Web Content Viewer
Actions
Wireless File Transmitter WFT-E5A
Wireless File Transmitters & Adapters
Features
Connecting the camera with WFT-E5A attached to a wired or wireless network couldn't be simpler. There are three ways to connect: With a Pushbutton Configuration (PBC Method), Wireless Protected Setup (WPS) PIN Method, or with a connection wizard through EOS Utility on the camera. No matter the situation or the level of security necessary, the WFT-E5A is designed to provide safe, speedy connections.
With the WFT-E5A, and Canon EOS Utility, photographers can pair their camera wirelessly through a browser or dedicated software for complete remote Live View composing, shooting and image transfer. This means easy control of the shoot through a computer, netbook, iPod Touch or iPhone, onsite or off, and is a simple and effective way to confirm and shoot no matter the physical location of the subject and photographer.
GPS devices can be connected to the WFT-E5A to transmit location and EXIF data for each image. With Bluetooth, photographers can fully employ GPS units without the concern of tangled wires and can connect directly to Bluetooth printers. With a USB connection, not only are GPS connections possible, connections to a hard drive for direct recording or backup are possible as well.
The WFT-E5A is compatible with all Digital Living Network Alliance (DLNA) compliant devices. With the WFT-E5A, the EOS 7D can create a dedicated DLNA media server, allowing numerous points of access to images, instantaneously and wirelessly. This means that not only can media recorded on the EOS 7D be uploaded wirelessly to a computer, they can also be viewed on DLNA compatible televisions, video players and more.
Camera linking with the WFT-E5A makes it possible for up to 10 cameras to shoot the same subject simultaneously, from different angles. Cameras can be connected without a WAP or network and set to shoot the instant the shutter is released on the Master camera. With an effective distance range up to approximately 330 feet, this linked shooting is invaluable for true multi-angle shooting.
Specifications
Type
Image transfer accessory compatible with IEEE 802.11a, IEEE 802.11b, IEEE 802.11g wireless LAN and Ethernet (wired LAN) (IPsec-compatible). Can be connected via USB to external media, GPS devices, and Bluetooth units.
Compatible Cameras
EOS 7D
FTP Transfer
Transfer images over a network to FTP servers
EOS Utility
EOS Utility-based control of cameras over a network
WFT Server
Browser-based remote capture and downloading of images over a network
Media Server
Transfer images over a network to DLNA-compatible media players
Linked Shooting
Wirelessly trigger shooting by Slave cameras linked to a Master camera
Camera Connection
System expansion terminal
Wired Lan Connection
Ethernet RJ-45 port
External Device Connection
Hi-Speed USB port (for attaching external media, GPS devices and Bluetooth units)
* Devices can be bus-powered.
Power Supply
One LP-E6 battery pack
Battery Level Indicator
6-level indicator
Image Transfer Capacity
NOTE:
About the same number of images can be transferred at room temperature (73°F/23°C) and at low temperatures (32°F/0°C). Using a fully charged LP-E6. Under Camera & Imaging Products Association (CIPA) conditions for testing shooting capacity, when using automatic image transfer with images that are approximately 6.1MB. Fewer images can be transferred if the wireless LAN transfer rate drops, and for consecutive image transfer over wireless LAN. Fewer images can be transferred when using bus-powered external media or GPS devices.
W x H x D
5.8 x 1.8 x 3.0 in./147.4 x 45.0 x 76.8 mm
Ounces/grams
Approx. 12.5 oz./355 g
Temperature
32°F to 104°F/0°C to 40°C
Humidity
85% or less
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Wireless Transmitter WFT-E5A that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Product Compatibility
EOS DSLR
This is to make Misc appear on the page when needed.
 Return to Top
