Web Content Viewer
Actions
imageRUNNER ADVANCE C5235
Multifunction Copiers
imageRUNNER ADVANCE Configurator. Build your model, and customize configurations based on specific needs.
Solutions to help increase office efficiencies and productivity
Advanced Solutions for your industry
From every point of view, it’s simply advanced
Features
The imageRUNNER ADVANCE C5200 Series helps each user accomplish every task with outstanding ease. A center of extraordinary productivity, these models are simple to personalize, creating a truly customized way to work.
A powerful digital communications center, the imageRUNNER ADVANCE C5200 Series integrates enterprise applications, connects to the cloud, and gives you the freedom to work from wherever you are, efficiently and easily.
In today's networked world, you need greater control over your resources and data. The imageRUNNER ADVANCE C5200 Series delivers just that with the ability to configure a system, safeguard information, and track resources, all right at your fingertips.
Accomplish multiple tasks with impressive speed, produce professional-quality documents, and seamlessly link to business applications-all with performance you can count on.
It's all about a brighter, greener future. The imageRUNNER ADVANCE C5200 Series, registered in EPEAT®, incorporates innovative, eco-conscious solutions that propel your business while reducing your environmental footprint.
Specifications
Model Name
Type
Color Digital Multifunction Imaging System
Letter: Up to 35/30 ppm
Legal: Up to 20/18 ppm
Ledger: Up to 20/18 ppm
Functions
Standard: Copy, Print (UFR II), Scan, Send, Store
Optional: Print (PCL, Adobe® PostScript® 3™), Fax (Up to 4 Lines)
Operation Panel
8.4 SVGA Full-Color TFT Screen
Image Server Memory
Standard: 2GB RAM
Maximum: 2.5GB RAM
Hard Disk Drive
Standard: 160GB
Maximum: 1TB
Mirroring Hard Disk Drive
Optional (160GB, 1TB), Method: RAID1
Network Interface Connection
Standard: 1000Base-T/100Base-TX/10Base-T
Optional: Wireless LAN (IEEE 802.1x via third-party adapter)
Other Interface
Standard: USB 2.0 (Host) x 2, USB 2.0 (Device)
Optional: Device Port [USB 2.0 (Host) x 2], Serial Interface, Copy Control Interface
Max Mailboxes Supported
100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes Approx.
Max Pages Stored
6,000 Maximum Pages Stored
Advanced Box
Available Disk Space
15GB (Standard HDD)
Approx. 629GB (1TB HDD)
Common Protocol
SMB or WebDAV
Supported Client PC
Windows® (Windows 2000/XP/Windows Vista®)
Max. Number of Concurrent Connections
SMB: 32, WebDAV: 12 (Active Sessions)
Advanced Box Features
Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
Memory Media
Standard
USB Memory
Optional
SD, SDHC, CompactFlash, Memory Stick, Microdrive
Scan Specifications
Network TWAIN Scan
Standard
Network Scan Utility
Color Network ScanGear
Standard Paper Capacity
Dual 550-sheet Paper Cassettes,
100-sheet Stack Bypass
Optional
Dual 550 Sheet Paper Cassettes,
2,700-sheet Paper Deck
Maximum Paper Capacity
5,000 Sheets
Output Paper Capacity
(20 lb. Bond): Standard: 250 Sheets (Inner Tray)
Maximum: 3,250 Sheets (w/Staple Finisher or Booklet Finisher)
Output Sizes
Cassette
12 x 18,* 11 x 17,* Legal, Letter, Letter-R, Statement-R, Executive, Custom Size (5-1/2 x 7-1/8 to 12 x 18)
Bypass
12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size (3-7/8 x 5-1/2 to 12-5/8 x 18)
Paper Deck: Letter
Other Option
Envelope Feeder Attachment (COM10 No.10, Monarch, DL, ISO-C5)** Tab Feeding Attachment Kit**
Acceptable Paper Weights
Cassette
14 lb. Bond to 80 lb. Cover (52 to 220g/m2)
Bypass
14 lb. Bond to 140 lb. Index (52 to 256g/m2)
Duplexing
Paper Size
Standard Automatic Trayless Duplexing (Executive to 12 x 18)
Paper Weight
Special Media Support
Thin, Plain 1 [17 lb. Bond to 21 lb. Bond (64g/m2 to 81g/m2)], Plain 2 [22 lb. Bond to 28 lb. Bond (82g/m2 to 105g/m2)], Recycled, Color, Pre-Punched, Bond, Heavy 1 [29 lb. Bond to 60 lb. Cover (106g/m2 to 163g/m2)], Heavy 2 [61 lb. Cover to 80 lb. Cover (164g/m2 to 220g/m2)], Heavy 3 [82 lb. Cover to 140 lb. Index (221g/m2 to 256g/m2)], Tracing, Coated, Labels, Transparency, Tab, Letterhead, and Envelopes
Warm Up Time
From Power On: 31 Seconds, From Sleep: 15 Seconds Quick Startup Mode: 7 Seconds***
Power Requirements
120V AC, 60Hz, 15A
Power Consumption
Maximum: 1.5kW
Sleep Mode: 0.8W
Plug
NEMA 5-15P
Dimension
36-5/8 x 24-3/8 x 28
(931mm x 620mm x 712mm)
Installation Space
33-1/2 x 28 (850mm x 712mm)
Weight
Approx. 333 lb. (151kg)†
Image Reader
Scan Resolution
Up to 600 x 600 dpi
Acceptable Originals
(Glass): Sheet, Book, 3-Dimensional objects [up to 4.4 lb. (2kg)]
Maximum Original Size
Up to 11 x 17
Basic Copy Features
First Copy Time: BW: 5.4 Seconds, Color: 8.1 Seconds
Multiple Copies: 1 to 999
Copy Exposure: Automatic or Manual (9 Levels)
Magnification: 25% - 400% (1% Increments)
Preset Reductions: 25%, 50%, 64%, 73%, 78%
Preset Enlargements: 121%, 129%, 200%, 400%
Security Features
Standard
Department ID Management, Single Sign On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, User Access Control of Advanced Box, Mail Box Password Protection, IPV6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Port Filtering, SMTP Authentication, POP Authentication before SMTP, HDD Erase (Up to 3x), HDD Initialize (Up to 9x), HDD Lock, IPSec, Adobe LiveCycle Rights Management ES2.5 Integration
Optional
Removable HDD, HDD Encryption, HDD Mirroring, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, Secure Watermark, IEEE 2600.1 Common Criteria CertificationΔΔ
Environmental Features
EPEAT® Rated ENERGY STAR® Qualified RoHS Compliant Ecomark Blue Angel WEEE Directive
Estimated Toner Yield
(Estimated Yield @ 5% Coverage): Black: 36,000 Copies/Bottle, Color (C,M,Y): 27,000 Copies/Bottle
Feeders
11 x 17, Legal, Letter, Letter-R, Statement, or Statement-R
Scan Method
Duplex Automatic Document Feeder
Scanning Speed
(BW/Color; Letter): Simplex: Up to 51/51 ipm (300 dpi)/ Up to 46/46 ipm (600 dpi)
Duplex: Up to 19.6/19.6 ipm (300 dpi)/ Up to 17.5/17.5 ipm (600 dpi)
Capacity
(20 lb. Bond): 100 Sheets
Paper Weight
1-sided scanning: 11 lb. Bond to 58 lb. Cover (42 to 157g/m2)
2-sided scanning: 13 lb. Bond to 58 lb. Cover (50 to 157g/m2)
Paper Supply Options
Description
Cassette Feeding Unit-AD2
Paper Capacity
550 Sheets x 2 Cassettes [20 lb. Bond (80g/m2)]
Paper Size
12 x 18, 11 x 17, Legal, Letter, Letter-R, Statement-R, Executive, and Custom Size [5-1/2 x 7-1/8 to 12 x 18 (139.7mm x 182mm to 304.8mm x 457.2mm)]
Paper Weight
Power Source
From the Main Unit
Power Consumption
Approximately 30W
Dimensions
9-7/8 x 24-3/8 x 27-5/8 (251mm x 620mm x 700mm)
Weight
Approximately 61.7 lb. (28kg)
Description
Paper Deck Unit-B2
Number Of Cassettes
1
Paper Capacity
2,700 sheets [20 lb. Bond (80g/m2)]
Paper Size
Letter
Paper Weight
14 lb. Bond to 60 lb. Cover (52 to 163g/m2)
Power Source
From Main Unit
Power Consumption
Approximately 45W
Dimensions
18-5/8 x 14-5/8 x 23-3/4
(473mm x 372mm x 603mm)
Weight
Approximately 81.6 lb. (37kg)
Description
Envelope Feeder Attachment-D1**
Paper Capacity
50 Sheets (or 30mm in height)
Paper Size
COM10 No.10, Monarch, DL, ISO-C5Feeding Speed: 10 cpm
Dimensions
3-1/4 x 17-1/4 x 12-1/8
(81mm x 439mm x 307mm)
Weight
Approximately 2.6 lb. (1.2kg)
Output Options
Copy Trays
Description
Inner 2-way Tray-F1Δ
Total Output Capacity
Top Tray: 250 Sheets (20 lb. Bond)
Lower Tray: 100 Sheets (20 lb. Bond)Number of Trays: 2
Paper Size
12 x 18, 12-5/8 x 17-11/16, 11 x 17, Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size [3-7/8 x 5-9/16 to 12-5/8 x 18 (99mm x 139.7mm to 320mm x 457.2mm)], and Envelopes
Paper Weight
Dimensions
3 x 16-3/4 x 16 (76mm x 427mm x 407mm)
Weight
Approximately 1.3 lb. (574g)
Finishers / Output Trays
Description
Inner Finisher-E1Δ
Paper Size
12 x 18, 12-5/8 x 17-11/16, 11 x 17, Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom size (3-7/8 x 5-9/16 to 12-5/8 x 18), and Envelopes
Paper Weight
Number Of Trays
Up to 2 Trays (With Inner Finisher Additional Tray-A1)
Without Inner Finisher Additional Tray-A1: 500 Sheets
Top Tray
(With Inner Finisher Additional Tray-A1): 100 Sheets (Letter)
Lower Tray
(With Inner Finisher Additional Tray-A1): 200 Sheets (Letter)
Staple Positions
Corner Stapling (11 x 17, Legal, Letter, Letter-R) Double Stapling (11 x 17, Legal, Letter, Letter-R)
Stapling Capacity
Letter and Executive: 50 Sheets (14 to 21 lb. Bond) 30 Sheets (22 to 28 lb. Bond) 2 Sheets (29 lb. Bond to 140 lb. Index)
11 x 17, Legal and Letter-R: 30 Sheets (14 to 21 lb. Bond) 20 Sheets (22 to 28 lb. Bond) 2 Sheets (28 lb. Bond to 140 lb. Index)Paper Capacity of Staple Mode: Top Tray: 3/8 in height
Lower Tray: 30 Sets (or 2-1/2 in height)
Type of Staple
Staple-J1 (5,000 x 3)
Power Source
From the Main Unit
Power Consumption
Approximately 40W
Dimensions
9-1/4 x 34-1/8 x 21-1/4 [234mm x 865mm x 540mm (When the Auxiliary Tray is extended)]
Weight
Approximately 28.7 lb. (13kg)
Description
Staple Finisher-J1Δ
Paper Size
12 x 18, 12-5/8 x 17-11/16, 11 x 17, Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size [3-7/8 x 5-9/16 to 12-5/8 x 18 (99 x 139.7mm to 320mm x 457.2mm)], and Envelopes
Paper Weight
Paper Type
Thin, Plain, Recycled, Color, Pre-Punched, Bond, Heavy, Tracing, Letterhead, Coated, Labels, Transparency, and Envelopes
Number Of Trays
2
3,000 Sheets (Letter, Statement-R, Executive)
Top Tray
1,300 Sheets (Letter, Statement-R, Executive) 650 Sheets (11 x 17, Legal, Letter-R)
Lower Tray
1,700 Sheets (Letter, Statement-R, Executive) 650 Sheets (11 x 17, Legal, Letter-R)
Staple Positions
Corner Stapling: (11 x 17, Legal, Letter, Letter-R, Executive)
Double Stapling: (11 x 17, Legal, Letter, Letter-R, Executive)
Stapling Capacity
Letter and Executive: 50 Sheets (14 to 21 lb. Bond) 30 Sheets (22 to 28 lb. Bond) 2 Sheets (29 lb. Bond to 140 lb. Index)11 x 17, Legal and Letter-R: 30 Sheets (14 to 21 lb. Bond) 20 Sheets (22 to 28 lb. Bond) 2 Sheets (29 lb. Bond to 140 lb. Index)Paper Capacity of Staple Mode: Top Tray: 1,300 Sheets/30 Sets (Letter, Executive), 650 Sheets/30 Sets (11 x 17, Legal, Letter-R)
Lower Tray: 1,700 Sheets/30 Sets (Letter, Executive), 650 Sheets/30 Sets (11 x 17, Legal, Letter-R)
Type of Staple
Power Source
From the Main Unit
Power Consumption
Approximately 100W
Dimensions
43-1/4 x 26-5/8 x 25-1/2 [1,097mm x 677mm x 646mm (When the Auxiliary Tray is extended)]
Weight
Approximately 101 lb. (46kg)
Description
Booklet Finisher-J1Δ
Paper Size
12 x 18, 12-5/8 x 17-11/16, 11 × 17, Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size [3-7/8 x 5-9/16 to 12-5/8 x 18 (99 x 139.7mm to 320mm x 457.2mm)], and Envelopes
Paper Weight
Paper Type
Plain, Heavy, Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Bond, Transparency, Envelopes
Number Of Trays
2
3,000 sheets (Letter, Statement-R, Executive)
Top Tray
Lower Tray
Paper Capacity of Saddle-Stitch Mode
16 Sheets (14 to 20 lb. Bond) 10 Sheets (22 to 28 lb. Bond)Paper Capacity of Saddle-Stitch Mode:25 Booklets (5-sheet Booklets)
Staple Positions
Corner/Double Stapling: 11 x 17, Legal, Letter, Letter-R, Executive
Saddle-Stitch: 11 x 17, Legal, Letter-R
Stapling Capacity
Letter and Executive: 50 Sheets (14 to 22 lb. Bond) 30 Sheets (22 to 28 lb. Bond) 2 Sheets (29 lb. Bond to 140 lb. Index)
Type of Staple
Staple-J1 (5,000 x 3) Staple Cartridge-D3 (2,000 x 3)
Power Source
From the Main Unit
Power Consumption
Approximately 123W
Dimensions
43-1/4 x 31-1/8 x 25-1/2 [1097mm x 789mm x 646mm (When the Auxiliary Tray is extended)]
Weight
Approximately 165 lb. (75kg)
Puncher Units
Description
External 2/3 Hole Puncher-B2
Paper Size
Paper Weight
Paper Type
Thin, Plain, Heavy, Color, Recycled, Letterhead,Coated
Punch Type
2 Holes: (Legal, Letter-R, Executive)
3 Holes: (11 x 17, Letter)
Tray Capacity
2 Holes: 10,000 sheets (21 lb. Bond)
3 Holes: 3,000 sheets (21 lb. Bond)
Distance Between Punch Holes
2 Holes: 2-3/4 (70mm)
3 Holes: 4-1/4 (108mm)
Power Requirements
From the Main Unit
Dimensions
36x 4-1/4 x 24-1/4 (915mm x 107mm x 615mm)
Weight
Approximately 15.9 lb. (7.2kg)
Fax Board
Applicable Line
4
Modem Speed
Super G3: 33.6 Kbps
G3: 14.4 Kbps
Data Compression
MH, MR, MMR, JBIG
Resolution
400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
Scanning/Recording Size
Statement to 11 x 17
Fax Features
Job Forwarding, Different-size Originals, Adjusting Overall Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Selecting the Telephone Line (when sending fax), Delayed Send, Preview, Finished Stamp, Job Done Notice, Original Type Selection, Two-sided Original, Book to Two Pages
Print Board
Processor
Canon Dual Custom Processor (Shared)
Standard Memory
2GB RAM
Maximum Memory
2.5GB RAM
Hard Disk
Standard: 160GB
Maximum: 1TB
Engine Resolution
1200 x 1200 dpi
PDL Support
Standard: UFR II
Optional: PCL 5c, PCL 6, Adobe PS 3
Print Controller Technology
UFR II, PCL 5c/6, Adobe PS 3: Windows® (XP/Windows Vista®/7), Windows Server (2003/ 2008/2008 R2/SBS 2011/2012), Windows Terminal Servers (Server 2003/Server 2008/Server 2008 R2/2012), Microsoft® Clustering Server (Server 2003/Server 2003 R2/Server 2008/Server 2008 R2), Citrix (Presentation Server 4.5, Xen App 5.0/6.0/6.5, Xen Desktop 4.0/5.0/5.5), Macintosh® (OS X 10.5.8 or later, UFR II and PS 3 only), VMware, SAP (PS and PCL Only)
Print Features
Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Black and White Printing, Objective, Color/Black-and-White Auto Detect, Toner Reduction, Poster Printing Direct Print Support: Standard: TIFF, JPEG
Optional: PDF, XPS††, EPS†††
Universal Send Specs
Sending Method
E-Mail, I-Fax, File Server (FTP, SMB, WebDAV), Mail Box, Super G3 Fax (Optional)
Color Mode
Auto Color Select (Color, Gray), Auto Color Select (Color, Black), Full Color, Grayscale, BW
Scan Resolution
600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100 dpi
Address Book Capacity
Max. 1,800 Destinations (Incl. 200 One-Touch Buttons)
Communication Protocol
File: FTP (TCP/IP), SMB (TCP/IP), WebDAV
E-mail/I-Fax: SMTP, POP3, I-FAX (Simple, Full)
File Format
Standard: TIFF, JPEG, PDF, PDF (Compact), PDF (Apply Policy), PDF (Optimize for Web), PDF/XPS (OCR), PDF/A-1b, XPS, XPS (Compact), OOXML (OCR) (.pptx and .docx)
Optional: PDF (Trace & Smooth), PDF (Encrypted), PDF/XPS (Digital Signature), PDF (Reader Extensions)
I-Fax Data Format
Color: .tfx (JPEG)
BW: .tif (MH, MR, MMR)Universal Send Features: Two-Sided Original, Different-size Originals, Original Type Selection, Book to Two Pages, Density Adjustment, Sharpness, Document Name, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-to, Sender's Name (TTI), E-Mail Priority * Not available on top cassette.
** Can be set to Cassette 2 only. Can not install Envelope Feeder Attachment and Tab Feeding Attachment at same time.
*** If Quick Startup Settings for Main Power is set to ON, it takes 7 seconds until the key operation on the touch panel display is available after turning on the main power.
† Includes consumables.
†† XPS cannot be printed directly from the Web Access software.
††† EPS can be printed directly only from Remote User Interface.
⟩ Not available at time of launch.
Δ The Inner 2-way Tray-F1, Inner Finisher-E1, Staple Finisher-J1, and Booklet Finisher-J1 cannot be installed at the same time.
ΔΔ Please see the Product Advisory for the latest status on this item.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER ADVANCE C5235 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Supplies
GPR-31 Toner
Color: Black
Item Code: 2790B03BA
Estimated Toner Yield: 36,000 Copies/Bottle (Estimated @ 5% Coverage)
Color: Cyan
Item Code: 2794B003AC
Estimated Toner Yield: 27,000 Copies/Bottle (Estimated @ 5% Coverage)
Color: Magenta
Item Code: 2798B003AC
Color: Yellow
Item Code: 2802B003AC
Accessories
Hardware Accessories
  • Inner 2-Way Tray-F1
  • Inner Finnisher-E1
  • Inner Finisher Additional Tray-A1 (Option for Inner Finisher)
  • Staple Finisher-J1
  • Booklet Finisher-J1
  • External 2/3 Hole Puncher-B2
  • Cassette Feeding Unit-AD2
  • Envelope Feeder Attachment Kit-D1
  • Tab Feeding Attachment Kit-B1
  • Cabinet Type-B1
  • Paper Deck Unit-B2
  • Copy Tray-J1
  • Utility Tray-A2
  • USB Keyboard
  • Universal Keyboard Stand-A1
  • Key Switch Unit-A2
  • Copy Card Reader Attachment Kit-B3
  • Copy Card Reader-F1
  • Braille Label Kit-F1
  • ADF Access Handle-A1
  • Copy Control Interface Kit-A1
  • Convenience Stapler-B1
System Connectivity Accessories
  • PCL Printer Kit-AR1
  • PCL International Font Set-A1
  • PS Printer Kit-AR1
  • Direct Printer Kit (for PDF/XPS)-H1
  • Encrypted Secure Print-D1
  • Barcode Printing Kit-D1
  • Web Access Software-H1
  • Universal Send Advanced Feature Set-F1
  • Universal Send Security Feature Set-D1
  • Universal Send Digital User Signature Kit-C1
  • Super G3 FAX Board-AE2
  • Super G3 2nd Line Fax Board-AE1
  • Super G3 3rd/4th Line Fax Board-AE1
  • Remote Fax Kit-A1
  • Secure Watermark-B1
  • Document Scan Lock Kit-B1
  • HDD Data Encryption and Mirroring Kit -C1
  • HDD Data Erase Scheduler
  • Removable HDD Kit-AC1
  • Additional Memory Type D (512 MB)
  • 2.5 inch/160GB HDD-G1
  • 2.5 inch/1TB HDD-H1
  • iR-ADV Security Kit-C1 for IEEE 2600.1 Common Criteria Certification*
  • USB Device Port-E3
  • Multimedia Reader/Writer-A2
  • Voice Guidance Kit-F2
  • Voice Operation Kit-C2
  • Remote Operator's Software Kit-B1
  • imagePASS-B2
  • Hot Folder v3 (for imagePASS-B2)
  • Productivity Package (for imagePASS-B2)
  • ColorPASS-GX-400+
  • SeeQuence Impose (for imagePASS-B2 & Color PASS-GX-400)
  • SeeQuence Compose
  • SeeQuence Suite
  • Removable Hard Disk Drive Kit-B1 (for ColorPASS-GX400)
  • Graphic Arts Package, Premium Edition V2.2 (for ColorPASS-GX400)
  • X-Rite Eye-One (for imagePASS-B2 & ColorPASS-GX400)
  • Integrated Interface & Stand-A1 (for ColorPASS-GX400)
Click here to learn about Software Solutions for imageRUNNER ADVANCE
Note: For additional details and descriptions for each accessory, please access the product configurator.
+ Only available for C5255.
* Please see the Product Advisory for the latest status on this item.
This is to make Misc appear on the page when needed.
Brochures
Loading...
imageRUNNER ADVANCE
RUN Use Cases
 Return to Top
