Web Content Viewer
Actions
imageRUNNER 1025iF
Multifunction Copiers
imageRUNNER ADVANCE Configurator. Build your model, and customize configurations based on specific needs.
Solutions to help increase office efficiencies and productivity
Advanced Solutions for your industry
Features
  • Operating at up to 25 pages-per-minute (LTR), the imageRUNNER 1025iF is equipped with 256 MB RAM. Exceptional memory capacity provides users with high-speed image processing of data and simultaneous processing of each function.
  • With a scanning resolution of 600 x 600 dpi, and print/copy resolution of enhanced 1200 x 600 dpi, the imageRUNNER 1025iF delivers outstanding, exceptional image quality for the most faithful reproduction of text and images.
  • Standard TWAIN/WIA compliant color scanning enables users to convert hardcopy-based information into electronic format for storage or integration into your workflow.
  • Color-enabled document distribution allows users to communicate information more effectively; Includes support for PDF High Compression technology for efficient handling of color image data.
  • Super G3-Fax capabilities gives users the ability to transmit and receive documents with speed and ease; Includes support for PC Fax.
  • Compact desktop design allows devices to be placed in areas with limited space. An integrated output tray saves space and organizes output for speedy distribution.
  • Standard automatic duplexing saves time and reduces paper cost by producing two-sided output without any manual intervention.
  • Designed with Canon's RAPID Fusing technology to significantly reduce energy consumption and improve productivity.
  • 50-sheet capacity Duplexing Automatic Document Feeder makes scanning multi-page and different-size originals quick and easy.
  • With a maximum paper capacity of 1,100 sheets, the imageRUNNER 1025iF device has been designed to meet the volume requirements of any small business or busy workgroup.
  • Standard UFR II LT printing to provide maximum flexibility and performance for busy workgroups and businesses. Optional PCL 5e/6 Printing Capabilities.
  • Cutting edge image processing technology enables high-speed image data processing and the simultaneous processing of multiple functions. Standard 10/100 BaseTX Ethernet and USB connectivity
  • A suite of management features including Department ID mode for tracking/monitoring device usage and Remote UI for controlling system functions through a Web Browser.
This is to make Misc appear on the page when needed.
Specifications
Model Name
imageRUNNER 1025iF
Type
Monochrome Digital, Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Fixing System
RAPID Fusing System
Image Server Memory
256MB RAM
Max Copy Reservation
5 Jobs
Scanning Resolution
600 x 600 dpi
Printing Resolution
1200 x 600 dpi
Halftone
256 Levels
Letter
Up to 25 ppm (LTR)⟩
First Copy Time
Less than 8 Seconds (From Platen Glass)
Less than 12 Seconds (From DADF)*
Multiple Copies
1 to 99
Magnification
50% to 200% (In 1% Increments)
Preset Reduction/Enlargement: 50%, 64%, 78%, 100%, 129%, 200%
Maximum Original Size
Legal
Standard Paper Capacity
1 x 500-Sheet Paper Cassette (21 lb. Bond)
1 x 100-Sheet Stack Bypass
Manual Bypass
(21 lb. Bond)
Maximum Paper Capacity
1,100 Sheets
Acceptable Paper Weights
Cassette
17 lb. to 24 lb. Bond
Bypass
15 lb. to 34 lb. Bond
Duplexing
Standard
Warm Up Time
Less than 19 Seconds
1.5 Seconds (From Energy Saver Mode)
Exposure Control
Automatic or Manual (9 Levels)
Power Requirements
120V AC, 60Hz, 5.4A
Power Consumption: 848W (Maximum)
Dimension
17-7/8 x 20-1/2 x 18
Weight
(Including Drum Unit, Excluding Toner Cartridge): Approximately 53.1 lb.
Estimated Toner Yield
8,400 1 crtg/case (Estimated @ 6% Coverage)
Feeders
Description
Duplexing Automatic Document FeederΔΔ
Acceptable Originals
Statement to Legal
Capacity
50 Sheets (21 lb. Bond)
Paper Weights
13 lb. to 34 lb. Bond (One-Sided Scanning)
13 lb. to 28 lb. Bond (Two-Sided Scanning)
Description
Cassette Feeding Module-N2 (Optional)
Capacity
1 x 500 - Sheet Paper Cassette (21 lb. Bond)
Paper Weights
Paper Size: Legal, Letter
Dimensions
6-1/4 x 20-1/2 x 17-3/8
Weight
Approximately 11.46 lb.
Paper Supply Options
Description
Cabinet-VI
Dimensions
20-5/8 x 20-1/2 x 19
Weight
27.9 lb.
Output Options
Fax Board
Description
Super G3 Fax Functionality††
Applicable Line
Public Switched Telephone Network (PSTN)
Connection Lines: One
Effective Image Size: Statement, Letter, Legal
Transmission Speed
Approximately 3 Seconds/Page†††33,600 bps (Maximum)
Data Compression
MH, MR, MMR, JBIG
Error Correction: Yes (ECM)
One Touch Speed Dialing Locations
23 Destinations
Coded Speed Dialing Locations
177 Destinations
Group Dials: 199 Destinations
Image Memory: Approximately 1,000 Pages†††
Print Board
Processor
Canon Custom Processor - Shared
Standard Memory
Shared with Main Unit - 256MB RAM
PDL Support
UFR II LT (Standard),** PCL 5e/6**
(Optional with PCL Printer Kit-AB1)
Interface Connections
USB 2.0 Hi-Speed
10/100Base-TX***
Network OS: Windows® 2000/XP/Server 2003/Windows Vista®
Macintosh®OS (10.2.8 to 10.4.6)†
Send Expansion Sets
Description
Sending Capabilities††
Sending Method
E-mail, I-fax, Fax, File Server (FTP/SMB)
Destinations
One-Touch Dials: 23 Destinations
Coded Dials: 177 Destinations
File Format
Black and White: TIFF, PDF
Color: JPEG, PDF (Compact)
Sending Size
Statement to Legal Utility Software
Remote UI/imageWARE Enterprise Management Console/Fax Driver/Cover Sheet Editor/iR Toolbox/Canon Font Manager Additional Supplies and Accessories Barcode Printing Kit-B1Basic Card Set Braille Label Kit-E1Card Reader Attachment-D2Card Reader-E1Cassette-AD1Copy Card SetsGPR-22 Black Toner PCL Printer Kit-AB1Network Interface Adapter-IN-E11**∂ Up to 24 ppm (LTR) when feeding from Stack Bypass
* Warm-Up/First-Copy Time may differ depending on the condition and environment of the device.
** Network printing requires the optional Network Interface Adapter-IN-E11 on the imageRUNNER 1025 model.
*** Optional for imageRUNNER 1025 model.
† Only available for UFR II LT.
†† Send/Fax capability is only available on the imageRUNNER 1025iF model.
††† Approximate 3-second-per-page fax transmission time based on ITU-T No.1 Chart (JBIG, Standard Mode) at 33.6 Kbps modem speed when transmitting to another V.34 machine. The Public Switched Telephone Network (PSTN) currently supports 28.8 Kbps Modem speeds or lower, depending on telephone line conditions.
Δ Based on ITU-T Standard Mode.
ΔΔ Only available on the imageRUNNER 1025N/1025iF models.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 1025iF that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Supplies
GPR-22 Toner
Color: Black
Item Code: 0386B003AA
Estimated Toner Yield: 8,400 Copies/Case  (Estimated @ 6% Coverage)
Product Configurator
Click here for the imageRUNNER 1025 Series Configurator
Brochures
Loading...
Videos
  • Click here to view the Canon "Protecting Your Environment" In-Brief Video.
Awards
BLI 2009 Recommended
BLI 2009 Reliability Seal
2010 BLI Performance Certified Seal
#1 Ease of Use Monochrome MFP Customer Survey
#1 Best Monochrome MFP's Customer Survey
 Return to Top
