Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
imageRUNNER ADVANCE 6255
Multifunction Copiers
Canon Store: $
Solutions to help increase office efficiencies and productivity
Advanced Solutions for your industry
From every point of view, it’s simply advanced
Features
Imaging and enterprise applications smoothly converge. Cloud printing and mobility solutions offer the freedom to work anywhere. Multistep tasks become a single step. Speed and accuracy increase with the Series' streamlined, efficient workflow.
In today's networked world, you need greater control over your resources and data. The imageRUNNER ADVANCE 6200 Series delivers just that, with the ability to configure a system, safeguard information, and track resources, all right at your fingertips.
The imageRUNNER ADVANCE 6200 Series keeps your business moving at peak efficiency with true multitasking power, the ability to customize workflow solutions, and the reliable output of professional-quality documents.
imageRUNNER ADVANCE 6200 Series Spec Sheet
imageRUNNER ADVANCE 6255 |
MAIN UNIT | |
SYSTEM TYPE | Monochrome Digital Multifunction Imaging System |
FUNCTIONS | Standard: Copy, Print (UFR II), Scan, Send, Store
Optional: Print (PCL 5e/6, Adobe® PostScript® 3™), Fax (Up to 4 Lines) |
OPERATION PANEL | Standard: 8.4" SVGA Full-Color, TFT Screen
Optional: 10.4" SVGA Full-Color, TFT Upright Screen |
MEMORY | Standard: 1.5GB RAM
Maximum: 2GB RAM |
HARD DISK DRIVE | Standard: 160GB
Maximum: 1TB |
MIRRORING HARD DISK DRIVE | Optional (160GB, 1TB), Method: RAID1 |
NETWORK INTERFACE CONNECTION | Standard: 10Base-T/100Base-TX/1000Base-T
Optional: Wireless LAN (IEEE 802.1x via third-party adapter) |
OTHER INTERFACE | Standard: USB 2.0 (Host) x2, USB 2.0 (Device)
Optional: Device Port [USB 2.0 (Host) x2], Serial Interface, Copy Control Interface |
COPY / PRINT SPEED (BW) | Letter: Up to 55 ppm Legal / 11" x 17": Up to 39 / 32 ppm |
FIRST-COPY-OUT-TIME (LETTER) | 3.3 Seconds or Less |
PAPER SOURCES (20 lb. Bond) | Standard: Dual 1,500-sheet Paper Drawers,
Dual 550-sheet Paper Cassettes,
100-sheet Stack Bypass
Optional: 3,500-sheet Paper Deck Unit-A1 or 3,500-sheet Paper Deck Unit-D1 Maximum: 7,700 Sheets (w/Paper Deck Unit Option) |
OUTPUT PAPER CAPACITY (LTR, 20LB BOND) | Standard: 250 Sheets (w/Copy Tray)
Maximum: 4,000 Sheets (w/Staple Finisher or Booklet Finisher) |
ACCEPTABLE PAPER SIZES | Drawers: Letter
Cassettes: 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 19-1/4") Bypass: 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (4" x 5-7/8" to 11-3/4" x 19-1/4") |
ACCEPTABLE PAPER WEIGHTS | Drawers/
Cassettes: 14 lb. Bond to 80 lb. Cover (52 to 220g/m2
Bypass: 14 lb. Bond to 140 lb. Index (52 to 256g/m2 ) |
DUPLEXING | Paper Size: Standard Automatic Trayless Duplexing
(Up to 11" x 17")
Paper Weights:14 lb. Bond to 80 lb. Cover (52 to 220g/m2 ) |
MEDIA SUPPORT | Thin [14 lb. Bond to 16 lb. Bond (52 to 63g/m2 )], Plain [17 lb. Bond to 24 lb. Bond (64 to 90g/m2 )], Heavy 1 [25 lb. Bond to 66 lb. Cover (91 to 180g/m2 )], Heavy 2 [67 lb. Cover to 80 lb. Cover (181 to 220g/m2 )], Heavy 3 [82 lb. Cover to 140 lb. Index (221 to 256g/m2 )], Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Bond, Letterhead, Tab |
WARM-UP TIME | From
Power On: 30 Seconds or Less
From Sleep Mode: 30 Seconds or Less Quick Startup Mode: 7 Seconds* |
POWER REQUIREMENTS / PLUG | 120-127V AC, 60Hz, 16A/NEMA 5-20P |
POWER CONSUMPTION | Maximum: 1.92kW
Sleep Mode: 0.9W or Less |
DIMENSIONS (W X D X H) | Without the Upright Control Panel:
48" x 25-3/8" x 30-3/8" (1220mm x 645mm x 770mm)
With the Upright Control Panel (To the right edge of the Upright Control Panel in the right-most position): 49-1/4" x 53-3/8" x 30-3/8" (1252mm x 1481mm x 770mm) |
INSTALLATION SPACE (WXD) | Without the Upright Control Panel:
53-5/8" x 30-3/8" (1362mm x 770mm)
With the Upright Control Panel: 74-7/8" x 30-3/8" (1901mm x 770mm) |
WEIGHT | Approx. 516 lb. (234kg)** |
IMAGE READER UNIT | |
SCAN RESOLUTION | Up to 600 x 600 dpi |
ACCEPTABLE ORIGINALS (GLASS) | Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2kg)] |
MAXIMUM ORIGINAL SIZE | Up to 11" x 17" |
DOCUMENT FEEDER | |
SCAN METHOD | Single-Pass Duplexing Automatic Document Feeder |
ACCEPTABLE ORIGINALS | Paper Sizes: 11" x 17", Legal, Letter, Letter-R, Statement,
Statement-R
Paper Weights: 1-sided scanning: 13 lb. Bond to 80 lb. Cover (50 to 220g/m2 ) 2-sided scanning (Black-and-white original): 13 lb. Bond to 80 lb. Cover (50 to 220g/m2 ) 2-sided scanning (Color original): 17 lb. Bond to 80 lb. Cover (64 to 220g/m2 ) |
SCAN SPEED (BW / COLOR; LETTER) | Simplex: Up to 120/85 ipm (300 dpi)
Up to 120/51 ipm (600 dpi)***
Duplex: Up to 200/100 ipm (300 dpi) Up to 120/51 ipm (600 dpi)*** |
PAPER CAPACITY (20 lb. Bond) | 300 Sheets |
COPY SPECIFICATIONS | |
FIRST-COPY-OUT TIME (Letter) | 3.3 Seconds or Less |
MULTIPLE COPIES | 1 to 9,999 |
COPY EXPOSURE | Automatic or Manual (9 Levels) |
MAGNIFICATION | 25% - 400% (1% Increments) |
PRESET REDUCTIONS | 25%, 50%, 64%, 73%, 78% |
PRESET ENLARGEMENTS | 121%, 129%, 200%, 400% |
BASIC COPY FEATURES | Preset R/E Ratios by Area, Finishing, Two-Sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying |
SPECIAL COPY FEATURES | Two-page Separation, Cover/Sheet Insertion, Booklet, Transparency Interleaving, Shift, Margin, Frame Erase, Image Combination, Different-size Original, Job Build, Job Done Notice, Scan Image Check, Mode Memory, Recall, Negative/ Positive Inversion, Image Repeat, Mirror Image, Sharpness, Tab Paper Creation, Form Composition, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date, Job Block Combination, Store in User Inbox, Cascade Copy |
PRINT SPECIFICATIONS | |
PROCESSOR | Canon Dual Custom Processor (Shared) |
Maximum: 2GB RAM |
Maximum: 1TB |
ENGINE RESOLUTION | 1200 x 1200 dpi |
PDL SUPPORT | Standard: UFR II
Optional: PCL 5e/6, Adobe PS 3 |
PRINT DRIVERS SUPPORTED OS | UFR II, PCL 5e/6, Adobe PS 3:
Windows® (XP/Windows Vista®/7), Windows Server (2003/ 2008/2008 R2/SBS 2011/2012), Windows Terminal Servers (Server 2003/Server 2008/Server 2008 R2/2012), Microsoft® Clustering Server (Server 2003/Server 2003 R2/Server 2008/ Server 2008 R2), Citrix (Presentation Server 4.5, Xen App 5.0/6.0/6.5, Xen Desktop 4.0/5.0/5.5), Macintosh® (OS X 10.5.8 or later, UFR II and PS 3 only), VMware, SAP (PS and PCL Only) |
DIRECT PRINT SUPPORT | Standard: TIFF (BW), JPEG
Optional: PDF, EPS****, XPS† |
PRINT FEATURES | Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secure Print, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Toner Reduction, Poster Printing |
SCAN SPECIFICATIONS | |
NETWORK TWAIN SCAN | Standard |
NETWORK SCAN UTILITY | Color Network ScanGear |
UNIVERSAL SEND SPECIFICATIONS | |
SENDING METHOD | E-mail, I-Fax, File Server (FTP, SMB, WebDAV), Mail Box, Super G3 Fax (Optional) |
COLOR MODE | Auto Color Select (Full Color, Grayscale), Auto Color Select (Color, BW), Full Color, Grayscale, BW |
SCAN RESOLUTION*** | 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100 dpi |
ADDRESS BOOK CAPACITY | Max. 1,800 Destinations (Incl. 200 One-Touch Buttons) |
COMMUICATION PROTOCOL | File: FTP (TCP/IP), SMB (TCP/IP), WebDAV
E-mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full) |
FILE FORMAT | Standard: TIFF (BW), JPEG, PDF, PDF (Compact), PDF
(Apply Policy), PDF (Optimize for Web), PDF/XPS
(OCR), PDF/A-1b, XPS, XPS (Compact), OOXML
(.pptx)
Optional: PDF (Trace & Smooth), PDF (Encrypted), PDF/XPS (Digital Signature), PDF (Reader Extensions) |
I-FAX DATA FORMAT | BW: TIFF (MH, MR, MMR)
Color: TIFF (Profile-C) |
UNIVERSAL SEND FEATURES | Two-sided Original, Different-size Originals, Original Type Selection, Book to Two Pages, Density Adjustment, Sharpness, Document Name, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-to, Sender's Name (TTI), E-mail Priority |
FAX SPECIFICATIONS | |
MAXIMUM NUMBER OF LINES | 4 |
MODEM SPEED | Super G3: 33.6 Kbps
G3: 14.4 Kbps |
COMPRESSION METHOD | MH, MR, MMR, JBIG |
RESOLUTION | 400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi |
SENDING / RECORDING SIZE | Statement-R to 11" x 17" |
FAX FEATURES | Job Forwarding, Different-size Originals, Adjusting Overall Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Selecting the Telephone Line (when sending fax), Delayed Send, Preview, Finished Stamp, Job Done Notice, Original Type Selection, Two-sided Original, Book to Two Pages |
STORE SPECIFICATIONS | |
MAIL BOX (NUMBER SUPPORTED) | 100 User Inboxes, 1 Memory RX Inbox,
50 Confidential Fax Inboxes
20,000 Maximum Pages Stored |
ADVANCED BOX | Available
Disk Space:
Approx. 15GB (Standard HDD)
Approx. 629GB (1TB HDD)
Communication Protocol: SMB or WebDAV Supported Client PC: Windows (Windows 2000/XP/7/Windows Vista) Concurrent Connections (Max.): SMB: 32, WebDAV: 12 (Active Sessions) Advanced Box Features: Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support |
MEMORY MEDIA | Standard: USB Memory
Optional: SD, SDHC, CompactFlash, Memory Stick, Microdrive |
SECURITY SPECIFICATIONS | |
STANDARD | Department ID Management, Single Sign-On H, Access Management System (Device and Function Level Log-in), Secure Print, Trusted Platform Module, User Access Control of Advanced Box, Mail Box Password Protection, IPv6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP, HDD Erase (Up to 3x), HDD Initialize (Up to 9x), HDD Lock, IPsec, Adobe LiveCycle® Rights Management ES2.5 Integration |
OPTIONAL | Removable HDD, HDD Encryption, HDD Mirroring, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, Secure Watermark, IEEE 2600.1 Common Criteria Certification†† |
ENVIRONMENTAL INFORMATION | |
ENERGY STAR® Qualified
EU RoHS Compliant Ecomark Blue Angel WEEE Directive |
CONSUMABLES | |
TONER | GPR-38 Toner |
TONER YIELD (ESTIMATED @ 6% COVERAGE) | Black: 56,000 Copies/Bottles |
FOOTNOTES | |
* If "Quick Startup Settings for Main Power" is set to ON, it takes 7 seconds
until the key operation on the touch-panel display is available after turning
on the main power. ** Including toner bottle and Duplex Color Image Reader. *** Standard color scan support is up to 300 dpi. Up to 600 dpi scanning requires Additional Memory Type D (512 MB). **** EPS can be printed directly only from Remote User Interface. † XPS cannot be printed directly from the Web Access software. †† Not available at time of launch. ††† Coated paper can be loaded from the Document Insertion Unit only. †††† When the Auxiliary Tray is extended. ■ Requires the Copy Card Reader Attachment Kit-A2. ■ ■ Requires PCL Printer Kit-AU1. ■■■ Requires Additional Memory Type D (512MB). ■■■■ Requires Direct Print Kit-H1 for printing PDF files. ▲ Requires Super G3 Fax Board-AL1. ▲▲ Requires Super G3 2nd Line Fax Board-AL1. ▲▲▲ Cannot be installed with Super G3 Fax Board-AL1. ◆ Requires USB Device Port-A2. ◆◆ Voice Guidance Kit-F2 and Voice Operation Kit-C2 cannot be installed together. ◆◆◆ Cannot be installed with Copy Card Reader-F1. |
Supplies
GPR-38 Toner
Color: Black
Item Code: 3766B003AA
Estimated Toner Yield: 56,000 Copies/Bottle (Estimated yield at 6% Coverage)
Accessories
Hardware Accessories
- Booklet Finisher-P1
- Staple Finisher-P1
- External 2/3-Hole Puncher-A1
- Document Insertion Unit-L1 (Requires a Finisher)
- Document Insertion/Folding Unit-H1
- Paper Deck Unit-A1
- Paper Deck Unit-D1
- Upright Control Panel-E1
- Copy Tray-J1
- Utility Tray-A2
- USB Keyboard
- Universal Keyboard Stand-A1
- Key Switch Unit-A2
- Copy Card Reader Attachment Kit-A2
- Copy Card Reader-F1
- Braille Label Kit-F1
- ADF Access Handle-A1
- Copy Control Interface Kit-A1
- Convenience Stapler-B1
System Connectivity Accessories
- PCL Printer Kit-AV1
- PCL International Font Set-A1
- PS Printer Kit-AV1
- Direct Printer Kit (for PDF/XPS)-H1
- Encrypted Secure Print-D1
- Barcode Printing Kit-D1
- Web Access Software-H1
- Universal Send Advanced Feature Set-F1
- Universal Send Security Feature Set-D1
- Universal Send Digital User Signature Kit-C1
- Super G3 FAX Board-AL1
- Super G3 2nd Line Fax Board-AL1
- Super G3 3rd/4th Line Fax Board-AL1
- Remote Fax Kit-A1
- Secure Watermark-B1
- Document Scan Lock Kit-B1
- HDD Data Encryption and Mirroring Kit -C5
- Removable HDD Kit-AG1
- Additional Memory Type D (512 MB)
- 2.5 inch/160GB HDD-J1
- 2.5 inch/1TB HDD-K1
- iR-ADV Security Kit-G1 for IEEE 2600.1 Common Criteria Certification (Pending)
- USB Device Port-A2
- Multimedia Reader/Writer-A2
- Voice Guidance Kit-F2
- Voice Operation Kit-C2
- Remote Operator's Software Kit-B1
- Silex Wireless Bridge SX-2500CG
- imagePASS-U2
- SeeQuence Suite (for imagePASS-U2)
- SeeQuence Impose (for imagePASS-U2)
- SeeQuence Compose (for imagePASS-U2)
- Removable Hard Disk Drive Kit-B4 (for imagePASS-U2)
- Fiery ImageViewer (for imagePASS-U2)
- Integrated Interface & Stand-B1 (for imagePASS-U2)
Click here to learn about Software Solutions for imageRUNNER ADVANCE
Note: For additional details and descriptions for each accessory, please access the product configurator.
Brochures
Videos
Conducting Business
RUN Use Cases
