Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
Wireless File Transmitter WFT-E2 II A
Wireless File Transmitters & Adapters
Canon Store: $
Overview
Compatible with the EOS-1D Mark IV, plus the EOS-1D Mark III (via firmware upgrade) and the EOS-1Ds Mark III (also via firmware upgrade), the compact, new Canon WFT-E2 II A raises the bar in what can be achieved wirelessly with an EOS camera. Its IEEE 802.11 a/b/g is compatible for fast communication, it connects easily and works with WPS setups, and it has Canon's amazing Camera Linking Function and WFT Server Remote Live View shooting. Built-in USB Host compatibility allows for connection to external hard drives, and select GPS units either by USB cable or optional Bluetooth dongle. Designed to mount directly to the side of a compatible EOS camera, it maintains all-weather-resistant seals and the rugged durability of the camera while affording access to all the camera's buttons and controls.
Features
Specifications
Type
Image transfer accessory compatible with IEEE 802.11a, IEEE 802.11b, IEEE 802.11g wireless LAN and Ethernet (wired LAN) (IPsec-compatible). Can be connected via USB to external media, GPS devices and Bluetooth units.
Compatible Cameras
EOS-1D Mark IV
These design specification details apply when attached to EOS-1D Mark IV. EOS-1Ds Mark III*, EOS-1D Mark III*
*Requires an update to firmware compatible with EOS-1Ds Mark III. After this, specifications are equivalent to those of WFT-E2A with the addition of IEEE 802.11a wireless networking.
FTP Transfer
Transfer images over a network to FTP servers
EOS Utility
EOS Utility-based control of cameras over a network
WFT Server
Browser-based remote capture and downloading of images over a network
Linked Shooting
Wirelessly trigger shooting by slave cameras linked to a master camera
Transmission Range
Approx. 328 ft. / 100 m from the master camera (when signal strength is favorable)
Camera Connection
System extension terminal
Wired Lan Connection
Ethernet RJ-45 port
External Device Connection
Hi-Speed USB port (for attaching external media, GPS devices, and Bluetooth units)
* Devices can be bus-powered.
Power Supply
Powered by the camera
Image Transfer Capacity
NOTE:
Using a fully charged LP-E4. Under Camera & Imaging Products Association (CIPA) conditions for testing shooting capacity, when using automatic image transfer with images that are approximately 6MB. Fewer images can be transferred if the wireless LAN transfer rate drops, and for consecutive image transfer over wireless LAN. Fewer images can be transferred when using bus-powered external media or GPS devices. If the remaining battery level drops below 19%, captured images cannot be transferred or backed up to external media.
W x H x D
1.0 x 3.8 x 1.3 in./26.0 x 97.7 x 31.8mm
Ounces/grams
Approx. 2.8 oz./80g
Temperature
32°F to 113°F/0°C to 45°C
Humidity
85% or less
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Wireless File Transmitter WFT-E2 II A that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
AC Adapter Kit ACK-E4
Canon ACK-E4 AC Adapter Kit for Canon EOS 1D Mark III SLR Digital Camera.
MSRP: 160.0
Angle Finder C (incl. Adapter Ec-C, Ed-C)
Angle Finder C lets you adjust the viewing angle while providing a 2.5x magnification for critical focusing with a full screen image that also shows exposure data.
MSRP: 280.0
Anti-Fog Eyepiece Eg
The Anti-Fog eyepiece uses specially treated advanced-process glass, which prevents condensation or fogging. Designed for use in warm and humid or cold weather when fogging is most likely to occur, and attaches easily to reduce condensation and help you maintain a clear view of your subject.
MSRP: 60.0
Battery Charger LC-E4
*Please note: You cannot charge any batteries other than Battery Pack LP-E4 with this charger.
MSRP: 400.0
Battery Pack LP-E4N
Designed to be used with the EOS-1D X, the LP-E4N is a high-capacity (2450 mAH) lithium-ion battery pack, offering approximately 10% larger capacity than the LP-E4. Exact battery info can be viewed on the camera's menu.
Belkin Mini HDMI RTL
This cable is designed for connecting to your television's component input so that you can playback both high-definition video and multichannel, digital audio quality through just one cable.
MSRP: 19.99
CB-570 Car Battery Cable
Combine the CB-570 with the CG-570 Battery Charger and charge your batteries directly from your car for the ultimate in power supply convenience.
MSRP: 50.0
Deluxe Back Pack 200EG
Backpack with carry handle and detachable strap. Holds 1-2 Cameras bodies, 3-4 lenses and accessories. Inside measurements (W x H x D): 10 x 14.75 x 5 inches. Rugged nylon, water-repellent, urethane coated for extra durability. Well-arranged divider system for secure storage and easy access. Lightweight construction, padded shoulder straps and back for comfort. Front webbing ideal for storing a light jacket. Tripod carrying straps. Color: Black with Olive.
MSRP: 75.0
Deluxe Gadget Bag 10EG
This gadget bag is an excellent value, with all the quality material of the Professional 1, at a slightly smaller size. It is designed to hold two 35mm SLR bodies, 5 - 8 lenses, plus film and accessories. It features full padding and interior partitions, leather reinforcing, high strength quick-release buckles, padded exterior pockets, leather snap handle and shoulder strap. Size: 10.5" (W) x 8"(H) x 7.5" (D)
MSRP: 130.0
Deluxe Tripod 200
This lightweight, high quality tripod is designed for easy portability and maximum stability. It features a 3-way pan head for precise control and smooth movement. The 3-section tubular leg construction allows for exceptional stability indoors or out.
MSRP: 45.0
Dioptric Adjustment Lens Eg (+1)
The Dioptric Adjustment Lens provides near- and far-sighted users a clear viewfinder image without the use of eyeglasses. The lens fits into the eyepiece holder of you EOS camera. Please see the Compatibility tab for a list of compatible EOS cameras.
MSRP: 45.0
Dioptric Adjustment Lens Eg (+2)
MSRP: 45.0
Dioptric Adjustment Lens Eg (+3)
MSRP: 45.0
Dioptric Adjustment Lens Eg (-2)
MSRP: 45.0
Dioptric Adjustment Lens Eg (-3)
MSRP: 45.0
Dioptric Adjustment Lens Eg (-4)
MSRP: 45.0
Dioptric Adjustment Lens Eg (0)
MSRP: 45.0
EOS-1D Mark IV
New 45-point Area AF sensor including 39 cross-type AF points plus improved AI Servo II AF algorithm Wide ISO range expandable to 102400 EOS HD movie with manual exposure control and multiple frame rates 16.1 Megapixel APS-H CMOS, Dual DIGIC 4
Eyecup Eg
Canon Eyecup EG for EOS 1D and 1Ds Mark III Digital Cameras.
MSRP: 20.0
FOCUSING SCREEN EC-S
The Canon Ec-S Focusing Screen with Canon's exclusive Super Precision Matte technology makes it easy for professional photographers to determine the precise point of sharpest focus during manual focusing. This is because the microlens on the screen's matte is optimally shaped to increase defocusing near the point of focus.
MSRP: 45.0
Focusing Screen Ec-A
MSRP: 45.0
Focusing Screen Ec-CII
MSRP: 45.0
Focusing Screen Ec-CIV
The Canon EC-CIV Focusing Screen laser matte achieves easier focusing and good background blur. It is brighter, less grainy and better balanced.
MSRP: 45.0
Focusing Screen Ec-D
The Ec-D focusing screen is a matte field with grid lines that assist in composition for close-up and copy work. The camera's AF points remain fully visible. It is for general photography.
MSRP: 45.0
Focusing Screen Ec-H
The Canon Ec-H Focusing Screen is a matte field with vertical and horizontal scales marked in mm. It is for close-up and microphotography, and for determining magnification ratios and composition.
MSRP: 45.0
Focusing Screen Ec-I
MSRP: 45.0
Focusing Screen Ec-L
MSRP: 45.0
Focusing Screen Ec-N
The Ec-N focusing screen has a Bright Laser Matte field with an AF ellipse center focusing spot. It is for general photography. Standard for EOS 3.
MSRP: 45.0
Focusing Screen Ec-R
The Canon Ec-R Focusing Screen compensates for decreased brightness due to low reflection from pellicle mirror. It is an overall bright laser matte and incorporates center spot metering. Standard for EOS 1N RS.
MSRP: 45.0
HTC-100
Mini-HDMI Cable: connects Canon HD Camcorders/select PowerShot Cameras to HDMI compatible TV.
MSRP: 80.0
Hand Strap E1
Hand strap E1 requires Battery Grip BG-E2
MSRP: 30.0
Hand Strap E2
The Canon Hand Strap E2 is designed to add support and comfort to hand-holding a Canon SLR camera. The strap attaches to the eyelets at the sides of the camera.
MSRP: 60.0
LC-5 Wireless Controller for EOS
Extended range wireless controller system.
MSRP: 680.0
LENS CASE 200
Original Data Security Kit OSK-E3
MSRP: 900.0
Professional Gadget Bag 1EG
Large gadget bag for the traveling professional. Size: 14.2" (W) x 8.7"(H) x 8.3"(D). This bag is designed to hold two 35mm SLR camera bodies, seven to ten lenses, flash, film, accessories, etc. It features full padding and interior dividers for cameras and lenses, as well as padded outside pockets. Features adjustable tripod straps, and high strength buckles for the main compartment. The Canon logo is embroidered on the top flap.
MSRP: 150.0
Professional Neck Strap
Replacement strap for all EOS Series SLR cameras.
MSRP: 15.0
Remote Switch RS-80N3
Remote switch for EOS cameras with the N3-type socket to prevent camera shake for super telephoto shots, macro photography shots and bulb exposures. The Remote Switch works just like a shutter button, enabling halfway or complete pressing. It has a shutter-release lock and a 2.6ft/80cm cord.
MSRP: 70.0
Timer Remote Controller TC-80N3
Remote switch for EOS cameras with the N3-type socket. This remote switch has a self-timer, interval timer, long exposure timer and exposure-count setting feature. The timer can be set from 1 second to 99 hours. A new dial enables you to easily enter the numeric settings with a single thumb. It has an illuminated LCD panel and a 2.6ft/80cm cord.
MSRP: 210.0
USB Cable IFC-200U
The Canon IFC-200U USB Interface Cable enables you to transfer your camera pictures to a computer fast. The cable connects to your camera and to the USB port on your PC or MAC Computer. Comes standard with the EOS 1Ds Mark III, 1D Mark IV, 1D Mark III, 5D Mark II, 7D, 60D, 50D, 40D, Rebel T2i, Rebel T1i, Rebel XSi and Rebel XS. Please see Compatibility tab for compatible models.
MSRP: 35.0
USB Cable IFC-500U
The Canon IFC-500U USB Interface Cable enables you to transfer your camera pictures to a computer fast. The cable connects to your camera and to the USB port on your PC or MAC Computer. Please see Compatibility tab for compatible models.
MSRP: 50.0
Video Cable AVC-DC400ST
Enables direct image display from the EOS to an HD television or a similar display device. Comes standard with the EOS 1D Mark IV, 7D, 60D, Rebel T3i and Rebel T2i. Please see Compatibility tab for compatible models.
MSRP: 25.0
Wireless File Transmitter WFT-E2A
Brochures
Product Compatibility
EOS DSLR
- ${title}${badge}
