Web Content Viewer
Actions
Wireless File Transmitter WFT-E8A
Wireless File Transmitters & Adapters
Item Code: 1173C001AA
Features
Supports Wireless LAN: IEEE 802.11ac/n/a/g/b for ultra high-speed image transfer using both 2.4 GHz or 5 GHz
Connecting to wireless Local Area Networks (LAN) via standards of IEEE 802.11ac/n/a/g/b on both 2.4 and 5 GHz bands, the Wireless File Transmitter WFT-E8A is the first Canon WFT that can communicate on the IEEE 802.11ac standard. On this fast standard, the WFT-E8A can transfer data at speeds of up to 433 Mbps, almost three times faster than on the IEEE 802.11n standard, at a range of up to 492 ft.
Transfer images at your convenience using FTP transfer, EOS Utility, WFT Server or Canon Camera Connect app*
The Wireless File Transmitter WFT-E8A offers a number of convenient ways to transfer images based on the location, available equipment and the task at hand. Image transfer directly from the camera to local or offsite servers is facilitated via easily configurable FTP transfer. With Canon's refined EOS Utility software installed on a PC, full-featured Live View remote shooting and image transfer are made simple. Accessed through a browser on a computer, tablet or compatible smartphone, Canon's WFT Server enables offsite still and movie capture without the need for additional software. Plus, with Canon's free Camera Connect app*, remote operation and image transfer can be completed simply on a compatible smartphone or tablet.
* Compatible with iOS versions 7.1/8.4/9.0, Android smartphone and tablet versions 4.0/4.1/4.2/4.3/4.4/5.0/5.1. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
Smart device connection is now available for remote shooting, sharing and transferring of images and video using the Canon Camera Connect app*
Canon's free Camera Connect app* makes it simple to connect a compatible smartphone or tablet to the EOS-1D X Mark II camera using the Wireless File Transmitter WFT-E8A. Remote operations such as Remote Live View still and motion capture, camera setting changes plus transferring images and MP4 movies are easily facilitated through the app's simple and clear user interface.
Specially designed for use with the new EOS-1D X Mark II camera, with an improved UI, organized settings and a more simple display configuration
Made to work seamlessly with the EOS-1D X Mark II camera, the Wireless File Transmitter WFT-E8A features dust- and moisture- resistance, and is also powered by the camera itself. Its new User Interface is designed to create wireless configurations of all levels of complexity, enabling wireless shooting and transfer of images and helping to create multi-camera wireless setup. Thanks to its reliable and robust wireless connections, the WFT-E8A helps enhance the creative options available to EOS-1D X Mark II users in both still and motion capture.
Wireless time syncing can sort images captured by multiple cameras and determine the accurate shooting sequence
Syncing cameras is simple with the Wireless File Transmitter WFT-E8A's wireless time syncing feature. Capable of syncing time on up to ten EOS-1D X Mark II cameras, the WFT-E8A enables recording of a timed succession of images from different sources and can be saved with a dependable level of precision. Event photographers will find this feature especially helpful as it's now possible to make time adjustments without having to connect directly to a computer.
Compact, durable and lightweight body sealed for dust- and water-resistance
Portability is almost as important as how well a product functions. Offering a compact design, the Wireless File Transmitter WFT-E8A is both light and compact. Built to withstand inclement weather, this transmitter has the same dustproof and waterproof construction used in the EOS-1D X Mark II camera body. A durable design helps ensure that equipment can be safely used in various conditions, making the WFT-E8A an ideal accessory for demanding photographers constantly on the move.
Specifications
Type
IEEE 802.11ac/n/a/g/b wireless LAN support; Image transfer accessory
Compatible Cameras
EOS-1D X Mark II Camera
FTP Transfer
Transfer images over a network to FTP servers
EOS Utility
EOS Utility-based control of cameras over a network
WFT Server
Browser-based remote image/video capture with downloading, playback and browsing of images/video over a network
Linked Shooting
Max. 10 receiver cameras
Transmission Range: Approx. 328 ft. / 100m from the sender camera (when signal strength is favorable)
WFT Server Start: Possible at manual connection with receiver camera
Transmission Range
Linked Shooting:
Wireless LAN:
Using an access point: Max. approx. 492 ft./150m
Transmitting directly to a smartphone: Max. approx. 49.2 ft./15m
In linked shooting: Max. approx. 328 ft. / 100m
With no obstructions between the transmitting and receiving antennas and no radio interference
Camera Connection
Terminal
Wired LAN Connection
None
External Device Connection
Available
Power Supply
Powered by the camera
Image Transfer Capacity
When a fully charged Wireless File Transmitter WFT-E8A is used with the EOS-1D X Mark II camera. Under Camera & Imaging Products Association (CIPA) conditions for testing shooting capacity, when using automatic image transfer with images that are approx. 6MB. Fewer images can be transferred if the wireless LAN transfer speed drops, and for consecutive image transfer over wireless LAN. If the remaining battery level drops below 19%, captured images cannot be transferred.
W x H x D
Approx. 0.97 x 2.24 x 1.34 in. / 24.7 x 57.0 x 34.1mm
Ounces/grams
Approx. 1.34 oz. / 38g
Temperature
32°F to 113°F/0°C to 45°C
Humidity
85% or less
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Wireless File Transmitter WFT-E8A that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
