Web Content Viewer
Actions
imageRUNNER ADVANCE 6555i III
Multifunction Copiers
imageRUNNER ADVANCE Configurator. Build your model, and customize configurations based on specific needs.
Solutions to help increase office efficiencies and productivity
Advanced Solutions for your industry
Introducing the third generation imageRUNNER ADVANCE third edition.
imageRUNNER ADVANCE III Third Edition
Features
  • 10.1" intuitive touchscreen with smartphone-like usability.
  • A unique, customized experience tailored to individual preferences using My ADVANCE.
  • Supports mobile solutions and integration with many popular cloud services like Google Drive.
  • Scan and convert documents to searchable digital files in a variety of file formats.
  • Integration with Canon and various third-party software with embedded application platform.
  • Advanced standard security feature set to help safeguard sensitive information and assist in regulatory compliance.
  • Integrates with existing, third-party Security Information and Event Management (SIEM) systems to help provide real-time comprehensive insights into potential threats to the network and printers.
  • Technology to verify that the device boot process, firmware, and applications initialize without alterations or tampering.
  • Security policy settings can be controlled with a dedicated password, configured from a central location, and exported to other supported devices.
  • Control access to the device and specific features, using a host of flexible authentication methods - PIN code, user name/password, or card access.
  • Canon's signature reliability and engine technologies help keep productivity high and minimize the impact on support resources.
  • Outstanding imaging technologies and toner allow for crisp text and consistent images in rich black-and-white tones.
  • Designed to achieve maximum uptime with status notifications that help keep supplies replenished and intuitive maintenance videos for consumables replacement.
  • imageRUNNER ADVANCE models have received many awards and recognition from leading industry analysts, often referencing strong reliability.
  • Designed for quick, easy deployment.
  • Remote diagnostics and parts life management for proactive maintenance and rapid fixes.
  • Easy and intuitive to monitor device status and consumable levels, turn off devices remotely, observe meter readings, manage settings, and implement security policies.
  • Common firmware and regular updates with Unified Firmware Platform (UFP) for continuous improvements and consistency across a fleet.
  • Track and assess print, copy, scan, and fax usage and allocate costs to departments or projects.
  • Apply print policies and restrict usage by user to help reduce unnecessary printing and contribute to cost efficiency.
  • Standard cloud-based solution provides a centralized dashboard with up-to-the-minute insights into printer activity.
  • Upgrade to uniFLOW server or cloud-based solutions for full accounting and reporting for compatible Canon and third-party devices, pull printing, job routing, and powerful scan workflows.
  • A combination of fusing technologies and low-melting-point toner minimizes power requirements and helps achieve low energy consumption.
  • Encourage environmentally conscious work practices by enabling multiple settings that can help save paper and energy.
  • ENERGY STAR® certified and rated EPEAT® Gold.
imageRUNNER ADVANCE 6500 III Series Spec Sheet
MAIN UNIT
TYPE Monochrome Laser Multifunctional
CORE FUNCTIONS Standard: Print, Copy, Scan, Send, Store
Optional: Fax
PROCESSOR Canon Dual Custom Processor (Shared)
CONTROL PANEL Standard: 10.1" TFT LCD WSVGA Color Flat- panel
Optional 10.4" TFT LCD SVGA Color Upright-panel
MEMORY 3.0 GB RAM
HARD DISK DRIVE Standard: 250 GB
Maximum: 1 TB
MIRRORING HARD DISK DRIVE Optional (250 GB, 1 TB), Method: Raid1
INTERFACE CONNECTION
NETWORK Network Standard: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n)
Optional: NFC, Bluetooth Low Energy
OTHERS Standard: USB 2.0 x2 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device)
Optional: Serial Interface, Copy Control Interface
PAPER CAPACITY (LTR, 20LB BOND) Standard: 4,200 Sheets
Maximum: 7,700 Sheets
PAPER SOURCES (LTR, 20LB BOND) Standard: Dual 1,500-sheet Paper Drawers, Dual 550-sheet Paper Cassettes, 100-sheet Stack Bypass
Optional: 3,500-sheet Paper Deck (POD DECK LITE-C1 or PAPER DECK UNIT-E1)
PAPER OUTPUT CAPACITY (LTR, 20LB BOND) With Copy Tray: 250 Sheets
With External Finishers: 3,500 Sheets
FINISHING CAPABILITIES With External Finishers: Collate, Group, Offset, Staple, Staple On Demand, Staple-free Staple, Booklet, Hole Punch, Document Insertion, C and Z Folding
SUPPORTED MEDIA TYPES Paper Drawers (1/2): Thin, Plain, Recycled, Color, Heavy, Pre-punched, Letterhead, Bond
Paper Cassettes (3/4): Thin, Plain, Recycled, Color, Heavy, Pre-punched, Letterhead, Bond, Tab.
Stack Bypass: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Bond, Transparency, Labels, Letterhead, Tab, Tracing1
POD DECK LITE-C1: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Letterhead, Bond, Transparency, Labels, Tab
PAPER DECK UNIT-E1: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Letterhead, Bond
SUPPORTED MEDIA SIZES Paper Drawers (1/2): Letter
Paper Cassettes (3/4): 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 19-1/4")
Stack Bypass: 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (4" x 5-7/8" to 11-3/4" x 19-1/4"), Free Size (4" x 7-1/8" to 11-3/4" x 19-1/4")
POD DECK LITE-C1: 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 19-1/4")
PAPER DECK UNIT-E1: Letter
SUPPORTED MEDIA WEIGHTS Paper Decks/Cassettes: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
Stack Bypass: 14 lb. Bond to 140 lb. Index (52 to 256 g/m2)
Duplexing: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
WARM-UP TIME From Power On: Approx. 30 Seconds2
From Sleep Mode: Approx. 30 Seconds3
Quick Startup Mode: Approx. 4 Seconds4
DIMENSIONS (W X D X H) 26-3/8" x 30-5/8" x 48" (670 mm x 779 mm x 1220 mm)
INSTALLATION SPACE (WXD) Basic: Stack Bypass Extended+ Cassette Drawers open + Copy Tray: 60-3/8" x 53-1/4" (1533 mm x 1353 mm)
Fully Configured: Booklet Finisher + Paper Deck + Insertion and Folding Unit + Puncher Unit + Cassette Drawers open: 95-7/8" x 53-1/4" (2436 mm x 1353 mm)
WEIGHT Approx. 515.9 lb. (234 kg)5
PRINT SPECIFICATIONS
PRINT / COPY SPEED (BW AND COLOR) Up to 55 ppm (Letter)
Up to 43 ppm (Letter-R)
Up to 39 ppm (Legal)
Up to 32 ppm (11" x 17")
PRINT RESOLUTION 1200 x 1200, 600 x 600
STANDARD PAGE DESCRIPTION LANGUAGES UFR III, PCL6, Adobe PS 3
DIRECT PRINT Available from USB, Advanced Box, Remote UI, and Web Access6
SUPPORTED FILE TYPES PDF, TIFF, JPEG, EPS,7 XPS
PRINTING FROM MOBILE DEVICES AND CLOUD-BASED SERVICES A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet-connected devices and cloud-based services depending on your requirements.
FONTS PCL fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese)8, Barcode Fonts9
PS fonts: 136 Roman
OPERATING SYSTEM10 UFRIII: Server 2008/Windows 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.9 or later)
PCL: Server 2008/Windows 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016
PS: Server 2008/Windows 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.9 or later)
PPD: MAC OS X (10.3.9 or later), Windows 7 / 8.1/ 10
PRINT FEATURES Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Watermark, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Front/Back Covers, Toner Reduction, Poster Printing
COPY SPECIFICATIONS
FIRST-COPY-OUT-TIME As fast as 3.3 seconds
COPY RESOLUTION Reading: 600 x 600
Printing: 1200 x 1200
MULTIPLE COPIES Up to 9,999 Copies
COPY EXPOSURE Automatic or Manual (9 Levels)
MAGNIFICATION 25%-400% (1% Increments)
PRESET REDUCTIONS 25%, 50%, 64%, 73%, 78%
PRESET ENLARGEMENTS 121%, 129%, 200%, 400%
BASIC COPY FEATURES Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing,
Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel
SPECIAL COPY FEATURES Book to Two Pages, Two-sided Original, Finishing, Booklet, Job Build, N on 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Print on Tab, Store in Mail Box, Superimpose Image, Cascade Copy, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original, Skip Blank Originals
SCAN SPECIFICATIONS
TYPE Color Platen and Single-pass Duplexing Automatic
Document Feeder
DOCUMENT FEEDER PAPER CAPACITY 300 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS BW Original: 13 lb. Bond to 80 lb. Cover (50 to 220 g/m2)
CL Original: 17 lb. Bond to 80 lb. Cover (64 to 220 g/m2)
PLATEN ACCEPTABLE ORIGINALS Sheet, Book, 3-Dimensional Objects [Height: up to 2" (50 mm), Weight: up to 4.4 lb. (2 kg)] Max. Platen
Scanning Size: 11-3/4" x 17" (297 mm x 431.8 mm)
PULL SCAN Color Network ScanGear2 for both Twain and WIA Supported OS: Windows 7/8.1/10 Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/Server 2016
SCAN RESOLUTION 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200,
200 x 100, 150 x 150, 100 x 100
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES A range of solutions is available to provide scanning to mobile devices and cloud-based services depending on your requirements.
SCAN SPEED (LETTER) Single-sided Scanning
BW: 120 ipm (300 dpi)/120 ipm (600 dpi)
Color: 120 ipm (300 dpi)
Double-sided Scanning
BW: 240 ipm (300 dpi)/150 ipm (600 dpi)
Color: 220 ipm (300 dpi)
SEND SPECIFICATIONS
DESTINATION Email/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional)
COLOR MODE Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White), Full color, Grayscale, and Black-and-White
ADDRESS BOOK LDAP (2,000)/Local (1,600)/Speed dial (200)
SEND RESOLUTION 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x 100, 150 x 150, 100 x 100
COMMUICATION PROTOCOL File: FTP, SMB v3.0, WebDAV
Email: SMTP, POP3, I-Fax (Simple, Full)
FILE FORMAT Standard: TIFF, JPEG, PDF (Compact, Searchable, Apply policy, Optimize for Web, PDF A/1-b, Encrypted, Device Signature), XPS (Compact, Searchable, Device Signature), Office Open XML (PowerPoint, Word)
Optional: PDF (Trace & Smooth, User Signature), XPS (User Signature)
UNIVERSAL SEND FEATURES Original Type Selection,Two-sided Original, Book to Two Pages, Different-size Originals, Density Adjustment, Sharpness, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Job Done Notice, File Name, Subject/Message, Reply-to, Email Priority, TX Report, Original Content Orientation, Skip Blank Originals, Multi Sheet Feed Detection
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES 4
MODEM SPEED Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE Statement-R to 11" x 17"
FAX MEMORY Up to 30,000 Pages
SPEED DIALS Max. 200
GROUP DIALS / DESTINATIONS Max. 199 Dials
SEQUENTIAL BROADCAST Max. 256 Addresses
MEMORY BACKUP Yes
FAX FEATURES Original Type Selection, Two-sided Original, Book to Two Pages, Different-size Originals, Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Sender's Name (TTI), Selecting the Telephone Line, Direct Send, Delayed Send, Preview, Job Done Notice, TX Report, Multi Sheet Feed Detection
STORE SPECIFICATIONS
MAIL BOX SIMPLE(NUMBER SUPPORTED) 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored
ADVANCED BOX Communication Protocol: SMB or WebDAV Supported Client PC: Windows (Windows 7/8.1/10) Concurrent Connections (Max.): SMB: 64 WebDAV: 3 (Active Sessions)
ADVANCED BOX AVAILABLE DISC SPACE Approx. 16 GB (Standard HDD) Approx. 480 GB (With Optional 1 TB HDD)
ADVANCED BOX FEATURES Authentication for Advanced Box Log-in, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
MEMORY MEDIA Standard: USB
SECURITY SPECIFICATIONS
AUTHENTICATION Standard: Universal Login Manager, uniFLOW Online Express,11 User Authentication, Department ID Authentication, (Device and Function Level Log-in), Access Management System
Optional: uniFLOW
DATA Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption(FIPS140-2 Validated), Verify System at Startup
Optional: Hard Disk Drive Mirroring, Hard Disk Drive removal, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW)
NETWORK Standard: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP, S/MIME, SIEM Integration
DOCUMENT Standard: Secure Watermark, Secure Print, Adobe LiveCycle Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Device Signature Optional: User Signature, Document Scan Lock
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT Temperature: 50 to 86 ºF Humidity: 20 to 80 % RH (Relative Humidity)
POWER REQUIREMENTS 120-127 V AC, 60 Hz, 16 A
PLUG (MAIN UNIT) NEMA 5-20P
POWER CONSUMPTION Maximum: Approx. 2,032 W
Standby: Approx. 237.3 W12
Sleep mode: 0.9 W13
Typical Electricity Consumption (TEC) Rating: 5.2 kWh
STANDARDS ENERGY STAR® Certified
Rated EPEAT® Gold14
CONSUMABLES
TONER GPR-38 Black Toner
TONER YIELD (ESTIMATED @ 6% COVERAGE) 56,000 Images
FOOTNOTES
  1. Some types of tracing paper cannot be used.
  2. Time from device power-on, until copy ready (not print reservation).
  3. Time from exiting Sleep mode to when printing is operational.
  4. Time from device power-on to when key operations can be performed on the touch panel.
  5. Includes Main Unit, ADF, and Consumables.
  6. PDF print from Websites is supported.
  7. EPS can be printed directly only from the Remote User Interface.
  8. Requires the optional PCL International Font Set-A1.
  9. Requires the optional Barcode Printer Kit-D1.
  10. Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
  11. No charge for this solution; however activation is required.
  12. Standby Reference Value: measured one unit.
  13. 0.9 W sleep mode not available in all circumstances due to certain settings.
  14. For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
This is to make Misc appear on the page when needed.
Supplies
GPR-38 Toner
Color: Black
Item Code: 3766B003AA
Estimated Toner Yield:  56,000 Copies/Bottle (Estimated @ 6% Coverage)
Accessories
Hardware Accessories
  • Paper Deck Unit-E1
  • POD Deck Lite-C1
  • Copy Tray-R2
  • Staple Finisher-V2
  • Booklet Finisher-V2
  • 2/3 Hole Puncher Unit-A1
  • Document Insertion Unit-P1
  • Document Insertion / Folding Unit-J1
  • Tab Feeding Attachment Kit-B1
  • Utility Tray-B1
  • Upright Control Panel-H1
  • Printer Cover-H1
  • USB Key Board (Cherry)
  • Copy Card Reader Attachment-A4
  • Copy Card Reader-F1
  • Canon Card Set-A1 (1-30)
  • Canon Card Set-A2 (31-100)
  • Canon Card Set-A3 (101-200)
  • Canon Card Set-A4 (201-300)
  • Canon Card Set-A5 (301-500)
  • Canon Card Set-A6 (501-1000)
  • Braille Label Kit-F1
  • ADF Access Handle-A1
  • Copy Control Interface Kit-A1
  • Convenience Stapler-A1 (White)
  • Universal Keyboard Stand-A1
  • Card Reader Assembly for Universal Keyboard Stand
System Connectivity Accessories
  • imagePASS-Y3
  • PCL International Font Set-A1
  • Barcode Printing Kit-D1
  • MEAP Web Connection Kit V5.3 SP1 for Gen3
  • Universal Send Trace & Smooth PDF Kit-A1
  • Universal Send Digital User Signature Kit-C1
  • Super G3 FAX Board-AS2
  • Super G3 2nd Line Fax Board-AS2
  • Super G3 3rd/4th Line Fax Board-AS2
  • IP FAX Expansion Kit-B1
  • Remote FAX Kit-A1
  • Document Scan Lock Kit-B2
  • HDD Mirroring Kit-J1
  • Removable HDD Kit-AL1
  • HDD Data Erase Scheduler V3.1.1
  • HDD Data Erase Scheduler V3.1.1 NFR
  • 2.5inch/250GB HDD-N1
  • 2.5inch/1TB HDD-P1
  • Voice Guidance Kit-G1
  • Voice Operation Kit-D1
  • iR-ADV Security Kit-AA1 for IEEE 2600 Common Criteria Certification
  • Connection Kit-A1 for Bluetooth LE
  • NFC Kit-A1 (for Upright Control Panel)
  • NFC Kit-C1 (for Flat Control Panel)
Click here to learn about Software Solutions for imageRUNNER ADVANCE
Note: For additional details and descriptions for each accessory, please access the product configurator.
Brochures
Loading...
Workflow Solutions
Mobile Solutions from Canon provide users with convenience and control when printing from various locations. The Canon imageRUNNER ADVANCE 6500 III Series is equipped to support the needs of mobile users based on varying company policies, types, common file formats, workflows, security requirements and more. On the road, in the home, or at the office, mobile business users can experience ease in printing and scanning with Canon’s mobile solution offering. Canon’s PRINT Business app lets users choose the send destination, enter the send job filename, or release a print job directly from the app on a compatible smartphone.
Document Capture and Distribution Solutions from Canon can help streamline workflows by digitizing data, sharing information, and distributing to a variety of destinations. The Canon imageRUNNER ADVANCE 6500 III Series offers secure and customizable user authentication, data tracking, and distribution options to help meet your organization's requirements. This series is designed with Document Capture and Distribution in mind.
The Output Management Solutions available for the Canon imageRUNNER ADVANCE 6500 III Series provide various levels of control and tracking to help reduce wasteful printing and provide you with the tools to help control access to confidential information. With easy functionality and numerous workflow settings, the imageRUNNER ADVANCE 6500 III Series is designed for high productivity, time efficiency, and cost savings. This enterprise-level, multifunction printing and copying solution is scalable to align with various customer environments as business needs evolve and change.
Information Management and Workflow Solutions from Canon offer powerful, end-to-end support for quickly retrieving information, giving users the capability to digitally store, organize, and manage content. With the Canon imageRUNNER ADVANCE 6500 III Series, customized workflows can be created to help users streamline daily document related activities and optimize business processes. The imageRUNNER ADVANCE 6500 III Series can be a key business solution for information management and easier workflow.
Device Management Solutions from Canon can help solve common workplace challenges and help improve efficiencies within your organization. The enterprise-class Canon imageRUNNER ADVANCE 6500 III Series offers solid, fleet-based management tools to establish an integrated solution that can help reduce costs and minimize IT resources. These models are designed to help companies realize increased productivity and focus on day-to-day IT activities.
Videos
Third Generation imageRUNNER ADVANCE Third Edition
imageRUNNER ADVANCE Control Video
Control over your MFPs, network communications and documents.
imageRUNNER ADVANCE Third Edition Home Screen Video
Simplify, Control, Evolve
Designed for Fleet Environments
Product Design
imageRUNNER ADVANCE 8500/6500 Series
Paper Handling and Finishing Option
Platform Overview
Mobile Device Integration
Third Generation imageRUNNER ADVANCE and the Canon PRINT Business app
Authentication with ULM
Third Generation imageRUNNER ADVANCE Feature Highlights
BLI A3 'Line of the Year' 2017
Canon Wins for Two Years in a Row
 Return to Top
