Web Content Viewer
Actions
Wireless File Transmitter WFT-E9A
Wireless File Transmitters & Adapters
Item Code: 3830C001AA
Features
Supports Wireless LAN: IEEE 802.11ac 2x2 MIMO/ac/a/n/g/b for Ultra High-speed Image Transfer using either 2.4 GHz or 5 GHz
Connecting to wireless Local Area Networks (LAN) via standards of IEEE 802.11ac 2X2 MIMO/ac/a/n/g/b on both 2.4 and 5 GHz bands, the Wireless File Transmitter WFT-E9A can communicate on the IEEE 802.11ac standard. On this fast standard, the WFT-E9A can transfer data at speeds of up to 867 Mbps on the IEEE 802.11 ac 2x2 MIMO, and 433 Mbps on IEEE 802.11 ac, almost three times faster than on the IEEE 802.11n standard, at a range of up to 492 ft.
Conveniently Transfer Images using FTP transfer, EOS Utility, or Browser Remote* (WFT server)
The Wireless File Transmitter WFT-E9A offers a number of convenient ways to transfer images based on the location, available equipment and the task at hand. Image transfer directly from the camera to local or offsite servers is facilitated via easily configurable FTP transfer. With Canon's refined EOS Utility software installed on a PC, full-featured Live View remote shooting and image transfer are made simple. Accessed through a browser on a computer, tablet or compatible smartphone, Canon's WFT Server enables offsite still and movie capture without the need for additional software. Plus, IPTC (International Press Telecommunication Council) metadata, which was previously editable only with EOS Utility when connected with an interface cable, can now be edited with Browser Remote*.
Improved User Interface to help Create Wireless Configurations of all Levels of Complexity
The Wireless File Transmitter WFT-E9A provides a fast throughput for image uploading and a revamped user interface to help enable speedy set-up and configuration of wireless networks. This compact and powerful transmitter also makes it simple to use a compatible smartphone as a remote control for still and video capture - even from a distance of approximately 32.8 feet. Plus, it can transfer recorded images back for viewing on the EOS-1D X Mark III camera's screen.
Compact, Durable and Lightweight Body sealed for Dust- and Water- Resistance
The Wireless File Transmitter WFT-E9A makes it ideal to take along for just about any activity due to its lightweight and compact design. Built to withstand inclement weather, this transmitter has the same dustproof and waterproof construction used in the EOS-1D X Mark III camera body. A durable design helps ensure that equipment can be safely used in various conditions, making the WFT-E9A an ideal accessory for demanding photographers constantly on the move.
Specifications
Type
Wireless LAN accessory
IEEE 802.11ac 2x2 MIMO/ac/n/a/g/b wireless LAN support; Image transfer accessory
Compatible Cameras
EOS-1D X Mark III Camera
C500 Mark II Digital Cinema Camera
FTP Transfer
Transfer images over a network to FTP servers
EOS Utility
EOS Utility-based control of cameras over a network
WFT Server
Browser Remote function is not available with EOS-1D X Mark III Camera firmware Ver.1.0.0. This function will be added to the future firmware update.
Linked Shooting
Max. 10 receiver cameras
Transmission Range: Approx. 492 ft. / 150m from the sender camera (when signal strength is favorable)
WFT Server Start: Possible at manual connection with receiver camera
Transmission Range
Using an access point: Max. approx. 492 ft./150m
Linked shooting: Max. approx. 164 ft. / 50m
Smartphone connection: Not supported
With no obstructions between the transmitting and receiving antennas and no radio interference
Camera Connection
Terminal
Wired LAN Connection
None
External Device Connection
Available
Power Supply
Powered by the camera
W x H x D
Approx. 0.98 x 2.54 x 1.32 in. / 25.0 x 64.5 x 33.5mm
Ounces/grams
Approx. 1.59 oz. / 45g
Temperature
32°F to 113°F/0°C to 45°C
Humidity
85% or less
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you WFT-E9A that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
DISCLAIMERS
* Browser Remote will be supported through firmware update after shipping.
 Return to Top
