Web Content Viewer
Actions
LASER CLASS 830i
Fax Machines
Features
  • Color Send: The LASER CLASS 830i model has color sending capabilities as standard. With Color Send technology, users can easily scan paper documents and send them to one or multiple destinations via e-mail or network folders, in one simple operation. Canon's proprietary PDF Compact mode is supported which helps reduce the size of the resulting Color PDF files when documents are distributed across a network. This will enable easy handling of large color documents across the network.
  • Super G3 Technology featuring JBIG compression helps reduce phone line charges by transmitting data at 33.6 Kbps with scanning at up to 45 images per minute. This helps save both time and money while increasing fax productivity.
  • High Speed, High Quality Output is standard on the LASER CLASS 800 Series devices. Documents can be printed as fast as 23-ppm, even when printing at 1200-dpi.
  • Productive Document Feeding via the 50-sheet Automatic Document Feeder. The LASER CLASS 830i includes new duplex scanning in addition to auto duplex output capabilities, enabling users to scan and copy with virtually nonstop productivity. The LASER CLASS 830i model can capture originals at up to 45 ipm (LTR, 100/200 dpi), and it supports scanning color originals up to Ledger size.
  • High Volume Paper Capacities: The LASER CLASS 830i comes standard with a paper supply of 600 sheets up to Legal-size: one 500-sheet front-loading adjustable cassettes and a 100-sheet multi-purpose tray, with the option of an additional 500-sheet letter-sized cassette, bringing the maximum paper capacity to 1,100 sheets.
  • Network Print Technology: The LASER CLASS 830i offers network print technology as standard. Canon's proprietary UFR II LT technology helps reduce the overall printing time as the processing tasks that conventionally execute within the printer are now done at the host PC. This allows the powerful processing power found in today's computers to be utilized to help achieve a significant increase in productivity. The LASER CLASS 830i also offers standard PCL 5e/6 support.
  • Memory: The LASER CLASS 830i ships standard with a large memory of up to 1,500 pages (40MB).
  • All-in-one Toner Cartridge: The LASER CLASS 830i provides for a quick and easy maintenance of customer-replaceable components. The black toner and drum unit are combined into one unit. The yield for this cartridge is approximately 4,500 pages @ 5% coverage.
This is to make Misc appear on the page when needed.
Specifications
Title
LASER CLASS 830i
Type
Desktop Transceiver
Applicable Line
Public Switched Telephone Network**
Letter Sized Sheets
Up to 50 Sheets*
Ledger Sized Sheets
Up to 20 Sheets*
Scanning Method
Contact Image Sensor Duplexing Automatic
Document Sizes
Maximum
11-3/4 x 24-7/8
Minimum
5-7/8 x 5-7/8
Paper Supply
Standard: 600 Sheets: 1 x 500-Sheet Adjustable Cassette
100-Sheet MultiPurpose Tray
Maximum: 1,100 Sheets with Optional
500-Sheet Cassette (Letter)
Acceptable Paper Weight: 17 lb. - 24 lb. Bond (Cassette)
15 lb. - 34 lb. Bond (MultiPurpose Tray)
Output Tray: 100 Sheets
Recording Paper Size: Letter/Legal
Duplex: Std. Scan and Print
Fixing System: RAPID Fusing System
Warm-Up Time: 19 seconds from Power On
Memory Backup: Up to 3 Hours
Data Compression System
MH, MR, MMR, JBIG
Modem Speed
33.6 Kbps Super G3 Automatic Fallback
Transmission Speed
Approx. 3 Sec./Page
(ECM-JBIG, Transmitting from Memory)***
Memory Transmission/Reception Approx. 1,500 Pages***
Receiving Resolution
Ultra Fine Mode
Ultra Fine
400 X 400 dpi
Super Fine Mode
Super Fine
200 x 400 dpi
Fine Mode
Fine Mode
200 x 200 dpi
Standard Mode
Standard Mode
200 x 100 dpi
Receiving Paper Tray
Cartridge Yield
Toner Cartridge: FX11 Cartridge Approx. 4,500 Pages (Estimated yield at 5% Coverage)
Power Consumption
Standby
16W
Sleep: Approx. 3.5W
Max.: 1020W
Power Source: 120V-127V 50/60Hz
Dimensions (excluding handset)
Main Unit: 17-3/4 x 20-1/2 x 19
With Cassette: 22-7/8 x 20-1/2 x 19
Installation Space (W x D): 43-1/4 x 38-3/4 (Including Optional Handset)
Weight (excluding handset)
56.2 lb.
Environmental Conditions
Temperature
59F - 86F (15C - 30C)
Humidity
10% - 80% RH
Features
Dialing
One Touch Speed Dialing
80 Destinations
Coded Speed Dialing
420 Destinations
Group Dialing
Group Dialing
499 Destinations
Address Book Dialing
Manual Dialing (Numeric Keys)
Manual Re-Dialing (Redial/Pause Key)
Polling Reception
Sequential Broadcast
501 Destinations
Options
Additional Fax Features:Remote RX Delayed TX Dual Access TX Document Archiving Reception Restriction Memory Lock Reception Confirming Entered Fax Numbers Restricting New Addresses PC Faxing
Options
COPY FEATURE
Type: Monochrome Laser
Copy Speed: Up to 23 Pages/Min. (Letter)
Max. Number of Copies: 99
Scan Resolution: 600 x 600 dpi
Copy Resolution: 1200 x 600 dpi (Enhanced)
Halftones: 256 Shades of Gray
First-Copy Time: Less Than 13 Seconds
Duplex Function: Yes (Letter-R/Legal)
Copy Features: Electronic Sort
Copy Memory (Shared): 256MB
Options
PRINT FEATURES:
Print Speed: Up to 23 Pages/Min. (Letter)
Supported PDL: Std. UFR II LT and PCL 5e/6
Interface: 10/100Base-TX, USB Hi-Speed 2.0
Print Resolution: 1200 x 600 dpi (Enhanced)
Print Memory (Shared): 256MB
Network OS: Windows 98/Me/2000/Server 2003/XP/Windows Vista/Macintosh OSX (10.2.8 - 10.4.6)
Options
COLOR SEND FEATURE: (LASER CLASS 830i ONLY)
Sending Methods: E-mail, I-fax, File Server
Color Mode: Color, Black and White
Communication Protocol
E-mail/I-fax: SMTP, POP3, I-fax (Simple Mode)
File Server: FTP (TCP/IP), SMB (TCP/IP)
Data Formats
File Server/E-mail: TIFF, PDF, JPEG, PDF (Compact)
I-fax: TIFF (MH, MR, MMR)
Options
FLX-Cassette Feeder 8 (500 Sheets)Handset Kit-10Stamp Unit-C1Stamp Ink Cartridge-B1FX11 CartridgeCabinet-V1
Legal
* 21 lb. Bond
** The Public Switched Telephone Network (PSTN) currently supports 28.8 Kbps modem speed or lower, depending on telephone line conditions.
*** Based on ITU No. 1 Chart (JBIG, Standard Mode).
^ Only one broadcast destination can be specified using the numeric keys.
^^ Standard on LASER CLASS 830i; optional on LASER CLASS 810.
^^^ Only available for UFR II LT.
Supplies
FX -11 Cartridge
Item Code: 1153B001AA
Estimated Toner Yield:  4,500 Copies/Cartridge (Estimated yield at 5% Coverage)
Brochures
Loading...
Awards
2008 BLI Pick of the Year Award
BLI 2008 Highly Recommended
Better Buys for Business 2008 Editor's Choice
BLI 2008 Reliability Certified
2010 BLI Performance Certified Seal
 Return to Top
