Web Content Viewer
Actions
FAX-JX210P
Fax Machines
Features
Ultra-High Quality(UHQ) - This image processing system accurately processes images of your original before transmission for clear, crisp documents. So you get better quality on the way in and on the way out. Plus, your outgoing faxes will now appear more like actual documents.
FINE Cartridge - Only Canon delivers Full-photolithography Inkjet Nozzle Engineering (FINE) which utilizes a high performance, integrated print head and ink tank for laser-quality, smudge-resistant text. Replacing your cartridge is also simple and convenient, giving you more time to take care of business.
Memory Capacity2-If you run out of paper or your line is busy it's no problem- the JX210P can hold up to 60 incoming pages.
One Touch Dialing- It's now almost too easy to contact those on your list. Do so with just the press of a button.
Automatic Document Feeder - The ADF holds up to 20 originals making it easier to copy, scan or fax multi-page documents.
Full Dot Matrix LCD- An LCD display makes text easier to read, making the JX210P easier to use.
USB 2.0 Hi-Speed - Plug the cable into your PC for a super-fast connection for your data transfers.
Fax- your business moving forward while faxing up to 14.4Kbps2, 69 speed-dial locations for phone numbers and receive up to 60 incoming pages in memory.
Energy Star qualified products and practices help you save money and reduce greenhouse emissions by meeting strict energy efficiency guidelines set by the U.S. Environmental Protection Agency and the U.S. Department of Energy. For more information regarding Canon Energy Star, visit www.usa.canon.com/energystar
FAX-JX210P Box Contents
FAX-JX210P Box Contents FAX-JX210P Document Kit: - Easy Setup Instructions - Quick Start Guide - Setup Software & User's Guide CD-ROM Ink Cartridge: PG-40 Black Power Cord Handset
Specifications
Coper Specification
Mono Copy Resolution
600 x 600 dpi
No Of Copies
99
Cartridge
PG-40 Black
Printers Specifications
Type
Printing Method: Inkjet
Nozzle Text
320 nozzles
Paper Sizes
Letter, Legal
Automatic Sheet Feeder
20 sheets; Letter (standard paper)
10 sheets; Legal (standard paper)
Facsimile Specifications
Modem Speed
14.4 Kbps3
Transmission Speed Approx
Approximately 6 seconds per page1
Transmission Reception Memory
60 pages2
Scanning Method
CIS (Contact Image Sensor)
Fax Resolution
600 x 600 dpi
Automatic Document Feeder Adf
A
Document Sizes W xL
8.5 x 14
Paper Tray Capacity Max
100 sheets
Other Features Networking
Caller ID Display4, Fax/Telephone auto switch, Sequential Broadcast(70 locations), Speed Dial-69 locations (9 one touch; 60 coded), Built-in Handset, UHQ (Ultra-High Quality) Processing System, Auto Document Feeder, Full DOT Matrix LCD)
General Specifications
Standard Interface
USB 2.0 Hi-Speed
Os Compatibility
Windows®7, Windows® Vista, Windows XP/2000
Noise
Weight
9.1 lbs
Warranty
Toll Free technical phone support plan 1 year limited warranty with InstantExchange Program5
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you FAX-JX210P that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
DISCLAIMERS
  1. Black and white document fax transmission speed is based on default using ITU-T No. 1 chart. Actual transmission speed may vary depending on document complexity, fax settings at receiving end, and line conditions etc.
  2. Page count is based on ITU-T No. 1 chart or CANON FAX Standard Chart No.1.
  3. The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
  4. Requires purchase of Caller ID service from your telecommunications provider.
  5. Warranty programs are subject to certain conditions and restrictions. See www.canontechsupport.com for details.
 Return to Top
