Web Content Viewer
Actions
imageRUNNER ADVANCE C3325i
Multifunction Copiers
imageRUNNER ADVANCE Configurator. Build your model, and customize configurations based on specific needs.
Solutions to help increase office efficiencies and productivity
Advanced Solutions for your industry
From every point of view, it’s simply advanced
Features
Designed for you.
Simple to use, highly responsive, and easily personalized, the imageRUNNER ADVANCE Series partners with individuals and workgroups to create a truly customized way to work.
A powerful digital communications center, the imageRUNNER ADVANCE C3300 Series integrates enterprise applications, connects to the cloud, and gives you the freedom to work from wherever you are, efficiently and easily.
Easy control.  Real peace of mind.
Whether you manage a fleet of devices or a single unit, you have the power to configure a system, help safeguard data, and maximize resources right at your fingertips.
Part of a very smart growth strategy.
Fast and powerful, the imageRUNNER ADVANCE Series is a center of outstanding productivity for any business.
It's all about a brighter, greener future. The imageRUNNER ADVANCE C3300 Series, registered in EPEAT®, incorporates innovative, eco-conscious solutions that propel your business while reducing your environmental footprint.
imageRUNNER ADVANCE C3300 Series Spec Sheet
MAIN UNIT
SYSTEM TYPE Color Digital Multifunction Imaging System
FUNCTIONS Standard: Copy, Print (UFR II, PCL 5c/6, Adobe® PostScript® 3™), Scan, Send Optional: Fax (Up to 2 Lines)
OPERATION PANEL 7” WVGA Full-Color TFT Screen
MEMORY Standard: 2 GB RAM
Maximum: 2 GB RAM
HARD DISK DRIVE Standard: 215 GB
Maximum: 215 GB
NETWORK INTERFACE CONNECTION Standard: 1000Base-TX/100Base-TX/10Base-T
Optional: Wireless LAN (IEEE 803.1x via third-party adapter)
OTHER INTERFACE Standard: USB 2.0 (Host) x 2, USB 2.0 (Device)
Optional: Device Port [USB 2.0 (Host) x 2], Copy Control Interface
COPY / PRINT SPEED (BW/COLOR) Letter: Up to 25/25 ppm
Legal/11” x 17”: Up to 15 ppm
FIRST-COPY-OUT-TIME (LETTER) As fast as 5.9 Seconds (BW), 8.2 Seconds (Color)
PAPER SOURCES (20LB BOND) Standard: Two 550-sheet Paper Cassettes 100-sheet Stack Bypass
Optional: Dual 550-sheet Paper Cassettes
Maximum: 2,300 Sheets
OUTPUT PAPER CAPACITY (20LB BOND) Standard: 250 Sheets (Inner Tray)
Maximum: 2,100 Sheets (w/Staple Finisher or Booklet Finisher)
OUTPUT PAPER SIZES Cassette 1: Statement, Letter, Executive, Envelope (ISO-C5), Custom Size (5-1/2” x 7-1/8” to 11-3/4” x 8-1/2”)
Cassette 2: 12” x 18”, 11” x 17”, Legal, Letter, Letter-R, Statement, Executive, Custom Size (5-1/2” x 7-1/8” to 12” x 18”), Envelopes (COM10 No.10, Monarch, DL)
Cassettes 12” x 18”, 11” x 17”, Legal, Letter, 3/4: Letter-R, Statement, Executive, Custom Size (5-1/2” x 7-1/8” to 12” x 18”) Bypass: 12” x 18”, 12-5/8” x 17-11/16”, 11” x 17”, Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size (3-7/8” x 5-1/2” to 12-5/8” x 18”), Envelopes (COM10 No.10, Monarch, DL, ISO-C5)
ACCEPTABLE PAPER WEIGHTS Cassettes: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m 2 )
Bypass: 14 lb. Bond to 140 lb. Index (52 to 256 g/m 2 )
DUPLEXING Paper Size: Standard Automatic Trayless Duplexing (Executive to 12” x 18”)
Paper Weight: 14 lb. Bond to 80 lb. Cover (220 g/m 2 )
SPECIAL MEDIA SUPPORT Tracing, Coated, Labels, Transparency, Pre-punched, Bond, and Envelopes
ENVELOPE FEEDING ATTACHMENT Paper Capacity: Up to 50 Sheets (or 45 mm in height) Acceptable
Envelope Type: COM10 No.10, Monarch, DL, ISO-C5
Feeding Speed: 10 cpm
WARM-UP TIME From Power On: Approx. 34 Seconds
From Sleep: Approx. 10 Seconds
Quick Startup Mode: Within 7 Seconds*
POWER REQUIREMENS / PLUG 120 V AC, 60 Hz, 7.5 A/NEMA 5-15P
POWER CONSUMPTION Maximum: 1.5 kW
Sleep Mode: 0.8 W
DIMENSIONS (W X D X H) 34-5/8” x 22-1/4” x 27-5/16” (878 mm x 565 mm x 693 mm)
INSTALLATION SPACE (WXD) 35-1/4” x 44” (894 mm x 1117 mm) (when the Multi-purpose Tray is extended.)
WEIGHT Approx. 163.4 lb. (74.1 kg)**
IMAGE READER UNIT
SCAN RESOLUTION Up to 600 x 600 dpi
ACCEPTABLE ORIGINALS (GLASS) Sheet, Book, 3-Dimensional objects [up to 4.4 lb. (2 kg)]
MAXIMUM ORIGINAL SIZE Up to 11” x 17”
DOCUMENT FEEDER
SCAN METHOD Duplex Automatic Document Feeder
ACCEPTABLE ORIGINALS Paper Sizes: 11” x 17”, Legal, Letter, Letter-R, Statement, or Statement-R
Paper Weights: 13 lb. Bond to 34 lb. Bond (50 to 128 g/m 2 )
SCAN SPEED (BW and Color; Letter) Simplex: Up to 55 ipm (300 dpi) Up to 30 ipm (600 dpi)
Duplex: Up to 27.5 ipm (300 dpi) Up to 15 ipm (600 dpi)
PAPER CAPACITY Up to 100 Sheets (20 lb. Bond)
COPY SPECIFICATIONS
MULTIPLE COPIES 1to 999
COPY EXPOSURE Automatic or Manual (9 Levels)
MAGNIFICATION 25% - 400% (1% Increments)
PRESET REDUCTIONS 25%, 50%, 64%, 73%, 78%
PRESET ENLARGEMENTS 121%, 129%, 200%, 400%
BASIC COPY FEATURES Preset R/E Ratios by Area, Finishing, Two-Sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying, ID Management, Counter Check
SPECIAL COPY FEATURES Two-page Separation, Cover/Sheet Insertion, Booklet, Transparency Interleaving, Shift, Margin, Frame Erase, Image Combination, Different Size Original, Job Build, Job Done Notice, Scan Image Check, Mode Memory, Recall, Negative/ Positive Inversion, Image Repeat, Mirror Image, Sharpness, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date, Document Scan Lock, Area Designation, ID Card Copy
PRINT SPECIFICATIONS
PROCESSOR Canon Dual Custom Processor (Shared)
Maximum: 2 GB RAM
Maximum: 215 GB
ENGINE RESOLUTION 1200 x 1200 dpi (Max.)
PDL SUPPORT Standard: UFR II, PCL 5c/6, Adobe PS 3
PRINT DRIVER SUPPORTED OS UFR II, PCL 5c/6, Adobe PS 3: Windows® (XP/Windows Vista®/7/8.1), Windows Server (2003/2003R2/2008 /2008 R2/ 2012/2012 R2), Windows Terminal Server (2003/2003R2/2008/2008 R2/2012/2012 R2), Microsoft Clustering Server 2003/2003R2/2008/ 2008 R2/2012/2012 R2), Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5/7.5, XenDesktop 4.0/5.0/5.5/5.6/7.0/7.1/7.5), VMware (vSphere 4/5/5.1), SAP (PS3, PCL), Macintosh® (OS X 10.5.8 or later)
DIRECT PRINT SUPPORT Standard: TIFF, JPEG, PDF, EPS,*** XPS†
PRINT FEATURES Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/ Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Black-and-White Printing, Objective, Color/Black-and-White Auto Detect, Toner Reduction, Poster Printing
SCAN SPECIFICATIONS
NETWORK TWAIN SCAN Standard
NETWORK SCAN UTILITY Color Network ScanGear
UNIVERSAL SEND SPECIFICATIONS
SENDING METHOD E-Mail, I-Fax, File Server (FTP, SMB, WebDAV), Super G3 Fax (Optional)
COLOR MODE Auto Color Select (Color, Gray), Auto Color Select (Color, Black), Full Color, Grayscale, BW
SCAN RESOLUTION 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100 dpi
ADDRESS BOOK CAPACITY Max. 1,800 Destinations (Incl. 200 One-Touch Buttons)
COMMUICATION PROTOCOL File: FTP (TCP/IP), SMB (TCP/IP), WebDAV
E-mail/ I-Fax: SMTP, POP3, I-FAX (Simple, Full)
FILE FORMAT Standard: TIFF, JPEG, PDF (Compact, Searchable, Apply Policy, Optimize for Web, PDF A/1-b), XPS (Compact, Searchable), OOXML (.pptx and .docx)
Optional: PDF (Trace & Smooth, Encrypted), PDF/XPS (Digital Signature)
I-FAX DATA FORMAT (BW and COLOR) TIFF (MH, MR, MMR)
UNIVERSAL SEND FEATURES Two-Sided Original, Different-size Originals, Original Type Selection, Book to Two Pages, Density Adjustment, Sharpness, Document Name, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-to, Sender’s Name (TTI), E-Mail Priority
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES 2
MODEM SPEED Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
SENDING / RECORDING SIZE Statement to 11” x 17”
FAX FEATURES Job Forwarding, Different-size Originals, Adjusting Overall Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender’s Name (when sending fax), Selecting the Telephone Line (when sending fax), Delayed Send, Preview, Finished Stamp, Job Done Notice, Original Type Selection, Two-sided Original, Book to Two Pages
STORE SPECIFICATIONS
STANDARD USB Memory, Mail Box Simple
ADVANCED BOX Store to Remote Advanced Box: Supported Print/View from Remote Advanced Box: Supported
SECURITY SPECIFICATIONS
STANDARD Department ID Management, Single Sign On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, IPV6, Restrict - ing Features (Restricting the Send Function, Restricting New Addresses on Address Book), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP, HDD Format, HDD Initialize (Up to 9x ), HDD Erase (Up to 3x), HDD Lock, IPsec, Adobe® LiveCycle® Rights Management ES2.5 Integration
OPTIONAL Removable HDD, HDD Encryption, HDD Data Erase Scheduler, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, Secure Watermark, IEEE 2600.1 Common Criteria Certification††
ENVIRONMENTAL SPECIFICATIONS
ENERGY STAR Qualified
Rated EPEAT Silver
EU RoHS Compliant
Ecomark
Blue Angel
WEEE Directive
CONSUMABLES
TONER GPR-53 Toner
TONER YIELD (ESTIMATED @ 5% COVERAGE) Black: 36, 000 Copies / Bottle
Color (C,M,Y): 19,000 Copies / Bottle
FOOTNOTES
* If “Quick Startup Settings for Main Power” is set to ON, it takes 7 seconds until the key operation on the touch panel display is available after turning on the main power.
** Includes consumables.
*** EPS can be printed directly only from Remote User Interface.
† XPS cannot be printed directly from the Web Access software.
†† Specified configurations and settings need to be applied to the device in order to achieve and maintain IEEE 2600.1 Common Criteria Certification. Not available at launch. Contact your Canon Authorized Dealer for more information.
††† Requires Cassette Feeding Unit-AL1. Cannot be installed with Cabinet Type-J. Staple Finisher-U1 and Booklet Finisher-U1 cannot be installed at the same time and cannot be installed with Inner Finisher-G1 or with Copy Tray-J2.
p Copy Tray-J2 cannot be installed with the Staple Finisher-U1 or the Booklet Finisher-U1.
This is to make Misc appear on the page when needed.
Brochures
Loading...
Supplies
GPR-53 Toner
Color: Black
Item Code: 8524B003AA
Estimated Toner Yield: 36,000 Copies/Bottle (Estimated @ 5% Coverage)
Color: Cyan
Item Code: 8525B003AA
Estimated Toner Yield: 19,000 Copies/Bottle (Estimated @ 5% Coverage)
Color: Magenta
Item Code: 8526B003AA
Color: Yellow
Item Code: 8527B003AA
Accessories
Hardware Accessories
  • Cassette Feeding Unit-AL1
  • Cabinet Type-J
  • Inner 2way Tray-J1
  • Inner Finisher-G1
  • Staple Finisher-U1
  • Booklet Finisher-U1
  • FL Cassette-AX1
  • FL Cassette-AY1
  • Copy Tray-J2
  • Utility Tray-A2
  • USB Key Board (Cherry)
  • Copy Card Reader Attachment-B4
  • Copy Card Reader-F1
  • Canon Card Set-A1 (1-30)
  • Canon Card Set-A2 (31-100)
  • Canon Card Set-A3 (101-200)
  • Canon Card Set-A4 (201-300)
  • Canon Card Set-A5 (301-500)
  • Canon Card Set-A6 (501-1000)
  • ADF Access Handle-A1
  • Braille Label Kit-F1
  • Copy Control Interface Kit-A1
  • Convenience Stapler-B1
  • Universal Keyboard Stand-A1
  • Card Reader Assembly for Universal Keyboard Stand
System Connectivity Accessories
  • Encrypted Secure Print-D1
  • Barcode Printing Kit-D1
  • PCL International Font Set-A
  • Web Access Software-H1
  • Universal Send Trace & Smooth Kit-A1
  • Universal Send Security Feature Set-D1
  • Universal Send Digital User Signature Kit-C1
  • Super G3 FAX Board-AR1
  • Super G3 2nd Line Fax Board-AR1
  • Remote Fax Kit-A1
  • Secure Watermark-B1
  • USB Device Port-E4
  • Document Scan Lock Kit-B1
  • HDD Data Encryption Kit-C9
  • HDD Data Erase Scheduler V3.0
  • HDD Data Erase Scheduler V3.0 NFR
  • Voice Guidance Kit-F2
  • Voice Guidance Connection Kit for iR-ADV C3300 series
  • Voice Operation Kit-C2
  • iR-ADV Security Kit-L1 for IEEE 2600.1 Common Criteria Certification Set
  • Silex Wireless Bridge SX-4600WAN
  • PCL Printer Kit-AY1
Click here to learn about Software Solutions for imageRUNNER ADVANCE
Note: For additional details and descriptions for each accessory, please access the product configurator.
Videos
Conducting Business
RUN Use Cases
Awards
2016 A3 MFP Line of the Year
Canon U.S.A., Inc. is the winner of Buyers Laboratory LLC’s (BLI) most coveted award: 2016 A3 MFP Line of the Year. “Canon offers consistently outstanding products across its entire A3 line in nearly every speed band,” said BLI Editor George Mikolay. “From its exceptional reliability and ease of use, to its innovation and customizability, Canon’s A3 line is the industry benchmark among its competitors.”
Outstanding 21- to 30-ppm A3 Color MFP
BLI honors the imageRUNNER ADVANCE C3325i for Outstanding 21- to 30-ppm A3 Color MFP based on outstanding value and reliability for workgroups looking for an affordable and reliable color device.
 Return to Top
