 5D Mark II
FTP Transfer
Transfer images over a network to FTP servers
EOS Utility
EOS Utility-based control of cameras over a network
WFT Server
Browser-based remote capture and downloading of images over a network
Linked Shooting
Wirelessly trigger shooting by Slave cameras linked to a Master camera
Transmission Range
Approx. 328 ft. / 100 m from the master camera (when signal strength is favorable)
Camera Connection
System extension terminal
Wired Lan Connection
Ethernet RJ-45 port
External Device Connection
Hi-Speed USB port (for attaching external media, GPS devices, and Bluetooth units)
* Devices can be bus-powered.
Power Supply
One LP-E6 battery pack
Battery Level Indicator
6-level indicator
Image Transfer Capacity
NOTE:
About the same number of images can be transferred at room temperature (73°F/23°C) and at low temperatures (32°F/0°C). Using a fully charged LP-E6. Under Camera & Imaging Products Association (CIPA) conditions for testing shooting capacity, when using automatic image transfer with images that are approximately 6MB. Fewer images can be transferred if the wireless LAN transfer rate drops, and for consecutive image transfer over wireless LAN. Fewer images can be transferred when using bus-powered external media or GPS devices.
W x H x D
5.9 x 1.8 x 3.0 in./149.1 x 45.3 x 76.1 mm
Ounces/grams
Approx. 12.7 oz./360 g
Temperature
32°F to 104°F/0°C to 40°C
Humidity
85% or less
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Wireless File Transmitter WFT-E4 II A that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Loading...
 Return to Top
