Web Content Viewer
Actions
Wireless File Transmitter WFT-E6A
Wireless File Transmitters & Adapters
Features
The new WFT-E6A is compatible with the EOS-1D X and offers a wireless-only LAN function for enhanced versatility when transferring data. It now also supports IEEE 802.11n to provide safer and faster wireless LAN transfers than previous models and has a new image resend features that ensures all images get transferred, even if a wireless signal drop interrupts transmission.
Wireless connectivity is gradually becoming an industry standard; many photographers are seeking convenient methods to transfer important image data securely and faster without the use of cables and wires. Canon developed the new WFT-E6A to support IEEE 802.11n, which provides seamless wireless transfers of large files at a speed roughly 3x faster than previous transmitters. For even more versatility, an internal Bluetooth function (Bluetooth v2.1 + EDR) is included. Bluetooth v2.1 + EDR allows the transmitter to have a secure connection to Bluetooth-compatible GPS devices while handling high-volume data transfers.
Syncing cameras just got easier with the WFT-E6A's new wireless time syncing feature. Although time synchronization can be performed by the EOS-1D X via wired LAN connection, the WFT-E6A provides the option to do it wirelessly. Event photographers will find this especially convenient as now its possible to make adjustments without having to use a direct connection to a computer.
Portability is just as important as how well a product functions. Offering a compact design, the WFT-E6A is lighter and smaller than its predecessors. Built to withstand inclement weather, this transmitter has the same dustproof and waterproof construction used in the EOS-1D X body. A compact and durable design ensures that equipment can be safely brought into rough environments, making the WFT-E6A an ideal accessory for demanding photographers constantly on the move.
No different from other wireless file transmitters, the WFT-E6A still retains the linked multi-camera shooting function. It's possible to link up to 10 cameras to take a picture of one subject simultaneously. An enhancement improves linkage to a WFT server by allowing it to start simultaneously when the master camera and slave cameras are manually connected. Each slave camera will have its own IP address to gain access to the server allowing the user to conveniently browse and load images. If desired, when the user accesses the master camera to release the shutter, the slave cameras, in turn, will perform the same action in coordination.
Type
Image transfer accessory compatible with IEEE 802.11a, IEEE 802.11b, IEEE802.11g and IEEE 802.11n wireless LAN support (IPsec-compatible). Can support GPS devices with an internal Bluetooth function.
Compatible Cameras
EOS-1D X, EOS C300, EOS C300 Mark II, EOS C500, EOS-1D C
FTP Transfer
Transfer images over a network to FTP servers
EOS Utility
EOS Utility-based control of cameras over a network
WFT Server
Browser-based remote capture and downloading of images over a network
Linked Shooting
Wirelessly trigger shooting by Slave cameras linked to a Master camera
Transmission Range
Linked Shooting: Approx. 328 ft. / 100 m from the master camera when signal strength is favorable
Wireless LAN: Approx. 492 ft. / 150 m
  • With no obstructions between the transmitting and receiving antennas and no radio interference
  • When a large, high-performance antenna is installed at a wireless LAN access point
Bluetooth v2.1 + EDR: Approx. TBA ft. / TBA m
Wireless Time Syncing
  • Master camera time is set for the EOS-1D X units (up to 10 units) connected in the wireless LAN.
  • Setting margin of error with master camera: Maximum Approx. ±TBA sec.
Camera Connection
System expansion terminal
Wired Lan Connection
Not Available; Wireless LAN function only
External Device Connection
USB host function is not included since this device is intended for wireless LAN function only
Power Supply
Powered by the camera
Battery Level Indicator
6-level indicator
W x H x D
TBA
Ounces/grams
TBA
Temperature
32°F to 104°F/0°C to 40°C
Humidity
85% or less
This is to make Misc appear on the page when needed.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Wireless Transmitter WFT-E6A that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Product Compatibility
EOS DSLR
 Return to Top
