Web Content Viewer
Actions
imageRUNNER ADVANCE 500iF
Multifunction Copiers
imageRUNNER ADVANCE Configurator. Build your model, and customize configurations based on specific needs.
Solutions to help increase office efficiencies and productivity
Advanced Solutions for your industry
From every point of view, it’s simply advanced
Features
The imageRUNNER ADVANCE 500iF/400iF allows each user to accomplish tasks quickly and effectively. And, these systems are readily customizable, delivering enhanced productivity to everyday workflow.
A powerful digital communications center, the imageRUNNER ADVANCE 500iF/400iF integrates enterprise applications, connects to the cloud, and gives you the freedom to work from wherever you are, efficiently and easily.
In today's networked world, you need greater control over your resources and data. The imageRUNNER ADVANCE 500iF/400iF delivers just that with the ability to configure a system, safeguard information, and track resources, right at your fingertips.
Produce professional-quality documents quickly and easily. The imageRUNNER ADVANCE 500iF/400iF provides eye-catching quality in a compact footprint-all with the reliable performance you expect from Canon.
It's all about a brighter, greener future. The imageRUNNER ADVANCE 500iF/400iF, registered in EPEAT®, incorporates innovative, eco-conscious solutions that propel your business while reducing your environmental footprint.
imageRUNNER ADVANCE 500iF/400iF Spec Sheet
MAIN UNIT
TYPE Monochrome Digital Multifunction Imaging System
FUNCTIONS Copy, Print (UFR II, PCL 5e/6, Adobe® PostScript® 3), Fax (Up to 2 Lines), Scan, Send, Store
OPERATION PANEL 7” WVGA Full-Color, TFT Screen
MEMORY Standard: 1.5GB RAM
Maximum: 1.5GB RAM
HARD DISK DRIVE Standard: 80GB
Maximum: 80GB
NETWORK INTERFACE CONNECTION Ethernet 10/100 Base-TX, Ethernet 1000 Base-TX
OTHER INTERFACE USB 2.0 x3 (Host), USB 2.0 (Device)
COPY / PRINT SPEED (BW) Letter: Up to 52/52 ppm
Legal: Up to 43/43 ppm
FIRST-COPY-OUT-TIME (LETTER) 5 Seconds or Less
PAPER SOURCES (20 LB. BOND) Standard: 550-sheet Paper Cassette / 100-sheet Stack Bypass
Optional: 550-sheet Paper Cassette (Up to 3)
Maximum: 2,300 Sheets
OUTPUT PAPER CAPACITY (20 LB. BOND) Standard: 250 Sheets
Maximum: 500 Sheets (with Staple Finisher-R1)
OUTPUT PAPER SIZES Cassettes: Legal, Letter, Statement, Executive, Custom size [5-1/2" x 8-1/4" to 8-1/2" x 14" (139.7mm x 210mm to 216mm x 355.6 mm)], and Envelopes (COM10, Monarch, DL, ISO-C5)*
Bypass: Legal, Letter, Statement, Executive, Custom size [3-7/8” x 5-1/2” to 8-1/2” x 14” (99mm x 139.7mm to 216mm x 355.6mm)], and Envelopes (COM10, Monarch, DL, ISO-C5)
Other Options: Envelope Feeder Attachment (COM10, Monarch, DL, ISO-C5)*
ACCEPTABLE PAPER WEIGHTS Cassettes: 17 lb. Bond to 28 lb. Bond (64 to 105g/m2 )
Bypass: 17 lb. Bond to 34 lb. Bond (64 to 128g/m2 )
DUPLEXING Paper Size: Standard Automatic Trayless Duplexing (Statement to Legal)
Paper Weights: Up to 34 lb. Bond (128g/m2 )
MEDIA SUPPORT Plain 1 [17 lb. Bond to 21 lb. Bond (64 to 80g/m2 )], Plain 2 [22 lb. Bond to 24 lb. Bond (81 to 90g/m2 )], Recycled [17 lb. Bond to 21 lb. Bond (64 to 80g/m2 )], Color [17 lb. Bond to 24 lb. Bond (64 to 90g/m2 )], Heavy 1 [25 lb. Bond to 28 lb. Bond (91 to 105g/m2 )], Heavy 2 [29 lb. Bond to 34 lb. Bond (106 to 128g/m2 )], Transparency [40 lb. Bond to 67 lb. Cover (151 to 181g/m2 )]**, Pre-punched [20 lb. Bond to 21 lb. Bond (75 to 80g/m2 )], Bond [20 lb. Bond to 24 lb. Bond (75 to 90g/m2 )], Labels [40 lb. Bond to 67 lb. Cover (151 to 181g/m2 )], Envelopes
WARM-UP TIME From Power On: 34 Seconds
From Sleep Mode: 10 Seconds or Less
Quick Startup Mode: Within 7 Seconds or Less***
POWER REQUIREMENTS / PLUG 120V AC, 60Hz, 10.5A, NEMA 5-15
POWER CONSUMPTION Maximum: 1.5 kW
Sleep Mode: 1 W
DIMENSIONS (W X D X H) 24-7/8” x 22-1/8” x 22-3/8” (633mm x 560mm x 567mm)
INSTALLATION SPACE (WXD) Without Staple Finisher-R1: 34-3/4” x 40-7/8” (881mm x 1035mm)
With Staple Finisher-R1: 50-1/4” x 40-7/8” (1276mm x 1035mm)
WEIGHT Approx. 107 lb. (48.7kg)
IMAGE READER UNIT
SCAN RESOLUTION Up to 600 x 600 dpi
ACCEPTABLE ORIGINALS (GLASS) Sheet, Book, 3-Dimensional Objects [up to 4.4 lb. (2kg)]
MAXIMUM ORIGINAL SIZE Legal (8-1/2" x 14")
DOCUMENT FEEDER
SCAN METHOD Duplexing Automatic Document Feeder
ACCEPTABLE ORIGINALS Paper Sizes: Legal, Letter, Statement
Paper Weights: One-sided scanning: 11 lb. Bond to 34 lb. Bond (42 to 128g/m2 ), Two-sided scanning: 13 lb. Bond to 34 lb. Bond (50 to 128g/m2 )
SCAN SPEED (BW / COLOR; LETTER) Simplex: 52 ipm (600 dpi)/52 ipm (300 dpi)
Duplex: 33 ipm (600 dpi)/33 ipm (300 dpi)
PAPER CAPACITY (20 LB. BOND) 100 Sheets
COPY SPECIFICATIONS
MULTIPLE COPIES 1 to 999
COPY EXPOSURE Automatic or Manual (9 Levels)
MAGNIFICATION 25 - 400% (1% Increments) from Platen Glass
25 - 200% (1% Increments) from Document Feeder
PRESET REDUCTIONS 78%, 64%, 50%, 25%
PRESET ENLARGEMENTS 400%, 200%, 129%
BASIC COPY FEATURES Preset R/E Ratios by Area, Finishing, Two-sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel, Standard Keys, Reset, Job Duration Display, Reserved Copying, ID Management, Counter Check
SPECIAL COPY FEATURES ID Card Copy, Shift, Frame Erase, Scan Image Check, Mode Memory, Recall, Sharpness, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date
PRINT SPECIFICATIONS
PROCESSOR Canon Dual Custom Processor (Shared)
ENGINE RESOLUTION 1200 x 1200 dpi
PDL SUPPORT UFR II, PCL 5e/6, Adobe® PostScript® 3
PRINT DRIVER SUPPORTED OS UFR II, Adobe PostScript 3: Windows® (XP/Vista/7/8), Windows Server (2003/2008/2008 R2/ SBS 2011/2012), Windows Terminal Server (2003/2008/2008 R2/ 2012), Microsoft Clustering Server (2003/2008/2008 R2/2012), Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5, XenDesktop 4.0/5.0/5.5/5.6), VMware (vSphere 4/5/5.1), SAP (PS3 Only), Macintosh® (OS X 10.5.8 or later)
PCL 5e/6: Windows® (Windows XP/Vista/7/8; Windows Server 2003/2008/2008 R2/SBS 20112012), Windows Terminal Server (2003/2008/2008 R2/2012), Microsoft Clustering Server (2003/2008/2008 R2/2012), Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5, XenDesktop 4.0/5.0/5.5/5.6), VMware (vSphere 4/5/5.1), SAP
DIRECT PRINT SUPPORT Standard: TIFF, JPEG, PDF, EPS
Optional: XPS
PRINT FEATURES Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Objective, Toner Reduction, Poster Printing, Form Overlay
SCAN SPECIFICATIONS
NETWORK TWAIN SCAN Standard
NETWORK SCAN UTILITY Color Network ScanGear
UNIVERSAL SEND SPECIFICATIONS
SENDING METHOD E-mail, I-Fax, File Server (FTP, SMB, WebDAV), Super G3 Fax
COLOR MODE Auto (Color, Gray), Auto (Color, Black), Full Color, Grayscale, BW
SCAN RESOUTION 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100 dpi
ADDRESS BOOK CAPACITY Max. 1,800 Destinations (Incl. 200 One-Touch Buttons)
COMMUNICATION PROTOCOL File: FTP (TCP/IP), SMB (TCP/IP), WebDAV
E-mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full)
FILE FORMAT Standard: TIFF, JPEG, PDF, PDF (Compact), PDF (Apply Policy), PDF (Optimize for Web), PDF/XPS (OCR), PDF/A-1b, XPS, XPS (Compact), OOXML (OCR) (.pptx)
Optional: PDF (Trace & Smooth), PDF (Encrypted), PDF/XPS (Digital Signature)
I-FAX DATA FORMAT Color: TIFF (MH, MR, MMR)
BW: TIFF (MH, MR, MMR)
UNIVERSAL SEND FEATURES Two-sided Original, Original Type Selection, Density Adjustment, Sharpness, Erase Frame, Delayed Send, Preview, File Name, Subject/Message, Reply-to, Sender's Name (TTI), E-Mail Priority, Send to Myself, Send to My Folder
FAX SPECIFICATIONS
NUMBER OF CONNECTIONLINES Standard: 1
Optional: Line 2
MODEM SPEED Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
SENDING / RECORDING SIZE Statement to Legal
FAX FEATURES Job Forwarding, Density Adjustment, Sharpness, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Selecting the Telephone Line (when sending fax), Delayed Send, Preview, Job Done Notice, Original Type Selection, Two-sided Original, Direct Send, On-Hook Dialing
STORE SPECIFICATIONS
ADVANCED BOX Store To Remote Advanced Box: Supported Print/View from Remote Advanced Box: Supported
MEMORY MEDIA Standard: USB Memory
SECURITY SPECIFICATIONS
STANDARD Department ID Management, Single Sign On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, IPv6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), Send to Myself (only), Send to My Personal Folder (only), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, IEEE 802.1x (wired/wireless), SMTP Authentication, POP Authentication before SMTP, HDD Initialize (Up to 9x) HDD Erase (Up to 3x), HDD Lock, IPsec, Adobe® LiveCycle® Rights Management ES2.5 Integration
OPTIONAL HDD Encryption, Encrypted Secure Print, Encrypted PDF, Secure Watermark, IEEE 2600.1 Common Criteria Certification
ENVIRONMENTAL INFORMATION
  • ENERGY STAR® Qualified
  • RoHS Compliant
  • Blue Angel
  • EPEAT® Rated
  • WEEE Directive
CONSUMABLES
TONER GPR-48 Toner
TONER YIELD (ESTIMATED @ 5% COVERAGE) 15,200 Copies / Bottle
FOOTNOTES
* Can be set to Cassette 2 only.
** Not available on top cassette.
*** If ”Quick Startup Settings for Main Power” is set to On, it takes seven seconds until the key operation on the touch-panel display is available after turning on the main power.
Includes consumables except for Toner.
EPS can be printed directly only from Remote User Interface.
XPS cannot be printed directly from Web Access Software.
Requires imageRUNNER ADVANCE device with Advanced Box.
Available approximately six months after launch.
This is to make Misc appear on the page when needed.
Supplies
GPR-48 Toner
Color: Black
Item Code: 2788B003AB
Estimated Toner Yield:  15,200 Copies/Bottle  (Estimated yield at 6% Coverage)
Accessories
Hardware Accessories
  • Cassette Module-AA1
  • Cabinet Type-H
  • Cabinet Type-L
  • Staple Finisher-R1
  • FL Cassette-AS1
  • Envelope Cassette-E1
  • Copy Card Reader-F1
  • Copy Card Reader Attachment-C2
  • ADF Access Handle-A1
  • Braille Label Kit-F1
  • USB Key Board
  • Universal Keyboard Stand-A1
  • Card Reader Assembly for Universal Keyboard Stand
  • Convenience Stapler-B1
System Connectivity Accessories
  • Super G3 2nd Line FAX Board-AM1
  • Direct Print Kit (for PDF/XPS)-H1
  • PCL International Font Set-B1
  • Barcode Printing Kit-D1
  • Encrypted Secure Print-D1
  • Web Access Software-H1
  • Universal Send Trace & Smooth PDF Kit-A1
  • Universal Send Security Feature Set-D1
  • Universal Send Digital User Signature Kit-C1
  • Secure Watermark-B1
  • iR-ADV Security Kit-C1 for IEEE 2600.1 Common Criteria Certification Set*
  • HDD Data Encryption Kit-C6
  • Remote Operators Software Kit-B1
  • IC Card Reader Box-A1
  • Silex Wireless Bridge SX-2500CG
Click here to learn about Software Solutions for imageRUNNER ADVANCE
Note: For additional details and descriptions for each accessory, please access the product configurator.
Brochures
Loading...
Videos
Conducting Business
RUN Use Cases
 Return to Top
