Web Content Viewer
Actions
imageRUNNER ADVANCE 4535i
Multifunction Copiers
imageRUNNER ADVANCE Configurator. Build your model, and customize configurations based on specific needs.
Solutions to help increase office efficiencies and productivity
Advanced Solutions for your industry
Advancing Business Solutions
Features
The imageRUNNER ADVANCE 4535i device offers an efficient workflow solution with an intuitive user interface, complete with color touchscreen display and smartphone-like usability. With Canon’s My ADVANCE feature, each user’s experience can be tailored to their specific needs and synchronized across multiple compatible devices.
Designed to deliver productive workflows, this multifunction printer offers output on various media weights and sizes up to 11” x 17.” The imageRUNNER ADVANCE 4535i model allows users to scan and convert documents to Searchable PDF, Microsoft® Word and PowerPoint® files. An optional single-pass duplexing feeder helps facilitate fast scanning. For mobile devices and flexible work styles, Canon users receive scalable support allowing them to capture or print documents remotely and even access certain cloud applications.*
* Subscription to a third-party cloud service required. Subject to third-party cloud service providers’ terms and conditions.
The Canon imageRUNNER ADVANCE 4535i all-in-one B&W printer supports output management solutions, such as optional uniFLOW, that can give small-to-medium workplace environments the ability to apply print policies, monitor output with detailed reporting and restrict usage by user, helping to reduce unnecessary printing and allowing businesses to monitor and control print-related costs.
This efficiently designed printer can maximize uptime and limit time spent troubleshooting technical issues. When paired with remote and centralized fleet management systems, management of multiple devices can be simplified. The imageRUNNER ADVANCE 4535i gives multi-user workplace environments a multifunction black and white printer with high-performance features in a compact, efficient design.
With a range of standard and optional security capabilities, the imageRUNNER ADVANCE 4535i can help protect sensitive information. This multifunction printer comes standard with Universal Login Manager (ULM), designed to control access with user authentication. This model’s HDD Encryption function – updated to obtain FIPS 140-2 validation - allows the device to automatically encrypt data stored on the main unit’s HDD to limit unauthorized access to internal data. The imageRUNNER ADVANCE 4535i model can help keep each business operation private and secure by controlling input and output using IPsec, port filtering capabilities and SSL technology when needed.
Canon’s imageRUNNER ADVANCE 4535i can serve as a reliable stand-alone printer, scanner, and copier, as well as an excellent addition to a multi-device environment. Canon’s device management tools provide a centralized point of control across multiple units, with the ability to synchronize settings across multiple compatible units. Plus, the imageRUNNER ADVANCE 4535i includes Standard Genuine Adobe® PostScript® and PCL® support integration with enterprise applications and legacy systems to help streamline business processes.
To keep demanding environments moving efficiently, the imageRUNNER ADVANCE 4535i all-in-one printer can provide outstanding quality and reliable performance. This model is designed to meet the needs of businesses and departments that require quality black and white printing, with outstanding imaging technologies that produce consistent output in 1200-dpi print resolution. The imageRUNNER ADVANCE 4535i multifunction printer is designed to save space with its compact design that includes internal finishing options. Users can work efficiently with an intuitive user experience, which includes status notifications for supplies, built-in maintenance videos, and the ability to replace toner on the fly.
Designed to achieve low energy consumption, the imageRUNNER ADVANCE 4535i includes efficient fixing technologies and toner that requires little heat for fusing. And, the imageRUNNER ADVANCE 4535i device can help minimize waste with sustainable features, such as Secure Print and Forced Hold, allowing users to hold, preview and change print settings at the device. Canon’s imageRUNNER ADVANCE 4335i is made with environmental concerns in mind, packed with sustainable features, ENERGY STAR®certified and rated EPEAT® Gold.*
* For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
imageRUNNER ADVANCE 4500 Series Spec Sheet
MAIN UNIT
TYPE Monochrome Laser Multifunctional
CORE FUNCTIONS Standard: Print, Copy, Scan, Send, Store
Optional: Fax
PROCESSOR Canon Dual Custom Processor (Shared)
CONTROL PANEL 10.1" TFT LCD WSVGA Color Touch-panel
MEMORY 3.0 GB RAM
HARD DISK DRIVE Standard: 250 GB
Maximum: 1 TB
MIRRORING HARD DISK DRIVE Optional (250 GB, 1 TB)
Method: Raid1
PRINT RESOLUTION 1200 dpi x 1200 dpi
INTERFACE CONNECTION Network
Standard: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n)
Optional: NFC, Bluetooth
Others
Standard: USB 2.0 x2 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device)
Optional: Serial Interface, Copy Control Interface
PAPER CAPACITY (LTR, 20LB BOND) Standard: 1,180 Sheets Maximum: 6,330 Sheets
PAPER SOURCES (LTR, 20LB BOND) Standard: Two 550-sheet Paper Cassettes, 80-sheet Stack Bypass
Optional: Two 550-sheet Paper Cassettes (Cassette Feeding Unit-AN1), 2,450-sheet Paper Deck (High Capacity Cassette Feeding Unit-B1), 2,700-sheet Paper Deck (Paper Deck Unit-F1)
PAPER OUTPUT CAPACITY (LTR, 20LB BOND) Standard: 250 Sheets
Maximum: 3,350 Sheets (with External Finishers)
FINISHING CAPABILITIES Standard: Collate, Group
With Inner Finisher: Collate, Group, Offset, Staple, Hole Punch,1 Staple-Free Staple, Staple On Demand
With External Finisher: Collate, Group, Offset, Staple, Booklet,2 Staple-Free Staple, Staple On Demand, Hole Punch3
SUPPORTED MEDIA TYPES Paper Cassettes: Thin, Plain, Recycled, Color, Heavy, Pre-punched
Stack Bypass: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Bond, Transparency, Label, Envelope
SUPPORTED MEDIA SIZES Paper Cassette (1): Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 15-3/8")
Paper Cassette (2): 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 15-3/8") Stack Bypass: 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (3-7/8" x 5-7/8" to 11-3/4" x 17")
SUPPORTED MEDIA WEIGHTS Paper Drawers: Paper Cassettes: 16 lb. Bond to 34 lb. Bond (60 to 128 g/m2)
Stack Bypass: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
Duplexing: 16 lb. Bond to 28 lb. Cover (60 to 105 g/m2)
WARM-UP TIME From Power On: 24 Seconds or Less
From Deep Sleep Mode: 10 Seconds or Less
Quick Startup Mode: 4 Seconds4
DIMENSIONS (W X D X H) 23-1/8" x 29-1/8" x 47" (587 mm x 740 mm x 1,193 mm)5
INSTALLATION SPACE (WXD) Basic [With ADF (Stack Bypass and Cassette Drawers Open)]: 35" x 46-1/2" (889 mm x 1,182 mm)
Fully Configured [With ADF+Paper Deck Unit-F1+ Booklet Finisher-Y1 (Cassette Drawers Open)]: 71-3/8" x 50-3/8" (1,811 mm x 1,280 mm)
WEIGHT Approx. 240.7 lb. (109.2 kg)6
PRINT SPECIFICATIONS
PRINT SPEED Up to 35 ppm (Letter); Up to 32 ppm (Letter-R); Up to 25 ppm (Legal); Up to 22 ppm (11" x 17")
STANDARD PAGE DESCRIPTION LANGUAGES UFR II, PCL®6, Adobe® PS® 3
DIRECT PRINT Available from USB, Advanced Box, Remote UI, and Web Access (Opt.)7
SUPPORTED FILE TYPES FOR DIRECT PRINT PDF, TIFF, JPEG, EPS, XPS
PRINTING FROM MOBILE AND CLOUD A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet-connected devices and cloud-based services depending on your requirements.
FONTS PCL fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),8 Barcode Fonts9
PS fonts: 136 Roman
OPERATING SYSTEM10 UFRII: Windows Vista®/Server 2008/Windows® 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10, MAC OS X (10.6.8 or later)
PCL: Windows Vista/Server 2008/Windows 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10
PS: Windows Vista/Server 2008/Windows 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10, MAC OS X (10.6.8 or later)
PPD: MAC OS 9.1 or later, MAC OS X (10.3.9 or later), Windows Vista/Windows 7/Windows 8/Windows 8.1/Windows 10
PRINT FEATURES Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Forced Hold Printing, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Toner Reduction, Poster Printing
COPY SPECIFICATIONS
COPY SPEED Up to 35 ppm (Letter); Up to 32 ppm (Letter-R); Up to 25 ppm (Legal); Up to 22 ppm (11" x 17")
FIRST-COPY-OUT-TIME As fast as 3.8 seconds
COPY RESOLUTION Reading: Up to 600 dpi x 600 dpi
Printing: 1200 dpi x 1200 dpi
MULTIPLE COPIES Up to 999 copies
COPY EXPOSURE Automatic or Manual (9 Levels)
MAGNIFICATION 25%-400% (1% Increments)
PRESET REDUCTIONS 25%, 50%, 64%, 73%, 78%
PRESET ENLARGEMENTS 121%, 129%, 200%, 400%
BASIC COPY FEATURES Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel
SPECIAL COPY FEATURES Book to Two Pages, Two-sided Original, Finishing, Booklet, Job Build, N on 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Store in Mail Box, Superimpose Image, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original
SCAN SPECIFICATIONS
TYPE Optional Single Pass Duplexing Automatic Document Feeder or Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY Single Pass DADF-A1: 150 Sheets (20 lb. Bond) DADF-AV1: 100 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHT Single Pass DADF-A1
BW Original: 13 lb. Bond to 58 lb. Cover (50 to 157 g/m2)
CL Original: 17 lb. Bond to 58 lb. Cover (64 to 157 g/m2)
DADF-AV1
BW Original: 13 lb. Bond to 34 lb. Bond (50 to 128 g/m2)
CL Original: 17 lb. Bond to 34 lb. Bond (64 to 128 g/m2)
PLATEN ACCEPTABLE ORIGINALS Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2 kg)]
PULL SCAN Color Network ScanGear2 for both Twain and WIA
Supported OS: Windows Vista/7/8/8.1/10 Windows Server 2008/Server 2008 R2/Server 2012/Server 2012 R2
SCAN RESOLUTION 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100dpi
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES A range of solutions is available to provide scanning to mobile devices and cloud-based services depending on your requirements.
SCAN SPEED (LETTER) Single Pass DADF-A1
Single-sided Scanning (BW): 80 ipm (300 dpi)/80 ipm (600 dpi)
Single-sided Scanning (Color): 80 ipm (300 dpi)/60 ipm (600 dpi)
Double-sided Scanning (BW): 160 ipm (300 dpi)/150 ipm (600 dpi)
Double-sided Scanning (Color): 160 ipm (300 dpi)/80 ipm (600 dpi)
DADF-AV1
Single-sided Scanning (BW): 70 ipm (300 dpi)/51 ipm (600 dpi)
Single-sided Scanning (Color): 70 ipm (300 dpi)/51 ipm (600 dpi)
Double-sided Scanning (BW): 35 ipm (300 dpi)/25.5 ipm (600 dpi)
Double-sided Scanning (Color): 35 ipm (300 dpi)/25.5 ipm (600 dpi)
SEND SPECIFICATIONS
DESTINATION E-mail/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional)
COLOR MODE Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White), Full color, Grayscale, and Black-and-White
ADDRESS BOOK Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White), Full color, Grayscale, and Black-and-White
SEND RESOLUTION 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100dpi
COMMUICATION PROTOCOL File: FTP, SMB v3.0, WebDAV
E-mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full)
FILE FORMAT Standard: TIFF, JPEG, PDF(Compact, Searchable, Apply policy, Optimize for Web, PDF A/1-b), XPS (Compact, Searchable), Office Open XML (PowerPoint®, Word)
Optional: PDF (Trace & Smooth, Encrypted), PDF/XPS (Digital Signature)
UNIVERSAL SEND FEATURES Original Type Selection,Two-sided Original, Book to Two Pages, Different-size Originals, Density Adjustment, Sharpness, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-to, E-mail Priority, TX Report, Original Content Orientation, Skip Blank Originals, Detect Feeder Multi Sheet Feed
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES 4
MODEM SPEED Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
SENDING / RECORDING SIZE Statement-R to 11" x 17"
FAX MEMORY Up to 30,000 pages
SPEED DIALS Max. 200
GROUP DIALS / DESTINATIONS Max. 199 dials
SEQUENTIAL BROADCAST Max. 256 addresses
MEMORY BACKUP Yes
FAX FEATURES Original Type Selection, Two-sided Original, Book to Two Pages, Different-size Originals, Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Sender's Name (TTI), Select Line, Selecting the Telephone Line (when sending fax), Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, TX Report, Detect Feeder Multi Sheet Feed
STORE SPECIFICATIONS
MAIL BOX (NUMBER SUPPORTED) 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored
ADVANCED BOX Communication Protocol: SMB or WebDAV Supported Client PC: Windows (Windows Vista/7/8/8.1/10)
Concurrent Connections (Max.)
SMB: 64
WebDAV: 3 (Active Sessions)
ADVANCED BOX AVAILABLE DISC SPACE Approx. 16 GB (Standard HDD)
Approx. 480 GB (1 TB HDD)
ADVANCED BOX FEATURES Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
MEMORY MEDIA Standard: USB
SECURITY SPECIFICATIONS
AUTHENTICATION Standard: Universal Login Manager, User Authentication, Department ID Authentication, Access Management System, Device and Function Level Log-in
Optional: uniFLOW
DATA Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption(FIPS140-2 Validated)
Optional: Hard Disk Drive Mirroring, Hard Disk Drive removal, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW)
NETWORK Standard: IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP
DOCUMENT Standard: Secure Print, Forced Hold Printing, Adobe LiveCycle® Rights Management ES2.5 Integration
Optional: Encrypted PDF, Encrypted Secure Print, User and Device signatures, Secure Watermarks, Document Scan Locking
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT Temperature: 50 to 86ºF
Humidity: 20 to 80% RH (no condensation)
POWER REQUIREMENTS 120-127 V AC, 60 Hz, 9.3A
PLUG (MAIN UNIT) NEMA 5-15P
POWER CONSUMPTION Maximum Approx. 1.5 kWh
Standby: Approx. 38 W
Sleep Mode: Approx. 0.9 W11
Typical Electricity Consumption (TEC) Rating: 1.8 kWh
STANDARDS ENERGY STAR® Certified
Rated EPEAT® Gold12
RoHS Compliant
CONSUMABLES
TONER GPR-57 Toner
TONER YIELD (ESTIMATED @ 6% COVERAGE) Black: 42, 100 Copies
FOOTNOTES
1 Requires the optional Inner 2/3 Hole Puncher-C1.
2 Booklet Finisher-Y1 only.
3 Requires the optional 2/3 Hole Puncher Unit-A1.
4 Time from device power-on to when copy jobs can be programmed.
5 Includes Main Unit, Single Pass DADF-A1, and Cassette Feeding Unit-AN1.
6 Includes Main Unit, Single Pass DADF-A1, Cassette Feeding Unit-AN1, and consumables.
7 PDF print from Web sites is supported.
8 Requires the optional PCL International Font Set-A1.
9 Requires the optional Barcode Printer Kit-D1.
10 Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
11 0.9 W Sleep mode is not available in all circumstances due to certain settings.
12 For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
This is to make Misc appear on the page when needed.
Supplies
GPR-57 Toner
Color: Black
Item Code: 0473C003AA
Estimated Toner Yield: 42,100 Copies/Bottle (Estimated yield at 6% Coverage)
Accessories
Hardware Accessories
  • Single Pass DADF-A1
  • DADF-AV1
  • Platen Cover Type W
  • High Capacity Cassette Feeding Unit-B1
  • Cassette Feeding Unit-AN1
  • Cabinet Type-Q
  • Paper Deck Unit-F1
  • FL Cassette-BC1 (replacement for cassette 1)
  • FL Cassette-BD1 (replacement for cassette 2, 3, 4)
  • Envelope Feeder Attachment-D1
  • Inner 2Way Tray-L1
  • Inner Finisher-J1
  • Inner 2/3 Hole Puncher-C1
  • Staple Finisher-Y1
  • Booklet Finisher-Y1
  • Buffer Pass Unit-N1
  • 2/3 Hole Puncher Unit-A1
  • Utility Tray-B1
  • USB Key Board (Cherry)
  • Copy Card Reader-F1
  • Copy Card Reader Attachment-B5
  • Canon Card Set-A1 (1-30)
  • Canon Card Set-A2 (31-100)
  • Canon Card Set-A3 (101-200)
  • Canon Card Set-A4 (201-300)
  • Canon Card Set-A5 (301-500)
  • Canon Card Set-A6 (501-1000)
  • Braille Label Kit-F1
  • ADF Access Handle-A1
  • Copy Control Interface Kit-A1
  • Convenience Stapler-A1
  • Universal Keyboard Stand-A1
  • Card Reader Assembly for Universal Keyboard Stand
System Connectivity Accessories
  • PCL International Font Set-A1
  • Encrypted Secure Print Software-D1
  • Barcode Printing Kit-D1
  • MEAP Web Connection Kit V2.3.3 for Gen3
  • Universal Send Trace & Smooth PDF Kit-A1
  • Universal Send Security Feature Set-D1
  • Universal Send Digital User Signature Kit-C1
  • Super G3 FAX Board-AS2
  • Super G3 2nd Line Fax Board-AS2
  • Super G3 3rd/4th Line Fax Board-AS2
  • IP FAX Expansion Kit-B1
  • Remote FAX Kit-A1
  • Secure Watermark-B1
  • IC Card Reader Box-C1
  • Document Scan Lock Kit-B1
  • HDD Mirroring Kit-J1
  • Removable HDD Kit-AL1
  • HDD Data Erase Scheduler V3.1
  • HDD Data Erase Scheduler V3.1 NFR
  • 2.5inch/250GB HDD-N1
  • 2.5inch/1TB HDD-P1
  • Voice Guidance Kit-G1
  • Voice Operation Kit-D1
  • iR-ADV Security Kit-S1 for IEEE 2600 Common Criteria Certification
  • Connection Kit-A1 for Bluetooth LE
  • NFC KIT-C1
Click here to learn about Software Solutions for imageRUNNER ADVANCE
Note: For additional details and descriptions for each accessory, please access the product configurator.
Brochures
Loading...
The Output Management Solutions available for the Canon imageRUNNER 4535i provides various levels of control and tracking to help reduce wasteful printing and provide you with the tools to help control access to confidential information. With easy functionality and numerous workflow settings, the imageRUNNER ADVANCE 4551i device is designed for high productivity, time efficiency, and cost savings. This enterprise-level, multifunction printing and copying solution is scalable to align with various customer environments as business needs evolve and change.
Document Capture and Distribution Solutions from Canon can help streamline workflows by digitizing data, sharing information, and distributing to a variety of destinations. The Canon imageRUNNER ADVANCE 4535i offers secure and customizable user authentication, data tracking, and distribution options to help meet your organization's requirements. This series is designed with Document Capture and Distribution in mind.
Mobile Solutions from Canon provide users with convenience and control when printing from various locations. The Canon imageRUNNER ADVANCE 4535i device is equipped to support the needs of mobile users based on varying company policies, device types, common file formats, workflows, security requirements and more. On the road, in the home, or at the office, mobile business users can experience ease in printing and scanning with Canon’s mobile solution offering. Canon’s PRINT Business app lets users choose the send destination, enter the send job filename, or release a print job directly from the app on a compatible smartphone.
Information Management and Workflow Solutions from Canon offer powerful, end-to-end support for quickly retrieving information, giving users the capability to digitally store, organize, and manage content. With the Canon imageRUNNER ADVANCE 4535i device, customized workflows can be created to help users streamline daily document related activities and optimize business processes. The multifunction imageRUNNER ADVANCE 4535i device can be a key business solution for information management and easier workflow.
Device Management Solutions from Canon can help solve common workplace challenges and help improve efficiencies within your organization. The enterprise-class Canon imageRUNNER ADVANCE 4535i model offers solid, fleet-based device management tools to establish an integrated solution that can help reduce costs and minimize IT resources. These devices are designed to help companies realize increased productivity and focus on day-to-day IT activities.
Videos
Product Design
Paper Handling and Finishing Option
Platform Overview
Third Generation imageRUNNER ADVANCE
Mobile Device Integration
Third Generation imageRUNNER ADVANCE and the Canon PRINT Business app
Authentication with ULM
BLI A3 'Line of the Year' 2017
Canon Wins for Two Years in a Row
Third Generation imageRUNNER ADVANCE Feature Highlights
 Return to Top
