Web Content Viewer
Actions
imageRUNNER ADVANCE C250iF
Multifunction Copiers
imageRUNNER ADVANCE Configurator. Build your model, and customize configurations based on specific needs.
Solutions to help increase office efficiencies and productivity
Advanced Solutions for your industry
From every point of view, it’s simply advanced
Features
The imageRUNNER ADVANCE C350iF/C250iF models allow each user to accomplish tasks quickly and effectively. And, these systems are readily customizable, delivering enhanced productivity to everyday workflow.
A powerful digital communications center, the imageRUNNER ADVANCE C350iF/C250iF models integrate enterprise applications, connects to the cloud, and gives you the freedom to work from wherever you are, efficiently and easily.
In today's networked world, you need greater control over your resources and data. The imageRUNNER ADVANCE C350iF/C250iF models deliver just that with the ability to configure a system, safeguard information, and track resources, right at your fingertips.
Produce professional-quality documents quickly and easily. The imageRUNNER ADVANCE C350iF/C250iF models provide eye-catching quality with Canon's V2 Color in a compact footprint-all with the reliable performance you expect from Canon.
It's all about a brighter, greener future. The imageRUNNER ADVANCE C350iF/C250iF models, registered in EPEAT®, incorporate innovative, eco-conscious solutions that propel your business while reducing your environmental footprint.
imageRUNNER ADVANCE C350iF/C250iF Spec Sheet
MAIN UNIT
SYSTEM TYPE Color Digital Multifunction Imaging System
FUNCTIONS Copy, Print (UFR II, PCL 5c/6, Adobe® PostScript® 3™), Fax (Up to 1 Line), Scan, Send
OPERATION PANEL 7” WVGA Full-Color TFT Screen
MEMORY Standard: 2 GB RAM
Maximum 2 GB RAM
HARD DISK DRIVE Standard: 80 GB
Maximum 80 GB
NETWORK INTERFACE CONNECTION Ethernet 10/100/1000Base-TX
OTHER INTERFACE USB 2.0 x3 (Host), USB 2.0 (Device)
COPY / PRINT SPEED (BW/COLOR) Letter: Up to 26/26 ppm
Legal: Up to 21/21 ppm
FIRST-COPY-OUT-TIME (LETTER) As fast as 8.4 Seconds (BW) and 10.5 Seconds (Color)
FIRST PRINT-OUT TIME (LETTER) As fast as 11.4 Seconds (BW) and 13.5 Seconds (Color)
PAPER SOURCES (20LB BOND) Standard: 550-sheet Paper Cassette 100-sheet Stack Bypass
Optional: 1 x 550-sheet Paper Cassette 3 x 550-sheet Paper Cassette
Maximum: 2,300 Sheets
OUTPUT PAPER CAPACITY (20LB BOND) Standard: 250 Sheets
Maximum: 500 Sheets (non-stapled with Staple Finisher-S1 attached)
OUTPUT PAPER SIZES Cassettes: Legal, Letter, Statement, Executive, Custom Size [(3-7/8" x 7-1/2" to 8-1/2" x 14") (98.4 mm x 190.5 mm to 216 mm x 355.6 mm)], and Envelopes (COM10, Monarch, DL, ISO-C5)*
Bypass: Legal, Letter, Statement, Executive, Custom Size [(3-7/8" x 5-7/8" to 8-1/2" x 14") (98.4 mm x 148 mm to 216 mm x 355.6 mm)], and Envelopes (COM10, Monarch, DL, ISO-C5)
ACCEPTABLE PAPER WEIGHTS Cassettes: 16 lb. Bond to 60 lb. Cover (60 to 163 g/m 2 )
Bypass: 16 lb. Bond to 80 lb. Cover (60 to 220 g/m 2 )
DUPLEXING Paper Size: Standard Automatic Trayless Duplexing (Statement to Legal)
Paper Weights: Up to 60 lb. Cover (163 g/m 2 )
MEDIA SUPPORT Thin [16 lb. Bond (60 to 63 g/m 2 )], Plain 1 [17 lb. Bond to 20 lb. Bond (64 to 75 g/m 2 )], Plain 2 [21 lb. Bond to 24 lb. Bond (76 to 90 g/m 2 )], Plain 3 [25 lb. Bond to 28 lb. Bond (91 to 105 g/m 2 )], Recycled 1 [17 lb. Bond to 20 lb. Bond (64 to 75 g/m 2 )], Recycled 2 [21 lb. Bond to 24 lb. Bond (76 to 90 g/m 2 )], Recycled 3[(25 lb. Bond to 28 lb. Bond (91 to 105 g/m 2 )], Color [17 lb. Bond to 20 lb. Bond (64 to 75 g/m 2 )], Heavy 1 [29 lb. Bond to 34 lb. Bond (106 to 128 g/m 2 )], Heavy 2 [35 lb. Bond to 60 lb. Cover (129 to 163 g/m 2 )], Heavy 3 [61 lb. Cover to 80 lb. Cover [164 to 220 g/m 2 )], Transparency [32 lb. Bond to 80 lb. Cover (121 to 220 g/m 2 )], Pre-punched [17 lb. Bond to 20 lb. Bond (64 to 75 g/m 2 )], Bond [24 lb. Bond (90 g/m 2 )], Labels [31 lb. Bond to 59 lb. Cover (118 to 160 g/m 2 )], Envelopes
WARM-UP TIME Quick Startup Mode: 10 Seconds**
From Sleep Mode: 10 Seconds
From Power On: 34 Seconds
POWER REQUIREMENS / PLUG 120 V, 60 Hz, 6.9 A/NEMA 5-15
POWER CONSUMPTION Maximum: 1.5 kW
Sleep Mode: 1 W
DIMENSIONS (W X D X H) 24" x 20-1/8" x 24-1/2" (610 mm x 511 mm x 621 mm)
INSTALLATION SPACE (WXD) 33-1/2" x 24-1/2" (852 mm x 621 mm) (When the Multipurpose Tray is extended)
WEIGHT Approx. 99.2 lb. (45 kg)***
IMAGE READER UNIT
SCAN RESOLUTION Up to 600 x 600 dpi
ACCEPTABLE ORIGINALS (GLASS) Sheet, Book, 3-Dimensional Objects [up to 4.4 lb. (2 kg)]
MAXIMUM ORIGINAL SIZE Legal (8-1/2" x 14")
DOCUMENT FEEDER
SCAN METHOD Duplexing Automatic Document Feeder
ACCEPTABLE ORIGINALS Paper Sizes: Legal, Letter, Statement
Paper Weights: 1-sided scanning (single sheet): 13 lb. Bond to 34 lb. Bond (50 to 128 g/m 2 ) 1-sided scanning (multiple sheets): 13 lb. Bond to 28 lb. Bond (50 to 105 g/m 2 ), 2-sided scanning: 17 lb. Bond to 28 lb. Bond (64 to 105 g/m 2 )
SCAN SPEED (Color/BW; Letter) Simplex: 26 ipm (300 dpi)/16 ipm (600 dpi)
Duplex: 9 ipm (300 dpi)/7 ipm (600 dpi)
PAPER CAPACITY (20 lb. Bond) 50 Sheets
COPY SPECIFICATIONS
MULTIPLE COPIES 1to 999
COPY EXPOSURE Automatic or Manual (9 Levels)
MAGNIFICATION 25 - 400% (1% Increments)
PRESET REDUCTIONS 25%, 50%, 64%, 78%
PRESET ENLARGEMENTS 129%, 200%, 400%
BASIC COPY FEATURES Preset R/E Ratios by Area, Finishing, Two-sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel, Standard Keys, Reset, Job Duration Display, Reserved Copying, ID Management, Counter Check
SPECIAL COPY FEATURES ID Card Copy, Shift, Frame Erase, Scan Image Check, Mode Memory, Recall, Sharpness, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date
PRINT SPECIFICATIONS
PROCESSOR Canon Dual Custom Processor (Shared)
ENGINE RESOLUTION 600 x 600 dpi
PDL SUPPORT UFR II, PCL 5c/6, Adobe PostScript 3
PRINT DRIVER SUPPORTED OS UFR II, Adobe PostScript 3: Windows® (XP/Windows Vista®/7/8.1), Windows Server (2003/2008 /2008 R2/SBS 2011/2012/2012 R2), Windows Terminal Server (2003/2008/2008 R2/2012/2012 R2), Microsoft Clustering Server (2003/2008/2008 R2/2012/2012 R2), Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5, XenDesktop 4.0/5.0/5.5/5.6/7.0), VMware (vSphere 4/5/5.1), SAP (PS3 Only), Macintosh® (OS X 10.5.8 or later)
PCL 5c/6: Windows® (Windows XP/Windows Vista®/7/8.1) Windows Server (2003/2008/2008 R2/SBS 2011/2012/2012 R2), Windows Terminal Server (2003/2008/2008 R2/2012/2012 R2), Microsoft Clustering Server (2003/2008/2008 R2/2012/2012 R2), Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5, XenDesktop 4.0/5.0/5.5/5.6/7.0), VMware (vSphere 4/5/5.1), SAP
DIRECT PRINT SUPPORT Standard: TIFF, JPEG, PDF, EPS†
Optional: XPS††
PRINT FEATURES Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Objective, Color/Black- and-White Auto Detect, Toner Reduction, Poster Printing, Form Overlay
SCAN SPECIFICATIONS
NETWORK SCAN (PULL) TWAIN
WIA
NETWORK SCAN UTILITY Color Network ScanGear 2
UNIVERSAL SEND SPECIFICATIONS
SENDING METHOD E-mail, I-Fax, File Server (FTP, SMB, WebDAV), Super G3 Fax
COLOR MODE Auto Color Select (Color, Gray), Auto Color Select (Color, Black) Full Color, Grayscale, BW
SCAN RESOLUTION BW: 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100 dpi
Color: 300 x 300 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100 dpi
ADDRESS BOOK CAPACITY Max. 1,800 Destinations (Incl. 200 One-Touch Buttons)
COMMUICATION PROTOCOL File: FTP (TCP/IP), SMB (TCP/IP), WebDAV
E-mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full)
FILE FORMAT Standard: TIFF, JPEG, PDF, PDF (Compact), PDF (Apply Policy), PDF (Optimize for Web), PDF/XPS (OCR), PDF-A-1b, XPS, XPS (Compact), OOXML (OCR) (.pptx)
Optional: PDF (Trace and Smooth), PDF (Encrypted), PDF/XPS (Digital Signature)
I-FAX DATA FORMAT BW: TIFF (MH, MR, MMR)
UNIVERSAL SEND FEATURES Two-sided Original, Original Type Selection, Density Adjustment, Sharpness, Erase Frame, Delayed Send, Preview, File Name, Subject/Message, Reply-to, Sender's Name (TTI), E-Mail Priority, Send to Myself, Send to My Folder
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES Standard: 1
Maximum: 1
MODEM SPEED Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
SENDING / RECORDING SIZE Statement to Legal
FAX FEATURES Job Forwarding, Density Adjustment, Sharpness, Erase Frame, Specifying the Sender's Name (when sending fax), Selecting the Telephone Line (when sending fax), Delayed Send, Preview, Job Done Notice, Original Type Selection, Two-sided Original, Direct Send, On-Hook Dialing
STORE SPECIFICATIONS
ADVANCED BOX Store to Remote Advanced Box: Supported ■ Print/View from Remote Advanced Box: Supported
MEMORY MEDIA Standard: Store to USB Memory ■
SECURITY SPECIFICATIONS
STANDARD Department ID Management, Single Sign On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, IPv6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), Send to Myself (only), Send to My Personal Folder (only), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, IEEE 802.1x (wired/wireless), SMTP Authentication, POP Authentication before SMTP, HDD Initialize (Up to 9x) HDD Erase (Up to 3x), HDD Lock, IPsec, Adobe® LiveCycle® Rights Management ES2.5 Integration
OPTIONAL HDD Encryption, HDD Erase Scheduler, Encrypted Secured Print, Encrypted PDF, Secure Watermark, IEEE 2600.1 Common Criteria Certification, ▲ imageWARE Secure Audit Manager Express, uniFLOW, AA-Print, Universal Login Manager
ENVIRONMENTAL SPECIFICATIONS
ENERGY STAR Qualified
RoHS Compliant
Blue Angel
EPEAT Rated
WEEE Directive
CONSUMABLES
TONER GPR-51 Toner
TONER YIELD (ESTIMATED @ 5% COVERAGE) Black: 19, 000 Copies / Bottle
Color (C,M,Y): 21, 500 Copies / Bottle
FOOTNOTES
* Envelopes supported from first cassette with included Envelope Feeder Attachment.
** If "Quick Startup Settings for Main Power" is set to On, it takes 10 seconds until the key operation on the touch-panel display is available after turning on the main power.
*** Including consumables.
† EPS can be printed directly only from Remote User Interface.
†† XPS cannot be printed directly from Web Access Software.
††† Requires imageRUNNER ADVANCE device with Advanced Box.
▲ Check with an Authorized Canon Dealer for availability.
■ C350iF/C250iF only.
This is to make Misc appear on the page when needed.
Supplies
GPR-51 Toner
Color: Black
Item Code: 8516B003AA
Estimated Toner Yield: 19,000 Copies/Bottle (Estimated @ 5% Coverage)
Color: Cyan
Item Code: 8517B003AA
Estimated Toner Yield: 21,500 Copies/Bottle (Estimated @ 5% Coverage)
Color: Magenta
Item Code: 8518B003AA
Color: Yellow
Item Code: 8519B003AA
Accessories
Hardware Accessories
  • Cassette Feeding Unit-AG1
  • Cassette Feeding Unit-AH1
  • FL Cassette-AT1
  • Staple Finisher-S1
  • Copy Card Reader-F1
  • Canon Card Set-A1 (1-30)
  • Canon Card Set-A2 (31-100)
  • Canon Card Set-A3 (101-200)
  • Canon Card Set-A4 (201-300)
  • Canon Card Set-A5 (301-500)
  • Canon Card Set-A6 (501-1000)
  • ADF Access Handle-A1
  • Copy Control Interface Kit-A1
  • IC Card Reader Box-A1
  • Braille Label Kit-F1
  • USB Keyboard (Cherry)
  • Universal Keyboard Stand-A1
  • Card Reader Assembly for Universal Keyboard Stand
  • Convenience Stapler-B1
System Connectivity Accessories
  • Direct Print Kit (for PDF/XPS)-H1
  • PCL International Font Set-B1
  • Barcode Printing Kit-D1
  • Encrypted Secure Print-D1
  • Web Access Software-H1
  • Universal Send Trace & Smooth PDF Kit-A1
  • Universal Send Security Feature Set-D1
  • Universal Send Digital User Signature Kit-C1
  • Secure Watermark-B1
  • iR-ADV Security Kit-J1 for IEEE 2600.1 Common Criteria Certification
  • HDD Data Encryption Kit-C6
  • HDD Data Erase Scheduler V2.3
  • HDD Data Erase Scheduler V2.3 NFR
  • Document Scan Lock Kit-B1
  • Silex Wireless Bridge SX-4600WAN
Click here to learn about Software Solutions for imageRUNNER ADVANCE
Note: For additional details and descriptions for each accessory, please access the product configurator.
Brochures
Loading...
Videos
Conducting Business
RUN Use Cases
Awards
Outstanding Color MFP for SMBs
BLI honors the imageRUNNER ADVANCE C250iF for Outstanding Color MFP for SMBs based on reliability, productivity, customizability and quality when compared to the competition.
 Return to Top
