Web Content Viewer
Actions
Color imageRUNNER C1030iF
Multifunction Copiers
Build your model, and customize configurations based on specific needs
Solutions to help increase office efficiencies and productivity
Advanced Solutions for your industry
Features
The Color imageRUNNER C1030iF models pack a powerful architecture based on the latest imageCHIP LITE platform that provides proven performance for handling concurrent print, copy, scan, fax, and send jobs. Each model has ample RAM, built-in Ethernet, dual USB 2.0 ports and a host of advanced functionality to enhance productivity. The systems also include Canon's Color RAPID Fusing System, which delivers short wait times between jobs, fast warm-up and first-copy-out times, and low energy consumption.
The Color imageRUNNER C1030iF models are remarkably compact and versatile, easily fitting on a desktop or in a centralized area with optional paper cassette or cabinet for walk-up convenience. Regardless of the placement, usability is simple with the stunning 3.5" color LCD display. The control panel also features an innovative scroll wheel for easy navigation and entry of alphanumeric characters, which is adjustable for optimal viewing angle.
Support for Canon's innovative UFR II LT print language is standard on each model. UFR II LT is optimized to produce high-speed output by automatically sharing processing tasks between the desktop computer and the device.
Color imageRUNNER C1030iF includes PCL 5c/6 support as standard. For more advanced workflows, PostScript 3 Emulation is also available as an option on both systems. PostScript 3 Emulation support delivers accurate rasterization of PS3 print data, particularly useful for design, publishing, education, and healthcare businesses.
In addition, Canon's print driver interface is consistent throughout the entire imageRUNNER line, simplifying output and ensuring a familiar user experience across devices.
Produce high-quality color output and accurate gradients through Canon's oil-free S Toners, which have been specifically engineered for uniformity in size and shape with a gloss-free look for superb results. And unlike other printers, the Color imageRUNNER C1030iF models feature Pure Black technology to produce black text and lines on the page with greater clarity using the black toner instead of mixing CMYK colors.
Increase your productivity with color sending capabilities that come standard, which enable you to electronically distribute documents to e-mail, fax, i-fax, SMB, FTP destinations, or save them to removable media. The systems support popular formats including TIFF, JPEG, PDF, PDF High Compression, and Searchable PDF.
For the ultimate in document portability, scanned pages can be saved as TIFF, JPEG, PDF Compact, or PDF OCR files using the Scan-to-USB Memory function. You can output documents when needed - even when you don't have access to a computer - with the Direct Print feature. This allows the reading of TIFF or JPEG files stored on a USB memory device or SD/MMC/CompactFlash media card.
Enhanced authentication and security settings for user access is now available as standard for easy access management, cost control, device security, secure print and send restrictions. Additionally, Copy Card and Proximity card is supported for easy authentication.
The Color imageRUNNER C1030iF models have been designed with front-load access to all consumables, providing quick replenishment with minimal downtime. The devices also use distinctive all-in-one cartridges to minimize the number of replacement parts needed to maintain uptime. Device setup, maintenance, and error recovery are facilitated through on-screen guides and tutorials on the control panel to get up and running quickly.
IT managers can easily manage multiple Canon devices and helps drive cost out of operations with a variety of tools including the standard Remote User Interface, support for Canon's imageWARE Enterprise Management Console application, and Canon's Generic PCL6 driver to simplify driver deployment and so much more.
Color imageRUNNER C1030iF is ready for your fleet business with an array of management tools.
Specifications
Model Name
Type
Color Digital Multifunction Imaging System
Functions
Standard: Copy, Print (UFR II LT, PCL), Scan, Send, Fax
Optional: PostScript 3 Emulation
Operation Panel
3.5 TFT Color LCD Screen
Image Server Memory
Standard/Maximum: 768MB RAM
Network Interface Connection: Ethernet 10/100Base-TX
Other Interface
Standard: USB 2.0 (Host)x2
USB 2.0 (Device)x1
Letter
(Color/BW): Up to 22/30 ppm
First Copy Time
Platen Glass: Less than 13 Seconds
Feeder: Less than 19 Seconds
Multiple Copies
1 to 99
Magnification
50% - 200% (1% Increments)
Preset Reductions
50%, 64%, 78%
Preset Enlargements
129%, 200%
Standard Paper Capacity
(20 lb. Bond): 250-sheet Paper Cassette
100-sheet Stack Bypass
Optional: 500-sheet Paper Cassette Feeder
Maximum Paper Capacity
850 Sheets
Output Paper Capacity: 250 Sheets
Output Sizes
Cassette
Legal, Letter, Executive
Bypass: Legal, Letter, Statement, Executive, Envelopes (COM10 No. 10/Monarch/DL/ISO-B5/ISO-C5) Custom Size (3" x 5" to 8-1/2" x 14")
Acceptable Paper Weights
Cassette
16 lb. Bond to 32 lb. Bond
Bypass: 16 lb. Bond to 47 lb. Bond
Duplexing
Standard Automatic Trayless Duplexing (Letter and Legal)
Warm Up Time
From Power On: 60 Seconds or Less
From Sleep Mode: 19 Seconds or Less
Exposure Control
Automatic or Manual (9 Levels)
Power Requirements
120V-127V, 60Hz, 15A
Plug: NEMA 5-15P
Power Consumption: Maximum: Less than 1300W
From Sleep Mode: 1W
Dimension
24-7/8 x 21-1/2 x 20-3/4
Installation Space (W x D) 21-1/2 x 44-7/8 (with drawer pulled out and back cover open)
Weight
Approximately 96 lb.
Toner
Black: 6,000 Copies/Bottle
Color (CMYK): 6,000 Copies/Bottle (Estimated @ 5% Coverage)
Estimated Toner Yield
Estimated Yield at 5% Coverage Scan Specifications Network TWAIN Scan: Standard Network Scan Utility: Color Network Scan Gear Security Specifications Department ID Management, User ID Management, IPv6, Restricting Features (Restricting New Addresses on Address Book, Address Book Password, Allow Fax Driver TX, Restrict Recall, Confirm Entered Fax Numbers, Restrict Sequential Broadcast, Restrict USB Interface), MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP, IEEE802.1x, User Authentication Features for Send Operation, Serverless Secure PrintΔΔΔ Environmental Information ENERGY STAR® Qualified RoHS Compliant Ecomark Blue Ange
Feeders
Description
Duplexing Automatic Document Feeder
Acceptable Originals
Statement to Legal
Scanning Speed
(BW/Color; Letter): 20 ipm (300 dpi)
20 ipm (600 dpi)
Capacity
(20 lb. Bond): 50 Sheets
Paper Weights
Paper Weight: One-sided Scanning (1 page): 13 to 34 lb. Bond*
One-sided Scanning (more than 2 pages): 13 to 28 lb. Bond**
Two-sided Scanning: 17 to 28 lb. Bond
Description
Cassette Feeding Unit-AB1
Capacity
550 Sheets x 1 Cassette (20 lb. Bond)
Paper Weights
Acceptable Paper Type: Plain, Recycled, Color Heavy (16 lb. Bond to 32 lb. Bond)
Dimensions
12 x 17-3/8 x 21-3/8
Weight
Approximately 28.7 lb
Output Options
Fax Board
Description
Super G3 Fax Board-AB1 (Optional for C1030, Standard on C1030iF)
Applicable Line
1
Modem Speed
33.6 Kbps
Data Compression
MH, MR, MMR, JBIG
Resolution (dpi): 400 x 400, 200 x 400, 200 x 200, 200 x 100
Sending/Recording Size: Statement to Legal
Print Board
Processor
Canon Custom Processor (Shared)
Standard Memory
768MB RAM
Maximum Memory
768MB RAM
Printing Resolution: 600 x 600 dpi (2400 dpi Enhanced x 600 dpi)
PDL Support
Standard: UFR II LT, PCL 5c/6
Print Controller Technology
UFR II LT, PostScript 3 Emulation: Windows® (Windows 2000/XP/Windows Vista®/Windows 7/Server 2003/Server 2008), Citrix Presentation Server 4.0/4.5, Citrix XenApp 5.0, XenDesktop 2.0/2.1/3.0/4.0, Macintosh® (OS X 10.4 or Greater), SAP (PS3 only) PCL 5c/6: Windows (Windows 2000/XP/Windows Vista/Windows 7/Server 2003/Server 2008), Citrix Presentation Server 4.0/4.5, Citrix XenApp 5.0, XenDesktop 2.0/2.1/3.0/4.0, SAP Direct Print
Supported Media: USB Memory, SD Secure Digital Memory Card, SDHC Memory Card, Compact Flash (CF) Card: Type I/II (3.3V), Microdrive, Memory Stick, Memory Stick PRO, miniSD Card,† microSD Card,† Memory Stick Duo,† Memory Stick PRO Duo† Data Format: TIFF, JPEG
Send Expansion Sets
Sending Method
E-Mail, I-Fax, File Server (FTP, SMB), Super G3 Fax (Standard on C1030iF, Optional for C1030)
Color Mode: Color, BW Scan Resolution (dpi): TIFF, PDF (BW) (OCR): 100 x 100, 150 x 150, 200 x 100, 200 x 200, 200 x 400, 300 x 300, 400 x 400, 600 x 600 JPEG, PDF (Color) (OCR): 100 x 100, 150 x 150, 200 x 200, 300 x 300, 600 x 600 PDF (Color) (Compact) (OCR): 300 x 300
Address Book Capacity
TIFF, JPEG, PDF, PDF (Compact), PDF (OCR)
I-Fax Data Format TIFF Other Optional Accessories Cabinet Type-A††Handset-J1†††Barcode Printing Kit-C1ΔCard Reader-E1ΔΔCard Reader Attachment Kit-F1Braille Label Kit-E1Serverless Secure Print ModuleΔΔΔ * 17 to 34 lb. (64 to 128g/m2) when copying originals smaller than LTR/A4. ** 17 to 28 lb. (64 to 105g/m2) when copying originals smaller than LTR/A4. † Memory cards that can be inserted into the slot using an adapter. †† The Cassette Feeding Unit-AB1 and Cabinet Type-A cannot both be installed at the same time. ††† Requires Fax capability for use. Δ Requires PCL Printer Kit-AK1 for C1030. ΔΔ Requires Card Reader Attachment Kit-F1 for installation. ΔΔΔ Late availability.
Brochures
Loading...
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you Color imageRUNNER C1030iF that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Supplies
GPR-28 Toner
Color: Black
Item Code: 1660B004BA
Estimated Toner Yield: 6,000 Copies/Bottle (Estimated @ 5% Coverage)
Color: Cyan
Item Code: 1659B004BA
Color: Magenta
Item Code: 1658B004BA
Color: Yellow
Item Code: 1657B004BA
This is to make Misc appear on the page when needed.
Yes, networking and security is standard on the Color imageRUNNER C1030.
Yes, LDAP Address Book lookup feature is standard on the device.
Yes, there is a standard send restriction feature called User Authentication at Send Operation, which restricts or prevents access to send features.
Optional for high security environments, the Color imageRUNNER C1030 does not come with an internal hard disk drive (HDD), thus eliminating concerns over confidential data retained on the MFP. (No HDD = no latent images.)
Yes, the Color imageRUNNER C1030 is Energy Star qualified and has low energy usage of less than 1,3000W maximum and only 1W during Sleep Mode.
Awards
2011 BLI Performance Certified Seal
Better Buys for Business 2011 Editor's Choice
BLI 2011 Reliability Seal
BLI 2011 Recommended Seal
Videos
  • Click here to view the Canon "Protecting Your Environment" In-Brief Video.
 Return to Top
