Web Content Viewer
Actions
imageRUNNER ADVANCE C475iF III
Multifunction Copiers
imageRUNNER ADVANCE Configurator. Build your model, and customize configurations based on specific needs.
Solutions to help increase office efficiencies and productivity
Advanced Solutions for your industry
Introducing the third generation imageRUNNER ADVANCE third edition.
imageRUNNER ADVANCE III Third Edition
Features
  • 10.1" intuitive touchscreen with smartphone-like usability.
  • A unique, customized experience tailored to individual preferences using My ADVANCE.
  • Supports mobile solutions and integration with many popular cloud services like Google Drive.
  • Scan and convert documents to searchable digital files in a variety of file formats.
  • Integration with Canon and various third-party software with embedded application platform.
  • Advanced standard security feature set to help safeguard sensitive information and assist in regulatory compliance.
  • Integrates with existing, third-party Security Information and Event Management (SIEM) systems to help provide real-time comprehensive insights into potential threats to the network and printers.
  • Technology to verify that the device boot process, firmware, and applications initialize at startup, without any alterations or tampering by malicious third parties. During operation, McAfee Embedded Control utilizes a whitelist to protect against malware and tampering of firmware and applications.*
  • Security policy settings can be controlled with a dedicated password, configured from a central location, and exported to other supported devices.
  • Control access to the device and specific features, using a host of flexible authentication methods PIN code, user name/password, or card access.
* These features are available on third generation imageRUNNER ADVANCE 3rd edition models only. McAfee Embedded Control requires Unified Firmware Platform v3.9.
  • Canon's signature reliability and engine technologies help keep productivity high and minimize the impact on support resources.
  • Outstanding imaging technologies and toner allow for consistently striking images, thanks to Canon's V2 color profile.
  • Designed to achieve maximum uptime with status notifications that help keep supplies replenished and intuitive maintenance videos for consumables replacement.
  • Designed for quick, easy deployment.
  • Remote diagnostics and parts life management for proactive maintenance and rapid fixes.
  • Easy and intuitive to monitor device status and consumable levels, turn off devices remotely, observe meter readings, manage settings, and implement security policies.
  • Common firmware and regular updates with Unified Firmware Platform (UFP) for continuous improvements and consistency across a fleet.
  • Track and assess print, copy, scan, and fax usage and allocate costs to departments or projects.
  • Apply print policies and restrict usage by user to help reduce unnecessary printing and contribute to cost efficiency.
  • Standard cloud-based solution provides a centralized dashboard with up-to-the-minute insights into printer activity.
  • Upgrade to uniFLOW server or cloud-based solutions for full accounting and reporting for compatible Canon and third-party devices, pull printing, job routing, and powerful scan workflows.
  • A combination of fusing technologies and low-melting-point toner minimizes power requirements and helps achieve low energy consumption.
  • Encourage environmentally conscious work practices by enabling multiple settings that can help save paper and energy.
  • ENERGY STAR® certified and rated EPEAT® Gold.
imageRUNNER ADVANCE C475iF / C475iFZ III Spec Sheet
MAIN UNIT
TYPE
Color Laser Multifunctional
CORE FUNCTIONS
Print, Copy, Scan, Send, Store, Fax
PROCESSOR
Canon Dual Custom Processor (Shared)
CONTROL PANEL
10.1" TFT LCD WSVGA Color Flat-panel
MEMORY
4.0 GB RAM
HARD DISK DRIVE
250 GB
INTERFACE CONNECTION
Network: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n),
Optional: NFC, Bluetooth Low Energy
Others
Standard: USB 2.0 x1 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device)
Optional: Copy Control Interface
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard: 650 Sheets
Maximum: 2,300 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)
Standard: 550-sheet Paper Cassette, 100-sheet Stack Bypass
Optional: 1,650-sheet Paper Cassette (Cassette Feeding Unit-AT1) 550-sheet Paper Cassette (Cassette Feeding Unit-AS1)
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)
Standard Model: 400 Sheets
Finisher Model: 900 Sheets (400 sheets: base tray, 400 sheets: upper tray, 100 sheets: lower tray)
FINISHING CAPABILITIES
Standard Model: Collate, Group
Finisher Model: Collate, Group, Offset, Staple
SUPPORTED MEDIA TYPES
Stack Bypass: Thin, Plain, Recycled, Heavy, Color, Bond, Envelope
Cassette: Thin, Plain, Recycled, Heavy, Color, Label, Bond
SUPPORTED MEDIA SIZES
Stack Bypass: Legal, Letter, Executive, Statement, Envelopes [No.10 (COM10), Monarch, DL, ISO-C5] Custom size: 3" x 5" to 8-1/2" x 14" (76 mm x 127 mm to 215.9 mm x 355.6 mm)
Cassette: Legal, Letter, Executive, Statement, Custom Size: 4" x 5-7/8" to 8-1/2" x 14" (101.6 mm x 148 mm to 215.9 mm x 355.6 mm)
SUPPORTED MEDIA WEIGHTS
Cassette: 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2)
Stack Bypass: 16 lb. Bond to 80 lb. Cover (60 to 216 g/m2)
Duplex: 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2)
WARM-UP TIME
From Power On: Approx. 10 Seconds1
From Sleep Mode: Approx. 10 Seconds2
Quick Startup Mode: Approx. 4 Seconds3
DIMENSIONS (W x D x H)
Standard Model: 20-1/2" x 25-3/8" x 26-3/8" (521 mm x 645 mm x 668 mm)
Finisher Model: 20-1/2" x 25-3/8" x 34" (521 mm x 645 mm x 864 mm)
DIMENSIONS (W x D x H) with Paper Feeding Unit
Standard Model: 25-1/4" x 26-3/8" x 44-1/4" (642 mm x 668 mm x 1,124 mm)
Finisher Model: 25-1/4" x 26-3/8" x 52" (642 mm x 668 mm x 1320 mm)
INSTALLATION SPACE (W x D x H)
37-3/8" x 33-1/8" (950 mm x 840 mm)
WEIGHT4
Standard Model: Approx. 101.4 lb. (46 kg)
Finisher Model: Approx. 121.3 lb. (55 kg)
PRINT SPECIFICATIONS
PRINT / COPY SPEED (BW AND COLOR)
Up to 50 (Letter), Up to 39 (Legal)
PRINT RESOLUTION (dpi)
1200 x 600
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II, PCL®6, Adobe® PS® 3
DIRECT PRINT
Available from USB, Advanced Box, Remote UI, and Web Access5
SUPPORTED FILES
PDF, TIFF, JPEG, EPS, XPS
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES
A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet connected devices and cloud-based services depending on your requirements.
FONTS
PCL fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),6 Barcode Fonts7
PS fonts: 136 Roman
OPERATING SYSTEM 8
UFRII: Windows® 7/8.1/10, Windows Server 2008/ 2008 R2/2012/2012 R2/2016, MAC OS X (10.9 or later)
PCL: Windows 7/8.1/10, Windows Server 2008/ 2008 R2/2012/2012 R2/2016
PS: Windows 7/ 8.1/10, Windows Server 2008/ 2008 R2/2012/2012 R2/2016, MAC OS X (10.9 or later)
PPD: Windows 7/ 8.1/10, MAC OS X (10.3.9 or later)
PRINT FEATURES
Suspend Job Timeout, Profile Settings, Secured Print, Encrypted Secure Print, Watermark, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations,9 Offsetting, Toner Reduction, Poster Printing, Forced Hold Printing 9
COPY SPECIFICATIONS
FIRST-COPY-OUT-TIME
As Fast as 5.1 Seconds/5.8 Seconds
COPY RESOLUTION
600 x 600
MULTIPLE COPIES
Up to 999 Copies
COPY EXPOSURE
Automatic or Manual (9 Levels)
MAGNIFICATION
25%-400% (1% Increments)
PRESET REDUCTIONS
25%, 50%, 64%, 78%
PRESET ENLARGEMENTS
129%, 200%, 400%
BASIC COPY FEATURES
Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two- Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel
SPECIAL COPY FEATURES
Two-sided Original, Finishing, Job Build, N on 1, Different Size Originals,9 Density Adjustment, Original Type Selection, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Job Done Notice, Copy ID Card, Skip Blank Pages, Multi-Sheet Feed Detection, Adjust One-Touch Color, Color Balance
SCAN SPECIFICATIONS
TYPE
Single-pass Duplexing Automatic Document Feeder10
DOCUMENT FEEDER PAPER CAPACITY
100 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES
Legal, Letter, Statement, Custom Size: 4-1/8" x 5-7/8" to 8-1/2" x 14" (105 mm x 148 mm to 216 mm x 355.6 mm)
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS
BW Original: 1-sided scanning: 12 to 33 lb. Bond (42 to 128 g/m2)
2-sided scanning: 13 to 33 lb. Bond (50 to 128 g/m2)
CL Original: 1-sided scanning: 17 to 33 lb. Bond (64 to 128 g/m2)
2-sided scanning: 17 to 33 lb. Bond (64 to 128 g/m2)
PLATEN ACCEPTABLE ORIGINALS
Sheet, Book, 3-Dimensional Objects [Height: Up to 1-1/4" (30 mm), Weight: up to 4.4 lb. (2kg)]
PULL SCAN
Color Network ScanGear2 for both Twain and WIA
Supported OS: Windows 7/8.1/10/ Server 2008/Server 2008 R2/ Server 2012/Server 2012 R2/Server 2016
SCAN RESOLUTION
600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x 100, 150 x 150, 100 x 100
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES
A range of solutions is available to provide scanning to mobile devices and cloud-based services depending on your requirements.
SCAN SPEED (LETTER)
Single-sided Scanning (BW and Color): 50 ipm (300 dpi )/30 ipm (600 dpi)
Double-sided Scanning (BW and Color): 100 ipm (300 dpi)/50 ipm (600 dpi)
SEND SPECIFICATIONS
DESTINATION
Standard: E-mail/Internet Fax (SMTP), SMB v3.0, FTP, WebDAV, Mail Box, Super G3 Fax Optional: IP Fax
COLOR MODE
Automatic-Color Select (Full Color/Grayscale), Automatic- Color Select (Full Color/Black-and-White), Full color, Grayscale, and Black-and-White
ADDRESS BOOK
LDAP (2,000)/Local (1,600)/Speed Dial (200)
SEND RESOLUTION
COMMUICATION PROTOCOL
File: FTP (TCP/IP), SMB v3.0, WebDAV
Email: SMTP, POP3
FILE FORMAT
Standard: TIFF, JPEG, PDF (Compact, Searchable, Apply policy, Optimize for Web, PDF A/1-b, Encrypted, Device Signature), XPS (Compact, Searchable, Device Signature), Office Open XML (PowerPoint, Word)
Optional: PDF (Trace & Smooth, User Signature), XPS (User Signature)
UNIVERSAL SEND FEATURES
Original Type Selection, Two-sided Original, Different-size Originals,9 Density Adjustment, Sharpness, Erase Frame, Job Build, Sender's Name (TTI), Delayed Send, Preview, Job Done Notice, File Name, Subject/Message, Reply-to, E-mail Priority, TX Report, Original Content Orientation, Skip Blank Pages, Multi-Sheet Feed Detection
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES
One
MODEM SPEED
Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD
MH, MR, MMR, JBIG
RESOLUTION
400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE
Statement to Legal
FAX MEMORY
Up to 30,000 Pages
SPEED DIALS
Max. 200
GROUP DIALS / DESTINATIONS
Max. 199 Dials
SEQUENTIAL BROADCAST
Max. 256 Addresses
MEMORY BACKUP
Yes
FAX FEATURES
Original Type Selection, Two-Sided Original, Density for Scanning, Sharpness, Erase Frame, Job Build, Sender's Name (TTI), Direct Send, Delayed Send, Preview, Job Done Notice, TX Report, Multi Sheet Feed Detection
STORE SPECIFICATIONS
MAIL BOX SIMPLE (NUMBER SUPPORTED)
100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored
ADVANCED BOX
Communication Protocol: SMB or WebDAV
Supported Client PC: Windows 7/8.1/10
Concurrent Connections (Max.)
SMB: 64
WebDAV: 3 (Active Sessions)
ADVANCED BOX AVAILABLE DISC SPACE
Approx. 16 GB
ADVANCED BOX FEATURES
Authentication for Advanced Box Log-in, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
MEMORY MEDIA
Standard: USB
SECURITY SPECIFICATIONS
AUTHENTICATION
Standard: Universal Login Manager (Device and Function Level Log-in), uniFLOW Online Express,11 User Authentication, Department ID Authentication, Access Management System
Optional: uniFLOW
DATA
Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated), Verify System at Startup, McAfee Embedded Control12
Optional: IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW)
NETWORK
Standard: IP/Mac Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP, S/MIME, SIEM Integration
DOCUMENT
Standard: Secure Print, Adobe LiveCycle® Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Device signature, Secure Watermark
Optional: User Signatures
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT
Temperature: 50 to 86 ºF
Humidity: 20 to 80 % RH (Relative Humidity)
POWER REQUIREMENTS
120-127V AC 60 Hz, 8.4 A
PLUG (MAIN UNIT)
NEMA 5-15P
POWER CONSUMPTION
Maximum: Approx. 1,500 W
Standby: Approx. 54.3 W13
Sleep Mode: Approx. 1 W14
Typical Electricity Consumption (TEC) Rating15 1.9 kWh
STANDARDS
ENERGY STAR® Certified
Rated EPEAT® Gold16
CONSUMABLES
TONER
TONER T04 BK/C/M/Y
TONER YIELD (ESTIMATED @ 5% COVERAGE)
TONER T04 BK: 33,000 pages17
TONER T04 C/M/Y: 27,500 pages17
FOOTNOTES
  1. Time from device power-on, until copy ready (not print reservation).
  2. Time from exiting Sleep mode to when printing is operational.
  3. Time from device power-on to when key operation can be performed on the touch screen.
  4. Includes consumables.
  5. PDF print from Web sites is supported.
  6. Requires the optional PCL International Font Set-A1.
  7. Requires the optional Barcode Printer Kit-D1.
  8. Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
  9. Only for Letter/Legal.
  10. Detect Feeder Multi Sheet Feed is supported.
  11. No charge for this solution; however activation is required.
  12. Requires Unified Firmware Platform v3.9.
  13. Reference value (measured one unit).
  14. 0.8 W sleep mode not available in all circumstances due to certain settings.
  15. Based on ENERGY STAR Product Specification for Imaging Equipment Version 2.0.
  16. For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
  17. Toner Cartridge yield in accordance with ISO/IEC 19798.
This is to make Misc appear on the page when needed.
Supplies
T04 Toner
Color: Black
Item Code: 2980C001AA
Estimated Toner Yield: 33,000 Copies/Bottle (yields are in accordance with ISO/IEC 19798)
Color: Cyan
Item Code: 2979C001AA
Estimated Toner Yield: 27,500 Copies/Bottle (yields are in accordance with ISO/IEC 19798)
Color: Magenta
Item Code: 2978C001AA
Color: Yellow
Item Code: 2977C001AA
Accessories
Hardware Accessories
  • Cassette Feeding Unit-AS1
  • Cassette Feeding Unit-AT1
  • Cassette Module-AJ1
  • Copy Card Reader-F1
  • Copy Card Reader Attachment-B5
  • Canon Card Set-A1 (1-30)
  • Canon Card Set-A2 (31-100)
  • Canon Card Set-A3 (101-200)
  • Canon Card Set-A4 (201-300)
  • Canon Card Set-A5 (301-500)
  • Canon Card Set-A6 (501-1000)
  • Braille Label Kit-F1
  • ADF Access Handle-A1
  • Copy Control Interface Kit-A1
  • USB Key Board (Cherry)
  • Convenience Stapler-A1
  • Universal Keyboard Stand-A1
  • Card Reader Assembly for Universal Keyboard Stand
System Connectivity Accessories
  • IP FAX Expansion Kit-B1
  • IC CARD READER Attachment-A1
  • HDD Data Erase Scheduler V3.1.1
  • HDD Data Erase Scheduler V3.1.1 NFR
  • PCL International Font Set-A1
  • Barcode Printing Kit-D1
  • Canon iR-ADV Security Kit-Y1 for IEEE 2600 Common Criteria Certification
  • Universal Send Trace & Smooth PDF Kit-A1
  • Universal Send Digital User Signature Kit-C1
  • Connection Kit-A1 for Bluetooth LE
  • NFC Kit-C1
Click here to learn about Software Solutions for imageRUNNER ADVANCE
Note: For additional details and descriptions for each accessory, please access the product configurator.
Brochures
Loading...
Workflow Solutions
Mobile Solutions from Canon provide users with convenience and control when printing from various locations. The Canon imageRUNNER ADVANCE C475iF III Series is equipped to support the needs of mobile users based on varying company policies, types, common file formats, workflows, security requirements and more. On the road, in the home, or at the office, mobile business users can experience ease in printing and scanning with Canon’s mobile solution offering. Canon’s PRINT Business app lets users choose the send destination, enter the send job filename, or release a print job directly from the app on a compatible smartphone.
Document Capture and Distribution Solutions from Canon can help streamline workflows by digitizing data, sharing information, and distributing to a variety of destinations. The Canon imageRUNNER ADVANCE C475iF III Series offers secure and customizable user authentication, data tracking, and distribution options to help meet your organization's requirements. This series is designed with Document Capture and Distribution in mind.
The Output Management Solutions available for the Canon imageRUNNER ADVANCE C475iF III Series provide various levels of control and tracking to help reduce wasteful printing and provide you with the tools to help control access to confidential information. With easy functionality and numerous workflow settings, the imageRUNNER ADVANCE C475iF III Series is designed for high productivity, time efficiency, and cost savings. This enterprise-level, multifunction printing and copying solution is scalable to align with various customer environments as business needs evolve and change.
Information Management and Workflow Solutions from Canon offer powerful, end-to-end support for quickly retrieving information, giving users the capability to digitally store, organize, and manage content. With the Canon imageRUNNER ADVANCE C475iF III Series, customized workflows can be created to help users streamline daily document related activities and optimize business processes. The imageRUNNER ADVANCE C475iF III Series can be a key business solution for information management and easier workflow.
Device Management Solutions from Canon can help solve common workplace challenges and help improve efficiencies within your organization. The enterprise-class Canon imageRUNNER ADVANCE C475iF III Series offers solid, fleet-based management tools to establish an integrated solution that can help reduce costs and minimize IT resources. These models are designed to help companies realize increased productivity and focus on day-to-day IT activities.
Videos
Third Generation imageRUNNER ADVANCE Third Edition
imageRUNNER ADVANCE Control Video
Control over your MFPs, network communications and documents.
imageRUNNER ADVANCE Third Edition Home Screen Video
Simplify, Control, Evolve
Designed for Fleet Environments
Product Design
imageRUNNER ADVANCE C5500 Series
Paper Handling and Finishing Option
Image Quality
Platform Overview
Mobile Device Integration
Third Generation imageRUNNER ADVANCE and the Canon PRINT Business app
Authentication with ULM
Third Generation imageRUNNER ADVANCE Feature Highlights
 Return to Top
