Web Content Viewer
Actions
imageRUNNER 1435i
Multifunction Copiers
Features
  • A compact MFP supporting up to legal-size paper, the imageRUNNER 1435i features a smart, comfortable design that can easily fit on a desktop or in a centralized area with optional paper cassette or cabinet for walk-up convenience cassette or cabinet for walk-up convenience.
  • The highly-visible 5-Line LCD, and logical button layout simplifies device use.
  • The imageRUNNER 1435i employs Canon's imageCHIP Lite platform, providing efficient performance to speed up concurrent print, copy, scan and send jobs. Built-in Ethernet, dual USB 2.0 ports and ample memory enhances the device's productivity.
  • Operating at print/copy speeds of 37ppm, the imageRUNNER 1435i delivers superior quality output. With a print a resolution of 600x600 dpi (1200x600 dpi equivalent), users will benefit from faithful reproduction and clarity of their documents.
  • With a standard 600-Sheet paper capacity and a maximum paper capacity of 1,100 sheets, the imageRUNNER 1435i enables offices to be more productive.
  • Canon's innovative UFR II LT print language is standard on the imageRUNNER 1435i. UFR II LT is optimized to produce high-speed output by automatically sharing processing tasks between the desktop computer and the device. The imageRUNNER 1435i also has optional PCL 5e/6 and Adobe PostScript 3, ideal for printing business documents.
  • Help secure your office with the standard User Authentication for Send Operations (ASend). ASend prompts users for their credentials before accessing the Send screen, and also allows for Send restrictions, such as Email to Self only.
  • Easily copy both sides of an ID Card onto a single page with ID Card Copy.
  • Browse the corporate address book for easy scan-and-send operations with LDAP Address Support.
  • IT Managers can take control and reduce costs of operations with a variety of tools such as Remote User Interface, imageWARE Enterprise Management Console and plug-ins, and embedded uniFLOW support.
  • Conveniently scan to/print from a USB memory stick with the front mounted USB port.
This is to make Misc appear on the page when needed.
imageRUNNER 1400 Series Spec Sheet
imageRUNNER 1435i
MAIN UNIT
SYSTEM TYPE Digital Multifunction Imaging System
FUNCTIONS Copy, Print, Scan, Send
OPERATION PANEL 5-line LCD
MEMORY RAM 512 MB; Standard USB Port
NETWORK INTERFACE CONNECTION Standard: 1000Base-T, 100Base-TX, 10Base-T
Other: USB2.0 x1 (Host), USB1.1 x1(Host), USB (Device)
COPY SPEED Letter: Up to 37 ppm Legal: Up to 25 ppm
PRINT SPEED Letter: Up to 37 ppm Legal: Up to 25 ppm
FIRST-COPY-OUT TIME (LETTER) As fast as 6.9 Seconds
FIRST-PRINT-OUT TIME (LETTER) As fast as 5.0 Seconds
PAPER SOURCES (20 lb. Bond) Standard: 500-sheet Cassette 100-sheet Bypass
Optional: 500-sheet Cassette
Maximum: 1,100 Sheets
OUTPUT CAPACITY (20 lb. Bond) Maximum: 100 Sheets
OUTPUT PAPER SIZES Cassette: Letter, Legal
Bypass: Letter, Legal, Statement, Executive, Custom Size (3” x 5” to 8-1/2” x 14”), Envelope (C5/DL/ COM-10/Monarch)
ACCEPTABLE PAPER WEIGHTS Cassette: 17 lb. Bond to 24 lb. Bond (64 to 90 g/m2)
Bypass: 16 lb. Bond to 34 lb. Bond (60 to 128 g/m2
WARM-UP TIME From Power On: 20 Seconds or Less
From Sleep: 7.8 Seconds or Less
POWER REQUIREMENTS / PLUG 120-127 V AC, 60 Hz, 7.8 A/NEMA 5-15P
POWER CONSUMPTION Maximum: 1,500 W
Sleep Mode: 2.0 W or Less
DIMENSIONS (W X D X H) 18-3/4” x 21-1/2” x 18” (475.3 mm x 545 mm x 457 mm)
INSTALLATION SPACE (WXD) 30-3/8” x 18” (772.1 mm x 457 mm) (when the Multi-purpose Tray is extended)
WEIGHT Approx. 52.3 lb. (23.74 kg)
IMAGE READER UNIT
SCAN RESOLUTION Up to 600 x 600 dpi
ACCEPTABLE ORIGINALS (GLASS) Sheet, Book, 3-Dimensional objects up to 4.4 lb. (2 kg)
MAXIMUM ORIGINAL SIZE Up to 8-1/2” x 14”
DOCUMENT FEEDER
SCAN METHOD Duplexing Automatic Document Feeder
ACCEPTABLE ORIGINALS Paper Sizes: 5-1/2” x 5” to 8-1/2” x 14”
Paper Weights:
Simplex: 13 lb. to 28 lb. Bond (50 to 105 g/m2)
Duplex: 17 lb. to 28 lb. Bond (64 to 105 g/m2)
SCAN SPEED (BW / COLOR; LETTER) Simplex: Up to 29 ipm (BW)/10 ipm (Color)
Duplex: Up to 10 ipm (BW)/6 ipm (Color)
PAPER CAPACITY (20 lb. Bond) : Up to 50 Sheets (20 lb. Bond)
COPY SPECIFICATIONS
MULTIPLE COPIES 1 to 999
COPY EXPOSURE Automatic or Manual (17 Levels)
MAGNIFICATION 25% - 400% (1% Increments) from Platen Glass
PRESET REDUCTIONS 25%, 50%, 64%, 78%
PRESET ENLARGEMENTS 129%, 200%, 400%
BASIC COPY FEATURES Preset R/E Ratios by Area, Two-Sided, Exposure Adjustment, Original Type Selection, Setting Confirmation/Cancel, Standard Keys, Reset, ID Management, Counter Check
SPECIAL COPY FEATURES ID Card Copy, Frame Erase, Mode Memory, Sharpness, Image Combination, Different Size Original
PRINT SPECIFICATIONS
PROCESSOR Canon Dual Custom Processor (Shared)
ENGINE RESOLUTION 600 x 600 dpi; 1200 x 600 dpi (Enhanced)
PDL SUPPORT Standard: UFR II LT
Standard (1435iF/1435P): PCL 5e/6, and Adobe PS 3
Optional: Barcode Printing Kit
PRINT DRIVERS SUPPORTED OS UFR II LT, PCL 5e/6, Adobe PS 3, Windows® (XP/Windows Vista®/7/8/8.1), Windows Server (2003/2003R2/2008 /2008 R2/ 2012/2012 R2), Windows Terminal Server (2003/2003R2/2008/2008 R2/2012/2012 R2), Microsoft Clustering Server 2003/2003R2/2008/ 2008 R2/2012/2012 R2),Microsoft App-V, Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5/7.5, XenDesktop 4.0/5.0/5.5/5.6/7.0/7.1/7.5), VMware (vSphere 4/5/5.1), SAP (PS3, PCL), Macintosh® (OS X 10.5.8 or later) (UFR II LT, PS 3)
DIRECT PRINT SUPPORT
Standard: TIFF, JPEG
Standard:: PDF
Optional: PDF (with optional USB Direct Print Kit or PS Printer Kit)
PRINT FEATURES Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-Sided Printing, Collating, Booklet Printing, Grouping, Printing on Transparencies, Front/ Back Covers, Objective, Toner Reduction, Poster Printing
SCAN SPECIFICATIONS
NETWORK TWAIN SCAN Standard
NETWORK SCAN UTILITY ScanGear MF
UNIVERSAL SEND SPECIFICATIONS
SENDING METHOD E-mail, USB, File Server (FTP, SMB)
COLOR MODE Color: 300 dpi, 200 dpi, 150 dpi
BW: 300 dpi, 150dpi
SCAN RESOLUTION 600 x 600 dpi, 400
ADDRESS BOOK CAPACITY Max. 300 Destinations (Incl. 19 One-Touch Buttons)
COMMUICATION PROTOCOL File: FTP (TCP/IP), SMB (TCP/IP)
E-mail: SMTP, POP3
FILE FORMAT Standard: TIFF, JPEG, PDF, PDF (Compact), PDF (Compact/OCR), PDF (OCR)
Optional: Encrypted PDF, Digital Signature PDF
UNIVERSAL SEND FEATURES Two Sided Original, Original Type Selection, Density Adjustment, Sharpness, Subject/Message, Reply-to, E-mail Priority, Senders Name
STORE SPECIFICATIONS
STANDARD USB Memory
SECURITY SPECIFICATIONS
STANDARD Department ID Management, IPv6, Restricting Features (Restricting New Addresses on Address Book, Allow Fax Driver TX, Restrict Recall, Confirm Entered Fax Numbers, Restrict Sequential Broadcast, Restrict USB Interface), Memory Lock, MAC/IP Address Filtering, SMTP Authentication POP Authentication before SMTP, IEEE802.1x, Authentication Feature for Send Operation (ASend), Secured Print, SNMP v1/v3, SSL Encrypted Communication, Fax Forwarding, Fax Destination Confirmation, USB Block, TLS Support for E-mail , Fax TX Archive
OPTIONAL Encrypted PDF, Device Signature PDF, uniFLOW
ENVIRONMENTAL INFORMATION
ENERGY STAR® Qualified
Rated EPEAT® Silver
EU RoHS Compliant
Blue Angel
WEEE Directive
CONSUMABLES
TONER GPR-54 Toner
TONER YIELD (ESTIMATED @ 6% COVERAGE) Black: 17, 600 Copies/Case
FOOTNOTES
* Duplexing Automat
Supplies
GPR-54 Toner
Color: Black
Item Code: 9436B003AA
Estimated Toner Yield: 17,600 copies/case (Estimated @ 6% Coverage)
Accessories
Hardware Accessories
  • Cassette Module-AC1
  • Cabinet Type-K
  • USB Keyboard (Cherry)
  • Copy Card Reader-F1
  • Copy Card Reader Attachment-E1
  • ADF Access Handle-A1
  • Braille Label Kit-F1
  • Copy Control Interface Kit-C1
  • Convenience Stapler-B1
  • Universal Keyboard Stand-A1
  • Card Reader Assembly for Universal Keyboard Stand
System Connectivity Accessories
  • Barcode Printing Kit-D1
  • Send PDF Security
Supplies
  • Canon GPR-54 Toner Black (Item # 9436B003AA)
Videos
  • Click here to view the Canon "Protecting Your Environment" In-Brief Video
 Return to Top
