Web Content Viewer
Actions
imageRUNNER ADVANCE 4225
Multifunction Copiers
imageRUNNER ADVANCE Configurator. Build your model, and customize configurations based on specific needs.
Solutions to help increase office efficiencies and productivity
Advanced Solutions for your industry
From every point of view, it’s simply advanced
Features
The imageRUNNER ADVANCE 4200 Series empowers users. With an impressive range of customizable, simple-to-use, streamlined features, these models help everyone work smarter and faster.
A powerful digital communications center, the imageRUNNER ADVANCE 4200 Series integrates enterprise applications, connects to the cloud, and gives you the freedom to work from wherever you are, efficiently and easily.
In today's networked world, you need greater control over your resources and data. The imageRUNNER ADVANCE 4200 Series delivers just that with the ability to configure a system, better safeguard information, and track resources, all right at your fingertips.
Give your business a real competitive edge with the imageRUNNER ADVANCE 4200 Series. True multitasking power keeps work moving. Custom workflow solutions streamline processes. And professional-quality documents are reliably produced.
It's all about a brighter, greener future. The imageRUNNER ADVANCE 4200 Series, registered in EPEAT®, incorporates innovative, eco-conscious features that keep your business operating efficiently while helping to reduce your environmental footprint.
imageRUNNER ADVANCE 4200 Series Spec Sheet
MAIN UNIT
SYSTEM TYPE Digital Multifunction Imaging System
FUNCTIONS Standard: Copy, Print (UFR II), Scan, Send, Store
Optional: Print (PCL, Adobe® PostScript® 3), Fax (Up to 4 Lines)
OPERATION PANEL 8.4" SVGA Full-Color TFT Screen
MEMORY Standard: 1.25GB RAM
Maximum: 1.75GB RAM
HARD DISK DRIVE Standard: 160GB
Maximum: 1TB
MIRRORING HARD DISK DRIVE Optional (160GB, 1TB), Method: RAID1
NETWORK INTERFACE CONNECTION Standard: 10/100/1000Base-TX
Optional: Wireless LAN
OTHER INTERFACE Standard: USB 2.0 (Host) x 2, USB 2.0 (Device)
Optional: Device Port [USB 2.0 (Host) x 2], Copy Control Interface
COPY / PRINT SPEED (BW) Letter: Up to 25 ppm
Legal: Up to 13 ppm
11" x 17": Up to 15 ppm
PAPER SOURCES (20 lb. Bond) Standard: Dual 550-sheet Paper Cassettes, 80-sheet Stack Bypass
Optional: Dual 550 Sheet Paper Cassettes, 2,700-sheet Paper Deck
Maximum: 4,980 Sheets
OUTPUT PAPER CAPACITY (20 lb. Bond) Standard: 250 Sheets (Inner Tray)
Maximum: 3,100 Sheets (w/Staple Finisher or Booklet Finisher)
OUTPUT PAPER SIZES Cassette 1: Legal, Letter, Letter-R, Statement-R, Executive, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 15-3/8")
Cassettes 2/3/4: 11" x 17", Legal, Letter, Letter-R, Statement-R, Executive, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 17")
Bypass: 11" x 17", Legal, Letter, Letter-R, Statement-R, Executive, Custom Size (3-7/8" x 5-7/8" to 11-3/4" x 17")
Other Option: Envelope Feeder Attachment** (COM10 No.10, Monarch, DL, ISO-C5)
ACCEPTABLE PAPER WEIGHTS Cassettes: 16 lb. Bond to 34 lb. Bond (60 to 128g/m2 )
Bypass: 14 lb. Bond to 80 lb. Cover (52 to 220g/m2 )
DUPLEXING Paper Size: Standard Automatic Trayless Duplexing (Executive to 11" x 17")
Paper Weights:14 lb. Bond to 28 lb. Bond (52 to 105g/m2 )
SPECIAL MEDIA SUPPORT Tracing, Labels, Transparency, and Envelopes
WARM-UP TIME From Power On: 30 Seconds
From Sleep Mode: 10 Seconds
Quick Startup Mode: 7 Seconds***
POWER REQUIREMENTS / PLUG 120V AC, 60Hz, 10.4A/NEMA 5-15P
POWER CONSUMPTION Maximum: 1,500W
Sleep Mode: 0.9W
DIMENSIONS (W X D X H) 30-3/8" x 22-1/4" x 27-5/8" (771mm x 565mm x 700mm)
INSTALLATION SPACE (WXD) (when the Multi-Purpose Tray is extended)
34-1/2" x 27-5/8" (876mm x 700mm)
WEIGHT (Includes consumables) Approx. 154 lb. (70kg)
IMAGE READER UNIT
SCAN RESOLUTION Up to 600 x 600 dpi
ACCEPTABLE ORIGINALS (GLASS) Sheet, Book, 3-Dimensional objects [up to 4.4 lb. (2kg)]
MAXIMUM ORIGINAL SIZE Up to 11" x 17"
DOCUMENT FEEDER
SCAN METHOD Duplexing Automatic Document Feeder
ACCEPTABLE ORIGINALS Paper Sizes: 11" x 17", Legal, Letter, Letter-R, Statement
Paper Weights: BW: 11 lb. Bond to 34 lb. Bond (42 to 128g/m2 ) Solid Black Text/Color: 17 lb. Bond to 34 lb. Bond (64 to 128g/m2 )
SCAN SPEED (BW / COLOR; LETTER) Simplex: 51/51 ipm (300 dpi) 51/30 ipm (600 dpi)
PAPER CAPACITY (20 lb. Bond) 100 Sheets
COPY SPECIFICATIONS
FIRST-COPY-OUT TIME (Letter) As fast as 5.2 Seconds
MULTIPLE COPIES 1 to 999
COPY EXPOSURE Automatic or Manual (9 Levels)
MAGNIFICATION From Platen Glass: 25% - 400% (1% increments)
From ADF: 25% - 200% (1% increments)
PRESET REDUCTIONS 25%, 50%, 64%, 73%, 78%
PRESET ENLARGEMENTS 121%, 129%, 200%, 400%
BASIC COPY FEATURES Preset R/E Ratios by Area, Finishing, Two-sided, Density/ Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying
SPECIAL COPY FEATURES Two-page Separation, Cover/Sheet Insertion, Booklet, Transparency Interleaving, Shift, Margin, Frame Erase, ID Card Copy, Image Combination, Different Size Original, Job Build, Job Done Notice, Scan Image Check, Mode Memory, Recall, Negative/ Positive Inversion, Image Repeat, Mirror Image, Sharpness, Tab Paper Creation, Form Composition, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date, Job Block Combination, Store in User Inbox
PRINT SPECIFICATIONS
PROCESSOR Canon Dual Custom Processor (Shared)
Maximum: 1.75GB RAM
Maximum: 1TB
ENGINE RESOLUTION 1200 x 1200 dpi
PDL SUPPORT Standard: UFR II
Optional: PCL 5e, PCL 6, Adobe PS 3
PRINT DRIVERS SUPPORTED OS UFR II, PCL 5e/6, Adobe PS 3:
Windows® (Windows XP/Windows Vista®/Windows 7/Server 2003/Server 2008/Server 2008 R2/Windows 8/Server 2012/ Small Business Server 2011), Windows Terminal Servers (Server 2003/Server 2008/Server 2008 R2/Server 2012), Small Business Server 2011, Windows Clustering Server (Windows Server 2003/ Server 2008/Server 2008 R2/Server 2012), Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5, XenDesktop 4.0/5.0/5.5/6), Macintosh® (OSX 10.5.8 or later, UFR II and PS 3 Only), VMware (vSphere 4/5/5.1), SAP (PS and PCL Only)
DIRECT PRINT SUPPORT Standard: TIFF, JPEG
Optional: PDF, EPS, XPS
PRINT FEATURES Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Printing on Transparencies, Front/Back Covers, Objective, Toner Reduction, Poster Printing
SCAN SPECIFICATIONS
NETWORK TWAIN SCAN Standard
NETWORK SCAN UTILITY Color Network ScanGear
UNIVERSAL SEND SPECIFICATIONS
SENDING METHOD E-Mail, I-Fax, File Server (FTP, SMB, WebDAV), Mail Box, Super G3 Fax (Optional), IP Fax (VoIP) (Optional)
COLOR MODE Auto Color Select (Color, Gray), Auto Color Select (Color, Black), Full Color, Grayscale, BW
SCAN RESOLUTION 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100 dpi
ADDRESS BOOK CAPACITY Max. 1,800 Destinations (Incl. 200 One-Touch Buttons)
COMMUICATION PROTOCOL File: FTP (TCP/IP), SMB (TCP/IP), WebDAV
E-mail/I-Fax: SMTP, POP3, I-FAX (Simple, Full)
FILE FORMAT Standard: TIFF, JPEG, PDF, PDF/XPS (Compact), PDF (Apply Policy), PDF (Optimize for Web), PDF/A-1b, XPS, PDF/XPS (OCR), OOXML (.pptx)
Optional: PDF (Trace & Smooth), PDF (Encrypted), PDF/XPS (Digital Signature)
I-FAX DATA FORMAT BW: TIFF (MH, MR, MMR)
UNIVERSAL SEND FEATURES Two-sided Original, Different-size Originals, Original Type Selection, Book to Two Pages, Density Adjustment, Sharpness, Document Name, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-to, Sender's Name (TTI), E-Mail Priority, Scan Recovery for Misfeeds
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES 4
MODEM SPEED Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
SENDING / RECORDING SIZE Statement to 11" x 17"
FAX FEATURES Job Forwarding, Different-size Originals, Adjusting Overall Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Selecting the Telephone Line (when sending fax), Delayed Send, Preview, Finished Stamp, Job Done Notice, Original Type Selection, Two-sided Original, Book to Two Pages
STORE SPECIFICATIONS
MAIL BOX (NUMBER SUPPORTED) 100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes
6,000 Maximum Pages Stored
ADVANCED BOX Available Disk Space: Approx. 15GB (Standard HDD) Approx. 629GB (1TB HDD)
Communication Protocol: SMB or WebDAV
Supported Client PC: Windows (Windows 2000/XP/Windows Vista/7)
Concurrent Connections (Max.): SMB: 32, WebDAV: 12 (Active Sessions)
Advanced Box Features: Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
MEMORY MEDIA Standard: USB Memory
Optional: SD, SDHC, CompactFlash®, Memory Stick, Microdrive
SECURITY SPECIFICATIONS
STANDARD Department ID Management, Single Sign On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, User Access Control of Advanced Box, Mail Box Password Protection, IPV6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Port Filtering, SMTP Authentication, POP Authentication before SMTP, HDD Erase (Up to 3x), HDD Initialize (Up to 9x), HDD Lock, IPsec, Adobe LiveCycle Rights Management ES2.5 Integration
OPTIONAL Removable HDD, HDD Encryption, HDD Mirroring, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, Secure Watermark, IEEE 2600.1 Common Criteria Certification
ENVIRONMENTAL INFORMATION
ENERGY STAR® Qualified
Rated EPEAT® Silver
EU RoHS Compliant
Ecomark
Blue Angel
WEEE Directive
CONSUMABLES
TONER GPR-43 Toner
TONER YIELD (ESTIMATED @ 6% COVERAGE) Black: 30,200 Copies / Bottle
FOOTNOTES
* Duplexing Automatic Document Feeder-AG1 optional on 4235/4225 models and standard on 4251/4245 models. Platen Cover Type-R or Duplexing Automatic Document Feeder-AG1 must be selected on 4235/4225 models.
** Can be set to Cassette 2 only. Can not install Envelope Feeder Attachment and Tab Feeder Attachment at same time.
*** If “Quick Startup Settings for Main Power” is set to ON, it takes seven seconds until the key operation on the touch panel display is available after turning on the main power and 10 seconds until the start button function is available.
Includes DADF.
Standard color scan support for 100 dpi and 300 dpi. Up to 600-dpi scanning requires additional Memory Type A (512MB).
EPS can be printed directly only from the Remote User Interface.
XPS cannot be printed directly from the Web Access Software.
 Specified configurations and settings need to be applied to the device in order to achieve and maintain IEEE 2600.1 Common Criteria Certification. Contact your Canon Authorized Dealer for more information and availability.
 Applies only to 4245/4235/4225 models.
▲ Option for Inner Finisher-D1.
▲ ▲ Option for Staple Finisher-G1 or Booklet Finisher-G1.
▲ ▲ ▲ Cannot be installed with Inner Finisher-D1 or 2/3 Hole Puncher-A1.
This is to make Misc appear on the page when needed.
Supplies
GPR-43 Toner
Color: Black
Item Code: 4792B003AA
Estimated Toner Yield:  30,200 Copies/Bottle  (Estimated yield at 6% Coverage)
Accessories
Hardware Accessories
  • Cassette Feeding Unit-AF1
  • Paper Deck Unit-B2
  • Envelope Feeder Attachment-D1
  • Inner 2-Way Tray-H1
  • Inner Finisher-D1
  • Staple Finisher-G1
  • Booklet Finisher-G1
  • Inner 2/3-Hole Puncher-A1
  • Cabinet Type-G
  • Platen Cover Type-R
  • Inner Finisher Additional Tray-A1
  • Inner Finisher-D1 with 2/3-Hole Puncher-A1
  • Utility Tray-A2
  • USB Keyboard
  • Card Reader-F1
  • Copy Card Reader Attachment Kit-B2
  • Convenience Stapler-B1
  • Braille Label Kit-F1
  • ADF Access Handle-A1
System Connectivity Accessories
  • imageRUNNER ADVANCE Essentials
  • Universal Send Advanced Feature Set-E1
  • Universal Send Security Feature Set-D1
  • Universal Send Digital User Signature Kit-C1
  • Super G3 Fax Board-AK1
  • Super G3 2nd Line Fax Board-AK1
  • Super G3 3rd/4th Line Fax Board-AE1
  • Remote Fax Kit-A1
  • PCL Printer Kit-AN1
  • PCL International Font Set-A1
  • PS Printer Kit-AN1
  • Direct Print Kit (for PDF/XPS)-H1
  • Encrypted Secure Print-D1
  • Barcode Printing Kit-D1
  • Web Access Software-H1
  • Secure Watermark-B1
  • Wireless LAN Board-B2
  • USB Device Port-D1
  • Multimedia Reader/Writer-A2
  • Additional Memory Type A (512MB)
  • Document Scan Lock Kit-B1
  • Data Erase Kit-C1
  • HDD Data Encryption and Mirroring Kit-C4
  • HDD Mirroring Kit-F1
  • Removable HDD Kit-AF1
  • 2.5-inch/80GB HDD-C1rr
  • 2.5-inch/250GB HDD-D1
  • iR-ADV Security Kit-B1 for IEEE 2600.1 Common Criteria Certification*
  • Expansion Bus-F2
  • Voice Guidance Kit-F2
  • Voice Operation Kit-C2
  • Remote Operator's Software Kit-B1
  • Copy Control Interface Kit-A1
  • eCopy Suite
  • imageWARE Suite
Click here to learn about Software Solutions for imageRUNNER ADVANCE
Note: For additional details and descriptions for each accessory, please access the product configurator.
Brochures
Loading...
Videos
Conducting Business
RUN Use Cases
 Return to Top
