Web Content Viewer
Actions
imagePRESS Lite C165
Multifunction Copiers
Features
  • Production speeds of up to 65 ipm
  • Up to 240/220 ipm single-pass
  • Duplex scanning at 300 dpi (color/black and white)
  • 7,050-sheet1 feeding capacity with up to six different sources2
  • Wide array of productive and versatile in-line accessories2
  • 2400 x 2400 dpi print resolution utilizing the unique R-VCSEL imaging technology
  • Translucent CV Toner helps users produce vibrant images on a wide variety of stocks
  • Multi D.A.T. helps produce consistent color automatically, with no operator intervention
  • Loop Sensor Control helps produce high and clear image quality on heavy and long stocks
  • Produce work on stocks up to 130 lb. Cover2
  • Supports a variety of specialty stocks including envelopes, tabs, and long sheets2
  • uniFLOW support to help manage your printing engines and scanning workflows2
  • Meets ENERGY STAR® standards and rated EPEAT Gold
imagePRESS Lite C65
Print Speed 8.5" x 11": Up to 65 ipm
11" x 17": Up to 32 ipm
13" x 19": Up to 31 ipm
Scan Speed (Letter, 300 dpi)1
BW: Up to 240 opm
Color: Up to 220 opm
First-Copy Output Time
BW: 4.8 seconds
Color: 5.9 seconds
Warm-Up Time
From Power ON: Approx. 30 Seconds2
From Sleep Mode: Approx. 30 Seconds3
Quick Startup Mode: Approx. 4 Seconds4
Print Resolution Up to 2400 x 2400 dpi
Paper Capacity5
Standard: Up to 3,550 Sheets
Maximum: Up to 7,050 Sheets
Paper Size
Standard: 5.5" x 7.17” to 13" x 19.2"
Optional: 3.94" x 5.83" to 13" x 51.2"
Paper Weight
Standard: 14 lb. Bond to 80 lb. Cover
Optional: 14 lb. Bond to 140 lb. Index
Envelopes6 #10, Monarch, ISO-C5, DL (Custom Size : 3.94” x 5.83” to 13” x 19.2”)
Long Sheets7 Up to 13" x 30"
FOOTNOTES
  1. Capacity based on 20 lb. Bond Letter.
  2. Time from device power ON until copy-ready (not print reservation).
  3. Time from exiting Sleep Mode to when printing is operational.
  4. Time from device power ON to when key operations can be performed on the touch-panel display.
  5. Based on 20 lb. Bond Letter.
  6. Envelope Attachment Kit required.
  7. Optional accessories may be required.
This is to make Misc appear on the page when needed.
Supplies
T07 Toner
Color: Black
Item Code: 3641C001AA
Estimated Toner Yield: 92,650 impressions @ 5% coverage / 54,500 impressions @ 8.5% coverage
Color: Cyan
Item Code: 3642C001AA
Estimated Toner Yield: 63,750 impressions @ 5% coverage / 37,500 impressions @ 8.5% coverage
Color: Magenta
Item Code: 3643C001AA
Color: Yellow
Item Code: 3644C001AA
Accessories
Feeding
  • Stack Bypass-D1 (standard)
  • Stack Bypass Alignment Tray-D1
  • Long Sheet Tray-B1
  • Letter Paper Deck Unit-E1
  • POD Deck Lite-C1
  • Tab Attachment Kit-F1
  • Envelope Attachment Kit-F1
  • Envelope Attachment Kit-G1
Finishing
  • Copy Tray-R2
  • Document Insertion Unit-N1
  • Insert/Fold Unit-K1
  • Multi Function Professional Puncher-B1
  • Paper Folding Unit-J1
  • Staple Finisher-AC1
  • Booklet Finisher-AC1
  • Jogger Kit-A1
  • 2-/3-Hole Puncher Unit-A1
  • Staple Finisher-W1
  • Booklet Finisher-W1
  • Puncher Unit-BS1/BT1
  • Booklet Trimmer-F1
Print Servers
  • imagePRESS Printer Kit (standard)
  • imagePRESS Server M10
  • imagePRESS Server L30
imagePRESS Server M10 Accessories
  • Productivity Package
  • Fiery Impose
  • Fiery Compose
  • X-Rite i1Pro2 Spectrophotometer
imagePRESS Server L30 Accessories
  • Graphics Art Package, Premium Edition
  • Removable HDD Kit
  • Fiery Impose
  • Fiery Compose
  • Fiery Job Flow
Brochures
Loading...
White Papers
Digital Printing: Where We Are Now?
Beyond the Press: Defining the Infrastructure for Operational Success
Optimizing Color Across Print Platforms
The Rise of the Digital Print Enhancement Opportunity
Best Practices in Digital Finishing
Videos
imagePRESS Lite C165 Overview
DISCLAIMERS
  2. Optional accessories may be required
 Return to Top
