Web Content Viewer
Actions
imageRUNNER 1435iF+
Multifunction Copiers
imageRUNNER ADVANCE Configurator. Build your model, and customize configurations based on specific needs.
Solutions to help increase office efficiencies and productivity
Advanced Solutions for your industry
Features
Whether you’re a small business or part of a workgroup the imageRUNNER 1435+ Series models can boost operational efficiency. Scan and email documents to clients and colleagues or conveniently scan to/print from a USB memory stick. The ID Card Copy feature easily copies cards and other small, two-sided documents onto the same page. Extend your document management capabilities when you scan using the standard PDF (OCR) format. These models enable mobile workers and offices with the ability to scan to/print from select mobile devices.
Safeguard information and help ensure security compliance with the imageRUNNER 1435+ Series. Canon’s uniFLOW solution lets users securely retrieve documents from any networked device. With the now standard Send PDF Security Set, users can send encrypted PDFs and add a digital device signature to PDF files. TX Archiving automatically forwards a copy of a fax to an administrator-defined destination. And with no hard disks in these models, there are no latent images.
Designed with your bottom line in mind, the Canon imageRUNNER 1435+ Series helps minimize costs and maximize reliability, while the robust design helps ensure long, dependable operation. Canon’s uniFLOW® software helps control costs by managing, tracking, and charging back usage. And simple-to-replace, high-yield consumables help keep work moving while achieving a lower cost per page.
An ideal replacement for single-function printers or older models, the imageRUNNER 1435+ Series easily integrates into your network of imageRUNNER devices to streamline and simplify management and maintenance. Even receive alerts when supplies or service calls are needed with imageWARE Enterprise Management Console and plug-ins.
With a first-copy-out time as fast as 6.9 seconds and output up to 37 ppm, the imageRUNNER 1435+ Series is a quick performer. Scan documents in black and white and color to email addresses or networked locations. The highly visible, 5-line display simplifies use. The standard 600-sheet capacity can be increased to 1,100 sheets to handle many jobs without interruption.
The imageRUNNER 1435+ Series meets ENERGY STAR® standards and has a low TEC (Total Energy Consumption) rating. EPEAT® rated, these models follow Canon’s stringent Green Procurement policy and environmental commitments.
imageRUNNER 1435+ Series Brochure
imageRUNNER 1435iF+
MAIN UNIT
TYPE Digital Multifunction Imaging System
CORE FUNCTIONS Print, Copy, Scan, Send, Fax
PROCESSOR Canon Dual Custom Processor (Shared)
OPERATION PANEL 5-line LCD
MEMORY RAM 512 MB, Standard USB Port
INTERFACE CONNECTION Network: 1000Base-T/100Base-TX/10Base-T
Optional: USB2.0 x1 (Host), USB1.1 x1 (Host), USB (Device)
PAPER SOURCES (LTR, 20LB BOND) Standard: 500-sheet Paper Cassette, 100-sheet Stack Bypass
Optional: 500-sheet CASSETTE MODULE-AC1
Maximum: 1,100 Sheets
PAPER OUTPUT CAPACITY (LTR, 20LB BOND) Maximum: 100 Sheets
SUPPORTED MEDIA SIZES Cassette: Letter, Legal
Bypass: Letter, Legal, Statement, Executive, Custom size (3" x 5" to 8-1/2" x 14"), Envelope (C5/DL/ COM-10/Monarch)
SUPPORTED MEDIA WEIGHTS Cassette: 17 lb. Bond to 24 lb. Bond (64 to 90 g/m2)
Bypass: 16 lb. Bond to 34 lb. Bond (60 to 128 g/m2)
COPY SPEED (BW) Up to 37 ppm (Letter); Up to 30 ppm (Legal)
PRINT SPEED (BW) Up to 37 ppm (Letter); Up to 30 ppm (Legal)
WARM-UP TIME From Power On: 20 Seconds or Less1
From Sleep Mode: 7.8 Seconds or Less
DIMENSIONS (W X D X H) 18-3/4" x 21-1/2" x 18" (475.3 mm x 545 mm x 457 mm)
INSTALLATION SPACE (WXD) 30-3/8" x 18" (772.1 mm x 457 mm) when multipurpose tray is extended
WEIGHT2 Approx. 52.3 lb. (23.74 kg)
PRINT SPECIFICATIONS
FIRST-PRINT-OUT TIME (LTR) As fast as 5 Seconds
PRINT RESOLUTION (dpi) 600 x 600; 1200 x 600 (Enhanced)
STANDARD PAGE DESCRIPTION LANGUAGES UFR II, PCL®5e/6, Adobe® PS® 3
Optional: Barcode Printing Kit
DIRECT PRINT SUPPORT Standard: TIFF, JPEG, PDF
Available from USB, Advanced Box, Remote UI, and Web Access3
OPERATING SYSTEM UFR II LT, PCL 5e/6, Adobe PS 3, Windows® (XP/Windows Vista®/7/8/8.1), Windows Server (2003/2003R2/2008/2008 R2/ 2012/2012 R2), Windows Terminal Server (2003/2003R2/2008/ 2008 R2/2012/2012 R2), Microsoft Clustering Server 2003/2003R2/2008/ 2008 R2/2012/2012 R2), Microsoft App-V, Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5/7.5, XenDesktop 4.0/5.0/5.5/5.6/7.0/7.1/7.5), VMware (vSphere 4/5/5.1), SAP (PS3, PCL), Macintosh® (OS X 10.5.8 or later) (UFR II LT, PS 3)
PRINT FEATURES Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-Sided Printing, Collating, Booklet Printing, Grouping, Printing on Transparencies, Front/Back Covers, Objective, Toner Reduction, Poster Printing
COPY SPECIFICATIONS
FIRST-COPY-OUT TIME (LTR) As fast as 6.9 Seconds (via Platen)
COPY RESOLUTION (dpi) Reading/Printing: Up to 600 x 600
COPY SPECIFICATIONS Automatic or Manual (9 Levels)
MULTIPLE COPIES Up to 999
MAGNIFICATION 25% - 400% (1% Increments) from Platen Glass
PRESET REDUCTIONS 25%, 50%, 64%, 78%
PRESET ENLARGEMENTS 129%, 200%, 400%
BASIC COPY FEATURES Preset R/E Ratios by Area, Two-Sided, Exposure Adjustment, Original Type Selection, Setting Confirmation/Cancel, Standard Keys, Reset, ID Management, Counter Check
SPECIAL COPY FEATURES ID Card Copy, Frame Erase, Mode Memory, Sharpness, Image Combination, Different Size Original
SCAN SPECIFICATIONS
TYPE Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY Up to 50 Sheets (20 lb. Bond)
MAXIMUM ORIGINAL SIZE Up to 8-1/2" x 14"
DOCUMENT FEEDER SUPPORTED MEDIA SIZES 5-1/2" x 5" to 8-1/2" x 14"
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHT Simplex: 13 lb. to 28 lb. Bond (50 to 105 g/m2)
Duplex: 17 lb. to 28 lb. Bond (64 to 105 g/m2)
PLATEN ACCEPTABLE ORIGINALS Sheet, Book, 3-Dimensional Objects Weight Up to 4.4 lb. (2 kg)
NETWORK TWAIN SCAN Standard
NETWORK SCAN UTILITY ScanGear MF
SCAN RESOLUTION Up to 600 x 600
SCAN SPEED (LTR) 300 dpi Simplex: Up to 29 ipm (BW)/10 ipm (Color)
Duplex: Up to 10 ipm (BW)/6 ipm (Color)
SEND SPECIFICATIONS
DESTINATION Email, USB, File Server (FTP, SMB)
COLOR MODE Color, BW
SCAN RESOLUTION Color: 300 dpi, 200 dpi, 150 dpi BW: 300 dpi, 150dpi
ADDRESS BOOK Max. 300 Destinations (Incl. 19 One-Touch Buttons)
COMMUICATION PROTOCOL File: FTP (TCP/IP), SMB (TCP/IP) Email: SMTP, POP3
FILE FORMAT Standard: TIFF, JPEG, PDF, PDF (Compact), PDF (Compact/OCR), PDF (OCR), Encrypted PDF, Digital Signature PDF
UNIVERSAL SEND FEATURES Two Sided Original, Original Type Selection, Density Adjustment, Sharpness, Subject/Message, Reply-to, Email Priority, Senders Name
FAX SPECIFICATIONS
MAXIMUM NUMBER OF CONNECTION LINES One
MODEM SPEED Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE Letter, Legal, Statement
FAX FEATURES Job Forwarding, Adjusting Density, Sharpness, Specifying the Sender’s Name, Selecting the Telephone Line Type, Two-Sided Original, TX Archive, Distinctive Ring Detection
STORE SPECIFICATIONS
MEMORY MEDIA Standard: USB
SECURITY SPECIFICATIONS
AUTHENTICATION Standard: Department ID Management, IPv6, Restricting Features (Restricting New Addresses on Address Book, Allow Fax Driver TX, Restrict Recall, Confirm Entered Fax Numbers, Restrict Sequential Broadcast, Restrict USB Interface), Memory Lock, MAC/IP Address Filtering, SMTP Authentication POP Authentication before SMTP, IEEE802.1x, Authentication Feature for Send Operation (AuSend), Secured Print, SNMP v1/v3, SSL Encrypted Communication, Fax Fowarding, Fax Destination Confirmation, USB Block, TLS Support for Email, Fax TX Archive, Encrypted PDF, Digital Signature PDF
Optional: uniFLOW
ENVIRONMENTAL SPECIFICATIONS
POWER REQUIREMENTS 120-127 V, 60 Hz, 7.8 A
PLUG (MAIN UNIT) NEMA 5-15P
POWER CONSUMPTION Maximum: 1,500 W
Sleep Mode: 2.0 W or Less4
STANDARDS ENERGY STAR® Certified
Rated EPEAT® Silver5
WEEE Directive5
CONSUMABLES
TONER GPR-54 Toner
TONER YIELD (ESTIMATED @ 6% COVERAGE) Black: 17,600 Copies/Case
FOOTNOTES
1 Time from device power-on until copy ready (not print reservation).
2 Includes consumables.
3 PDF print from Web sites is supported.
4 2.0 W sleep mode not available in all circumstances due to certain settings.
5 For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
This is to make Misc appear on the page when needed.
Supplies
GPR-54 Toner
Color: Black
Item Code: 9436B003AA
Estimated Toner Yield: 17,600 copies/case (Estimated @ 6% Coverage)
Accessories
Hardware Accessories
  • Cassette Module-AC1
  • Cabinet Type-K
  • USB Keyboard (Cherry)
  • Copy Card Reader-F1
  • Copy Card Reader Attachment-E1
  • ADF Access Handle-A1
  • Braille Label Kit-F1
  • Copy Control Interface Kit-C1
  • Convenience Stapler-B1
  • Universal Keyboard Stand-A1
  • Card Reader Assembly for Universal Keyboard Stand
System Connectivity Accessories
  • Barcode Printing Kit-D1
  • Send PDF Security
Brochures
Loading...
 Return to Top
