Web Content Viewer
Actions
imageRUNNER ADVANCE 8205
Multifunction Copiers
imageRUNNER ADVANCE Configurator. Build your model, and customize configurations based on specific needs.
Solutions to help increase office efficiencies and productivity
Advanced Solutions for your industry
From every point of view, it’s simply advanced
Features
With blazing speed, intuitive operation, and unparalleled reliability, the Canon imageRUNNER ADVANCE 8200 Series delivers the outstanding output that high-volume offices, in-plant reprographic facilities, and print-for-pay businesses require.
  • Continuous run
  • Long-running reliability
  • Robust paper handling
  • Professional control
  • Productive scanning flow
  • 4 Rich detail
  • 3 Consistent quality
  • 2 pO Toner
  • 1 Precise registration
Today's fast-paced business world demands rapid turnaround with exceptional quality. The imageRUNNER ADVANCE 8200 Series makes this easy with time-saving connectivity solutions, streamlined production processes, and expanded versatility options.
It's all about a brighter, greener future. The imageRUNNER ADVANCE 8200 Series, registered in EPEAT®, incorporates innovative, eco-conscious solutions that keep your business operating efficiently while helping reduce your environmental footprint.
imageRUNNER ADVANCE 8200 Series Spec Sheet
MAIN UNIT
SYSTEM TYPE Monochrome Digital Multifunction Imaging System
FUNCTIONS Standard: Copy, Print (UFR II), Scan, Send, Store
Optional: Print (PCL 5e/6, Adobe® PostScript® 3<sup>™</sup>), Fax (Up to 4 Lines)
OPERATION PANEL 10.4" SVGA Full-Color, TFT Upright Screen
MEMORY Standard: 1.5GB RAM
Maximum: 2GB RAM
HARD DISK DRIVE Standard: 160GB
Maximum: 1TB
MIRRORING HARD DISK DRIVE Optional (160GB, 1TB), Method: RAID1
NETWORK INTERFACE CONNECTION Standard: 10Base-T/100Base-TX/1000Base-T
Optional: Wireless LAN (IEEE 802.1x via third-party adapter)
OTHER INTERFACE Standard: USB 2.0 (Host) x2, USB 2.0 (Device)
Optional: Device Port [USB 2.0 (Host) x2], Serial Interface, Copy Control Interface
COPY / PRINT SPEED (BW) Up to 105 ppm
Legal/11" x 17": Up to 64/53 ppm
FIRST-COPY-OUT-TIME (LETTER) 2.7 Seconds
PAPER SOURCES (20 lb. Bond) Standard: Dual 1,500-sheet Paper Drawers, Dual 550-sheet Paper Cassettes, 100-sheet Stack Bypass
Optional: 3,500-sheet Paper Deck Unit or 3,500-sheet POD Deck Lite
Maximum: 7,700 Sheets (with Optional Paper Deck Unit)
OUTPUT PAPER CAPACITY (20 lb. Bond) Maximum: 4,250 Sheets (with Staple Finisher-N1 or Booklet Finisher-N1) 5,000 (with Booklet Finisher-Q1 PRO)
ACCEPTABLE PAPER SIZES Drawers: Letter
Cassette: 13" x 19", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 13" x 19-1/4")
Bypass (with Staple Finisher-Q1 PRO/Booklet Finisher-Q1 PRO attached): 13" x 19", 12-5/8" x 17-11/16", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (4" x 7-1/8" to 13" x 19-1/4")
Bypass (with Staple Finisher-N1/Booklet Finisher-N1 attached): 13" x 19", 12-5/8" x 17-11/16", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (4" x 5-7/8" to 13" x 19-1/4")
ACCEPTABLE PAPER WEIGHTS Drawers/ Cassettes: 14 lb. Bond to 80 lb. Cover (52 to 220g/m<sup>2</sup> )
Bypass: 14 lb. Bond to 140 lb. Index (52 to 256g/m<sup>2</sup> )
DUPLEXING Paper Size: Standard Automatic Trayless Duplexing (Up to 13" x 19")
Paper Weight: 14 lb. Bond to 80 lb. Cover (52 to 220g/m<sup>2</sup> )
MEDIA SUPPORT Thin [14 lb. Bond to 16 lb. Bond (52 to 63g/m<sup>2</sup> )], Plain [17 lb. Bond to 24 lb. Bond (64 to 90g/m<sup>2</sup> )], Heavy 1 [25 lb. Bond to 66 lb. Cover (91 to 180g/m<sup>2</sup> )], Heavy 2 [67 lb. Cover to 80 lb. Cover (181 to 220g/m<sup>2</sup> )], Heavy 3 [82 lb. Cover to 140 lb. Index (221 to 256g/m<sup>2</sup> )], Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Bond, Letterhead, Tab
WARM-UP TIME From Power On: 60 Seconds or Less
From Sleep: 60 Seconds or Less
Quick Startup Mode: 7 Seconds**
POWER REQUIREMENTS / PLUG 120-127V AC, 60Hz, 16A/NEMA 5-20P
POWER CONSUMPTION Maximum: 1.92kW
Sleep Mode: 0.9W or Less
DIMENSIONS (W X D X H) With the Upright Control Panel (To the right edge of the Upright Control Panel in the right-most position): 49-1/4" x 53-3/8" x 30-3/8"
Without the Upright Control Panel: 48" x 25-3/8" x 30-3/8"
INSTALLATION SPACE (WXD) With the Upright Control Panel: 100-1/4" x 31-7/8"
Without the Upright Control Panel: 79" x 31-7/8"
WEIGHT Approx. 535 lb. (242.5kg)***
Approx. 526 lb. (238.5kg)****
IMAGE READER UNIT
SCAN RESOLUTION Up to 600 x 600 dpi
ACCEPTABLE ORIGINALS (GLASS) Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2kg)]
MAXIMUM ORIGINAL SIZE Up to 11" x 17"
DOCUMENT FEEDER
SCAN METHOD Single-Pass Duplexing Automatic Document Feeder
ACCEPTABLE ORIGINALS Paper Sizes: 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R
Paper Weights: 1-sided scanning: 13 lb. Bond to 80 lb. Cover (50 to 220g/m<sup>2</sup> ) 2-sided scanning (Black-and-white original): 13 lb. Bond to 80 lb. Cover (50 to 220g/m<sup>2</sup> ) 2-sided scanning (Color original): 17 lb. Bond to 80 lb. Cover (64 to 220g/m<sup>2</sup> )
SCAN SPEED (BW / COLOR; LETTER) Simplex: Up to 120/85 ipm (300 dpi) / Up to 120/51 ipm (600 dpi)
Duplex: Up to 200/100 ipm (300 dpi) / Up to 120/51 ipm (600 dpi)
PAPER CAPACITY (20 lb. Bond) 300 Sheets
COPY SPECIFICATIONS
FIRST-COPY-OUT TIME (Letter) 2.7 Seconds
MULTIPLE COPIES 1 to 9,999
COPY EXPOSURE Automatic or Manual (9 Levels)
MAGNIFICATION 25% - 400% (1% Increments)
PRESET REDUCTIONS 25%, 50%, 64%, 73%, 78%
PRESET ENLARGEMENTS 121%, 129%, 200%, 400%
BASIC COPY FEATURES Preset R/E Ratios by Area, Finishing, Two-sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying
SPECIAL COPY FEATURES Two-page Separation, Cover/Sheet Insertion, Booklet, Transparency Interleaving, Shift, Margin, Frame Erase, Image Combination, Different-size Original, Job Build, Job Done Notice, Scan Image Check, Mode Memory, Recall, Negative/ Positive Inversion, Image Repeat, Mirror Image, Sharpness, Tab Paper Creation, Form Composition, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date, Job Block Combination, Store in User Inbox, Cascade Copy
PRINT SPECIFICATIONS
PROCESSOR Canon Dual Custom Processor (Shared)
Maximum: 2GB RAM
Maximum: 1TB
ENGINE RESOLUTION 1200 x 1200 dpi
PDL SUPPORT Standard: UFR II
Optional: PCL 5e/6, Adobe PS 3
PRINT DRIVERS SUPPORTED OS UFR II, PCL 5e/6, Adobe PS 3: Windows® (XP/Windows Vista®/7/8), Windows Server (2003/ 2008/2008 R2/SBS 2011/2012), Windows Terminal Servers (Server 2003/Server 2008/Server 2008 R2/2012), Microsoft® Clustering Server (Server 2003/Server 2003 R2/Server 2008/ Server 2008 R2), Citrix (Presentation Server 4.5, Xen App 5.0/6.0/6.5, Xen Desktop 4.0/5.0/5.5/5.6), Macintosh® (OS X 10.5.8 or later, UFR II and PS 3 only), VMware, SAP (PS and PCL Only)
DIRECT PRINT SUPPORT Standard: TIFF, JPEG
Optional: PDF, EPS, XPS
PRINT FEATURES Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secure Print, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Toner Reduction, Poster Printing
SCAN SPECIFICATIONS
NETWORK TWAIN SCAN Standard
NETWORK SCAN UTILITY Color Network ScanGear
UNIVERSAL SEND SPECIFICATIONS
SENDING METHOD E-mail, I-Fax, File Server (FTP, SMB, WebDAV), Mail Box, Super G3 Fax (Optional)
COLOR MODE Auto Color Select (Full Color, Grayscale), Auto Color Select (Color, BW), Full Color, Grayscale, BW
SCAN RESOLUTION 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100 dpi
ADDRESS BOOK CAPACITY Max. 1,800 Destinations (Incl. 200 One-touch Buttons)
COMMUICATION PROTOCOL File: FTP (TCP/IP), SMB (TCP/IP), WebDAV
E-mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full)
FILE FORMAT Standard: TIFF (BW), JPEG, PDF, PDF (Compact), PDF (Apply Policy), PDF (Optimize for Web), PDF/XPS (OCR), PDF/A-1b, XPS, XPS (Compact), OOXML (.pptx)
Optional: PDF (Trace & Smooth), PDF (Encrypted), PDF/XPS (Digital Signature), PDF (Reader Extensions)
I-FAX DATA FORMAT BW: TIFF (MH, MR, MMR)
Color: TIFF (Profile-C)
UNIVERSAL SEND FEATURES Two-sided Original, Different-size Originals, Original Type Selection, Book to Two Pages, Density Adjustment, Sharpness, Document Name, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-to, Sender's Name (TTI), E-mail Priority
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES 4
MODEM SPEED Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
SENDING / RECORDING SIZE Statement-R to 11" x 17"
FAX FEATURES Job Forwarding, Different-size Originals, Adjusting Overall Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Selecting the Telephone Line (when sending fax), Delayed Send, Preview, Finished Stamp, Job Done Notice, Original Type Selection, Two-sided Original, Book to Two Pages
STORE SPECIFICATIONS
MAIL BOX (NUMBER SUPPORTED) 100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes
20,000 Maximum Pages Stored
ADVANCED BOX Available Disk Space: Approx. 15GB (Standard HDD) Approx. 629GB (1TB HDD)
Communication Protocol: SMB or WebDAV
Supported Client PC: Windows (Windows 2000/XP/7/8/Windows Vista)
Concurrent Connections (Max.): SMB: 32, WebDAV: 12 (Active Sessions)
Advanced Box Features: Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
MEMORY MEDIA Standard: USB Memory
Optional: SD, SDHC, CompactFlash, Memory Stick, Microdrive
SECURITY SPECIFICATIONS
STANDARD Department ID Management, Single Sign-On H, Access Management System (Device and Function Level Log-in), Secure Print, Trusted Platform Module, User Access Control of Advanced Box, Mail Box Password Protection, IPV6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP, HDD Erase (Up to 3x), HDD Initialize (Up to 9x), HDD Lock, IPsec , Adobe LiveCycle® Rights Management ES2.5 Integration
OPTIONAL Removable HDD, HDD Encryption, HDD Mirroring, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, Secure Watermark, IEEE 2600.1 Common Criteria Certification
ENVIRONMENTAL INFORMATION
ENERGY STAR® Qualified
EU RoHS Compliant
Ecomark
Blue Angel
WEEE Directive
CONSUMABLES
TONER GPR-37 Toner
TONER YIELD (ESTIMATED @ 6% COVERAGE) Black: 70,000 Copies / Bottle
FOOTNOTES
* The Upright Control Panel is standard on 8205/8295 models, and optional on the 8285 model.
** If "Quick Startup Settings for Main Power" is set to ON, it takes 7 seconds until the key operation on the touch-panel display is available after turning on the main power.
*** Including the toner bottle, Duplex Color Image Reader, and the Upright Control Panel.
**** Including the toner bottle and Duplex Color Image Reader Unit.
Standard color scan support is up to 300 dpi. Up to 600 dpi scanning requires Additional Memory Type D (512 MB).
EPS can be printed directly only from Remote User Interface.
XPS cannot be printed directly from the Web Access software.
Available Q4 2013.
▲ Stacking capacity will vary depending on paper type.
▲▲ Coated paper can be loaded from the Document Insertion Unit only.
▲▲▲ Option for Staple Finisher-Q1 PRO or Booklet F
inisher-Q1 PRO.
▲▲▲▲ Option for Booklet Finisher-Q1 PRO.
▼ When the Auxiliary Tray is extended.
▼▼ Installs internally with Staple Finisher-N1 or Booklet Finisher-N1.
▼▼▼ Installs internally with Booklet Finisher-N1.
▼▼▼▼ Requires Staple Finisher-N1, Booklet Finisher-N1, Staple Finisher-Q1 PRO, or Booklet Finisher-Q1 PRO.
● Requires the Copy Card Reader Attachment Kit-A2.
●● Requires PCL Printer Kit-AU1.
●●● Requires Additional Memory Type D (512MB).
■ Requires Direct Print Kit-H1 for printing PDF files.
■ ■ Requires Super G3 Fax Board-AL1.
◆ Requires Super G3 2nd Line Fax Board-AL1.
◆◆ Cannot be installed with Super G3 Fax Board-AL1.
◆◆◆ Requires USB Device Port-A2.
 Voice Guidance Kit-F2 and Voice Operation Kit-C2 cannot be installed together.
 Cannot be installed with Copy Card Reader-F1.
This is to make Misc appear on the page when needed.
Supplies
GPR-37 Toner
Color: Black
Item Code: 3764B003AA
Estimated Toner Yield: 70,000 Copies/Bottle (Estimated @ 6% Coverage)
Accessories
Hardware Accessories
  • Booklet Finisher-Q1 PRO
  • Puncher Unit-BS1 (Option for Booklet Finisher-Q1 PRO)
  • Booklet Trimmer-D1 (Option for Booklet Finisher-Q1 PRO)
  • Booklet Finisher-N1
  • Staple Finisher-N1
  • Puncher Unit-BF1 (Option for Booklet Finisher-N1 or Staple Finisher-N1)
  • Inner Booklet Trimmer-A1 (Option for Booklet Finisher-N1)
  • Document Insertion Unit-K1 (Requires a Finisher)
  • Professional Puncher-C1/Professional Puncher Integration Unit-B1 (Requires a Finisher)
  • Paper Folding Unit-H1 (Require a Finisher)
  • Paper Deck Unit-C1
  • POD Deck Lite-A1
  • Utility Tray-A2
  • USB Keyboard
  • Universal Keyboard Stand-A1
  • Key Switch Unit-A2
  • Copy Card Reader Attachment Kit-A2
  • Copy Card Reader-F1
  • Braille Label Kit-F1
  • ADF Access Handle-A1
  • Copy Control Interface Kit-A1
  • Convenience Stapler-B1
System Connectivity Accessories
  • PCL Printer Kit-AU1
  • PCL International Font Set-A1
  • PS Printer Kit-AU1
  • Direct Printer Kit (for PDF/XPS)-H1
  • Encrypted Secure Print-D1
  • Barcode Printing Kit-D1
  • Web Access Software-H1
  • Universal Send Advanced Feature Set-F1
  • Universal Send Security Feature Set-D1
  • Universal Send Digital User Signature Kit-C1
  • Super G3 FAX Board-AL1
  • Super G3 2nd Line Fax Board-AL1
  • Super G3 3rd/4th Line Fax Board-AL1
  • Remote Fax Kit-A1
  • Secure Watermark-B1
  • Document Scan Lock Kit-B1
  • HDD Data Encryption and Mirroring Kit -C5
  • Removable HDD Kit-AG1
  • Additional Memory Type D (512 MB)
  • 2.5 inch/160GB HDD-J1
  • 2.5 inch/1TB HDD-K1
  • iR-ADV Security Kit-G1 for IEEE 2600.1 Common Criteria Certification (Pending)
  • USB Device Port-A2
  • Multimedia Reader/Writer-A2
  • Voice Guidance Kit-F2
  • Voice Operation Kit-C2
  • Remote Operator's Software Kit-B1
  • Silex Wireless Bridge SX-2500CG
  • imagePASS-U2
  • SeeQuence Suite (for imagePASS-U2)
  • SeeQuence Impose (for imagePASS-U2)
  • SeeQuence Compose (for imagePASS-U2)
  • Removable Hard Disk Drive Kit-B4 (for imagePASS-U2)
  • Fiery ImageViewer (for imagePASS-U2)
  • Integrated Interface & Stand-B1 (for imagePASS-U2)
Click here to learn about Software Solutions for imageRUNNER ADVANCE
Note: For additional details and descriptions for each accessory, please access the product configurator.
Brochures
Loading...
Videos
Conducting Business
RUN Use Cases
 Return to Top
