Web Content Viewer
Fax Machines
  • Super G3 Technology featuring JBIG compression helps reduce phone line charges by transmitting data at 33.6 Kbps with scanning at up to 37 images per minute. This helps save both time and money while increasing fax productivity.
  • High Speed, High Quality Output is standard on the LASER CLASS 800 Series devices. Documents can be printed as fast as 23-ppm, even when printing at 1200-dpi.
  • Productive Document Feeding via the 50-sheet Automatic Document Feeder. The LASER CLASS 810 includes new duplex scanning in addition to auto duplex output capabilities, enabling users to scan and copy with virtually nonstop productivity. The LASER CLASS 810 model can capture originals at up to 37 ipm (LTR, 100/200 dpi).
  • High Volume Paper Capacities: The LASER CLASS 810 comes standard with a paper supply of 600 sheets up to Legal-size: one 500-sheet front-loading adjustable cassettes and a 100-sheet multi-purpose tray, with the option of an additional 500-sheet letter-sized cassette, bringing the maximum paper capacity to 1,100 sheets.
  • UFR II LT Print Technology: The LASER CLASS 810 utilizes the optional UFR II LT print technology for direct or shared network printing. UFR II LT helps reduce the overall printing time as the processing tasks that conventionally execute within the printer are now done at the host PC. This allows the powerful processing power found in today's computers to be utilized to help achieve a significant increase in productivity.
  • Memory: The LASER CLASS 810 comes standard with a memory of up to 512 pages, with the option to upgrade to up to 1,500 pages.
  • All-in-one Toner Cartridge: The LASER CLASS 810 provides for a quick and easy maintenance of customer-replaceable components. The black toner and drum unit are combined into one unit. The yield for this cartridge is approximately 4,500 pages @ 5% coverage.
This is to make Misc appear on the page when needed.
Desktop Transceiver
Applicable Line
Public Switched Telephone Network**
Letter Sized Sheets
Up to 50 Sheets*
Up to 20 Sheets
Scanning Method
Contact Image Sensor Duplexing Automatic
Document Sizes
8-7/8 x 24-7/8
5-7/8 x 5-7/8Paper Supply
Standard: 600 Sheets: 1 x 500-Sheet Adjustable Cassette
100-Sheet MultiPurpose Tray
Maximum: 1,100 Sheets with Optional 500-Sheet Cassette (Letter)
Acceptable Paper Weight: 17 lb. - 24 lb. Bond (Cassette)
15 lb. - 34 lb. Bond (MultiPurpose Tray)
Data Compression System
Modem Speed
33.6 Kbps Super G3
Transmission Speed
Approx. 3 Sec./Page
(ECM-JBIG, Transmitting from Memory)***
Memory Transmission/Reception: Approx. 512 Pages (1,500 with Opt. Printer Kit)***
Receiving Resolution
Ultra Fine Mode
Ultra Fine
400 X 400 dpi
Super Fine Mode
Super Fine
200 x 400 dpi
Fine Mode
Fine Mode
200 x 200 dpi
Standard Mode
Standard Mode
200 x 100 dpi
Receiving Paper Tray
100 Sheets
Recording Paper Size
Duplex: Std. Scan and Print
Fixing System: RAPID Fusing System
Warm-Up Time: 19 seconds from Power On
Cartridge Yield
Toner Cartridge: FX11 Cartridge Approx. 4,500 Pages (Estimated yield at 5% Coverage)
Power Consumption
Sleep: Approx. 3.0W (3.5W with Printer Kit)
Max.: 1020W
Power Source: 120V-127V 50/60Hz
Memory Backup: Up to 3 Hours
Dimensions (excluding handset)
Main Unit: 17-3/4 x 20-1/2 x 19
With Cassette: 22-7/8 x 20-1/2 x 19
Installation Space (W x D): 43-1/4 x 38-3/4 (Including Optional Handset)
Weight (excluding handset)
54.2 lb.
Environmental Conditions
59F - 86F (15C - 30C)
10% - 80% RH
One Touch Speed Dialing
80 Destinations
Coded Speed Dialing
120 Destinations
Group Dialing
Group Dialing
199 Destinations
Address Book Dialing
Manual Dialing (Numeric Keys)
Automatic Re-Dialing
Manual Re-Dialing (Redial/Pause Key)
Polling Reception
Sequential Broadcast
201 Destinations
Additional Fax Features:Remote RX Delayed TX Dual Access TX Document Archiving Reception Restriction Memory Lock Reception Confirming Entered Fax Numbers Restricting New Addresses PC Faxing
Type: Monochrome Laser
Copy Speed: Up to 23 Pages/Min. (Letter)
Max. Number of Copies: 99
Scan Resolution: 600 x 600 dpi
Copy Resolution: 1200 x 600 dpi (Enhanced)
Halftones: 256 Shades of Gray
First-Copy Time: Less Than 13 Seconds
Duplex Function: Yes (Letter-R/Legal)
Copy Features: Electronic Sort
Copy Memory (Shared): 64MB
Print Speed: Up to 23 Pages/Min. (Letter)
Supported PDL: Opt. UFR II LT
Interface: 10/100Base-TX, USB Hi-Speed 2.0
Print Resolution: 1200 x 600 dpi (Enhanced)
Print Memory (Shared): 64MB
Network OS: Windows 98/Me/2000/Server 2003/XP/Windows Vista/Macintosh OSX (10.2.8 - 10.4.6)
FLX-Cassette Feeder 8 (500 Sheets)UFR II LT Printer Kit-X1 (LC810 Only)Handset Kit-10Stamp Unit-C1Stamp Ink Cartridge-B1FX11 CartridgeCabinet-V1
* 21 lb. Bond.
** The Public Switched Telephone Network (PSTN) currently supports 28.8 Kbps modem speed or lower, depending on telephone line conditions.
*** Based on ITU No. 1 Chart (JBIG, Standard Mode).
^ Only one broadcast destination can be specified using the numeric keys.
^^ Standard on LASER CLASS 830i; optional on LASER CLASS 810.
^^^ Only available for UFR II LT.
FX -11 Cartridge
Item Code: 1153B001AA
Estimated Toner Yield:  4,500 Copies/Cartridge (Estimated yield at 5% Coverage)
Better Buys for Business 2008 Editor's Choice
 Return to Top
